[General] Salesforce Plat-Admn-202 Exam Sims & Plat-Admn-202 Simulation Questions
128
【General】 Salesforce Plat-Admn-202 Exam Sims & Plat-Admn-202 Simulation Questions
Posted at 12 hour before      View:17 | Replies:0        Print      Only Author   [Copy Link] 1#
By selecting our Plat-Admn-202 study materials, you do not need to purchase any other products. Our passing rate may be the most attractive factor for you. Our Plat-Admn-202 learning guide have a 99% pass rate. This shows what? As long as you use our products, you can pass the exam! Do you want to be one of 99? Quickly purchase our Plat-Admn-202 Exam Questions! And you will find that the coming exam is just a piece of cake in front of you.
The Plat-Admn-202 exam study guide includes the latest Plat-Admn-202 PDF test questions and practice test software which can help you to pass the Plat-Admn-202 test smoothly. The test questions cover the practical questions in the test Plat-Admn-202 certification and these possible questions help you explore varied types of questions which may appear in the Plat-Admn-202 test and the approaches you should adapt to answer the questions. Every Plat-Admn-202 exam question is covered in our Plat-Admn-202 learning braindump. You will get the Plat-Admn-202 certification for sure with our Plat-Admn-202 training guide.
New Plat-Admn-202 Exam Sims 100% Pass | High-quality Plat-Admn-202 Simulation Questions: Salesforce Certified Platform App BuilderThe actual Salesforce Plat-Admn-202 exam questions are in PDF format for the one who wants to study offline. The actual Salesforce Plat-Admn-202 exam questions are in simple PDF form. The PDF format is suitable both for smartphones as well as tablets. You can print documents and study anywhere. The plus point is that the PDF version is updated regularly to improve its Plat-Admn-202 Exam Questions and reflect changes in the syllabus of the exam.
Salesforce Certified Platform App Builder Sample Questions (Q149-Q154):NEW QUESTION # 149
Cloud Kicks is implementing an approval process for opportunities that requires managers to approve all opportunities above $50,000 before they can be marked as Closed Won.
Which two delivery methods can a manager utilize to respond to approval requests in the Salesforce mobile app?
Choose 2 answers
  • A. Navigation Menu
  • B. In-App Notification
  • C. Home Screen
  • D. Record Detail
For managers to respond to approval requests for opportunities above $50,000 in the Salesforce mobile app:
B . In-App Notification: Managers receive notifications within the Salesforce mobile app when there is an approval request, allowing them to approve or reject directly from the notification.
C . Record Detail: Managers can access the approval request directly from the Opportunity's detail page in the mobile app, where they can review and respond to the request.
Steps to configure approval process notifications:
Navigate to Setup → Approval Processes → select the relevant approval process.
Ensure the process is active and configured to send notifications to approvers.
Managers need to have the Salesforce mobile app configured to receive notifications.
For best practices on managing approvals in Salesforce, see Approvals in Salesforce.
NEW QUESTION # 150
The Service Manager provided the app builder with color code requirements for case age on open cases.
New cases populate a green circle
Day-old cases populate a yellow circle
Three-day-old cases populate a red circle
How should an app builder implement this requirement?
  • A. Quick Action
  • B. Formula Field
  • C. Custom Button
  • D. Lightning Web Component
A formula field is a read-only field that derives its value from a formula expression you define. The formula field is updated when any of the source fields change. You can use formula fields to display images based on certain conditions. In this case, a formula field can be used to display a green, yellow, or red circle image based on the case age.
NEW QUESTION # 151
Ursa Major Solar's service department gets requests for several types of services, such as installation, repair, and maintenance. Service managers need to be able to tell when maintenance was last done on on asset to help determine If they are meeting contract agreements, but the last maintenance date can be difficult to determine when there are many work orders related to the asset. They think it would be helpful to have a field auto-populated on the Asset record when a maintenance work order gets closed.
What tool should an app builder recommend to help meet this requirement?
  • A. Flow
  • B. Apex Trigger
  • C. Roll-up Summary
  • D. Visualforce
A flow is an application that automates a business process by collecting data and performing operations in your org or an external system. Flows can also manipulate data in your org by creating, updating, deleting, or submitting records for approval. You can use flows to update fields on related records when a certain event occurs, such as closing a work order. In this case, a flow can be used to update the last maintenance date field on the Asset record when a maintenance work order gets closed.
NEW QUESTION # 152
Manage at Universal Containers want a quick to create additional accounts to form a hierarchy from a parent account record. They want to auto-populate five fields based on the parent to make it easier for users to create the child accounts quickly.
  • A. Custom Global Quick Action
  • B. Custom action on Account
  • C. Custom Global Quick Account.
  • D. Custom link on Account
A custom action on Account can be used to create additional accounts from a parent account record. A custom action can have predefined values for certain fields based on the parent record. A custom global action can be used to create records that do not have any relationship with other objects. A custom link on Account can be used to execute JavaScript or link to an external URL.
NEW QUESTION # 153
Which opportunity standard field is available to be configured directly? Choose3
  • A. Stage
  • B. Type
  • C. Forecast category
  • D. Lead source
Answer: A,B,D
The opportunity standard fields that are available to be configured directly are Stage, Lead Source, and Type. These fields can be modified by editing their picklist values, adding or removing values, or changing their default values. Option A is incorrect because Forecast Category is not a standard field on the opportunity object, but rather a system field that is automatically derived from the Stage field.
NEW QUESTION # 154
Windows, Mac, iOS, Android, and Linux support this Plat-Admn-202 practice exam. The desktop Salesforce Certified Platform App Builder (Plat-Admn-202) practice test software is similar to the web-based Plat-Admn-202 format as far as its features are concerned. But it works offline only on the Windows operating system. The offline Plat-Admn-202 Practice Exam can be taken easily just by just installing the software on your Windows laptop or computer. All three Salesforce Certified Platform App Builder (Plat-Admn-202) formats of PassTestking are according to the latest content of the Salesforce Plat-Admn-202 examination.
Plat-Admn-202 Simulation Questions: https://www.passtestking.com/Salesforce/Plat-Admn-202-practice-exam-dumps.html
Salesforce Plat-Admn-202 Exam Sims Each version is aimed at satisfying different customers' demand, Salesforce Plat-Admn-202 Exam Sims Can I purchase PDF files, The most notable feature of the Plat-Admn-202 learning quiz is that they provide you with the most practical solutions to help you learn the exam points of effortlessly and easily, then mastering the core information of the certification course outline, This desktop practice exam software completely depicts the Salesforce Plat-Admn-202 exam scenario with proper rules and regulations so you can practice all the hurdles and difficulties.
Using Models to Improve Processes, The goal of these new specialty introduction Plat-Admn-202 certifications was to provide candidates with the skills necessary to identify and implement the technologies in each specialty.
Pass Guaranteed High-quality Salesforce - Plat-Admn-202 - Salesforce Certified Platform App Builder Exam SimsEach version is aimed at satisfying different customers' demand, Can I purchase PDF files, The most notable feature of the Plat-Admn-202 learning quiz is that they provide you with the most practical solutions to help you learn the Exam Plat-Admn-202 Dumps exam points of effortlessly and easily, then mastering the core information of the certification course outline.
During the process, they were absorbed in the concrete contents and assimilate useful information with the help of our Plat-Admn-202 practice test questions to deal with the exam certainly, and they are filled with admiration during the preparation process for the high quality of our Plat-Admn-202 study guide.
