[General] NCP-EUC Latest Exam Guide & Valid NCP-EUC Learning Materials
135
【General】 NCP-EUC Latest Exam Guide & Valid NCP-EUC Learning Materials
Posted at 8 hour before      View:16 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Nutanix NCP-EUC dumps are available on Google Drive shared by Lead2PassExam: https://drive.google.com/open?id=1IIhFIyA60-EhuYt_jx50GiDZAMv1vwZz
Several advantages we now offer for your reference. On the one hand, our NCP-EUC learning questions engage our working staff in understanding customers’ diverse and evolving expectations and incorporate that understanding into our strategies, thus you can 100% trust our NCP-EUC Exam Engine. On the other hand, the professional NCP-EUC study materials determine the high pass rate. According to the research statistics, we can confidently tell that 99% candidates have passed the NCP-EUC exam.
The NCP-EUC certification exam is an ideal choice for IT professionals who want to validate their skills and knowledge in end-user computing. Nutanix Certified Professional - End User Computing (NCP-EUC) 6.10 Exam certification exam is designed to help IT professionals demonstrate their expertise in Nutanix's end-user computing technology solutions. NCP-EUC exam covers a wide range of topics, including Nutanix VDI, application delivery, and management, as well as the deployment and troubleshooting of these technologies.
To prepare for the Nutanix NCP-EUC exam, candidates are recommended to have a solid understanding of virtualization, networking and storage concepts, as well as experience with Nutanix technology. Nutanix offers a range of training courses and resources to help candidates prepare for the exam, including instructor-led training, e-learning courses, and hands-on labs. Candidates can also take advantage of study guides and practice exams to help them prepare for the exam. By passing the Nutanix NCP-EUC Exam, IT professionals can demonstrate their expertise in end-user computing and enhance their career prospects in this field.
NCP-EUC Pass-King Torrent - NCP-EUC Actual Exam & NCP-EUC Exam TorrentWe have harmonious cooperation with exam candidates. The relation comes from the excellence of our NCP-EUC training materials. We never avoid our responsibility of offering help for exam candidates like you, so choosing our NCP-EUC practice dumps means you choose success. Moreover, without the needs of waiting, you can download the NCP-EUC Study Guide after paying for it immediately. And we have patient and enthusiastic staff offering help on our NCP-EUC learning prep.
Nutanix Certified Professional - End User Computing (NCP-EUC) 6.10 Exam Sample Questions (Q46-Q51):NEW QUESTION # 46
An administrator is investigating a complaint about poor performance and slow response times for a virtual desktop environment.
The administrator has obtained the following statistics from the environment:
* vCPU to pCPU ratio is 4:1
* VM Guest OS is Windows 10
* VMs are configured with 4 vCPUs each
* VM Guests are configured with 16GB of RAM
* The SSD cache tier is 85% full, and the capacity tier is 45% full
* Host CPU utilization is < 40%
What is the most likely cause of the poor performance?
  • A. vCPU to pCPU ratio is too high.
  • B. Capacity tier is over-provisioned.
  • C. SSD Cache tier is over-committed.
  • D. VM RAM is over-provisioned.
The performance statistics indicate that the SSD Cache tier is 85% full, which is the primary bottleneck. In a Nutanix cluster, the SSD tier serves as the high-performance "Hot Tier" (Extent Store and Oplog) for active data. When the SSD tier utilization exceeds recommended thresholds (typically above 75-80%), the system must aggressively destage data to the slower HDD Capacity tier to free up space for incoming writes.
This destaging process and the lack of available SSD space for the active working set (WS) force read and write operations to be served from the slower Capacity tier (HDD), resulting in significantly higher latency and "sluggish" desktop performance. The vCPU ratio (4:1) and Host CPU (< 40%) are well within healthy limits, ruling out CPU contention.
NEW QUESTION # 47
An administrator is in charge of an EUC environment consisting of a Nutanix cluster and an Omnissa Horizon desktop environment. During routine LCM maintenance on the Nutanix cluster, the administrator notices that the desktop pool provisioning is in an error state and new instance clones are not being created.
What are two causes of this issue? (Choose two.)
  • A. The cluster is experiencing high CPU/memory load, causing provisioning issues.
  • B. Pool provisioning was not disabled prior to maintenance starting.
  • C. LCM didn't inventory the environment successfully before starting maintenance.
  • D. The host having maintenance performed contains the replica VMs.
When performing maintenance (such as Life Cycle Manager updates) on a Nutanix cluster hosting Omnissa (VMware) Horizon Instant Clones, specific operational steps are required to avoid provisioning failures.
* Pool provisioning was not disabled (Option D): It is a mandatory best practice to disable provisioning in the Horizon Connection Server before starting cluster maintenance. If provisioning remains active, the broker attempts to create VMs on hosts that may be rebooting or entering maintenance mode, leading to error states.
* The host having maintenance performed contains the replica VMs (Option C): Instant Clones rely on a "Replica" VM (a powered-on parent VM) typically residing on one of the hosts. If the host holding this Replica VM enters maintenance mode without the broker's awareness or without proper evacuation handling, the "Link" required to generate new clones is broken, causing provisioning tasks to fail immediately.
NEW QUESTION # 48
An administrator wants to utilize bidirectional replication to ensure that the user profile is present in both sites. This will allow the user to move between physical sites and access data locally.
What feature should the administrator configure to provide this functionality?
  • A. Files DR
  • B. Data Consolidation
  • C. VDI Sync
  • D. Smart DR
To achieve the requirement of bidirectional replication where a user can access their profile data locally at either site (Active-Active profile availability), the administrator should configure VDI Sync.
VDI Sync is a specialized configuration within the Nutanix Files ecosystem designed to synchronize User Profile directories across distributed file server instances. Unlike standard one-way Disaster Recovery (Smart DR) which is designed for failover, VDI Sync ensures that changes made to a profile at Site A are replicated to Site B, and vice-versa, allowing users to roam between physical locations while maintaining a consistent, local copy of their profile data.
NEW QUESTION # 49
A Windows IO VM fails to power on With an NVIDIA vCPU profile in ESXi 7. The VM is configured with NVIDIA profile by selecting Shared PCl Device, adding the NVIDIA GRID vCPU device. and selecting the Profile under VM settings.
The following error message is displayed in the vSphere web client:
What should be done to resolve this issue?
  • A. Switch the GPU mode to compute mode using gpumodeswitch command.
  • B. change the Graphics mode of the host from Shared Direct to Shared.
  • C. Change the Graphics mode of the host from Shared to Shared Direct
  • D. Change the Graphics mode of the host from Shared to Shared Direct
  • E. Switch the GPU mode to graphics mode using gpumodeswitch command.
Answer: E
gpumodeswitch is a command-line tool that is used to switch supported NVIDIA GPUs between compute and graphics mode. Compute mode allows multiple VMs to share a GPU for CUDA workloads. Graphics mode allows a single VM to use a GPU for graphics workloads12.
NEW QUESTION # 50
A new large multisite environment is being designed with a requirement to focus on workload availability and failover while reducing the brokering infrastructure footprint and management. Infrastructure components that are deployed must follow vendor recommendations for high availability and redundancy.
Which Citrix control plane should be used and where should they be deployed in this scenario?
  • A. Citrix DaaS with highly available cloud connectors on AHV infrastructure clusters in each resource location
  • B. Citrix VAD with highly available delivery controllers on AHV workload clusters in each site
  • C. Citrix VAD with highly available delivery controllers on AHV infrastructure clusters in each site
  • D. Citrix DaaS with highly available cloud connectors on AHV workload clusters in each resource location
Comprehensive and Detailed Explanation From Exact Extract of Nutanix End User Computing documents:
According to Nutanix Validated Designs (NVD) for Citrix DaaS:
* Control Plane: The requirement to "reduce brokering infrastructure footprint" dictates the use of Citrix DaaS (formerly Citrix Cloud), which offloads the Delivery Controllers and SQL databases to the Citrix cloud service, leaving only the lightweight Cloud Connectors on-premises.
* Placement: In a large multisite architecture using the standard "Block and Pod" design, Nutanix recommends separating Management/Infrastructure functions from Workload functions.
* Best Practice: Cloud Connectors are critical infrastructure components. They should be deployed on the AHV Infrastructure Clusters (Management Clusters) in each resource location, rather than the Workload clusters, to ensure they are protected from resource contention caused by user desktops and to maintain a clean separation of duties.
NEW QUESTION # 51
Our Lead2PassExam NCP-EUC exam materials provide all candidates with available free Demo. Before you decide to purchase NCP-EUC exam materials, we suggest that you should download our Demo. You can check for free demos to see if our exam questions contain what you need for the NCP-EUC exam, and you can view other exam applicants' experiences by using our exam materials. Tested and verified - Our NCP-EUC Exam Materials were trusted by thousands of candidates. You can visit our recommendation section and read the first-hand experience of verified users. Our NCP-EUC exam materials will help you figure out what the actual product will provide you, and whether these features will help future users learn within a week and pass the exam successfully.
Valid NCP-EUC Learning Materials: https://www.lead2passexam.com/Nutanix/valid-NCP-EUC-exam-dumps.html
P.S. Free & New NCP-EUC dumps are available on Google Drive shared by Lead2PassExam: https://drive.google.com/open?id=1IIhFIyA60-EhuYt_jx50GiDZAMv1vwZz
