Free download Fortinet certification NSE7_SOC_AR-7.6 exam practice questions and
123
Posted at yesterday 03:25      View:20 | Replies:0        Print      Only Author   [Copy Link] 1#
As the unprecedented intensity of talents comes in great numbers, what abilities should a talent of modern time possess and finally walk to the success? Well, of course it is NSE7_SOC_AR-7.6 exam qualification certification that gives you capital of standing in society. Our NSE7_SOC_AR-7.6 preparation materials display a brand-new learning model and a comprehensive knowledge structure on our official exam bank, which aims at improving your technical skills and creating your value to your future. You will be bound to pass the NSE7_SOC_AR-7.6 Exam with our advanced NSE7_SOC_AR-7.6 exam questions.
Are you still worried about the exam? Don't worry! Our NSE7_SOC_AR-7.6 exam torrent can help you overcome this stumbling block during your working or learning process. Under the instruction of our NSE7_SOC_AR-7.6 test prep, you are able to finish your task in a very short time and pass the exam without mistakes to obtain the NSE7_SOC_AR-7.6 certificate. We will tailor services to different individuals and help them take part in their aimed exams after only 20-30 hours practice and training. Moreover, we have experts to update NSE7_SOC_AR-7.6 quiz torrent in terms of theories and contents on a daily basis.
Pass Guaranteed Quiz Fantastic Fortinet - NSE7_SOC_AR-7.6 - Fortinet NSE 7 - Security Operations 7.6 Architect Official Practice TestAs is known to us, a suitable learning plan is very important for all people. For the sake of more competitive, it is very necessary for you to make a learning plan. We believe that our NSE7_SOC_AR-7.6 actual exam will help you make a good learning plan. You can have a model test in limited time by our NSE7_SOC_AR-7.6 Study Materials, if you finish the model test, our system will generate a report according to your performance. And in this way, you can have the best pass percentage on your NSE7_SOC_AR-7.6 exam.
Fortinet NSE 7 - Security Operations 7.6 Architect Sample Questions (Q47-Q52):NEW QUESTION # 47
Refer to the Exhibit:
An analyst wants to create an incident and generate a report whenever FortiAnalyzer generates a malicious attachment event based on FortiSandbox analysis. The endpoint hosts are protected by FortiClient EMS integrated with FortiSandbox. All devices are logging to FortiAnalyzer.
Which connector must the analyst use in this playbook?
  • A. FortiSandbox connector
  • B. FortiClient EMS connector
  • C. Local connector
  • D. FortiMail connector
* Understanding the Requirements:
* The objective is to create an incident and generate a report based on malicious attachment events detected by FortiAnalyzer from FortiSandbox analysis.
* The endpoint hosts are protected by FortiClient EMS, which is integrated with FortiSandbox. All logs are sent to FortiAnalyzer.
* Key Components:
* FortiAnalyzer: Centralized logging and analysis for Fortinet devices.
* FortiSandbox: Advanced threat protection system that analyzes suspicious files and URLs.
* FortiClient EMS: Endpoint management system that integrates with FortiSandbox for endpoint protection.
* Playbook Analysis:
* The playbook in the exhibit consists of three main actions: GET_EVENTS, RUN_REPORT, and CREATE_INCIDENT.
* EVENT_TRIGGER: Starts the playbook when an event occurs.
* GET_EVENTS: Fetches relevant events.
* RUN_REPORT: Generates a report based on the events.
* CREATE_INCIDENT: Creates an incident in the incident management system.
* Selecting the Correct Connector:
* The correct connector should allow fetching events related to malicious attachments analyzed by FortiSandbox and facilitate integration with FortiAnalyzer.
* Connector Options:
* FortiSandbox Connector:
* Directly integrates with FortiSandbox to fetch analysis results and events related to malicious attachments.
* Best suited for getting detailed sandbox analysis results.
* Selected as it is directly related to the requirement of handling FortiSandbox analysis events.
* FortiClient EMS Connector:
* Used for managing endpoint security and integrating with endpoint logs.
* Not directly related to fetching sandbox analysis events.
* Not selected as it is not directly related to the sandbox analysis events.
* FortiMail Connector:
* Used for email security and handling email-related logs and events.
* Not applicable for sandbox analysis events.
* Not selected as it does not relate to the sandbox analysis.
* Local Connector:
* Handles local events within FortiAnalyzer itself.
* Might not be specific enough for fetching detailed sandbox analysis results.
* Not selected as it may not provide the required integration with FortiSandbox.
* Implementation Steps:
* Step 1: Ensure FortiSandbox is configured to send analysis results to FortiAnalyzer.
* Step 2: Use the FortiSandbox connector in the playbook to fetch events related to malicious attachments.
* Step 3: Configure the GET_EVENTS action to use the FortiSandbox connector.
* Step 4: Set up the RUN_REPORT and CREATE_INCIDENT actions based on the fetched events.
Fortinet Documentation on FortiSandbox Integration FortiSandbox Integration Guide Fortinet Documentation on FortiAnalyzer Event Handling FortiAnalyzer Administration Guide By using the FortiSandbox connector, the analyst can ensure that the playbook accurately fetches events based on FortiSandbox analysis and generates the required incident and report.
NEW QUESTION # 48
You notice that the custom event handler you configured to detect SMTP reconnaissance activities is creating a large number of events. This is overwhelming your notification system.
How can you fix this?
  • A. Increase the log field value so that it looks for more unique field values when it creates the event.
  • B. Decrease the time range that the custom event handler covers during the attack.
  • C. Disable the custom event handler because it is not working as expected.
  • D. Increase the trigger count so that it identifies and reduces the count triggered by a particular group.
* Understanding the Issue:
* The custom event handler for detecting SMTP reconnaissance activities is generating a large number of events.
* This high volume of events is overwhelming the notification system, leading to potential alert fatigue and inefficiency in incident response.
* Event Handler Configuration:
* Event handlers are configured to trigger alerts based on specific criteria.
* The frequency and volume of these alerts can be controlled by adjusting the trigger conditions.
* Possible Solutions:
* A. Increase the trigger count so that it identifies and reduces the count triggered by a particular group:
* By increasing the trigger count, you ensure that the event handler only generates alerts after a higher threshold of activity is detected.
* This reduces the number of events generated and helps prevent overwhelming the notification system.
* Selected as it effectively manages the volume of generated events.
* B. Disable the custom event handler because it is not working as expected:
* Disabling the event handler is not a practical solution as it would completely stop monitoring for SMTP reconnaissance activities.
* Not selected as it does not address the issue of fine-tuning the event generation.
* C. Decrease the time range that the custom event handler covers during the attack:
* Reducing the time range might help in some cases, but it could also lead to missing important activities if the attack spans a longer period.
* Not selected as it could lead to underreporting of significant events.
* D. Increase the log field value so that it looks for more unique field values when it creates the event:
* Adjusting the log field value might refine the event criteria, but it does not directly control the volume of alerts.
* Not selected as it is not the most effective way to manage event volume.
* Step 1: Access the event handler configuration in FortiAnalyzer.
* Step 2: Locate the trigger count setting within the custom event handler for SMTP reconnaissance.
* Step 3: Increase the trigger count to a higher value that balances alert sensitivity and volume.
* Step 4: Save the configuration and monitor the event generation to ensure it aligns with expected levels.
* Conclusion:
* By increasing the trigger count, you can effectively reduce the number of events generated by the custom event handler, preventing the notification system from being overwhelmed.
Fortinet Documentation on Event Handlers and Configuration FortiAnalyzer Administration Guide Best Practices for Event Management Fortinet Knowledge Base By increasing the trigger count in the custom event handler, you can manage the volume of generated events and prevent the notification system from being overwhelmed.
NEW QUESTION # 49
Which two options describe how the Update Asset and Identity Database playbook is configured? (Choose two.)
  • A. The playbook is using a local connector.
  • B. The playbook is using an on-demand trigger.
  • C. The playbook is using a FortiMail connector.
  • D. The playbook is using a FortiClient EMS connector.
* Understanding the Playbook Configuration:
* The playbook named "Update Asset and Identity Database" is designed to update the FortiAnalyzer Asset and Identity database with endpoint and user information.
* The exhibit shows the playbook with three main components: ON_SCHEDULE STARTER, GET_ENDPOINTS, and UPDATE_ASSET_AND_IDENTITY.
* Analyzing the Components:
* ON_SCHEDULE STARTER:This component indicates that the playbook is triggered on a schedule, not on-demand.
* GET_ENDPOINTS:This action retrieves information about endpoints, suggesting it interacts with an endpoint management system.
* UPDATE_ASSET_AND_IDENTITY:This action updates the FortiAnalyzer Asset and Identity database with the retrieved information.
* Evaluating the Options:
* Option A:The actions shown in the playbook are standard local actions that can be executed by the FortiAnalyzer, indicating the use of a local connector.
* Option B:There is no indication that the playbook uses a FortiMail connector, as the tasks involve endpoint and identity management, not email.
* Option C:The playbook is using an "ON_SCHEDULE" trigger, which contradicts the description of an on-demand trigger.
* Option D:The action "GET_ENDPOINTS" suggests integration with an endpoint management system, likely FortiClient EMS, which manages endpoints and retrieves information from them.
* Conclusion:
* The playbook is configured to use a local connector for its actions.
* It interacts with FortiClient EMS to get endpoint information and update the FortiAnalyzer Asset and Identity database.
Fortinet Documentation on Playbook Actions and Connectors.
FortiAnalyzer and FortiClient EMS Integration Guides.
NEW QUESTION # 50
You must configure the FortiGate connector to allow FortiSOAR to perform actions on a firewall. However, the connection fails. Which two configurations are required? (Choose two answers)
  • A. HTTPS must be enabled on the FortiGate interface that FortiSOAR will communicate with.
  • B. An API administrator must be created on FortiGate with the appropriate profile, along with a generated API key to configure on the connector.
  • C. The VDOM name must be specified, or set to VDOM_1, if VDOMs are not enabled on FortiGate.
  • D. Trusted hosts must be enabled and the FortiSOAR IP address must be permitted.
Comprehensive and Detailed Explanation From FortiSOAR 7.6., FortiSIEM 7.3 Exact Extract study guide:
To establish a successful integration betweenFortiSOAR 7.6and aFortiGatefirewall via the FortiGate connector, specific administrative and network requirements must be met on the FortiGate side:
* API Administrator and Key (D):FortiSOAR does not use standard UI login credentials. Instead, it requires aREST API Administratoraccount to be created on the FortiGate. This account must be assigned an administrative profile with the necessary permissions (e.g., Read/Write for Firewall policies or Address objects). Upon creation, the FortiGate generates a uniqueAPI Key, which must be entered into the "API Key" field of the FortiSOAR configuration wizard as shown in the exhibit.
* HTTPS Management Access (C):The connector communicates with the FortiGate using REST API calls overHTTPS(port 443 by default). Therefore, the physical or logical interface on the FortiGate that corresponds to the "Hostname" IP (172.16.200.1) must haveHTTPSenabled under "Administrative Access" in its network settings. If HTTPS is disabled, the connection will time out or be refused.
* Trusted hosts (A):While it is a best practice to restrict API access to specific IPs (like the FortiSOAR IP), the integration can technically function without "Trusted hosts" enabled if the network allows the traffic. However, theabsenceof an API key or HTTPS access will definitively cause a failure regardless of trusted host settings.
* VDOM name (B):In the exhibit, the VDOM field contains multiple values ("VDOM_1", "VDOM_2").
If VDOMs are disabled on the FortiGate, this field should generally be left blank or set to the default
"root." Setting it specifically to "VDOM_1" when VDOMs are disabled is not a universal requirement for connectivity; the primary handshake depends on the API key and HTTPS connectivity.
NEW QUESTION # 51
When configuring a FortiAnalyzer to act as a collector device, which two steps must you perform? (Choose two.)
  • A. Configure the data policy to focus on archiving.
  • B. Configure log forwarding to a FortiAnalyzer in analyzer mode.
  • C. Configure Fabric authorization on the connecting interface.
  • D. Enable log compression.
* Understanding FortiAnalyzer Roles:
* FortiAnalyzer can operate in two primary modes: collector mode and analyzer mode.
* Collector Mode: Gathers logs from various devices and forwards them to another FortiAnalyzer operating in analyzer mode for detailed analysis.
* Analyzer Mode: Provides detailed log analysis, reporting, and incident management.
* Steps to Configure FortiAnalyzer as a Collector Device:
* A. Enable Log Compression:
* While enabling log compression can help save storage space, it is not a mandatory step specifically required for configuring FortiAnalyzer in collector mode.
* Not selected as it is optional and not directly related to the collector configuration process.
* B. Configure Log Forwarding to a FortiAnalyzer in Analyzer Mode:
* Essential for ensuring that logs collected by the collector FortiAnalyzer are sent to the analyzer FortiAnalyzer for detailed processing.
* Selected as it is a critical step in configuring a FortiAnalyzer as a collector device.
* Step 1: Access the FortiAnalyzer interface and navigate to log forwarding settings.
* Step 2: Configure log forwarding by specifying the IP address and necessary credentials of the FortiAnalyzer in analyzer mode.
Fortinet Documentation on Log Forwarding FortiAnalyzer Log Forwarding
C). Configure the Data Policy to Focus on Archiving:
Data policy configuration typically relates to how logs are stored and managed within FortiAnalyzer, focusing on archiving may not be specifically required for a collector device setup.
Not selected as it is not a necessary step for configuring the collector mode.
D). Configure Fabric Authorization on the Connecting Interface:
Necessary to ensure secure and authenticated communication between FortiAnalyzer devices within the Security Fabric.
Selected as it is essential for secure integration and communication.
Step 1: Access the FortiAnalyzer interface and navigate to the Fabric authorization settings.
Step 2: Enable Fabric authorization on the interface used for connecting to other Fortinet devices and FortiAnalyzers.
Reference: Fortinet Documentation on Fabric Authorization FortiAnalyzer Fabric Authorization Implementation Summary:
Configure log forwarding to ensure logs collected are sent to the analyzer.
Enable Fabric authorization to ensure secure communication and integration within the Security Fabric.
Conclusion:
Configuring log forwarding and Fabric authorization are key steps in setting up a FortiAnalyzer as a collector device to ensure proper log collection and forwarding for analysis.
Fortinet Documentation on FortiAnalyzer Roles and Configurations FortiAnalyzer Administration Guide By configuring log forwarding to a FortiAnalyzer in analyzer mode and enabling Fabric authorization on the connecting interface, you can ensure proper setup of FortiAnalyzer as a collector device.
NEW QUESTION # 52
We all have same experiences that some excellent people around us further their study and never stop their pace even though they have done great job in their surrounding environment. So it is of great importance to make yourself competitive as much as possible. Facing the NSE7_SOC_AR-7.6 exam this time, your rooted stressful mind of the exam can be eliminated after getting help from our NSE7_SOC_AR-7.6 practice materials. They do not let go even the tenuous points about the NSE7_SOC_AR-7.6 exam as long as they are helpful and related to the exam. And let go those opaque technicalities which are useless and hard to understand, which means whether you are newbie or experienced exam candidate of this area, you can use our NSE7_SOC_AR-7.6 real questions with ease.
NSE7_SOC_AR-7.6 Free Braindumps: https://www.examtorrent.com/NSE7_SOC_AR-7.6-valid-vce-dumps.html
Our NSE7_SOC_AR-7.6 top torrent materials are being compiled wholly based on real questions of the test, What’s more, the NSE7_SOC_AR-7.6 questions and answers are the best valid and latest, which can ensure 100% pass, We know that most candidates have a busy schedule, making it difficult to devote much time to their Fortinet NSE 7 - Security Operations 7.6 Architect (NSE7_SOC_AR-7.6) test preparation, With ExamTorrent NSE7_SOC_AR-7.6 exam PDF and exam VCE simulator, NSE7_SOC_AR-7.6 candidates can shorten the preparation time and be prepared efficiently.
The British Computer Society wants women in IT NSE7_SOC_AR-7.6 Official Practice Test careers to receive the same pay as their male counterparts, In conversations with Mac business software developers, I was told again and again NSE7_SOC_AR-7.6 that the past couple of years has seen a significant increase in demand for their products.
Top NSE7_SOC_AR-7.6 Official Practice Test Free PDF | Professional NSE7_SOC_AR-7.6 Free Braindumps: Fortinet NSE 7 - Security Operations 7.6 ArchitectOur NSE7_SOC_AR-7.6 top torrent materials are being compiled wholly based on real questions of the test, What’s more, the NSE7_SOC_AR-7.6 questions and answers are the best valid and latest, which can ensure 100% pass.
All operating systems such as Mac, iOS, Windows, Linux, and Android support the web-based Fortinet NSE 7 - Security Operations 7.6 Architect NSE7_SOC_AR-7.6 practice exam.
