[General] Integration-Architect VCE Exam Simulator & Valid Integration-Architect Study
138
【General】 Integration-Architect VCE Exam Simulator & Valid Integration-Architect Study
Posted at yesterday 17:03      View:12 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New Integration-Architect dumps are available on Google Drive shared by Dumpcollection: https://drive.google.com/open?id=1O0LoAposgsXwetPQKk0XcnSxU4B77fUM
All these three Dumpcollection Salesforce Certified Integration Architect (Integration-Architect) exam questions formats are easy to use and perfectly work with all devices, operating systems, and the latest web browsers. So rest assured that with the Integration-Architect Exam Dumps you will get everything that you need to learn, prepare and pass the challenging Integration-Architect exam with good scores.
Salesforce trained experts have made sure to help the potential applicants of Salesforce Integration-Architect certification to pass their Salesforce Integration-Architect exam on the first try. Our PDF format carries real Salesforce Certified Integration Architect exam dumps. You can use this format of Salesforce Integration-Architect Actual Questions on your smart devices.
Valid Integration-Architect Study Notes, Detail Integration-Architect ExplanationThe experts and professors of our company have designed the three different versions of the Integration-Architect prep guide, including the PDF version, the online version and the software version. Now we are going to introduce the online version for you. There are a lot of advantages about the online version of the Integration-Architect exam questions from our company. For instance, the online version can support any electronic equipment and it is not limited to all electronic equipment. More importantly, the online version of Integration-Architect study practice dump from our company can run in an off-line state, it means that if you choose the online version, you can use the Integration-Architect exam questions when you are in an off-line state. In a word, there are many advantages about the online version of the Integration-Architect prep guide from our company.
Salesforce Certified Integration Architect Sample Questions (Q103-Q108):NEW QUESTION # 103
Northern Trail Outfitters needs to make synchronous callouts "available to promise"services to query product availability and reserve inventory during customer checkout process.
Which two considerations should an integration architect make when building a scalable integration solution?
Choose 2 answers
  • A. The typical and worst-case historical response times.
  • B. How many concurrent service calls are being placed.
  • C. The number batch jobs that can run concurrently.
  • D. The maximum query cursors open per user on the service.
The typical and worst-case historical response times, and how many concurrent service calls are being placed are two considerations that an integration architect should make when building a scalable integration solution for synchronous callouts to "available to promise" services. These two factors can affect the performance, reliability, and availability of the integration solution, as well as the user experience of the customer checkout process. The integration architect should design the solution to handle high volumes of service calls, optimize the response times, handle errors and timeouts, and avoid hitting governor limits or service quotas.
References: Certification - Integration Architect - Trailhead, [Callout Limits and Limitations], [Integration Patterns and Practices]
NEW QUESTION # 104
A global financial company sells financial products and services that include the following:
1. Bank Accounts
2. Loans
3. Insurance
The company has a core banking system that is state of the art and is the master system to store financial transactions, financial products and customer information. The core banking system currently processes 10M financial transactions per day. The CTO for the company is considering building a community port so that customers can review their bank account details, update their information and review their account financial transactions.
What should an integration architect recommend as a solution to enable customer community users to view their financial transactions?
  • A. Use Salesforce Connect to display the financial transactions as an external object.
  • B. Use Salesforce Connect to display the financial transactions as an external object.
  • C. Use Iframe to display core banking financial transactions data in the customer community.
  • D. Use Salesforce External Service to display financial transactions in a community lightning page.
The integration architect should recommend using Salesforce Connect to display the financial transactions as an external object. Salesforce Connect is a feature that allows you to integrate external data sources with Salesforce and access them in real time via external objects. External objects are similar to custom objects, but they store metadata only and not data. You can use external objects to display data from the core banking system in the customer community without copying or syncing the data. You can also use standard Salesforce features, such as reports, dashboards, or global search, with external objects. Salesforce External Service is a feature that allows you to import an external schema definition and generate an Apex wrapper class that can invoke an external service. This is useful for integrating complex business processes or workflows with Salesforce, but not for displaying data in a community lightning page. Iframe is a HTML element that allows you to embed another web page within a web page. This is not a recommended solution for displaying data in a customer community, as it can pose security risks, performance issues, or user interface problems.
References: [Salesforce Connect], [Salesforce External Services], [Using Iframes in Lightning Components]
NEW QUESTION # 105
Northern Trail Outfitters wants to use Salesforce as a front end for creating accounts using the lead-to-opportunity process.
1. An order is created in Salesforce when the opportunity is closed and won, but the back-end ERP system is the data master for order,
2. Customer wants to be able to see within Salesforce all the stages of order processing like Order Created, Order Shipped, Order Paid that are within the retention window.
Which two message durability considerations should an Integration Architect make when designing a solution to meet these business requirements?
Choose 2 answers
  • A. High-volume event messages are stored for 24 hours (one day).
  • B. When subscribing to Salesforce Event bus, ReplaylD is used with a value of -2 to be able to see old and new events.
  • C. High-volume event messages are stored for 72 hours (three days).
  • D. When subscribing to Salesforce Event bus, ReplaylD is used with a value of -1 to be able to see new events.
The message durability considerations that an Integration Architect should make when designing a solution to meet these business requirements are:
When subscribing to Salesforce Event bus, ReplayID is used with a value of -2 to be able to see old and new events.
A Salesforce Event bus is a messaging service that allows you to publish and subscribe to events in Salesforce or from external sources. ReplayID is a property of an event message that indicates its position in the event stream. By using ReplayID with a value of -2, you can replay all events stored in the retention window, which can help you see the stages of order processing in Salesforce. High-volume event messages are a type of event message that can handle large volumes of data and are optimized for performance and scalability.
High-volume event messages are stored for 72 hours (three days) in the event bus, which means they can be replayed within that time frame. The other options are not correct. Using ReplayID with a value of -1 means you can only see new events that are published after your subscription. High-volume event messages are not stored for 24 hours (one day), but for 72 hours (three days).
NEW QUESTION # 106
A customer is migrating from an old legacy system to Salesforce. As part of the modernization effort, they would like to integrate al existing systems that currently work with their legacy application with Salesforce.
Which three constraints and pain-points should an integration architect consider when choosing the integration pattern/mechanism?
Choose 3 answers
  • A. Reporting and usability requirements
  • B. Multi-language and multi-currency requirement
  • C. System types - APIs, File systems, Email
  • D. Data Volume and Processing volume
  • E. Error handling mechanisms
Answer: C,D,E
The system types, the error handling mechanisms, and the data volume and processing volume are three constraints and pain-points that an integration architect should consider when choosing the integration pattern/mechanism. The system types determine what kind of interfaces and protocols are available or required for the integration, such as APIs, file systems, email, etc. The error handling mechanisms ensure that the integration can handle any failures or exceptions gracefully and provide appropriate logging and notification.
The data volume and processing volume affect the performance and scalability of the integration, as well as the choice of synchronous or asynchronous methods. Reference: Salesforce Integration Architecture Designer Resource Guide, page 17
NEW QUESTION # 107
Northern Trail Outfitters is planning to perform nightly batch loads into Salesforce from an external system with a custom Java application using the Bulk API. The CIO is curious about monitoring recommendations for the jobs from the technical architect. Which recommendation should help meet the requirements?
  • A. Set the Salesforce debug logs level to "finest", and add the user ID running the job to monitor in the
    "Debug Logs" in the setup menu.
  • B. Write the error response from the Bulk API status to a custom error logging object in Salesforce using an Apex trigger, and create reports on the object.
  • C. Use the getBatchInfo method in the Java application to monitor the status of the jobs from the Java application.
For high-volume data loads using the Bulk API, monitoring should be performed programmatically by the orchestrating client-in this case, the custom Java application. The Bulk API is asynchronous, meaning that when you submit a job, Salesforce acknowledges the request and processes it in the background.
The Java application must actively track the state of its own jobs. Using the `getBatchInfo` (or `getJobInfo` in Bulk API 2.0) method allows the application to retrieve the real-time status of each batch. The application can check for statuses such as `Queued`, `InProgress`, `Completed`, or `Failed`. Once a batch is marked as
`Completed`, the application can then call `getBatchResult` to retrieve a list of successes and failures for individual records.
Option B is architecturally unsound because Bulk API operations are designed to bypass most synchronous Apex logic to ensure performance; furthermore, creating custom records for every error in a "nightly batch load" would likely hit other platform limits (like storage or CPU) and defeat the purpose of using the Bulk API. Option C is ineffective for Bulk API monitoring, as debug logs do not capture the background processing of bulk batches and would quickly hit the log size limits.
By recommending Option A, the architect ensures that the Java application maintains full control over the integration lifecycle. The application can log errors locally, implement automated retries for transient failures, and provide the CIO with accurate, high-level reporting on the success rate of the nightly loads without placing unnecessary overhead on the Salesforce platform.
NEW QUESTION # 108
People need to increase their level by getting the Salesforce Integration-Architect certification. If you take an example of the present scenario in this competitive world, you will find people struggling to meet their ends just because they are surviving on low-scale salaries. Even if they are thinking about changing their jobs, people who are ready with a better skill set or have prepared themselves with Salesforce Integration-Architect Certification grab the chance. This leaves them in the same place where they were.
Valid Integration-Architect Study Notes: https://www.dumpcollection.com/Integration-Architect_braindumps.html
Just like the old saying goes:" Facts are stronger than arguments." You can choose to download our free demo at any time as you like, you are always welcome to have a try, and we trust that our Integration-Architect exam materials will never let you down, Salesforce Integration-Architect VCE Exam Simulator If you have valid exam preparation, it will be difficult for you to pass, Salesforce Integration-Architect VCE Exam Simulator And you are affirmatively more competitive for a higher position with those who haven't possessed the certification yet.
Formatting with `ICustomFormatter` and `StringBuilder`, Setting Reliable Integration-Architect Exam Cram Text Alignment Within a Cell, Just like the old saying goes:" Facts are stronger than arguments." You can choose to download our free demo at any time as you like, you are always welcome to have a try, and we trust that our Integration-Architect Exam Materials will never let you down.
Pass Guaranteed Quiz Valid Integration-Architect - Salesforce Certified Integration Architect VCE Exam SimulatorIf you have valid exam preparation, it will be difficult for you Valid Integration-Architect Study Notes to pass, And you are affirmatively more competitive for a higher position with those who haven't possessed the certification yet.
Actualtests Achieve your lifelong dream of getting Reliable Integration-Architect Exam Cram astounding in exam certification with the assistance of the prestigious onlineinstitutions which offer exam dumps and exam Integration-Architect VCE Exam Simulator practice the most wanted procedures for the regulation of certification examination.
We give you 100 percent guarantee that Integration-Architect if you fail the test unluckily, we will return full refund to you.
What's more, part of that Dumpcollection Integration-Architect dumps now are free: https://drive.google.com/open?id=1O0LoAposgsXwetPQKk0XcnSxU4B77fUM
