Quiz Salesforce - High Pass-Rate Data-Con-101 - Salesforce Certified Data Cloud
Posted at 11 hour before
Our Data-Con-101 training materials offer you everything you need to take the certification and face the challenge of professional knowledge points. The Data-Con-101 exam dumps are written and approved by our IT specialist based on the real questions of the formal test. Our latest learning materials contain the valid test questions and correct Data-Con-101 Test Answers along with detailed explanation. We will give your money back in full if you lose exam with our Data-Con-101 practice exam.
The learners' learning conditions are varied and many of them may have no access to the internet to learn our Data-Con-101 study question. If the learners leave home or their companies they can't link the internet to learn our Data-Con-101 test pdf. But you use our APP online version you can learn offline. If only you use the Data-Con-101 study question in the environment of being online for the first time you can use them offline later. So it will be very convenient for every learner because they won't worry about anywhere to learn our Data-Con-101 exam practice materials.
Valid Salesforce Data-Con-101 Test Simulator | Data-Con-101 Reliable Test PdfWe have prepared our Data-Con-101 training materials for you. They are professional practice material under warranty. Accompanied with acceptable prices for your reference, all our materials with three versions are compiled by professional experts in this area more than ten years long. Moreover, there are a series of benefits for you. So the importance of Data-Con-101 Actual Test is needless to say. If you place your order right now, we will send you the free renewals lasting for one year. All those supplements are also valuable for your Data-Con-101 practice exam.
Salesforce Data-Con-101 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Act on Data: This domain focuses on leveraging Data Cloud data for downstream actions through activations and data actions. It covers working with attributes, managing timing dependencies, troubleshooting activation issues like errors and rejected counts, and understanding requirements for triggering automated processes.
| | Topic 2 | - Identity Resolution: This domain explores creating unified customer profiles through matching and reconciliation processes. It covers how rule sets determine when records link together, how conflicting data is resolved, and understanding the outcomes and use cases of unified identities.
| | Topic 3 | - Data Ingestion and Modeling: This domain addresses bringing data into Data Cloud and structuring it properly through transformation, ingestion from various sources, and data mapping. It emphasizes best practices for modeling data to support identity resolution and validating ingested data using available tools.
Salesforce Certified Data Cloud Consultant Sample Questions (Q135-Q140):NEW QUESTION # 135
Northern Trail Outfitters (NTD) creates a calculated insight to compute recency, frequency, monetary {RFM) scores on its unified individuals. NTO then creates a segment based on these scores that it activates to a Marketing Cloud activation target.
Which two actions are required when configuring the activation?
Choose 2 answers
- A. Select contact points.
- B. Add the calculated insight in the activation.
- C. Add additional attributes.
- D. Choose a segment.
To configure an activation to a Marketing Cloud activation target, you need to choose a segment and select contact points. Choosing a segment allows you to specify which unified individuals you want to activate.
Selecting contact points allows you to map the attributes from the segment to the fields in the Marketing Cloud data extension. You do not need to add additional attributes or add the calculated insight in the activation, as these are already part of the segment definition. References: Create a Marketing Cloud Activation Target; Types of Data Targets in Data Cloud
NEW QUESTION # 136
A Data Cloud consultant recently discovered that their identity resolution process is matching individuals that share email addresses or phone numbers, but are not actually the same individual.
What should the consultant do to address this issue?
- A. Create and run a new rules fewer matching rules, compare the two rulesets to review and verify the results, and then migrate to the new ruleset once approved.
- B. Create and run a new ruleset with stricter matching criteria, compare the two rulesets to review and verify the results, and then migrate to the new ruleset once approved.
- C. Modify the existing ruleset with stricter matching criteria, compare the two rulesets to review and verify the results, and then migrate to the new ruleset once approved.
- D. Modify the existing ruleset with stricter matching criteria, run the ruleset and review the updated results, then adjust as needed until the individuals are matching correctly.
Identity resolution is the process of linking source profiles from different data sources into unified individual profiles based on match and reconciliation rules. If the identity resolution process is matching individuals that share email addresses or phone numbers, but are not actually the same individual, it means that the match rules are too loose and need to be refined. The best way to address this issue is to create and run a new ruleset with stricter matching criteria, such as adding more attributes or increasing the match score threshold. Then, the consultant can compare the two rulesets to review and verify the results, and see if the new ruleset reduces the false positives and improves the accuracy of the identity resolution. Once the new ruleset is approved, the consultant can migrate to the new ruleset and delete the old one. The other options are incorrect because modifying the existing ruleset can affect the existing unified profiles and cause data loss or inconsistency.
Creating and running a new ruleset with fewer matching rules can increase the false negatives and reduce the coverage of the identity resolution. References: Create Unified Individual Profiles, AI-based Identity Resolution: Linking Diverse Customer Data, Data Cloud Identiy Resolution.
NEW QUESTION # 137
Which solution provides an easy way to ingest Marketing Cloud subscriber profile attributes into Data Cloud on a daily basis?
- A. Marketing Cloud Connect API
- B. Marketing Cloud Data extension Data Stream
- C. Email Studio Starter Data Bundle
- D. Automation Studio and Profile file API
The solution that provides an easy way to ingest Marketing Cloud subscriber profile attributes into Data Cloud on a daily basis is the Marketing Cloud Data extension Data Stream. The Marketing Cloud Data extension Data Stream is a feature that allows customers to stream data from Marketing Cloud data extensions to Data Cloud data spaces. Customers can select which data extensions they want to stream, and Data Cloud will automatically create and update the corresponding data model objects (DMOs) in the data space.
Customers can also map the data extension fields to the DMO attributes using a user interface or an API. The Marketing Cloud Data extension Data Stream can help customers ingest subscriber profile attributes and other data from Marketing Cloud into Data Cloud without writing any code or setting up any complex integrations.
The other options are not solutions that provide an easy way to ingest Marketing Cloud subscriber profile attributes into Data Cloud on a daily basis. Automation Studio and Profile file API are tools that can be used to export data from Marketing Cloud to external systems, but they require customers to write scripts, configure file transfers, and schedule automations. Marketing Cloud Connect API is an API that can be used to access data from Marketing Cloud in other Salesforce solutions, such as Sales Cloud or Service Cloud, but it does not support streaming data to Data Cloud. Email Studio Starter Data Bundle is a data kit that contains sample data and segments for Email Studio, but it does not contain subscriber profile attributes or stream data to Data Cloud.
Marketing Cloud Data Extension Data Stream
Data Cloud Data Ingestion
[Marketing Cloud Data Extension Data Stream API]
[Marketing Cloud Connect API]
[Email Studio Starter Data Bundle]
NEW QUESTION # 138
When performing segmentation or activation, which time zone is used to publish and refresh data?
- A. Time zone of the Data Cloud Admin user
- B. Time zone set by the Salesforce Data Cloud org
- C. Time zone of the user creating the activity
- D. Time zone specified on the activity at the time of creation
The time zone that is used to publish and refresh data when performing segmentation or activation is D. Time zone set by the Salesforce Data Cloud org. This time zone is the one that is configured in the org settings when Data Cloud is provisioned, and it applies to all users and activities in Data Cloud. This time zone determines when the segments are scheduled to refresh and when the activations are scheduled to publish.
Therefore, it is important to consider the time zone difference between the Data Cloud org and the destination systems or channels when planning the segmentation and activation strategies. References: Salesforce Data Cloud Consultant Exam Guide, Segmentation, Activation
NEW QUESTION # 139
What should a user do to pause a segment activation with the intent of using that segment again?
- A. Delete the segment.
- B. Skip the activation.
- C. Deactivate the segment.
- D. Stop the publish schedule.
The correct answer is A. Deactivate the segment. If a segment is no longer needed, it can be deactivated through Data Cloud and applies to all chosen targets. A deactivated segment no longer publishes, but it can be reactivated at any time1. This option allows the user to pause a segment activation with the intent of using that segment again.
The other options are incorrect for the following reasons:
B). Delete the segment. This option permanently removes the segment from Data Cloud and cannot be undone2. This option does not allow the user to use the segment again.
C). Skip the activation. This option skips the current activation cycle for the segment, but does not affect the future activation cycles3. This option does not pause the segment activation indefinitely.
D). Stop the publish schedule. This option stops the segment from publishing to the chosen targets, but does not deactivate the segment4. This option does not pause the segment activation completely.
1: Deactivated Segment article on Salesforce Help
2: Delete a Segment article on Salesforce Help
3: Skip an Activation article on Salesforce Help
4: Stop a Publish Schedule article on Salesforce Help
NEW QUESTION # 140
With the rapid development of the world economy and frequent contacts between different countries, looking for a good job has become more and more difficult for all the people. So it is very necessary for you to get the Data-Con-101 certification, you have to increase your competitive advantage in the labor market and make yourself distinguished from other job-seekers. Our Data-Con-101 Exam Questions can help you make it. As the most professional Data-Con-101 study guide, we have helped numerous of our customer get a better career and live a better life now.
Valid Data-Con-101 Test Simulator: https://www.exams-boost.com/Data-Con-101-valid-materials.html
- Exam Data-Con-101 Actual Tests 😵 Latest Braindumps Data-Con-101 Ebook 👕 Practice Data-Con-101 Engine 🧀 Search on 【 [url]www.troytecdumps.com 】 for 《 Data-Con-101 》 to obtain exam materials for free download 🧳Data-Con-101 Test Topics Pdf[/url]
- Data-Con-101 Exams ❤️ Data-Con-101 Valid Practice Materials 🕯 Data-Con-101 New Test Camp 🏵 Search for ⮆ Data-Con-101 ⮄ and easily obtain a free download on ➡ [url]www.pdfvce.com ️⬅️ 🖌Data-Con-101 Valid Practice Materials[/url]
- Learning Data-Con-101 Materials 👎 Data-Con-101 Test Valid 🏵 New Data-Con-101 Mock Test 🎼 Easily obtain ✔ Data-Con-101 ️✔️ for free download through 「 [url]www.pass4test.com 」 🏴Learning Data-Con-101 Materials[/url]
- Data-Con-101 Associate Level Exam 💎 Data-Con-101 Test Topics Pdf 📥 Data-Con-101 Test Topics Pdf 🦒 Search for 「 Data-Con-101 」 on ▷ [url]www.pdfvce.com ◁ immediately to obtain a free download 🦠New Data-Con-101 Braindumps Pdf[/url]
- Data-Con-101 Study Test 👭 Data-Con-101 Reliable Exam Cost 🤣 Real Data-Con-101 Exam 😶 Download ➽ Data-Con-101 🢪 for free by simply searching on 《 [url]www.dumpsmaterials.com 》 👨New Data-Con-101 Mock Test[/url]
- 100% Pass Efficient Salesforce - Data-Con-101 - Salesforce Certified Data Cloud Consultant New Dumps Files 🆖 Open ⏩ [url]www.pdfvce.com ⏪ enter ☀ Data-Con-101 ️☀️ and obtain a free download 🔣New Data-Con-101 Test Papers[/url]
- Salesforce Data-Con-101 Questions: Turn Your Exam Fear into Confidence [2026] 😅 Search for “ Data-Con-101 ” and download exam materials for free through ▛ [url]www.torrentvce.com ▟ 🎶Data-Con-101 Reliable Braindumps Questions[/url]
- [url=https://ruslandwi.com/?s=Quiz%202026%20Salesforce%20Data-Con-101:%20Salesforce%20Certified%20Data%20Cloud%20Consultant%20%e2%80%93%20Professional%20New%20Dumps%20Files%20%f0%9f%8e%af%20Copy%20URL%20%e2%96%b6%20www.pdfvce.com%20%e2%97%80%20open%20and%20search%20for%20[%20Data-Con-101%20]%20to%20download%20for%20free%20%f0%9f%8d%a7Data-Con-101%20Valid%20Practice%20Materials]Quiz 2026 Salesforce Data-Con-101: Salesforce Certified Data Cloud Consultant – Professional New Dumps Files 🎯 Copy URL ▶ www.pdfvce.com ◀ open and search for [ Data-Con-101 ] to download for free 🍧Data-Con-101 Valid Practice Materials[/url]
- Quiz 2026 Salesforce Data-Con-101: Salesforce Certified Data Cloud Consultant – Professional New Dumps Files 🧲 Go to website ✔ [url]www.exam4labs.com ️✔️ open and search for ➽ Data-Con-101 🢪 to download for free 📊Real Data-Con-101 Exam[/url]
- Data-Con-101 New Test Camp 🌤 Exam Data-Con-101 Actual Tests 🍝 New Data-Con-101 Braindumps Pdf 🏹 The page for free download of ➽ Data-Con-101 🢪 on ⮆ [url]www.pdfvce.com ⮄ will open immediately 🏺Real Data-Con-101 Exam[/url]
- 100% Pass Efficient Salesforce - Data-Con-101 - Salesforce Certified Data Cloud Consultant New Dumps Files 🖌 Go to website ➠ [url]www.vce4dumps.com 🠰 open and search for ➤ Data-Con-101 ⮘ to download for free 🧭Reliable Data-Con-101 Source[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.disciplesinstitute.com, www.stes.tyc.edu.tw, Disposable vapes
