[General] Valid Dumps Microsoft DP-420 Sheet - DP-420 Reliable Test Cost
138
【General】 Valid Dumps Microsoft DP-420 Sheet - DP-420 Reliable Test Cost
Posted at 3 hour before      View:15 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest ExamDumpsVCE DP-420 PDF Dumps and DP-420 Exam Engine Free Share: https://drive.google.com/open?id=17sg73Z7bMCyNrN8s773SR9LKpyu3_9I7
ExamDumpsVCE deeply believe that our latest DP-420 exam torrent will be very useful for you to strength your ability, pass your DP-420 exam and get your certification. Our DP-420 study materials with high quality and high pass rate in order to help you get out of your harassment. If you do not have access to internet most of the time, if you need to go somewhere is in an offline state but you want to learn for your DP-420 Exam. Our website will help you solve your problem with the help of our excellent DP-420 exam questions.
Microsoft DP-420 (Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB) Certification Exam is an advanced-level certification designed for professionals who want to demonstrate their expertise in designing and implementing cloud-native applications using Microsoft Azure Cosmos DB. Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB certification exam is designed to test the candidates' skills and knowledge related to designing and implementing cloud-native applications using Cosmos DB, including concepts like partitioning, scalability, and consistency.
Microsoft DP-420 Reliable Test Cost, New DP-420 Test AnswersPreparing for the DP-420 real exam is easier if you can select the right test questions and be sure of the answers. The DP-420 test answers are tested and approved by our certified experts and you can check the accuracy of our questions from our free demo. Expert for one-year free updating of DP-420 Dumps PDF, we promise you full refund if you failed exam with our dumps.
Microsoft DP-420 certification exam is aimed at professionals who want to validate their skills and knowledge in designing and implementing cloud-native applications using Azure Cosmos DB. DP-420 exam covers a wide range of topics related to Azure Cosmos DB, including data modeling, partitioning, indexing, querying, and tuning. Candidates should have experience with cloud-native application development and a strong understanding of Azure services to prepare for DP-420 exam. Microsoft offers a variety of training resources to help candidates prepare for the DP-420 Exam.
To pass the DP-420 exam, candidates need to demonstrate their competence in designing, developing, and deploying Azure Cosmos DB solutions. DP-420 exam consists of multiple-choice questions, scenario-based questions, and performance-based tasks that test the candidate's ability to design and implement cloud-native applications using Azure Cosmos DB. DP-420 exam also covers topics such as data modeling, data partitioning, indexing, querying, and tuning the performance of Azure Cosmos DB solutions.
Microsoft Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Sample Questions (Q130-Q135):NEW QUESTION # 130
You have an Azure Cosmos DB for NoSQL container named Contacts that is configured as shown in the following exhibit.
Contacts contains the items shown in the following table.
To Contacts, you plan to insert the items shown in the following table.
For each of the following statements select Yes if the statement is true. Otherwise, select No.
NEW QUESTION # 131
You plan to create an operational system that will store data in an Azure Cosmos OB 'or NoSQL account. You need to configure the account to meet the following requirements:
* Support Spar* queries.
* Support the analysis of data from the last six months.
* Only pay for analytical compute when running queries.
Which three actions should you perform? Each correct answer presents part of the solution. NOTE Each correct selection is worth one point.
  • A. Create a container and set the time to live to six months.
  • B. Create an Azure Synapse pipeline.
  • C. Enable Azure Synapse Link for the account
  • D. Create a container and set the analytical property to six months.
  • E. Create an Azure Databanks notebook.
  • F. Create an Azure Synapse linked service.
Answer: C,D,E
NEW QUESTION # 132
You have an Azure Cosmos DB Core (SQL) API account named storage1 that uses provisioned throughput capacity mode.
The storage1 account contains the databases shown in the following table.
The databases contain the containers shown in the following table.
https://docs.microsoft.com/en-us ... b/plan-manage-costs
https://azure.microsoft.com/en-us/pricing/details/cosmos-db/
NEW QUESTION # 133
You have an Azure Cosmos DB Core (SQL) account that has a single write region in West Europe.
You run the following Azure CLI script.
https://docs.microsoft.com/en-us ... how-to-multi-master
https://docs.microsoft.com/en-us ... timize-cost-regions
NEW QUESTION # 134
You have a container in an Azure Cosmos DB Core (SQL) API account. The container stores telemetry data from IoT devices. The container uses telemetryId as the partition key and has a throughput of 1,000 request units per second (RU/s). Approximately 5,000 IoT devices submit data every five minutes by using the same telemetryId value.
You have an application that performs analytics on the data and frequently reads telemetry data for a single IoT device to perform trend analysis.
The following is a sample of a document in the container.
You need to reduce the amount of request units (RUs) consumed by the analytics application.
What should you do?
  • A. Increase the offerThroughput value for the container.
  • B. Decrease the offerThroughput value for the container.
  • C. Move the data to a new container that has a partition key of deviceId.
  • D. Move the data to a new container that uses a partition key of date.
The partition key is what will determine how data is routed in the various partitions by Cosmos DB and needs to make sense in the context of your specific scenario. The IoT Device ID is generally the "natural" partition key for IoT applications.
Reference: https://docs.microsoft.com/en-us ... iot-using-cosmos-db
NEW QUESTION # 135
DP-420 Reliable Test Cost: https://www.examdumpsvce.com/DP-420-valid-exam-dumps.html
