【Android】
Online Audio Cutter
Posted at 4 hour before
I recently explored Online Audio Cutter, a web-based tool designed for precise audio editing https://audiocutter.online . The interface is intuitive and flexible: you can drop an audio file anywhere on the page to start editing, or import a saved project to pick up where you left off. For newcomers, there’s even a demo project to explore before working on your own files. The platform allows you to cut, trim & split audio with impressive accuracy. Whether you’re working with MP3, WAV, or other formats, it’s possible to remove unwanted sections, extract segments, or split long recordings into multiple files. For anyone dealing with multiple recordings, the merge audio files feature is practical. You can combine music tracks, voice recordings, or sound clips into one seamless file, with optional fade transitions to smooth out the joins. Another standout function is the ability to extract audio from video. This feature supports MP4, WebM, and other video formats, allowing you to convert them to MP3, WAV, or FLAC. The built-in audio converter also handles a variety of formats like OGG, AAC, AIFF, and even MP4 audio. Users can adjust quality, bitrate, and sample rate for optimal results. For creative finishing touches, Online Audio Cutter offers fade-in / fade-out effects, volume adjustment, and audio normalization. These functions help avoid abrupt starts and endings, ensure consistent loudness, and refine the overall sound for music, podcasts, or voice recordings. The audio compression tool is particularly useful, balancing loud and quiet parts for a polished, professional output. Advanced users will appreciate the frequency filter options, including high-pass, low-pass, band-pass, and notch filters. These tools can remove unwanted hum, hiss, or rumble, or isolate specific frequency ranges. There’s also an automated remove silence from audio feature, which detects silent sections and simplifies editing for podcasts, interviews, or voiceovers.
