[General] Order-Management-Administrator Reliable Test Tips & Latest Order-Management-
128
【General】 Order-Management-Administrator Reliable Test Tips & Latest Order-Management-
Posted at 13 hour before      View:20 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that TrainingDump Order-Management-Administrator dumps now are free: https://drive.google.com/open?id=15dcBQ_ZoX5CYEg7Ry-Vc5CIweE4Lyl4a
With our customizable learning experience and self-assessment features of practice exam software for Order-Management-Administrator exam, you will be able to know your strengths and areas of improvement. We provide authentic braindumps for Order-Management-Administrator certification exam. In fact, we guarantee that you will pass the Order-Management-Administrator Certification Exam on your very first try. If we fail to deliver this promise, we will give your money back! Aside from providing you with the most reliable dumps for Order-Management-Administrator, we also offer our friendly customer support staff. They will be with you every step of the way.
Moreover, it is portable enabling you to prepare for the Salesforce Order-Management-Administrator exam from everywhere and at any time. You will find another convenience to make notes on Salesforce Order-Management-Administrator files combined with the facility to print them out. The Order-Management-Administrator Dumps PDF format can turn your preparation systematic and hassle-free. It will function smoothly on all smart devices.
Latest Order-Management-Administrator Test Question, Reliable Order-Management-Administrator Exam PatternIn order to cater to different kinds of needs of candidates, we offer three versions for Order-Management-Administrator training materials for you to select. Each version has its own advantage, and you can choose the most suitable one in accordance with your own needs. Order-Management-Administrator PDF version is printable, and you can print it into paper if you like. Order-Management-Administrator Soft test engine can stimulate the real exam environment, so that you can build up your confidence for the exam. Order-Management-Administrator Online test engine is convenient and easy to learn, and it supports offline proactive. You can also have a review of what you have learned through Order-Management-Administrator Online test engine.
Salesforce Order Management Administrator Accredited Professional Sample Questions (Q37-Q42):NEW QUESTION # 37
Which three objects need to be utilized when creating orders using the composite API?
  • A. Account
  • B. Pricebook Entry
  • C. Order Summary
  • D. Contact
  • E. Product
Answer: A,B,D
The PricebookEntry, Contact, and Account objects are required when creating orders using the composite API. The composite API is a REST API that allows creating multiple records in one request. To create an order using the composite API, an administrator needs to provide the following information:
The Account ID of the customer who placed the order
The Contact ID of the customer who placed the order
The Pricebook Entry IDs of the products that are ordered
The quantity and unit price of each product
The order status andcurrency References: [Create Orders Using Composite API], [Composite Resources]
NEW QUESTION # 38
A customer orders 10 products. The products must be shipped to three different locations. Two of the orders are fulfilled at the same location. How many Fulfillment Orders would be created for this order?
  • A. One Fulfillment Order pet destination, totaling 3
  • B. One Fulfillment Order per Fulfillment Location, totaling 2
  • C. One Fulfillment Order
  • D. One Fulfilment Order per item in the order, totaling 10
The number of Fulfillment Orders that would be created for this order is one per destination, totaling 3. A Fulfillment Order is a record that represents a group of products in an order that are fulfilled together from the same location. A Fulfillment Order has a lookup relationship to the Order Summary object, and it contains information such as the fulfillment location, delivery method, status, etc. The number of Fulfillment Orders created depends on three factors: Fulfillment Location, Delivery Method and Recipient Address. These factors determine how the Order Items are grouped and allocated to Fulfillment Orders based on routing rules and inventory availability. In this case, since the products must be shippedto three different locations, three Fulfillment Orders are created for each destination. Verified References:https://help.salesforce.com/s
/articleView?id=sf.order_management_fulfillment_order.htm&type=5
NEW QUESTION # 39
A company has an external system that stores client accounting data but they want to be able to search for this data within Salesforce. What three steps should the administrator take to implement this functionality?
  • A. Create an External Data Source pointing to the external system's database
  • B. Create an automated import of the external data using the Job Scheduler
  • C. Create an External Object for each fable of accounting data in the external system
  • D. Create an Indirect Lookup field to connect to the Account
  • E. Create an automated data capture (or the external system
Answer: A,C,D
Three steps that the administrator should take to implement this functionality are:
Create an External Data Source pointing to the external system's database. An External Data Source is a type of metadata that defines the connection and authentication information for an external system that stores data outside of Salesforce. The administrator can create an External Data Source using the Lightning Connect OData 2.0 or 4.0 adapters, which support read-only access to data in relational databases.
Create an External Object for each table of accounting data in the external system. An External Object is a type of custom object that maps to a table in an external system. The administrator can create an External Object for each table of accounting data that they want to access from Salesforce, and define its fields and relationships accordingly.
Create an Indirect Lookup field to connect to the Account. An Indirect Lookup field is a type of custom field that links a child External Object record to a parent standard or custom object record. The administrator can create an Indirect Lookup field on the External Object that references the Account object, and specify the external column name and value that match the Account ID.
Verified References: https://help.salesforce.com/s/ar ... view.htm&type=5
https://help.salesforce.com/s/ar ... hips.htm&type=5
NEW QUESTION # 40
What object does the Ensure Funds Apex Flow action look for when resolving Invoice balances associated with an Order Summary?
  • A. Order Payments
  • B. Payments
  • C. Order Payment Summaries
  • D. Payment Summaries
The object that the Ensure Funds Apex Flow action looks for when resolving Invoice balances associated with an Order Summary is Order Payment Summaries. Thisobject represents the payments made for an order, and it has a lookup relationship to both Invoice and Order Summary objects. The Ensure Funds Apex Flow action uses this object to calculate the balance due for each Invoice and update its status accordingly. Verified References: https://help.salesforce.com/s/ar ... er_payment_summary.
htm&type=5https://help.salesforce.com/s/articleView?id=sf.
flow_ref_elements_om_actions_ensure_funds_async.htm&type=5
NEW QUESTION # 41
An administrator is creating a flow to manage order fulfillment The administrator creates a fault path to handle a possible error. What object record should the administrator create in the fault path to notify users of an error?
  • A. Process Exception
  • B. Fulfillment Error
  • C. Order Summary Exception
  • D. OrderError
The object record that the administrator should create in the fault path to notify users of an error is Process Exception. A Process Exception is a record thatrepresents an error or exception that occurred during the order lifecycle, such as payment authorization failure, inventory allocation failure, fulfillment location assignment failure, etc. A Process Exception has a lookup relationship to the Order object,and it contains information such as the exception type, status, message, etc. Verified References:https://help.salesforce.com/s/articleView?
id=sf.order_management_process_exception.htm&type=5
NEW QUESTION # 42
The name of these formats are Salesforce Order-Management-Administrator PDF dumps file, desktop practice test software, and web-based practice test software. All these three Salesforce Cloud Order-Management-Administrator practice test formats are easy to use and perfectly work with all devices, operating systems, and web browsers. The Order-Management-Administrator Pdf Dumps file is a simple collection of Real and Updated Salesforce Order Management Administrator Accredited Professional (Order-Management-Administrator) exam questions in PDF format and it is easy to install and use.
Latest Order-Management-Administrator Test Question: https://www.trainingdump.com/Salesforce/Order-Management-Administrator-practice-exam-dumps.html
Our web-based practice exam creates a similar situation to the Order-Management-Administrator real exam questions, making it easier for you to pass, Salesforce Order-Management-Administrator Reliable Test Tips So, they are both efficient in practicing and downloading process, Salesforce Order-Management-Administrator Reliable Test Tips It is very good to experience the simulate environment in advance, Salesforce Order-Management-Administrator Reliable Test Tips The description is vivid and full of interesting.
therefore, answers C and D are incorrect, The Event Heard Againand Againand Again, Our web-based practice exam creates a similar situation to the Order-Management-Administrator Real Exam Questions, making it easier for you to pass.
Free PDF First-grade Salesforce Order-Management-Administrator - Salesforce Order Management Administrator Accredited Professional Reliable Test TipsSo, they are both efficient in practicing and downloading process, Order-Management-Administrator It is very good to experience the simulate environment in advance, The description is vivid and full of interesting.
The Order-Management-Administrator exam materials provided by TrainingDump are collected and sorted out by experienced team.
BONUS!!! Download part of TrainingDump Order-Management-Administrator dumps for free: https://drive.google.com/open?id=15dcBQ_ZoX5CYEg7Ry-Vc5CIweE4Lyl4a
