Test 1z0-1196-25 Practice | 1z0-1196-25 Standard Answers
Posted at 4 hour before
2026 Latest Lead2PassExam 1z0-1196-25 PDF Dumps and 1z0-1196-25 Exam Engine Free Share: https://drive.google.com/open?id=1Os4LLPQu73JoS28wPxeoYlclJYA9Q33f
Not only our 1z0-1196-25 study guide has the advantage of high-quality, but also has reasonable prices that are accessible for every one of you. So it is incumbent upon us to support you. On the other side, we know the consumers are vulnerable for many exam candidates are susceptible to ads that boost about 1z0-1196-25 skills their practice with low quality which may confuse exam candidates like you, so we are trying hard to promote our high quality 1z0-1196-25 study guide to more people.
Just the same as the free demo, we have provided three kinds of versions of our 1z0-1196-25 preparation exam, among which the PDF version is the most popular one. It is quite clear that the PDF version is convenient for our customers to read and print the contents in our 1z0-1196-25 study guide. After printing, you not only can bring the 1z0-1196-25 Study Materials with you wherever you go, but also can make notes on the paper at your liberty, which may help you to understand the contents of our 1z0-1196-25 learning materials. Do not wait and hesitate any longer, your time is precious!
1z0-1196-25 Questions of the Highest Quality - Unlock Your SuccessAs the captioned description said, our 1z0-1196-25 practice materials are filled with the newest points of knowledge about the exam. With many years of experience in this line, we not only compile real test content into our 1z0-1196-25 practice materials, but the newest in to them. Allowing for there is a steady and growing demand for our 1z0-1196-25 practice materials with high quality at moderate prices, we never stop the pace of doing better. All newly supplementary updates will be sent to your mailbox one year long. And we shall appreciate it if you choose any version of our 1z0-1196-25 practice materials for exam and related tests in the future.
Oracle Utilities Customer to Meter and Customer Cloud Service 2025 Implementation Professional Sample Questions (Q19-Q24):NEW QUESTION # 19
Meters are a type of device, which can be physical or virtual objects, that can produce data to be handled by the system. Which two statements are true regarding meters?
- A. Only one device configuration can be associated with a meter.
- B. One or more measuring components can be associated with a meter's device configuration.
- C. A meter can only have scalar or interval measuring components associated with it.
- D. Only one measuring component can be associated with a meter's device configuration.
- E. One or more device configurations can be associated with a meter over time.
Answer: B,E
Meters in Oracle Utilities Customer to Meter are devices that generate measurement data, and their configurations are critical for accurate data processing. The Oracle Utilities Customer to Meter documentation provides the following insights:
Statement A: "One or more measuring components can be associated with a meter's device configuration." This is true because a meter's device configuration can include multiple measuring components to capture different types of data (e.g., consumption, demand, or time-of-use readings).
Statement D: "One or more device configurations can be associated with a meter over time." This is also true, as a meter may have different configurations applied at different times, such as when a meter is reconfigured or upgraded.
The other statements are incorrect:
Statement B: "Only one measuring component can be associated with a meter's device configuration" is false because, as noted, multiple measuring components can be linked to a single device configuration.
Statement C: "Only one device configuration can be associated with a meter" is false because a meter can have multiple device configurations over its lifecycle.
Statement E: "A meter can only have scalar or interval measuring components associated with it" is false because meters can also support other types of measuring components, such as register or profile components, depending on the system configuration.
Thus, the correct answers areAandD, as they align with the system's flexibility in associating measuring components and device configurations with meters.
Oracle Utilities Customer to Meter Configuration Guide, Section: Device Configuration and Measuring Components Oracle Utilities Customer to Meter Implementation Guide, Chapter: Meter Management
NEW QUESTION # 20
A Rate Schedule contains the calculation rules that perform specific types of calculations. Which three options are controlled by a Rate Schedule's configuration?
- A. The SA Types that are valid for the rate schedule
- B. Which Usage Calculation Group to initiate for usage calculations
- C. The General Ledger (GL) account impacted by each bill segment calculation line
- D. The contents of each bill segment calculation line
- E. The method used to calculate each bill segment calculation line's value
Answer: A,C,E
In Oracle Utilities Customer to Meter, aRate Scheduledefines the rules and calculations used to determine charges for services, forming the backbone of the billing process. The Oracle Utilities Customer to Meter Configuration Guide details the components controlled by a Rate Schedule's configuration:
Option A: The method used to calculate each bill segment calculation line's value.This is correct, as the Rate Schedule specifies the calculation methods (e.g., flat rate, tiered rate, time-of-use) for determining the monetary value of each bill segment calculation line based on usage or other factors.
Option B: The SA Types that are valid for the rate schedule.This is also correct, as the Rate Schedule defines which Service Agreement Types (SA Types) can use the rate, ensuring that only applicable services are billed under the schedule.
Option E: The General Ledger (GL) account impacted by each bill segment calculation line.This is correct, as the Rate Schedule configuration includes the GL accounts to which charges are posted, ensuring accurate financial reporting.
The Oracle Utilities Customer to Meter Billing Guide explains that Rate Schedules are highly configurable, allowing utilities to tailor billing calculations to diverse customer needs and regulatory requirements. For instance, a Rate Schedule for residential electricity might include tiered pricing, specify eligible SA Types (e.
g., residential electric service), and map charges to a revenue GL account.
The other options are incorrect:
Option C: The contents of each bill segment calculation line.While the Rate Schedule influences the calculation, the actual contents (e.g., description, quantity) are determined by the bill segment generation process, not directly by the Rate Schedule.
Option D: Which Usage Calculation Group to initiate for usage calculations.The Usage Calculation Group is defined by the usage subscription, not the Rate Schedule, which focuses on billing calculations rather than usage processing.
Practical Example:A Rate Schedule for a commercial water service might define a tiered rate structure (e.g.,
$2 per unit for 0-100 units, $3 per unit above 100 units), restrict its use to commercial SA Types, and post charges to a specific GL account (e.g., "Water Revenue"). When a customer uses 150 units, the Rate Schedule calculates the bill segment line values ($200 for the first 100 units + $150 for the next 50 units = $350) and directs the charge to the designated GL account.
The Oracle Utilities Customer to Meter Implementation Guide underscores that Rate Schedules are critical for aligning billing with business and regulatory requirements, providing flexibility to handle complex pricing models.
Oracle Utilities Customer to Meter Configuration Guide, Section: Rate Schedule Configuration Oracle Utilities Customer to Meter Billing Guide, Section: Rate Calculations and GL Integration Oracle Utilities Customer to Meter Implementation Guide, Chapter: Rate Management
NEW QUESTION # 21
In which plug-in spot can an implementation configure an algorithm to delete a bill as part of the bill completion process?
- A. Customer Class - Post Bill Completion
- B. Service Agreement Type - Pre-Bill Completion
- C. Customer Class - Bill Completion
- D. Service Agreement Type - Bill Completion
- E. Customer Class - Pre-Bill Completion
In Oracle Utilities Customer to Meter, plug-in spots allow implementations to configure custom algorithms for specific processes, such as bill completion. The Oracle Utilities Customer to Meter Configuration Guide specifies that theCustomer Class - BillCompletionplug-in spot is used to configure algorithms that execute during the bill completion process, including actions like deleting a bill under certain conditions (e.g., zero balance or errors).
Option A: The Service Agreement Type - Pre-Bill Completion plug-in spot is used for actions before bill completion, not for deleting a bill.
Option B: The Customer Class - Pre-Bill Completion plug-in spot is also for pre-completion actions, not bill deletion.
Option C: The Customer Class - Post Bill Completion plug-in spot is for actions after the bill is completed, not during the completion process.
Option D: The Service Agreement Type - Bill Completion plug-in spot is not a standard spot for bill deletion algorithms; customer class-level configuration is more appropriate.
Thus, the correct answer isE, as the Customer Class - Bill Completion plug-in spot is the correct location for configuring bill deletion algorithms.
Oracle Utilities Customer to Meter Configuration Guide, Section: Plug-In Spots for Bill Completion Oracle Utilities Customer to Meter Implementation Guide, Chapter: Customizing Billing Processes
NEW QUESTION # 22
Where would an implementation configure the system to prevent duplicate persons from being added?
- A. Person Contact Type
- B. Person Identifier Type
- C. Person Type
- D. Installation Options
- E. Person
In Oracle Utilities Customer to Meter, preventing the addition of duplicatepersonrecords is a critical function to maintain data integrity and avoid redundancy in customer information. The Oracle Utilities Customer to Meter Configuration Guide explicitly states that the system can be configured to prevent duplicate persons through thePerson Identifier Type. The Person Identifier Type defines the types of identifiers (e.g., Social Security Number, Tax ID, Driver's License) that can be associated with a person record and includes settings to enforce uniqueness for specific identifiers.
By configuring a Person Identifier Type to require uniqueness, the system checks whether an identifier (e.g., a specific SSN) already exists before allowing a new person record to be created. If a duplicate identifier is detected, the system prevents the creation of the new record and prompts the user to review the existing record. This functionality is essential for ensuring that each individual or business is represented by a single person record, reducing errors in billing, communication, and account management.
The Oracle Utilities Customer to Meter Implementation Guide further elaborates that the uniqueness check is implemented through validation rules defined in the Person Identifier Type, which can be customized to align with business requirements. For example, a utility might configure the SSN identifier type to be unique, ensuring that no two person records can share the same SSN.
The other options are incorrect for the following reasons:
Option A: Personrefers to the individual record itself, not a configuration point for preventing duplicates.
Option B: Person Contact Typedefines how contact information (e.g., phone, email) is stored but does not control duplicate prevention.
Option D: Installation Optionsmanage global system settings, such as default parameters, but do not specifically handle duplicate person checks.
Option E: Person Typecategorizes persons (e.g., residential, commercial) but does not include settings for duplicate prevention.
Practical Example:A utility configures the Person Identifier Type for "Social Security Number" to enforce uniqueness. When a customer service representative attempts to create a new person record with an SSN that already exists in the system, the system displays an error message, preventing the duplicate record and directing the representative to the existing person record. This ensures accurate customer data and avoids confusion in billing or service delivery.
The Oracle Utilities Customer to Meter User Guide highlights that configuring duplicate prevention via Person Identifier Type is a best practice for data quality, particularly in large utilities with millions of customers, where manual checks are impractical.
Oracle Utilities Customer to Meter Configuration Guide, Section: Person Identifier Type Configuration Oracle Utilities Customer to Meter Implementation Guide, Chapter: Customer Information Management Oracle Utilities Customer to Meter User Guide, Section: Managing Person Records
NEW QUESTION # 23
What determines an account's balance?
- A. The amount recorded in the "Balance Due" field on an account
- B. The sum of all the balances recorded in the "Balance Due" field on each service agreement related to the account
- C. The sum of all the financial transactions linked directly to the account
- D. The logic defined in a plug-in spot on Installation Options
- E. The sum of all the financial transactions linked directly to the service agreements related to the account
Answer: E
In Oracle Utilities Customer to Meter, anaccount's balancerepresents the total amount owed or credited for all services associated with the account. The Oracle Utilities Customer to Meter Billing Guide explicitly states that the account's balance is determined bythe sum of all the financial transactions linked directly to the service agreements related to the account. Financial transactions, such as bill segments, payments, and adjustments, are recorded against specific service agreements, which are in turn linked to the account. The account's balance is the aggregate of these transactions, reflecting the net financial position.
This approach ensures that the balance accurately captures all charges, payments, and adjustments associated with the account's service agreements. For example, if an account has two service agreements-one for electricity and one for water-each with its own bill segments and payments, the account's balance is the sum of the financial transactions (e.g., charges minus payments) for both agreements.
Option B: The logic defined in a plug-in spot on Installation Optionsmay influence how transactions are processed, but it does not directly determine the account's balance.
Option C: The amount recorded in the "Balance Due" field on an accountis a display field that reflects the calculated balance, not the source of the balance determination.
Option D: The sum of all the financial transactions linked directly to the accountis incorrect because financial transactions are linked to service agreements, not directly to the account.
Option E: The sum of all the balances recorded in the "Balance Due" field on each service agreementis misleading, as service agreements do not maintain a separate "Balance Due" field; the balance is calculated at the account level based on transactions.
Practical Example:Consider an account with a service agreement for electricity, which has a bill segment of
$100 and a payment of $80. The financial transactions for this service agreement total $20 ($100 - $80). If the account has no other service agreements, the account's balance is $20, calculated by summing the financial transactions linked to the service agreement.
The Oracle Utilities Customer to Meter Implementation Guide emphasizes that this structure allows for accurate financial tracking, as all transactions are tied to service agreements, which roll up to the account level for billing and reporting purposes.
Oracle Utilities Customer to Meter Billing Guide, Section: Account Balance Calculation Oracle Utilities Customer to Meter Implementation Guide, Chapter: Financial Transactions and Account Management
NEW QUESTION # 24
You can use this Oracle simulation software without an internet connection after installation. Tracking and reporting features of our Oracle Utilities Customer to Meter and Customer Cloud Service 2025 Implementation Professional 1z0-1196-25 Practice Exam software makes it easier for you to identify and overcome mistakes. Customization feature of this format allows you to change time limits and questions numbers of mock exams.
1z0-1196-25 Standard Answers: https://www.lead2passexam.com/Oracle/valid-1z0-1196-25-exam-dumps.html
It has helped so many candidates passed their 1z0-1196-25 exam, The PDF version of 1z0-1196-25 test questions can be printed out to facilitate your learning anytime, anywhere, as well as your own priorities, One year free updating of our 1z0-1196-25 exam dumps, Our 1z0-1196-25 practice test files can simulate the real examination environment, which is very helpful to you, Oracle Test 1z0-1196-25 Practice Take it easy, our specialists have given a vivid explanation to the difficult point.
You'll then notice that the Photos app automatically sorts your 1z0-1196-25 Braindumps images using the dates and times they were taken, Phillips tells you the way it is, how it is, and how it will probably work in your environment, sharing with you the most practical approach 1z0-1196-25 based on his consulting gigs and years and years of experience as a project manager, consultant, and business writer.
Top Test 1z0-1196-25 Practice Free PDF | Valid 1z0-1196-25 Standard Answers: Oracle Utilities Customer to Meter and Customer Cloud Service 2025 Implementation ProfessionalIt has helped so many candidates passed their 1z0-1196-25 exam, The PDF version of 1z0-1196-25 test questions can be printed out to facilitate your learning anytime, anywhere, as well as your own priorities.
One year free updating of our 1z0-1196-25 exam dumps, Our 1z0-1196-25 practice test files can simulate the real examination environment, which is very helpful to you.
Take it easy, our specialists 1z0-1196-25 Braindumps have given a vivid explanation to the difficult point.
- Quiz 2026 Valid Oracle 1z0-1196-25: Test Oracle Utilities Customer to Meter and Customer Cloud Service 2025 Implementation Professional Practice 🔡 Easily obtain 《 1z0-1196-25 》 for free download through 【 [url]www.examcollectionpass.com 】 🐗Braindumps 1z0-1196-25 Pdf[/url]
- 1z0-1196-25 Reliable Exam Blueprint 🏫 Braindumps 1z0-1196-25 Pdf 🧿 1z0-1196-25 Reliable Braindumps Questions 🎵 Open ☀ [url]www.pdfvce.com ️☀️ and search for 「 1z0-1196-25 」 to download exam materials for free 👺New 1z0-1196-25 Test Price[/url]
- 1z0-1196-25 – 100% Free Test Practice | Excellent Oracle Utilities Customer to Meter and Customer Cloud Service 2025 Implementation Professional Standard Answers 🥑 Go to website ✔ [url]www.prep4sures.top ️✔️ open and search for ➥ 1z0-1196-25 🡄 to download for free 🚪Valid 1z0-1196-25 Test Duration[/url]
- 1z0-1196-25 Questions Pdf 🙀 Latest 1z0-1196-25 Test Practice 🛺 Latest 1z0-1196-25 Real Test 🍹 Search for [ 1z0-1196-25 ] and download exam materials for free through [ [url]www.pdfvce.com ] 📚1z0-1196-25 Test Dump[/url]
- 1z0-1196-25 Latest Exam Materials 🍽 1z0-1196-25 Reliable Braindumps Questions 📂 Valid 1z0-1196-25 Dumps Demo 🤔 Copy URL 《 [url]www.validtorrent.com 》 open and search for [ 1z0-1196-25 ] to download for free 🧅1z0-1196-25 Test Dump[/url]
- Free PDF Quiz 2026 1z0-1196-25: Pass-Sure Test Oracle Utilities Customer to Meter and Customer Cloud Service 2025 Implementation Professional Practice ◀ The page for free download of { 1z0-1196-25 } on ▛ [url]www.pdfvce.com ▟ will open immediately ↙1z0-1196-25 Questions Pdf[/url]
- Quiz 2026 Valid Oracle 1z0-1196-25: Test Oracle Utilities Customer to Meter and Customer Cloud Service 2025 Implementation Professional Practice 🧀 Open ☀ [url]www.validtorrent.com ️☀️ enter ➥ 1z0-1196-25 🡄 and obtain a free download 🥋Valid 1z0-1196-25 Dumps Demo[/url]
- 2026 High Hit-Rate Oracle Test 1z0-1196-25 Practice 👑 Simply search for ▛ 1z0-1196-25 ▟ for free download on “ [url]www.pdfvce.com ” ☣1z0-1196-25 Reliable Exam Blueprint[/url]
- Quiz 2026 Valid Oracle 1z0-1196-25: Test Oracle Utilities Customer to Meter and Customer Cloud Service 2025 Implementation Professional Practice 🚀 Open { [url]www.vce4dumps.com } and search for [ 1z0-1196-25 ] to download exam materials for free 📩1z0-1196-25 High Passing Score[/url]
- New 1z0-1196-25 Test Price 😭 1z0-1196-25 Vce Download 🚙 1z0-1196-25 Reliable Exam Blueprint 🎈 Easily obtain 「 1z0-1196-25 」 for free download through ➥ [url]www.pdfvce.com 🡄 🚠New 1z0-1196-25 Test Price[/url]
- Download 1z0-1196-25 Demo 🦚 1z0-1196-25 Exam Fee 🧩 1z0-1196-25 High Passing Score 🔒 Easily obtain 【 1z0-1196-25 】 for free download through ⮆ [url]www.torrentvce.com ⮄ 🧲Intereactive 1z0-1196-25 Testing Engine[/url]
- skilldasher.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, infofitsoftware.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, demo.webdive.in, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
