[Hardware] CCFH-202b Certification Sample Questions - CCFH-202b Practice Questions
【Hardware】 CCFH-202b Certification Sample Questions - CCFH-202b Practice Questions
Posted at 16 hour before      View:19 | Replies:0        Print      Only Author   [Copy Link] 1#
The CrowdStrike Certified Falcon Hunter (CCFH-202b) certification exam is a valuable credential that is designed to validate the candidates' skills and knowledge level. The CCFH-202b certification exam is one of the high in demand industrial recognized credentials to prove your skills and knowledge level. With the CrowdStrike CCFH-202b Certification Exam everyone can upgrade their skills and become competitive and updated in the market.
The exact replica of the real CrowdStrike CCFH-202b exam questions is another incredible feature of the web-based practice test software. With this, you can kill your CrowdStrike CCFH-202b exam anxiety. Another format of the CrowdStrike Certified Falcon Hunter (CCFH-202b) practice test material is the CCFH-202b desktop practice exam software. All traits of the web-based CCFH-202b practice test are present in this version.
Magnificent CCFH-202b Preparation Exam: CrowdStrike Certified Falcon Hunter forms high-quality Training Engine - Actual4DumpsWhen preparing to take the CrowdStrike Certified Falcon Hunter (CCFH-202b) exam dumps, knowing where to start can be a little frustrating, but with CrowdStrike CCFH-202b practice questions, you will feel fully prepared. Using our CrowdStrike CCFH-202b practice test Actual4Dumps, you can prepare for the increased difficulty on CCFH-202b Exam day. Plus, we have various question types and difficulty levels so that you can tailor your CrowdStrike CCFH-202b exam dumps preparation to your requirements.
CrowdStrike Certified Falcon Hunter Sample Questions (Q51-Q56):NEW QUESTION # 51
Which of the following is a way to create event searches that run automatically and recur on a schedule that you set?
  • A. Workflows
  • B. Scheduled Searches
  • C. Event Search
  • D. Scheduled Reports
Scheduled Searches are a way to create event searches that run automatically and recur on a schedule that you set. You can use Scheduled Searches to monitor your environment for specific conditions or patterns, generate reports or alerts, or enrich your data with additional fields or tags. Workflows, Event Search, and Scheduled Reports are not ways to create event searches that run automatically and recur on a schedule.
NEW QUESTION # 52
To view Files Written to Removable Media within a specified timeframe on a host within the Host Search page, expand and refer to the _______dashboard panel.
  • A. Suspicious File Activity
  • B. Command Line and Admin Tools
  • C. Processes and Services
  • D. Registry, Tasks, and Firewall
To view Files Written to Removable Media within a specified timeframe on a host within the Host Search page, you need to expand and refer to the Suspicious File Activity dashboard panel. The Suspicious File Activity dashboard panel shows information such as files written to removable media, files written to system directories by non-system processes, files written to startup folders, etc. The other dashboard panels do not show files written to removable media.
NEW QUESTION # 53
Adversaries commonly execute discovery commands such as netexe, ipconfig.exe, and whoami exe. Rather than query for each of these commands individually, you would like to use a single query with all of them. What Splunk operator is needed to complete the following query?
  • A. AND
  • B. NOT
  • C. OR
  • D. IN
The OR operator is needed to complete the following query, as it allows to search for events that match any of the specified values. The query would look like this:
event_simpleName=ProcessRollup2 FileName=net.exe OR FileName=ipconfig.exe OR FileName=whoami.exe The OR operator is used to combine multiple search terms or expressions and return events that match at least one of them. The IN, NOT, and AND operators are not suitable for this query, as they have different functions and meanings.
NEW QUESTION # 54
What topics are presented in the Hunting and Investigation Guide?
  • A. Detailed tutorial on writing advanced queries such as sub-searches and joins
  • B. Recommended platform configurations and prevention settings to ensure detections are generated for hunting leads
  • C. Detailed summary of event names, descriptions, and some key data fields for hunting and investigation
  • D. Sample hunting queries, select walkthroughs and best practices for hunting with Falcon
This is the correct answer for the same reason as above. The Hunting and Investigation guide provides sample hunting queries, select walkthroughs, and best practices for hunting with Falcon. It does not provide a detailed tutorial on writing advanced queries, a detailed summary of event names and descriptions, or recommended platform configurations and prevention settings.
NEW QUESTION # 55
To find events that are outliers inside a network,___________is the best hunting method to use.
  • A. stacking
  • B. machine learning
  • C. searching
  • D. time-based
Stacking (Frequency Analysis) is the best hunting method to use to find events that are outliers inside a network. Stacking involves grouping events by a common attribute and counting their frequency, then sorting them by ascending or descending order to identify rare or common events. This can help find anomalies or deviations from normal behavior that could indicate malicious activity. Time-based searching, machine learning, and searching are not specific hunting methods to find outliers.
NEW QUESTION # 56
To those time-sensitive exam candidates, our high-efficient CCFH-202b actual dumps comprised of important news will be best help. Only by practicing our CCFH-202b learning guide on a regular base, you will see clear progress happened on you. Besides, rather than waiting for the gain of our CCFH-202b Practice Engine, you can download them immediately after paying for it, so just begin your journey toward success now.
CCFH-202b Practice Questions: https://www.actual4dumps.com/CCFH-202b-study-material.html
Now pass CrowdStrike CCFH-202b Exam in First attempt, Furthermore, although our CCFH-202b exam dumps materials are the best in this field, in order to help more people, the price of our product is reasonable in the market, If you are looking for CCFH-202b real exam questions urgently so that you can pass a certification successfully, our CCFH-202b real test questions can help you achieve your goal, To make you understand the content more efficient, our experts add charts, diagrams and examples in to CCFH-202b exam questions to speed up you pace of gaining success.
Provos and Holz have written the book that the bad guys don't want CCFH-202b you to read, The common thread throughout the thumbnail and preview options is the trade-off between resources and responsiveness.
CCFH-202b Certification Sample Questions | High-quality CrowdStrike Certified Falcon Hunter 100% Free Practice QuestionsNow pass CrowdStrike CCFH-202b Exam in First attempt, Furthermore, although our CCFH-202b exam dumps materials are the best in this field, in order to help more people, the price of our product is reasonable in the market.
If you are looking for CCFH-202b real exam questions urgently so that you can pass a certification successfully, our CCFH-202b real test questions can help you achieve your goal.
Buy the CCFH-202b test preparation material now and start your journey towards success in the CrowdStrike Certified Falcon Hunter (CCFH-202b) examination.
