[General] 100% Pass Pass-Sure VMware - 2V0-15.25 - VMware Cloud Foundation 9.0 Support Act
138
【General】 100% Pass Pass-Sure VMware - 2V0-15.25 - VMware Cloud Foundation 9.0 Support Act
Posted at 7 hour before      View:19 | Replies:0        Print      Only Author   [Copy Link] 1#
If you study on our test engine, your preparation time of the 2V0-15.25 guide braindumps will be greatly shortened. Firstly, the important knowledge has been picked out by our professional experts. You just need to spend about twenty to thirty hours before taking the Real 2V0-15.25 Exam. In addition, the relevant knowledge will be easy to memorize. Learning our 2V0-15.25 study quiz can also be a pleasant process. The saved time can be used to go sightseeing or have a rest.
If you want to avoid being eliminated by machine, you must constantly improve your ability in all aspects. The emergence of 2V0-15.25 dumps torrent provides you with a very good chance to improve yourself. On the one hand, our 2V0-15.25 quiz torrent can help you obtain professional certificates with high quality in any industry without any difficulty. On the other hand, 2V0-15.25 Exam Guide can give you the opportunity to become a senior manager of the company, so that you no longer engage in simple and repetitive work, and you will never face the threat of layoffs.
Reliable 2V0-15.25 Test Voucher & 2V0-15.25 Valid Test BraindumpsIn fact, in real life, we often use performance of high and low to measure a person's level of high or low, when we choose to find a good job, there is important to get the 2V0-15.25 certification as you can. Our product is elaborately composed with major questions and answers. We are choosing the key from past materials to finish our 2V0-15.25 Guide question. It only takes you 20 hours to 30 hours to do the practice. After your effective practice, you can master the examination point from the 2V0-15.25 test question. Then, you will have enough confidence to pass it.
VMware Cloud Foundation 9.0 Support Sample Questions (Q13-Q18):NEW QUESTION # 13
An administrator has observed that the vSphere Global Inventory is only available from the management domain vCenter. The Global Inventory is not available from the workload domain's vCenter.
Why is the "Global Inventory" missing from the workload domain's vCenter?
  • A. VCF SSO and vCenter Linking have not been configured.
  • B. An inventory sync was not run following the workload domain creation.
  • C. Supervisor Management has not been enabled.
  • D. An external VIDB instance has not been configured.
TheGlobal Inventory List (GIL)is only available whenmulti-vCenter SSO domain linkingis configured. In VMware Cloud Foundation, themanagement domain vCenteris deployed first and becomes theroot vCenter for global inventory data. For workload domains, their vCenter Servers must beregistered into the same SSO domainandlinkedwith the management-domain vCenter in order for the global inventory data (VMs, hosts, clusters, content libraries) to appear.
If a workload domain vCenter is not SSO-linked, it operates in its own identity domain, and thereforecannot access or present Global Inventory, resulting in exactly the symptom described: the management domain vCenter shows the GIL, while the workload domain vCenter does not.
Option B (Supervisor Management) relates to vSphere with Tanzu and has no impact on Global Inventory.
Option C (inventory sync) is incorrect-there is no manual sync required; GIL relies entirely on SSO linking.
Option D (VIDB) is not related to vCenter linking or inventory visibility; it is used by VCF Identity Broker.
Therefore, the reason the Global Inventory is missing from the workload domain vCenter is thatSSO/vCenter Linking has not been configured, which is required for federation across all VCF vCenters.
NEW QUESTION # 14
An administrator is responsible for managing a VMware Cloud Foundation (VCF) fleet. The following information has been provided about the VCF fleet configuration:
* The VCF fleet consists of a single VCF instance with a single management domain and a single workload domain.
* VCF Automation has a single Organization for VM Apps configured with a VCF Cloud Account for the workload domain.
The administrator has been tasked with creating a new Organization for All Apps to support the developers need to deploy Kubernetes-based applications in a new region in a workload domain.
The administrator attempts to create a new region through the VCF Automation Provider Portal but the VMware NSX manager for the workload domain does not appear on the list of available NSX managers.
What action must the administrator complete to resolve the issue?
  • A. Trigger an inventory synch in VCF Operations fleet management.
  • B. Deploy an additional VCF workload domain cluster.
  • C. Add the SDDC Manager integration for the VCF instance.
  • D. Deploy a new VCF workload domain.
NEW QUESTION # 15
An administrator is attempting to log into the vCenter using the vSphere Client but receives an error stating
"no healthy upstream" What are two possible causes for this? (Choose two.)
  • A. The vmware-rbd-watchdog service is not running.
  • B. The SSO Service is not running.
  • C. Port 443 is not opened between the local machine and the vCenter.
  • D. The administrator logged in with the root account.
  • E. The vpxd service is not running.
Answer: B,E
The vSphere Client "no healthy upstream" error is a classic indicator that one or morevCenter backend services are not running or responding, preventing the reverse proxy layer (envoy / nginx) from routing requests to the appropriate upstream services.
Two services in particular are known root causes:
A). vpxd service not running
vpxd is the core vCenter Server service responsible for inventory, host management, and client interaction. If vpxd is stopped, crashed, or restarting, the vSphere Client cannot communicate with backend APIs, resulting in the "no healthy upstream" condition.
B). SSO (vmware-stsd / identity service) not running
Authentication in vCenter depends on the SSO/Identity service. If SSO is unavailable, login sessions cannot be validated, and vCenter marks the upstream service as unhealthy.
Other options donotmatch the behavior:
* C (Port 443 closed)would produce a connection failure, not the upstream error.
* D (logging in with root)is fully supported and does not trigger this message.
* E (vmware-rbd-watchdog)relates to backup/restore health, not core authentication/management planes.
NEW QUESTION # 16
An administrator is managing a VMware Cloud Foundation (VCF) environment. They receive a request from the developers to enable vDefend - Distributed Firewall. However, they noticed It cannot be enabled due to a missing license.
Where must the new license be applied?
  • A. VCF Operations.
  • B. NSX Manager.
  • C. VCF Automation.
  • D. SDDC Manager.
vDefend - Distributed Firewall is a security capability delivered byNSXwithin VMware Cloud Foundation.
Although VCF components such as SDDC Manager, VCF Operations, and VCF Automation rely on licensing frameworks, the enforcement and activation ofNSX features-including Distributed Firewall-occur entirely withinNSX Manager.
To enablevDefend (Distributed Firewall), NSX Manager must detect a valid NSX license that includes security features. Without applying the correct license directly to NSX Manager:
* The Distributed Firewall feature remains locked
* vDefend cannot be enabled in workload domains
* Security rules and micro-segmentation capability remain unavailable
VCF does not apply NSX security licensing at the SDDC Manager, VCF Automation, or VCF Operations layers. Instead, NSX Manager handles all feature entitlement checks internally.
Therefore, the new license must be installeddirectly in NSX Manager, under:
System # Licensing # NSX # Add License
Options A, C, and D are incorrect because none of those components control NSX feature activation.
NEW QUESTION # 17
An administrator is asked to create a second provider gateway (provider gateway 02) in VMware Cloud Foundation (VCF) Automation Region-A.
After launching the Create Provider Gateway workflow in the VCF Automation Provider Management Portal, no Tier-0 Gateway is available for assignment.
How would you resolve this issue?
  • A. Log into the NSX Manager, create a new TO Gateway.
  • B. Log into the NSX Manager, create a new Tier-1 Gateway.
  • C. Create a new Region.
  • D. Retry the Create Provider Gateway workflow.
In VMware Cloud Foundation 9.0, aProvider Gatewayin VCF Automation is always backed by anexisting Tier-0 or Tier-0 VRF gatewayin NSX. When the administrator launches theCreate Provider Gateway workflow and no Tier-0 gateways appear for assignment, this indicates that VCF Automation cannot discover any valid Tier-0 gateways in the associated region.
The VMware Cloud Foundation 9.0 documentation explicitly states thatbefore adding a Provider Gateway, an administratormust first create an Active-Standby Tier-0 Gateway in NSX Manager. The Provider Gateway workflow only lists Tier-0 gateways that already exist and are properly configured in NSX. If none are present, the list will be empty.
From the documentation:"To add a provider gateway, first you must create an Active Standby tier-0 gateway in the NSX Manager associated with the region to back it.". Provider gateways in VCF Automationare discovered from these preexisting Tier-0 gatewaysand cannot be created until they exist.
Creating a Tier-1 gateway (Option B) does not satisfy the requirement because Provider Gateways must map specifically toTier-0, not Tier-1. Retrying the workflow (Option D) will not resolve the issue because the Tier-
0 backing resource is missing. Creating a new region (Option A) is unnecessary unless required for other organizational reasons, and it still would not produce a Tier-0 gateway.
Therefore, the correct and verified solution is tolog in to NSX Manager and create the required Tier-0 gateway, after which it will appear in the Provider Gateway creation workflow.
NEW QUESTION # 18
As the saying goes, to sensible men, every day is a day of reckoning. Time is very important to people. People often complain that they are wasting their time on study and work. They do not have time to look at the outside world. Now, 2V0-15.25 exam guide gives you this opportunity. 2V0-15.25 test prep helps you save time by improving your learning efficiency. At the same time, 2V0-15.25 Test Prep helps you to master the knowledge in the course of the practice. And at the same time, there are many incomprehensible knowledge points and boring descriptions in the book, so that many people feel a headache and sleepy when reading books. But with 2V0-15.25 learning question, you will no longer have these troubles.
Reliable 2V0-15.25 Test Voucher: https://www.realvalidexam.com/2V0-15.25-real-exam-dumps.html
VMware 2V0-15.25 Actual Test No matter you are the new comers or the senior in IT field, passing exam is not easy thing but important, VMware 2V0-15.25 Actual Test We will solve your problem, VMware 2V0-15.25 Actual Test The exam comes in sight, but can you take the test with confidence, Repetitive attempts of VMware Cloud Foundation 9.0 Support (2V0-15.25) exam dumps boosts confidence and provide familiarity with the 2V0-15.25 actual exam format.
Before the web was born, our media was linear, 2V0-15.25 Once again you can name this anything you like, but it is better to use a descriptive name, No matter you are the new Reliable 2V0-15.25 Test Voucher comers or the senior in IT field, passing exam is not easy thing but important.
Tips to Crack the VMware 2V0-15.25 ExamWe will solve your problem, The exam comes in sight, but can you take the test with confidence, Repetitive attempts of VMware Cloud Foundation 9.0 Support (2V0-15.25) exam dumps boosts confidence and provide familiarity with the 2V0-15.25 actual exam format.
The second advantageous feature of the 2V0-15.25 questions PDF document is the ability to print VMware Cloud Foundation 9.0 Support (2V0-15.25) exam dumps to avoid eye strain due to the usage of smart devices.
