[General] Free PDF 2026 Esri EAEP2201: Efficient New Enterprise Administration Professiona
135
【General】 Free PDF 2026 Esri EAEP2201: Efficient New Enterprise Administration Professiona
Posted at 9 hour before      View:20 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New EAEP2201 dumps are available on Google Drive shared by ValidExam: https://drive.google.com/open?id=1gpqQTWybZ1ZBeP1zf3hLh78FfNtyMVe5
It is certain that the pass rate of our EAEP2201 study guide among our customers is the most essential criteria to check out whether our EAEP2201 training materials are effective or not. The good news is that according to statistics, under the help of our EAEP2201 learning dumps, the pass rate among our customers has reached as high as 98% to 100%. It is strongly proved that we are professonal in this career and our EAEP2201 exam braindumps are very popular.
Esri EAEP2201 (Enterprise Administration Professional 2201) Exam is a certification program designed for professionals who specialize in administering and managing enterprise-level GIS systems. EAEP2201 exam is developed and offered by Esri, a leading global provider of GIS software and solutions. The EAEP2201 Exam validates the proficiency of individuals in the deployment, configuration, and maintenance of enterprise GIS systems, as well as their ability to troubleshoot and solve issues related to these systems.
Updated New EAEP2201 Exam Format offer you accurate Reliable Exam Blueprint | Esri Enterprise Administration Professional 2201ValidExam EAEP2201 valid training material is the efforts of our professional experts. They edit and compile the EAEP2201 questions and answers using their professional technology and hands-on experience. So if you want to pass with 100% guarantee, EAEP2201 vlid exam files will give you security and high scores. You will complete your Esri EAEP2201 exam preparation in a short time and attend the actual test with comfortable mood.
Esri EAEP2201: Enterprise Administration Professional 2201 Exam is an essential certification for IT professionals, GIS managers, and system administrators seeking to demonstrate their expertise in Esri enterprise GIS software administration. EAEP2201 exam covers a range of topics related to the configuration and management of Esri software, including installation, database management, security, licensing, and performance tuning. Candidates are encouraged to prepare thoroughly for EAEP2201 Exam and demonstrate their knowledge and skills in the administration of Esri software.
Esri Enterprise Administration Professional 2201 Sample Questions (Q65-Q70):NEW QUESTION # 65
An organization is considering deploying ArcGIS Enterprise. A needs assessment shows that all users need access to the following applications and capabilities:
* ArcGIS Pro
* ArcGIS StoryMaps
* View, edit and create portal content items
Which user type should be assigned for these users?
  • A. Creator
  • B. Editor
  • C. GIS Professional
To meet the listed requirements, the appropriate user type isGIS Professional. This user type includes:
* Access to ArcGIS Pro(essential for desktop GIS work and analysis)
* Full content management and sharing privileges in the portal
* Use of premium apps likeArcGIS StoryMaps,Experience Builder, and others TheCreatoruser type provides access to web-based apps and content butdoes not include ArcGIS Pro without an additional add-on license. TheEditoruser type is limited to viewing and editing existing data and does not support app creation or use of ArcGIS Pro.
Reference Source:ArcGIS Enterprise user type documentation - Application access matrix
NEW QUESTION # 66
A client has an internet-accessible ArcGIS Enterprise deployment with the Web Adaptors in the DMZ, and the remaining components are on an internal network behind a firewall. A user on the internet must access a web map in that environment.
Which ports must be open in the firewall between the DMZ and the internal network?
  • A. 6443 and 7443
  • B. 2443 and 6443
  • C. 443 and 6443
  • D. 80 and 443
NEW QUESTION # 67
A GIS administrator is analyzing the usage statistics of ArcGIS Enterprise. The administrator needs to pull tabular statistics on various groups and users about the type of content that they produce and consume.
Which action should the administrator perform?
  • A. Run usage reports in Portal for ArcGIS to determine the effect on the organization.
  • B. Use ArcGIS Monitor to capture desired information over a period of time in a report.
  • C. Open ArcGIS Server statistics to create a report for commonly used items.
NEW QUESTION # 68
An organization wants to use the standardfeature analysis toolsavailable in ArcGIS Enterprise to create hosted feature layersfor planning and design.
Which data store is required for this work?
  • A. File-based geodatabase
  • B. Tile cache data store
  • C. Relational data store
  • D. Spatiotemporal big data store
Thestandard feature analysis toolsin ArcGIS Enterprise (e.g., buffer, overlay, aggregate points) require hosted feature layers, which depend on therelational data store(a component of ArcGIS Data Store). The relational data store is the default location for hosting feature layers.
From ArcGIS Enterprise documentation:
"To use the standard spatial analysis tools and create hosted feature layers, the ArcGIS Data Store (relational) must be configured and set as the default hosting location."
* OptionA(spatiotemporal big data store) is used forreal-time and big data feeds, not standard analysis.
* OptionCsupportscached tiles, not feature layers.
Reference:ArcGIS Enterprise -Configuring the Relational Data Store for Hosting Feature Layers
NEW QUESTION # 69
An ArcGIS Enterprise administrator wants to publish their feature classes as layers in bulk from a registered geodatabase.
  • A. Register as a hosted layer in ArcGIS Data Store
  • B. Register the geodatabase in ArcGIS Server Manager
  • C. Create a data store item in the ArcGIS Enterprise portal
  • D. Import an SDE connection file into ArcGIS Server Administrator Directory
To publish feature classes as services in bulk from an enterprise geodatabase, it must first beregistered with the ArcGIS Server site. This registration tells ArcGIS Server where to access the data directly for referenced service publishing. The proper way to do this is throughArcGIS Server Manager.
"To publish layers directly from a registered enterprise geodatabase without copying data, you must register the geodatabase with your ArcGIS Server site using ArcGIS Server Manager."
* OptionBis used for hosted services, not referenced publishing.
* OptionCis not the correct interface for registering data sources.
* OptionDinvolves hosting data, which is not applicable for referenced layers from a geodatabase.
Reference:ArcGIS Server -Registering Data Stores for Publishing Referenced Services
NEW QUESTION # 70
EAEP2201 Reliable Exam Blueprint: https://www.validexam.com/EAEP2201-latest-dumps.html
What's more, part of that ValidExam EAEP2201 dumps now are free: https://drive.google.com/open?id=1gpqQTWybZ1ZBeP1zf3hLh78FfNtyMVe5
