[General] Free PDF 2026 Fortinet FCSS_EFW_AD-7.6: Latest FCSS - Enterprise Firewall 7.6 Ad
【General】 Free PDF 2026 Fortinet FCSS_EFW_AD-7.6: Latest FCSS - Enterprise Firewall 7.6 Ad
Posted at 6 hour before      View:17 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of TrainingQuiz FCSS_EFW_AD-7.6 dumps for free: https://drive.google.com/open?id=14o747VNSHw_J_LrXjKaRx57vA9H-3VP2
In the era of informational globalization, the world has witnessed climax of science and technology development, and has enjoyed the prosperity of various scientific blooms. In 21st century, every country had entered the period of talent competition, therefore, we must begin to extend our FCSS_EFW_AD-7.6 personal skills, only by this can we become the pioneer among our competitors. We here tell you that there is no need to worry about. Our FCSS_EFW_AD-7.6 Actual Questions are updated in a high speed. Since the date you pay successfully, you will enjoy the FCSS_EFW_AD-7.6 test guide freely for one year, which can save your time and money. We will send you the latest FCSS_EFW_AD-7.6 study dumps through your email, so please check your email then.
Fortinet FCSS_EFW_AD-7.6 Exam Syllabus Topics:
  • Central Management: This section of the exam measures the skills of a Security Operations Manager and covers the implementation of centralized management systems for coordinated control and oversight of distributed Fortinet security infrastructures across enterprise environments.
  • System Configuration: This section of the exam measures the skills of a Network Security Architect and covers the implementation and integration of core Fortinet infrastructure components. It includes deploying the Security Fabric, enabling hardware acceleration, configuring high availability operational modes, and designing enterprise networks utilizing VLANs and VDOM technologies to meet specific organizational requirements.
  • Security Profiles: This section of the exam measures the skills of a Threat Prevention Specialist and covers the configuration and management of comprehensive security profiling systems. It includes implementing SSL
  • SSH inspection, combining web filtering and application control mechanisms, integrating intrusion prevention systems, and utilizing the Internet Service Database to create layered security protections for organizational networks.
  • Routing: This section of the exam measures the skills of a Network Infrastructure Engineer and covers the implementation of dynamic routing protocols for enterprise network traffic management. It includes configuring both OSPF and BGP routing protocols to ensure efficient and reliable data transmission across complex organizational networks.
Topic 5
  • VPN: This section of the exam measures the skills of a VPN Solutions Engineer and covers the implementation of various virtual private network technologies. It includes configuring IPsec VPN using IKE version 2 protocols and implementing Automatic Discovery VPN solutions to establish on-demand secure tunnels between multiple sites within an enterprise network infrastructure.
Fortinet FCSS_EFW_AD-7.6 Dumps PDF FormatThe FCSS_EFW_AD-7.6 test materials are mainly through three learning modes, Pdf, Online and software respectively. Among them, the software model is designed for computer users, can let users through the use of Windows interface to open the FCSS_EFW_AD-7.6 test prep of learning. It is convenient for the user to read. The FCSS_EFW_AD-7.6 test materials have a biggest advantage that is different from some online learning platform which has using terminal number limitation, the FCSS_EFW_AD-7.6 Quiz torrent can meet the client to log in to learn more, at the same time, the user can be conducted on multiple computers online learning, greatly reducing the time, and people can use the machine online of FCSS_EFW_AD-7.6 test prep more conveniently at the same time. As far as concerned, the online mode for mobile phone clients has the same function.
Fortinet FCSS - Enterprise Firewall 7.6 Administrator Sample Questions (Q20-Q25):NEW QUESTION # 20
Refer to the exhibit, which shows a network diagram showing the addition of site 2 with an overlapping network segment to the existing VPN IPsec connection between the hub and site 1.
Which IPsec phase 2 configuration must an administrator make on the FortiGate hub to enable equal-cost multi-path (ECMP) routing when multiple remote sites connect with overlapping subnets?
  • A. Set route-overlap to either use-new or use-old
  • B. Set single-source to enable
  • C. Set route-overlap to allow
  • D. Set net-device to ecmp
When multiple remote sites connect to the same hub using overlapping subnets, FortiGate needs to determine which route should be used for traffic forwarding. The route-overlap setting in IPsec Phase 2 allows FortiGate to handle this scenario by deciding whether to keep the existing route (use-old) or replace it with a new route (use-new).
In an ECMP (Equal-Cost Multi-Path) routing setup, both routes should be retained and balanced, but FortiGate does not support ECMP directly over overlapping routes in IPsec Phase 2. Instead, an administrator must decide which connection takes precedence using route-overlap settings.
NEW QUESTION # 21
An administrator applied a block-all IPS profile for client and server targets to secure the server, but the database team reported the application stopped working immediately after. How can an administrator apply IPS in a way that ensures it does not disrupt existing applications in the network?
  • A. Use an IPS profile with all signatures in monitor mode and verify patterns before blocking.
  • B. Select flow mode in the IPS profile to accurately analyze application patterns.
  • C. Set the IPS profile signature action to default to discard all possible false positives.
  • D. Limit the IPS profile to server targets only to avoid blocking connections from the server to clients.
Applying an aggressive IPS profile without prior testing can disrupt legitimate applications by incorrectly identifying normal traffic as malicious. To prevent disruptions while still monitoring for threats:
Enable IPS in "Monitor Mode" first:
This allows FortiGate to log and analyze potential threats without actively blocking traffic.
Administrators can review logs and fine-tune IPS signatures to minimize false positives before switching to blocking mode.
Verify and adjust signature patterns:
Some signatures might trigger unnecessary blocks for legitimate application traffic. By analyzing logs, administrators can disable or modify specific rules causing false positives.
NEW QUESTION # 22
How will configuring set tcp-mss-sender and set tcp-mss-receiver in a firewall policy affect the size and handling of TCP packets in the network?
  • A. The TCP packet modifies the packet size only if the size of the packet is less than the one the administrator configured in the firewall policy.
  • B. The administrator must consider the payload size of the packet and the size of the IP header to configure a correct value in the firewall policy.
  • C. Applying commands in a firewall policy determines the largest payload a device can handle in a single TCP segment.
  • D. The maximum segment size permitted in the firewall policy determines whether TCP packets are allowed or denied.
The set tcp-mss-sender and set tcp-mss-receiver commands in a firewall policy allow an administrator to adjust the Maximum Segment Size (MSS) of TCP packets.
This setting controls the largest payload size that a device can handle in a single TCP segment, ensuring that packets do not exceed the allowed MTU (Maximum Transmission Unit) along the network path.
# set tcp-mss-sender adjusts the MSS value for outgoing TCP traffic.
# set tcp-mss-receiver adjusts the MSS value for incoming TCP traffic.
This helps prevent issues with fragmentation and MTU mismatches, improving network performance and avoiding retransmissions.
NEW QUESTION # 23
An administrator configured the following command on FortiGate.
config router ospf
set restart-mode graceful-restart
Which two statements correctly describe the result of the above command? (Choose two.)
  • A. The OSPF neighbor that receives the grace link-state advertisement (LSA) will enter into helper mode.
  • B. In an HA cluster, FortiGate devices will keep the OSPF routes in their routing table to avoid traffic interruption during an HA failover.
  • C. FortiGate is configured with graceful restart, and will exit graceful mode, if the network topology changes.
  • D. After the default 40 seconds wait time, the OSPF neighbors will resume communication with the restarting router.
NEW QUESTION # 24
Refer to the exhibit, which shows the packet capture output of a three-way handshake between FortiGate and FortiManager Cloud.
What two conclusions can you draw from the exhibit? (Choose two.)
  • A. FortiGate is connecting to the same IP server and will receive an independent certificate for its connection between FortiGate and FortiManager Cloud.
  • B. If the TLS handshake contains 17 cipher suites it means the TLS version must be 1.0 on this three-way handshake.
  • C. FortiGate will receive a certificate that supports multiple domains because FortiManager operates in a cloud computing environment.
  • D. The wildcard for the domain *.fortinet-ca2.support.fortinet.com must be supported by FortiManager Cloud.
The packet capture output displays a TLS Client Hello message from FortiGate to FortiManager Cloud. This message contains Server Name Indication (SNI), which is used to indicate the domain name that FortiGate is trying to connect to.
FortiManager Cloud hosts multiple customers and domains under a shared infrastructure. The TLS handshake includes SNI (Server Name Indication), which allows FortiManager Cloud to serve multiple certificates based on the requested domain. This means FortiGate will likely receive a multi-domain or wildcard certificate that can be used for multiple customers under FortiManager Cloud.
The wildcard for the domain .fortinet-ca2.support.fortinet.com must be supported by FortiManager Cloud.
The SNI extension contains the domain 9398.support.fortinet-ca2.fortinet.com.
FortiManager Cloud must support wildcard certificates such as *.fortinet-ca2.support.fortinet.com to securely manage multiple subdomains and customers.
This ensures that FortiGate can validate the server certificate without any TLS errors.
NEW QUESTION # 25
As everybody knows, the most crucial matter is the quality of FCSS - Enterprise Firewall 7.6 Administrator study question for learners. We have been doing this professional thing for many years. Let the professionals handle professional issues. So as for us, we have enough confidence to provide you with the best FCSS_EFW_AD-7.6 Exam Questions for your study to pass it. Only with strict study, we write the latest and the specialized study materials. We can say that our FCSS_EFW_AD-7.6 exam questions are the most suitable for examinee to pass the exam.
Training FCSS_EFW_AD-7.6 For Exam: https://www.trainingquiz.com/FCSS_EFW_AD-7.6-practice-quiz.html
P.S. Free 2026 Fortinet FCSS_EFW_AD-7.6 dumps are available on Google Drive shared by TrainingQuiz: https://drive.google.com/open?id=14o747VNSHw_J_LrXjKaRx57vA9H-3VP2
