[Hardware] MB-280 Latest Dumps Pdf | Reliable MB-280 Test Cram
【Hardware】 MB-280 Latest Dumps Pdf | Reliable MB-280 Test Cram
Posted at 8 hour before      View:20 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that PracticeMaterial MB-280 dumps now are free: https://drive.google.com/open?id=1JQTE8YPIck3NRJ_jvD2sbDZ500JXwphc
As the captioned description said, our MB-280 practice materials are filled with the newest points of knowledge about the exam. With many years of experience in this line, we not only compile real test content into our MB-280 learning quiz, but the newest in to them. And our professionals always keep a close eye on the new changes of the subject and keep updating the MB-280 study questions to the most accurate.
Microsoft MB-280 Exam Syllabus Topics:
  • Implement Dynamics 365 Sales: This section focuses on the essential processes for setting up and managing Dynamics 365 Sales effectively for Dynamics 365 Sales Professionals.
  • Implement the Dynamics 365 App for Outlook: This section emphasizes the integration of Dynamics 365 with Outlook to enhance productivity and streamline sales processes for Dynamics 365 Sales Professionals.
  • Demonstrate Dynamics 365 Customer Insights Capabilities: This section focuses on leveraging customer data to drive sales strategies through Dynamics 365 Customer Insights.
  • Extend and Enhance Dynamics 365 Sales Capabilities: For Dynamics 365 Sales Professionals, this section evaluates the ability to extend Dynamics 365 Sales functionality and integrate it with other applications using Power Platform tools.
Reliable MB-280 Test Cram & Authorized MB-280 PdfHave you ever noticed that people who prepare themselves for Microsoft MB-280 certification exam do not need to negotiate their salaries for a higher level, they just get it after they are Microsoft MB-280 Certified? The reason behind this fact is that they are considered the most deserving candidates for that particular job.
Microsoft Dynamics 365 Customer Experience Analyst Sample Questions (Q10-Q15):NEW QUESTION # 10
You are reviewing a Dynamics 365 implementation for your customer.
During the review, the customer tells you that they want a central search function which displays results by relevance.
You need to prepare to configure Dataverse search for the implementation.
Solution: Ensure that any tables you wish to display results from are included in the model-driven apps.
Does this meet the goal?
  • A. Yes
  • B. No
Correct:
* Recognize that when you enable Dataverse search, it is enabled for all model-driven apps.
Turning on Dataverse search allows global search in all model-driven apps in that environment and allows generative AI experiences to work.
Incorrect:
* Ensure that any tables you wish to display results from are included in the model-driven apps.
* Ensure that you add columns to the search criteria by editing the Advanced Find view for each table.
https://learn.microsoft.com/en-u ... search-organization
NEW QUESTION # 11
You use business process flows for all Dynamics 365 opportunities.
Some opportunities are closed before business process flow durations are calculated.
You need to ensure that business process flow duration values are calculated.
Solution: Create a flow to update the Status Reason of the business process flow table record to
"Finished" and the Status to "Inactive" when the opportunity is won.
  • A. No
  • B. Yes
Creating a flow to update the Status Reason of the business process flow record to "Finished" and the Status to "Inactive" when the opportunity is won will effectively meet the goal of ensuring that business process flow duration values are calculated.
By marking the business process flow as "Finished," you indicate that the flow has completed its execution, allowing the system to finalize any calculations related to duration before transitioning to an inactive state. This approach ensures that the necessary data is captured and calculated properly, allowing you to accurately report on the durations associated with the business process flow.
NEW QUESTION # 12
Hotspot Question
You are a Dynamics 365 Sales administrator. You create a forecast by using the forecast category layout shown in the exhibit:
Use the drop-down menus to select the answer choice that answers each question based on the information presented in the graphic.
Where should you rename the Omitted column to Cancelled for this forecast? - Layout column settings Renaming or customizing columns in the forecast layout would be done through the layout column settings where you control what each column is labeled.
Where should you delete the Lost column for this forecast? - Forecast configuration To remove a column like "Lost" from the forecast, you need to adjust the forecast configuration settings. This is where structural changes such as adding or removing columns are managed.
NEW QUESTION # 13
A company uses Dynamics 365 Sales with assignment rules. The assignment rules use a segment to filter the lead records.
A sales manager wants to automatically add a series of tasks by using the same criteria as the assignment rules.
You need to create the tasks and assign the tasks to the lead records.
In which order should you perform the actions? To answer, move all actions from the list of actions to the answer area and arrange them in the correct order.
Add Tasks to the Sequence:
After creating the sequence, add the specific tasks that need to be automatically generated and assigned to the leads. These tasks can be calls, follow-ups, emails, etc., that need to be completed as part of the sales process.
Connect the Existing Segment to the Sequence:
Once the tasks are added, connect the sequence to the existing segment that filters the lead records based on assignment rules. This ensures that only leads within this specific segment are targeted by the sequence.
The segment is a subset of leads that meet certain criteria, and connecting it to the sequence allows for automated task assignment according to the segment's filtering rules.
Activate the Sequence:
Finally, activate the sequence to begin the automated assignment of tasks to lead records that meet the segment criteri a. Activation makes the sequence live, enabling the automated process to assign tasks to each lead as per the sequence setup.
By following these steps, the sales manager can ensure that tasks are automatically generated and assigned to leads according to the same criteria used by the assignment rules, streamlining task management for the sales team.
NEW QUESTION # 14
You have opportunities that have values in multiple currencies. You manually update currency exchange rates once per month. You need to ensure that currency values are accurately reported. When is the new currency exchange rate applied to the opportunity records?
  • A. When an opportunity changes the status.
  • B. When the calculate rollup field system job for the msdyn_projectteam table runs.
  • C. When the calculate rollup field system job for the account table runs.
  • D. When an opportunity changes the status reason.
* In Dynamics 365 Sales, currency exchange rates are applied to opportunity records when specific triggers occur. These exchange rates are updated manually on a periodic basis (e.g., once a month) to reflect current currency values.
* Exchange rates are recalculated for an opportunity when there is a change in the status reason (e.g., from open to won or lost). This trigger ensures that the most recent exchange rate is used when key changes occur in the opportunity lifecycle, maintaining accurate currency reporting.
NEW QUESTION # 15
Our MB-280 training braindump is elaborately composed with major questions and answers. We are choosing the key from past materials to finish our MB-280 guide question. It only takes you 20 hours to 30 hours to do the practice. After your effective practice, you can master the examination point from the MB-280 Test Question. Then, you will have enough confidence to pass the MB-280 exam. What are you waiting for? Just come and buy our MB-280 exam questions!
Reliable MB-280 Test Cram: https://www.practicematerial.com/MB-280-exam-materials.html
BONUS!!! Download part of PracticeMaterial MB-280 dumps for free: https://drive.google.com/open?id=1JQTE8YPIck3NRJ_jvD2sbDZ500JXwphc
