1z0-1104-25 Test Torrent | 1z0-1104-25 Valid Test Vce
Posted at 11 hour before
What's more, part of that TestkingPDF 1z0-1104-25 dumps now are free: https://drive.google.com/open?id=162F6ajpIvZP4DY6ZcgZGmCQgc0mvcINU
Why do we need so many certifications? One thing has to admit, more and more certifications you own, it may bring you more opportunities to obtain a better job, earn more salary. This is the reason why we need to recognize the importance of getting the test 1z0-1104-25 certification. Therefore, our 1z0-1104-25 Study Tool can help users pass the qualifying examinations that they are required to participate in faster and more efficiently as our 1z0-1104-25 exam questions have a pass rate of more than 98%. Just buy our 1z0-1104-25 practice guide, then you will pass your 1z0-1104-25 exam.
Oracle 1z0-1104-25 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Protecting Infrastructure - Network and Applications: This section of the exam measures the skills of Cloud Security Professionals and covers methods for securing networks and applications on OCI. Topics include network security groups, firewalls, and security lists, while also focusing on the use of load balancers for availability. The section further addresses the configuration of OCI certificates and web application firewalls to strengthen infrastructure security.
| | Topic 2 | - Implementing OS and Workload Protection: This section of the exam measures the skills of OCI Administrators and looks at securing workloads and operating systems. It includes the use of OCI Bastion for time-limited access, vulnerability scanning of hosts and containers, and the use of OS management for automated updates. The goal is to ensure that workloads remain resilient and well-protected.
| | Topic 3 | - Implementing Identity and Access Management (IAM): This section of the exam measures skills of OCI Administrators and focuses on identity and access controls. It covers IAM domains, users, groups, and compartments, as well as the use of IAM policies to manage access to resources. Candidates are also tested on configuring dynamic groups, network sources, and tag-based access control, along with managing MFA, sign-on policies, and activity monitoring.
1z0-1104-25 Valid Test Vce & 1z0-1104-25 Practical InformationTo make sure get the certification easily, our test engine simulates the atmosphere of the 1z0-1104-25 real exam and quickly grasp the knowledge points of the exam. Our 1z0-1104-25 vce dumps contain the latest exam pattern and learning materials, which will help you clear exam 100%. Please feel free to contact us if you have any problems about the pass rate or quality of 1z0-1104-25 Practice Test or updates.
Oracle Cloud Infrastructure 2025 Security Professional Sample Questions (Q36-Q41):NEW QUESTION # 36
You are a security architect at your organization and have noticed an increase in cyberattacks on your applications, including Cross-Site Scripting (XSS) and SQL Injection. To mitigate these threats, you decide to use OCI Web Application Firewall (WAF).
Which type of OCI WAF rule should you configure to protect against these attacks?
- A. Encryption rule
- B. Protection rule
- C. Access control rule
- D. Rate Limiting rule
NEW QUESTION # 37
Task 4: Create a Certificate Authority (CA)
Create a certificate authority, where:
CA name: PBT-CERT-CA-01-<username>
For example, if your username is 99008677-lab.user01, then the certificate authority name should be PBT- CERT-CA-01990086771abuser01 Ensure you eliminate special characters from the user name.
Common name: PBT-CERT-OCICA-01
Master Encryption Key: PBT-CERT-MEK-01 (created in the previous task)
See the solution below in Explanation.
Step 1: Access the OCI Vault
* Log in to the OCI Console.
* Navigate toIdentity & Security>Vault.
* Select the root compartment.
* Locate and click on the vault named PBI_Vault_SP.
Step 2: Create the Certificate Authority
* In the PBI_Vault_SP vault details page, underResources, clickCertificate Authorities.
* ClickCreate Certificate Authority.
* Enter the following details:
* Name: Replace <username> with your username (e.g., if your username is 99008677-lab.user01, remove special characters like - and . to get 99008677labuser01, then use PBT-CERT-CA-
0199008677labuser01).
* Common Name: Enter PBT-CERT-OCICA-01.
* Master Encryption Key: Select the PBT-CERT-MEK-01<username> key created in Task 3 (e.
g., PBT-CERT-MEK-0199008677labuser01).
* Subject: Leave as default or adjust (e.g., Organization, Country) if required by your setup.
* Validity Period: Set as needed (e.g., 10 years), or use the default.
* Compartment: Ensure it's set to the root compartment.
* ClickCreate Certificate Authorityand wait for the CA to be provisioned.
Step 3: Verify the Certificate Authority
* After creation, go to theCertificate Authoritiessection under PBI_Vault_SP.
* Confirm the CA PBT-CERT-CA-01<username> (e.g., PBT-CERT-CA-0199008677labuser01) is listed and its status is active.
NEW QUESTION # 38
"A company, ABC, is planning to launch a new web application on OCI. Based on past experiences, they expect a significant surge in traffic after the launch. You are responsible for ensuring that the application is highly available.
Which step would you perform to achieve this goal?
- A. Configure Cloud Guard to prevent large amounts of traffic from reaching the web application.
- B. Use a Virtual Cloud Network (VCN) with subnets, security lists, and routing rules to isolate the web application from the Internet and other resources.
- C. Use a load balancer to distribute incoming traffic evenly across multiple instances of the web application."
- D. Implement security controls, such as web application firewalls, to protect against common attack vectors.
NEW QUESTION # 39
Within OCI IAM identity domains, the AD Bridge component serves a critical role. How does the AD Bridge functionality specifically enhance Identity and Access Management (IAM) practices?
- A. It directly integrates with OCI MFA providers, allowing for seamless enforcement of MFA for users authenticated through AD credentials.
- B. It strengthens access security by providing an additional layer of authentication through AD integration.
- C. It simplifies user provisioning by enabling automated synchronization of user accounts and group memberships from an existing Microsoft Active Directory (AD) environment.
- D. It facilitates delegated administration, allowing authorized AD users to manage specific resources within the OCI identity domain.
NEW QUESTION # 40
You're managing an Oracle Cloud Infrastructure (OCI) environment where a public website hosts downloadable assets stored in Object Storage buckets. These buckets need to be publicly accessible for website visitors, but Cloud Guard keeps flagging them as security risks.
How can Cloud Guard be configured to ignore problems specific to public buckets while still ensuring security checks are applied to other resources that require them?
- A. A public bucket is a security risk, so Cloud Guard will keep detecting it.
- B. Fix the baseline by configuring the Conditional groups for the detector.
- C. Resolve or remediate the problems by making the buckets private.
- D. Dismiss problems associated with those resources.
NEW QUESTION # 41
As a professional multinational company, we fully take into account the needs of each user when developing products. For example, in order to make every customer can purchase at ease, our 1z0-1104-25 study materials will provide users with three different versions for free trial, corresponding to the three official versions. You can feel the characteristics of our 1z0-1104-25 Study Materials and whether they are suitable for you from the trial. After your payment, we'll send you a connection of our 1z0-1104-25 study materials in 5 to 10 minutes and you can download immediately without wasting your valuable time.
1z0-1104-25 Valid Test Vce: https://www.testkingpdf.com/1z0-1104-25-testking-pdf-torrent.html
- 1z0-1104-25 Reliable Exam Syllabus 👘 1z0-1104-25 Pdf Torrent 🚎 1z0-1104-25 Online Test 📽 Open ▶ [url]www.prepawaypdf.com ◀ and search for 「 1z0-1104-25 」 to download exam materials for free ⚛1z0-1104-25 Online Test[/url]
- 1z0-1104-25 Testking Learning Materials 🍃 Valid 1z0-1104-25 Exam Answers 🙆 1z0-1104-25 Valid Test Voucher 🥄 Search for ▷ 1z0-1104-25 ◁ and obtain a free download on ▶ [url]www.pdfvce.com ◀ 😣1z0-1104-25 Latest Examprep[/url]
- Dump 1z0-1104-25 File 🥀 Valid 1z0-1104-25 Exam Answers 👄 1z0-1104-25 Free Study Material 💾 Immediately open [ [url]www.vce4dumps.com ] and search for ▛ 1z0-1104-25 ▟ to obtain a free download 🏂1z0-1104-25 Online Test[/url]
- Latest 1z0-1104-25 Training 🦽 1z0-1104-25 Free Study Material 👈 Valid 1z0-1104-25 Exam Guide 🥇 Copy URL ( [url]www.pdfvce.com ) open and search for ➥ 1z0-1104-25 🡄 to download for free 🏘1z0-1104-25 Vce Exam[/url]
- 1z0-1104-25 Latest Cram Materials 😺 1z0-1104-25 Latest Examprep 🕎 Valid 1z0-1104-25 Exam Answers 🏐 Search for ⇛ 1z0-1104-25 ⇚ and download it for free on ⇛ [url]www.practicevce.com ⇚ website 🥴1z0-1104-25 Pass Guaranteed[/url]
- High-quality 1z0-1104-25 Test Torrent - Find Shortcut to Pass 1z0-1104-25 Exam 🤧 Simply search for ⏩ 1z0-1104-25 ⏪ for free download on { [url]www.pdfvce.com } 🎵Valid 1z0-1104-25 Exam Answers[/url]
- 1z0-1104-25 Pass Guaranteed 🏬 1z0-1104-25 Pass Guaranteed 🔂 Valid 1z0-1104-25 Exam Answers 👘 Search for ▛ 1z0-1104-25 ▟ and download it for free immediately on “ [url]www.torrentvce.com ” 🐜1z0-1104-25 Latest Cram Materials[/url]
- 1z0-1104-25 Vce Exam 🐦 1z0-1104-25 Online Test 🧝 1z0-1104-25 Pass Guaranteed 💏 Copy URL ➡ [url]www.pdfvce.com ️⬅️ open and search for 《 1z0-1104-25 》 to download for free 🏮Exam 1z0-1104-25 Lab Questions[/url]
- 1z0-1104-25 Reliable Dumps Ppt 🚨 1z0-1104-25 Valid Exam Book 🚀 1z0-1104-25 Testking Learning Materials 📸 The page for free download of [ 1z0-1104-25 ] on 《 [url]www.pass4test.com 》 will open immediately 🦗1z0-1104-25 Free Study Material[/url]
- [url=https://kardinalexclusive.com/?s=Pass%20Guaranteed%20Quiz%202026%20Oracle%201z0-1104-25:%20Trustable%20Oracle%20Cloud%20Infrastructure%202025%20Security%20Professional%20Test%20Torrent%20%f0%9f%98%b1%20Easily%20obtain%20%e3%80%8c%201z0-1104-25%20%e3%80%8d%20for%20free%20download%20through%20[%20www.pdfvce.com%20]%20%f0%9f%9a%bb1z0-1104-25%20Valid%20Test%20Voucher]Pass Guaranteed Quiz 2026 Oracle 1z0-1104-25: Trustable Oracle Cloud Infrastructure 2025 Security Professional Test Torrent 😱 Easily obtain 「 1z0-1104-25 」 for free download through [ www.pdfvce.com ] 🚻1z0-1104-25 Valid Test Voucher[/url]
- Realistic 1z0-1104-25 Test Torrent Provide Prefect Assistance in 1z0-1104-25 Preparation 🥫 Immediately open ▷ [url]www.practicevce.com ◁ and search for ⇛ 1z0-1104-25 ⇚ to obtain a free download 🐓Latest 1z0-1104-25 Training[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, generativetechinsights.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, interncertify.com, Disposable vapes
BTW, DOWNLOAD part of TestkingPDF 1z0-1104-25 dumps from Cloud Storage: https://drive.google.com/open?id=162F6ajpIvZP4DY6ZcgZGmCQgc0mvcINU
