[General] Pdf Cisco 300-410 Files - 300-410 Reliable Dumps Ebook
135
【General】 Pdf Cisco 300-410 Files - 300-410 Reliable Dumps Ebook
Posted at 10 hour before      View:19 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New 300-410 dumps are available on Google Drive shared by itPass4sure: https://drive.google.com/open?id=14ZQzAsaTcP0IZ247DBZqPNIWRloIYCgY
itPass4sure also presents desktop-based Cisco 300-410 practice test software which is usable without any internet connection after installation and only required license verification. Implementing Cisco Enterprise Advanced Routing and Services (300-410) practice test software is very helpful for all those who desire to practice in an actual Implementing Cisco Enterprise Advanced Routing and Services (300-410) exam-like environment. Implementing Cisco Enterprise Advanced Routing and Services (300-410) practice test software contains many Cisco 300-410 practice exam designs just like the real Implementing Cisco Enterprise Advanced Routing and Services (300-410) exam.
Cisco 300-410 Exam Certification Details:
Duration90 minutes
Passing ScoreVariable (750-850 / 1000 Approx.)
Recommended TrainingImplementing Cisco Enterprise Advanced Routing and Services (ENARSI)
Exam NameImplementing Cisco Enterprise Advanced Routing and Services
Exam Price$300 USD
Exam RegistrationPEARSON VUE
Exam Code300-410 ENARSI
Cisco 300-410 Certification Exam is part of the Cisco Certified Network Professional (CCNP) Enterprise certification path. Implementing Cisco Enterprise Advanced Routing and Services certification path is designed to validate an individual's skills in enterprise networking technologies and solutions. By passing the 300-410 exam, candidates can demonstrate their proficiency in implementing advanced routing technologies and services in an enterprise network.
300-410 Reliable Dumps Ebook, Exam 300-410 PriceAs we all know, HR form many companies hold the view that candidates who own a 300-410 professional certification are preferred, because they are more likely to solve potential problems during work. And the 300-410 certification vividly demonstrates the fact that they are better learners. As for candidates who possessed with a 300-410 professional certification are more competitive. The current word is a stage of science and technology, social media and social networking has already become a popular means of 300-410 Exam Materials. As a result, more and more people study or prepare for exam through social networking. By this way, our 300-410 learning guide can be your best learn partner.
Cisco Implementing Cisco Enterprise Advanced Routing and Services Sample Questions (Q10-Q15):NEW QUESTION # 10
Refer to the exhibit. The traffic from spoke to hub is dropping. The operations team observes:
- R2-R3 link is down due to the fiber cut.
- R2 and R5 receive traffic from R1 in AS 65101.
- R3 and R6 receive traffic from R4 in AS 65201.
Which configuration resolves the issue?
  • A. R6(config)#router bgp 65101
    R6(config-router)#no neighbor 10.0.0.17 update-source Loopback0
  • B. R6(config)#router bgp 65201
    R6(config-router)#neighbor 10.10.10.5 remote-as 65101
    R6(config-router)#neighbor 10.10.10.5 update-source Loopback0
    R6(config-router)#neighbor 10.10.10.5 ebgp-multihop 3
  • C. R5(config)#router bgp 65101
    R5(config-router)#no neighbor 10.0.0.18 update-source Loopback0
  • D. R5(config)#router bgp 65101
    R5(config-router)#neighbor 10.10.10.6 remote-as 65201
    R5(config-router)#neighbor 10.10.10.6 update-source Loopback0
    R5(config-router)#neighbor 10.10.10.6 ebgp-multihop 3
NEW QUESTION # 11
An engineer must override the normal routing behavior of a router for Telnet traffic that is destined to
10.10.10.10 from 10.10.1.0/24 via a next hop of 10.4.4.4. which is directly connected to the router that is connected to the 10.1.1.0/24 subnet Which configuration reroutes traffic according to this requirement?
  • A. Option A
  • B. Option C
  • C. Option B
  • D. Option D
NEW QUESTION # 12
Which two actions should be taken to access the server? (Choose two.)
  • A. Modify distribute list seq 10 to permit the route to 192.168.2.2.
  • B. Add a floating static route to reach to 192.168.2.2 with administrative distance higher than OSPF
  • C. Modify the access list to add a second line of permit ip any
  • D. Add a sequence 20 in the route map to permit access list 1.
  • E. Modify the access list to deny the route to 192.168.2.2.
Answer: B,E
NEW QUESTION # 13
An engineer configured SNMP communities on the Core_SW1, but the SNMP server cannot obtain information from Core_SW1. Which configuration resolves this issue?
  • A. access-list 20 permit 10.221.10.11
  • B. snmp-server group NETVIEW v2c priv read NETVIEW access 20
  • C. access-list 20 permit 10.221.10.12
  • D. snmp-server group NETADMIN v3 priv read NETVIEW write NETADMIN access 22
NEW QUESTION # 14
Refer to the exhibit. The default route is not advertised to the neighboring router. Which action resolves the issue?
  • A. Configure OSPF on the Dialer0 interface.
  • B. Configure the redistribute static metric 200 subnets command under OSPF.
  • C. Configure the network 0.0.0.0 255.255.255.255 area 0 command under OSPF.
  • D. Configure the default-information originate command under OSPF.
NEW QUESTION # 15
If you are aiming to become a certified Cisco 300-410, you should prepare with actual exam questions and study guides. These study materials will enable you to pass the exam without much difficulty. Cisco's practice exams will help you prepare well for the actual exam. The questions are updated and easy to understand. The test materials also consist of a realistic scenario that simulates the exam environment.
300-410 Reliable Dumps Ebook: https://www.itpass4sure.com/300-410-practice-exam.html
BTW, DOWNLOAD part of itPass4sure 300-410 dumps from Cloud Storage: https://drive.google.com/open?id=14ZQzAsaTcP0IZ247DBZqPNIWRloIYCgY
