[Hardware] 300-745 Exam PDF - Valid Dumps 300-745 Pdf
【Hardware】 300-745 Exam PDF - Valid Dumps 300-745 Pdf
Posted at 3 hour before      View:10 | Replies:0        Print      Only Author   [Copy Link] 1#
The price for 300-745 training materials is quite reasonable, and no matter you are a student at school or an employee in the company, you can afford the expense. You just think that you only need to spend some money, and you can pass the exam and get the certificate, which is quite self-efficient. In addition, 300-745 Exam Dumps are edited by the professional experts, who are quite familiar with the professional knowledge and testing center, and the quality and accuracy can be guaranteed. We have 24 hours service stuff, and if you any questions about 300-745 training materials, just contact us.
In the past ten years, we have made many efforts to perfect our Cisco 300-745 study materials. Our 300-745 study questions cannot tolerate any small mistake. All staff has made great dedication to developing the Cisco 300-745 Exam simulation. Our professional experts are devoting themselves on the compiling and updating the exam materials.
100% Pass Quiz Efficient Cisco - 300-745 - Designing Cisco Security Infrastructure Exam PDFOur 300-745 exam questions are famous for the good performance and stale operation. Customers usually attach great importance on the function of a product. So after a long period of research and development, our 300-745 learning prep has been optimized greatly. We can promise that all of your operation is totally flexible. Even if we come across much technology problems, we have never given up. Also, we take our customers’ suggestions of the 300-745 Actual Test guide seriously. Sometimes, we will receive some good suggestions from our users. Once our researchers regard it possible to realize, we will try our best to perfect the details of the 300-745 learning prep. We are keeping advancing with you. You will regret if you do not choose our study materials.
Cisco Designing Cisco Security Infrastructure Sample Questions (Q15-Q20):NEW QUESTION # 15
A security engineer on an application design team must choose a framework of attack patterns to evaluate during threat modeling. Which framework provides the common set of attacks?
  • A. SOC2
  • B. GDPR
  • C. MITRE CAPEC
  • D. Cisco SAFE
MITRE CAPEC (Common Attack Pattern Enumeration and Classification) provides a standardized catalog of attack patterns. It is specifically designed for use in threat modeling and application design, allowing security engineers to anticipate and evaluate common attacks.
NEW QUESTION # 16
How does AI improve the performance of intrusion prevention systems (IPS)?
  • A. Enables real-time dynamic rule creation
  • B. Bypasses signature-based detection
  • C. Decreases SNMP load
  • D. Disables logging overhead
AI enables IPS platforms to analyze traffic patterns in real time and dynamically create or adjust rules to respond to new and evolving threats.
NEW QUESTION # 17
A financial company is focused on proactively protecting sensitive data stored on the devices. The company recognizes the potential risks associated with lost or stolen devices and they want a solution to ensure that if unauthorized user access the device, the data it contains is not accessible or misused. The solution includes implementing a strategy that renders data unreadable without user authentication. Which solution meets the requirement?
  • A. Apply GPS tracking.
  • B. Implement data encryption on disk.
  • C. Install Kensington Lock.
  • D. Use a BIOS password.
For a financial company, protecting "data at rest" is a critical requirement of the Cisco Security Infrastructure blueprint. While physical security and BIOS-level protections have their place,Data encryption on disk(such as BitLocker, FileVault, or hardware-encrypted drives) is the only solution that fulfills the requirement of rendering the actual data unreadable if the device is lost or stolen.
Disk encryption uses cryptographic algorithms to transform readable data into ciphertext. Without the correct decryption key-which is typically released only after successful user authentication-the data remains a meaningless string of characters even if the hard drive is removed and connected to a different machine. A Kensington Lock(Option A) is a physical deterrent to prevent theft but does not protect the data if the lock is cut or the device is stolen. ABIOS password(Option B) can prevent the OS from booting but does not stop an attacker from reading the data directly from the storage media.GPS tracking(Option D) helps in recovery but does not prevent unauthorized data access in the interim. Implementing full-disk encryption aligns with the Cisco SAFEprinciple of pervasive data protection and ensures compliance with financial regulations regarding the safeguarding of sensitive client information on mobile endpoints.
NEW QUESTION # 18
An agricultural company wants to enhance the cybersecurity posture by implementing a defense- in-depth strategy to protect against polymorphic malware threats. Currently, the company's security infrastructure relies solely on a stateful traditional edge firewall that does not provide adequate protection against malware variants. Which technology must be added to the company's security architecture to achieve the goal?
  • A. network performance monitor
  • B. heuristics-based IPS
  • C. web application firewall
  • D. physical security control
A heuristics-based Intrusion Prevention System (IPS) analyzes traffic behavior and patterns, allowing it to detect and block polymorphic malware that constantly changes its signature to evade traditional defenses. Adding this technology strengthens the company's defense-in-depth strategy beyond the limitations of a stateful firewall.
NEW QUESTION # 19
A company recently discovered that a former employee, who left to join a competitor, continued to access and exfiltrate sensitive data over several weeks after leaving. The breach highlighted vulnerabilities in the organization's data security and access management practices. To prevent such incidents in the future, the organization must adopt measures that detect and restrict unauthorized data access and transfer. Which mitigation strategy must be implemented to address the issue?
  • A. Implement data loss prevention strategy.
  • B. Implement web application firewall.
  • C. Deploy audit logging and monitoring solution.
  • D. Upgrade network policy access.
A Data Loss Prevention (DLP) strategy directly addresses the problem of unauthorized access and exfiltration of sensitive data. DLP tools monitor, detect, and block suspicious data transfers, ensuring that insiders or former employees cannot copy, email, or upload sensitive information without authorization. This provides the required prevention and control that the scenario calls for.
NEW QUESTION # 20
Using the 300-745 Study Materials, you will find that you can grasp the knowledge what you need in the exam in a short time. Because users only need to spend little hours on the 300-745 study materials, our learning materials will help users to learn all the difficulties of the test site, to help users pass the qualifying examination and obtain the qualification certificate. If you think that time is important to you, try our learning materials and it will save you a lot of time.
Valid Dumps 300-745 Pdf: https://www.dumpcollection.com/300-745_braindumps.html
The update version for 300-745 exam braindumps will be sent to you automatically, Cisco 300-745 Exam PDF Are you still distressed by the low salary and the tedious work, Our Designing Cisco Security Infrastructure (300-745) exam dumps are top-notch and designed to help students pass the Designing Cisco Security Infrastructure (300-745) test on the first try, Dumpcollection 300-745 Desktop Practice Exam Software: In the Desktop 300-745 practice exam software version of 300-745 practice test is updated and real.
For example, a program coordinator could create a book that contains 300-745 all of the most common type of documents that need to be printed or faxed, Commendation  Non-fiction Book, Golden Door Awards.
Free PDF Cisco - Accurate 300-745 - Designing Cisco Security Infrastructure Exam PDFThe update version for 300-745 Exam Braindumps will be sent to you automatically, Are you still distressed by the low salary and the tedious work, Our Designing Cisco Security Infrastructure (300-745) exam dumps are top-notch and designed to help students pass the Designing Cisco Security Infrastructure (300-745) test on the first try.
Dumpcollection 300-745 Desktop Practice Exam Software: In the Desktop 300-745 practice exam software version of 300-745 practice test is updated and real, Now choosing us it is easy.
