New NSE6_SDW_AD-7.6 Exam Duration - NSE6_SDW_AD-7.6 Certification Questions
Posted at yesterday 03:04      View:24 | Replies:0        Print      Only Author   [Copy Link] 1#
The Fortinet NSE6_SDW_AD-7.6 exam questions are being offered in three different formats. These formats are Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator (NSE6_SDW_AD-7.6) PDF dumps files, desktop practice test software, and web-based practice test software. All these three Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator (NSE6_SDW_AD-7.6) exam dumps formats contain the real Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator (NSE6_SDW_AD-7.6) exam questions that assist you in your Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator (NSE6_SDW_AD-7.6) practice exam preparation and finally, you will be confident to pass the final NSE6_SDW_AD-7.6 exam easily.
Our company deeply knows that product quality is very important, so we have been focusing on ensuring the development of a high quality of our NSE6_SDW_AD-7.6 test torrent. All customers who have purchased our products have left deep impression on our NSE6_SDW_AD-7.6 guide torrent. Of course, the customer not only has left deep impression on the high quality of our products but also the efficiency of our products. Our NSE6_SDW_AD-7.6 Exam Questions can help you save much time, if you use our products, you just need to spend 20-30 hours on learning, and you will pass your exam successfully. What most important is that you can download our study materials about 5~10 minutes after you purchase.
NSE6_SDW_AD-7.6 Certification Questions, NSE6_SDW_AD-7.6 Study MaterialsSome candidates say that they prepare for NSE6_SDW_AD-7.6 exam using some exam materials from other site but fail. If you still do not know how to pass exam, our Fortinet NSE6_SDW_AD-7.6 actual test will be a clever choice for you now. You will know both dump price and exam quantity should not take into key account. The most key consideration is the quality of NSE6_SDW_AD-7.6 Actual Test. If you are afraid of failure please rest assured to purchase our exam questions, I am sure that our NSE6_SDW_AD-7.6 actual test will help you pass exam.
Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator Sample Questions (Q85-Q90):NEW QUESTION # 85
Refer to the exhibits.
The exhibits show two IPsec templates to define Branch IPsec 1 and Branch_IPsec_2. Each template defines a VPN tunnel. The error message that FortiManager displayed when the administrator tried to assign the second template to the FortiGate device is also shown.
Which statement best describes the cause of the issue?
  • A. You can assign only one IPsec template to each FortiGate device.
  • B. You should review the branch1_fgt configuration for configured tunnels in the rootVDOM.
  • C. You can assign only one template with a tunnel type of static to each FortiGate device.
  • D. You should use the same outgoing interface of both templates.
The FortiManager SD-WAN overlay system allows only one IPsec template to be assigned to each device per overlay operation. The guide clarifies:
"If you attempt to assign more than one IPsec template to a FortiGate device for the same overlay type, FortiManager will display an error, preventing duplicate or conflicting tunnel configurations. This limitation ensures a one-to-one mapping between device and overlay template per operation, maintaining configuration integrity and preventing routing issues." This prevents complex troubleshooting scenarios and enforces best practices for overlay design.
NEW QUESTION # 86
Refer to the exhibit that shows a diagnose output on FortiGate.
Based on the output shown in the exhibit, what can you say about the device role and how it handles health checks?
  • A. The device is a spoke. It provides embedded health-check measures for each tunnel to the hub.
  • B. The device is a hub. It receives health-check measures for the tunnels of a spoke.
  • C. The device is a hub. It receives embedded health-check measures for each tunnel from the spoke.
  • D. The device is a spoke. It receives health-check measures for the tunnels of another spoke.
The diagnose output shows multiple ADVPN tunnels (HUB1-VPN1, HUB1-VPN2, HUB1-VPN3) with detailed latency, jitter, and packet loss values being reported for each. In ADVPN, the spoke performs embedded health checks and provides the hub with the performance metrics for each tunnel. Therefore, the device in the exhibit is a spoke, and it is sending health-check measurements for each tunnel to the hub.
NEW QUESTION # 87
The exhibit shows the health-check configuration on a FortiGate device used as a spoke. You notice that the hub FortiGate doesn't prioritize the traffic as expected.
Which two configuration elements should you check on the hub? (Choose two.)
  • A. The performance SLA is configured with set embedded-measure accept.
  • B. The performance SLA uses the same criteria.
  • C. The performance SLA has the parameter priority-out-sla configured.
  • D. This performance SLA uses the same members.
The hub must use a performance SLA with the same criteria as the spoke's health check. The spoke's health check is using ping (protocol ping) and measuring latency (link-cost-factor latency). For the hub to use the data sent by the spoke, its performance SLA must be configured to measure the same metrics. If the hub is looking for jitter or packet loss, it will not use the latency data sent by the spoke.
When a spoke sends embedded health data, the hub FortiGate must be configured to receive and use it. This is done by setting set embedded-measure accept within the performance SLA configuration on the hub. This setting explicitly tells the hub to trust and use the performance metrics received from the remote FortiGate (the spoke). Without this setting, the hub will likely ignore the embedded health data and rely on its own health checks, which could lead to incorrect traffic prioritization.
NEW QUESTION # 88
SD-WAN interacts with many other FortiGate features. Some of them are required to allow SD-WAN to steer the traffic.
Which three configuration elements that you must configure before FortiGate can steer traffic according to SD-WAN rules? (Choose three.)
  • A. Traffic shaping
  • B. Security profiles
  • C. Interfaces
  • D. Firewall policies
  • E. Routing
Answer: C,D,E
Before FortiGate can steer traffic according to SD-WAN rules, certain configuration elements must be present. The guide states:
"SD-WAN is not a standalone feature and interacts with several fundamental FortiGate configurations.
Specifically, you must: (1) Define the interfaces (physical, VLAN, or IPsec) that will act as SD-WAN members, (2) Create firewall policies to allow traffic to be steered by SD-WAN, and (3) Set up routing so that traffic has valid routes via SD-WAN members. Without these, SD-WAN rules will not be able to match or steer any traffic." Security profiles and traffic shaping are not mandatory for basic SD-WAN steering but can be layered on for enhanced security and QoS once foundational elements are present.
[FCSS_SDW_AR-7.4 1-0.docx Q16]
FortiOS 7.4 SD-WAN Concept Guide, "rerequisite Configuration Elements for SD-WAN Steering
NEW QUESTION # 89
An SD-WAN member is no longer used to steer SD-WAN traffic. The administrator updated the SD-WAN configuration and deleted the unused member. After the configuration update, users report that some destinations are unreachable. You confirm that the affected flow does not match an SD-WAN rule.
What could be a possible cause of the traffic interruption?
  • A. FortiGate, with SD-WAN enabled, cannot route traffic through interfaces that are not SD-WAN members.
  • B. FortiGate removes the layer 3 settings for interfaces that are removed from the SD-WAN configuration.
  • C. FortiGate administratively brings down interfaces when they are removed from the SD-WAN configuration.
  • D. FortiGate can remove some static routes associated with an interface when the member is removed from SD-WAN.
When an SD-WAN member is deleted, FortiGate can also remove static routes that were tied to that interface.
If those routes are needed for destinations not covered by SD-WAN rules, traffic to those networks becomes unreachable. This explains why flows not matching SD-WAN rules are interrupted after the member was removed.
NEW QUESTION # 90
They are not forced to buy one format or the other to prepare for the Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator NSE6_SDW_AD-7.6 exam. ITdumpsfree designed Fortinet NSE6_SDW_AD-7.6 exam preparation material in Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator NSE6_SDW_AD-7.6 PDF and practice test. If you prefer PDF Dumps notes or practicing on the Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator NSE6_SDW_AD-7.6 practice test software, use either.
NSE6_SDW_AD-7.6 Certification Questions: https://www.itdumpsfree.com/NSE6_SDW_AD-7.6-exam-passed.html
Fortinet New NSE6_SDW_AD-7.6 Exam Duration Therefore, whatever questions you have, you can get immediate answers so that you will no longer be troubled by any problem, Therefore, entering into this field becomes everyone's dream, especially getting the NSE6_SDW_AD-7.6 certification, Fortinet New NSE6_SDW_AD-7.6 Exam Duration If we fail to deliver this promise, we will give your money back, If you don't receive our NSE6_SDW_AD-7.6 study materials in five minutes, please contact with our online worker.
On dismissal, it fades back to the original view, These eight tips will save NSE6_SDW_AD-7.6 you time and frustration, Therefore, whatever questions you have, you can get immediate answers so that you will no longer be troubled by any problem.
Free PDF Quiz 2026 NSE6_SDW_AD-7.6: Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator – High Pass-Rate New Exam DurationTherefore, entering into this field becomes everyone's dream, especially getting the NSE6_SDW_AD-7.6 Certification, If we fail to deliver this promise, we will give your money back!
If you don't receive our NSE6_SDW_AD-7.6 study materials in five minutes, please contact with our online worker, We can tell you with confidence that the NSE6_SDW_AD-7.6 practice materials are superior in all respects to similar products.
