[General] Pass Guaranteed CT-AI - Certified Tester AI Testing Exam–Professional Latest Exa
【General】 Pass Guaranteed CT-AI - Certified Tester AI Testing Exam–Professional Latest Exa
Posted at 10 hour before      View:17 | Replies:0        Print      Only Author   [Copy Link] 1#
As a key to the success of your life, the benefits that our CT-AI study braindumps can bring you are not measured by money. CT-AI exam questions can not only help you pass the exam, but also help you master a new set of learning methods and teach you how to study efficiently, our CT-AI Study Materials will lead you to success. And CT-AI study materials provide free trial service for consumers. Come and have a try!
Our CT-AI practice questions are undetected treasure for you if this is your first time choosing them. These advantages help you get a thorough look in details. First of all, the price of our CT-AI exam braindumps is reasonable and affordable, no matter the office staffs or the students can afford to buy them. Secondly, the quality of our CT-AI Study Guide is high. You can just look the pass rate of our CT-AI training quiz, it is high as 98% to 100%.
Real ISTQB CT-AI Exam Question Samples For FreeThe online version of CT-AI study materials are based on web browser usage design and can be used by any browser device. The first time you open CT-AI study materials on the Internet, you can use it offline next time. CT-AI study materials do not need to be used in a Wi-Fi environment, and it will not consume your traffic costs. You can practice with CT-AI study materials at anytime, anywhere. On the other hand, the online version has a timed and simulated exam function. You can adjust the speed and keep vigilant by setting a timer for the simulation test. At the same time online version of CT-AI Study Materials also provides online error correction—Through the statistical reporting function, it will help you find the weak links and deal with them. Of course, you can also choose two other versions. The contents of the three different versions of CT-AI study materials are the same and all of them are not limited to the number of people/devices used at the same time.
ISTQB Certified Tester AI Testing Exam Sample Questions (Q23-Q28):NEW QUESTION # 23
"BioSearch" is creating an Al model used for predicting cancer occurrence via examining X-Ray images. The accuracy of the model in isolation has been found to be good. However, the users of the model started complaining of the poor quality of results, especially inability to detect real cancer cases, when put to practice in the diagnosis lab, leading to stopping of the usage of the model.
A testing expert was called in to find the deficiencies in the test planning which led to the above scenario.
Which ONE of the following options would you expect to MOST likely be the reason to be discovered by the test expert?
SELECT ONE OPTION
  • A. The input data has not been tested for quality prior to use for testing.
  • B. A lack of similarity between the training and testing data.
  • C. A lack of focus on non-functional requirements testing.
  • D. A lack of focus on choosing the right functional-performance metrics.
The question asks which deficiency is most likely to be discovered by the test expert given the scenario of poor real-world performance despite good isolated accuracy.
A lack of similarity between the training and testing data (A): This is a common issue in ML where the model performs well on training data but poorly on real-world data due to a lack of representativeness in the training data. This leads to poor generalization to new, unseen data.
The input data has not been tested for quality prior to use for testing (B): While data quality is important, this option is less likely to be the primary reason for the described issue compared to the representativeness of training data.
A lack of focus on choosing the right functional-performance metrics (C): Proper metrics are crucial, but the issue described seems more related to the data mismatch rather than metric selection.
A lack of focus on non-functional requirements testing (D): Non-functional requirements are important, but the scenario specifically mentions issues with detecting real cancer cases, pointing more towards data issues.
ISTQB CT-AI Syllabus Section 4.2 on Training, Validation, and Test Datasets emphasizes the importance of using representative datasets to ensure the model generalizes well to real-world data.
Sample Exam Questions document, Question #40 addresses issues related to data representativeness and model generalization.
NEW QUESTION # 24
"Splendid Healthcare" has started developing a cancer detection system based on ML. The type of cancer they plan on detecting has 2% prevalence rate in the population of a particular geography. It is required that the model performs well for both normal and cancer patients.
Which ONE of the following combinations requires MAXIMIZATION?
SELECT ONE OPTION
  • A. Maximize accuracy and recall
  • B. Maximize specificity number of classes
  • C. Maximize precision and accuracy
  • D. Maximize recall and precision
* Prevalence Rate and Model Performance:
* The cancer detection system being developed by "Splendid Healthcare" needs to account for the fact that the type of cancer has a 2% prevalence rate in the population. This indicates that the dataset is highly imbalanced with far fewer positive (cancer) cases compared to negative (normal) cases.
* Importance of Recall:
* Recall, also known as sensitivity or true positive rate, measures the proportion of actual positive cases that are correctly identified by the model. In medical diagnosis, especially cancer detection, recall is critical because missing a positive case (false negative) could have severe consequences for the patient. Therefore, maximizing recall ensures that most, if not all, cancer cases are detected.
* Importance of Precision:
* Precision measures the proportion of predicted positive cases that are actually positive. High precision reduces the number of false positives, meaning fewer people will be incorrectly diagnosed with cancer. This is also important to avoid unnecessary anxiety and further invasive testing for those who do not have the disease.
* Balancing Recall and Precision:
* In scenarios where both false negatives and false positives have significant consequences, it is crucial to balance recall and precision. This balance ensures that the model is not only good at detecting positive cases but also accurate in its predictions, reducing both types of errors.
* Accuracy and Specificity:
* While accuracy (the proportion of total correct predictions) is important, it can be misleading in imbalanced datasets. In this case, high accuracy could simply result from the model predicting the majority class (normal) correctly. Specificity (true negative rate) is also important, but for a cancer detection system, recall and precision take precedence to ensure positive cases are correctly and accurately identified.
* Conclusion:
* Therefore, for a cancer detection system with a low prevalence rate, maximizing both recall and precision is crucial to ensure effective and accurate detection of cancer cases.
This explanation aligns with the principles outlined in the ISTQB CT-AI Syllabus, particularly sections on performance metrics for ML models and handling imbalanced datasets (Chapter 5: ML Functional Performance Metrics).
NEW QUESTION # 25
Which ONE of the following approaches to labelling requires the least time and effort?
SELECT ONE OPTION
  • A. Outsourced
  • B. Al-Assisted
  • C. Pre-labeled dataset
  • D. Internal
* Labelling Approaches: Among the options provided, pre-labeled datasets require the least time and effort because the data has already been labeled, eliminating the need for further manual or automated labeling efforts.
* Reference: ISTQB_CT-AI_Syllabus_v1.0, Section 4.5 Data Labelling for Supervised Learning, which discusses various approaches to data labeling, including pre-labeled datasets, and their associated time and effort requirements.
NEW QUESTION # 26
A system was developed for screening the X-rays of patients for potential malignancy detection (skin cancer). A workflow system has been developed to screen multiple cancers by using several individually trained ML models chained together in the workflow.
Testing the pipeline could involve multiple kind of tests (I - III):
I . Pairwise testing of combinations
II . Testing each individual model for accuracy
III . A/B testing of different sequences of models
Which ONE of the following options contains the kinds of tests that would be MOST APPROPRIATE to include in the strategy for optimal detection?
SELECT ONE OPTION
  • A. Only III
  • B. I and II
  • C. Only II
  • D. I and III
The question asks which combination of tests would be most appropriate to include in the strategy for optimal detection in a workflow system using multiple ML models.
Pairwise testing of combinations (I): This method is useful for testing interactions between different components in the workflow to ensure they work well together, identifying potential issues in the integration.
Testing each individual model for accuracy (II): Ensuring that each model in the workflow performs accurately on its own is crucial before integrating them into a combined workflow.
A/B testing of different sequences of models (III): This involves comparing different sequences to determine which configuration yields the best results. While useful, it might not be as fundamental as pairwise and individual accuracy testing in the initial stages.
ISTQB CT-AI Syllabus Section 9.2 on Pairwise Testing and Section 9.3 on Testing ML Models emphasize the importance of testing interactions and individual model accuracy in complex ML workflows.
NEW QUESTION # 27
Which of the following is an example of a clustering problem that can be resolved by unsupervised learning?
  • A. Estimating the expected purchase of cat food after a particularly successful ad campaign
  • B. Classifying muffin purchases based on the perceived attractiveness of their packaging
  • C. Grouping individual fish together based on their types of fins
  • D. Associating shoppers with their shopping tendencies
The syllabus defines clustering as:
"Clustering: This is when the problem requires the identification of similarities in input data points that allows them to be grouped based on common characteristics or attributes. For example, clustering is used to categorize different types of customers for the purpose of marketing." (Reference: ISTQB CT-AI Syllabus v1.0, Section 3.1.2, page 26 of 99)
NEW QUESTION # 28
Most of the materials on the market do not have a free trial function. Even some of the physical books are sealed up and cannot be read before purchase. As a result, many students have bought materials that are not suitable for them and have wasted a lot of money. Especially for those students who are headaches when reading a book, CT-AI study tool is their gospel. Because doing exercises will make it easier for one person to concentrate, and at the same time, in the process of conducting a mock examination to test yourself, seeing the improvement of yourself will makes you feel very fulfilled and have a stronger interest in learning. CT-AI Guide Torrent makes your learning process not boring at all.
CT-AI Valid Test Questions: https://www.actualtestsit.com/ISTQB/CT-AI-exam-prep-dumps.html
For ISTQB CT-AI certification test, are you ready, ISTQB CT-AI Latest Exam Registration It includes questions and answers, and issimilar with the real exam questions, Make sure you choose the top-notch ISTQB CT-AI study materials to get ready for this exam, In the process of using the CT-AI study training materials, once users have any questions about our study materials, the user can directly by E-mail us, our products have a dedicated customer service staff to answer for the user, they are 24 hours service for you, we are very welcome to contact us by E-mail and put forward valuable opinion for us, You can have a comprehensive understanding of our CT-AI study materials after you see this information.
Build smart, efficient cities brimming with opportunity, Jesse: At Adaptive Path, we talk about our work as a practice, For ISTQB CT-AI Certification test, are you ready?
It includes questions and answers, and issimilar with the real exam questions, Make sure you choose the top-notch ISTQB CT-AI study materials to get ready for this exam.
Realistic ISTQB CT-AI Exam Questions with Accurate AnswersIn the process of using the CT-AI study training materials, once users have any questions about our study materials, the user can directly by E-mail us, our products have adedicated customer service staff to answer for the user, they CT-AI are 24 hours service for you, we are very welcome to contact us by E-mail and put forward valuable opinion for us.
