[General] Palo Alto Networks PCNSE Sample Test Online - PCNSE Test Questions
【General】 Palo Alto Networks PCNSE Sample Test Online - PCNSE Test Questions
Posted at yesterday 19:17      View:24 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest It-Tests PCNSE PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1sEEhriR0f9PzPUIj_GJhevXAfpq-XbdT
We believe our PCNSE exam questions will meet all demand of all customers. If you long to pass the exam and get the certification successfully, you will not find the better choice than our PCNSE preparation questions. Now you can have a chance to try our PCNSE study braindumps before you pay for them. There are the free demos on our website for you download to check the quality and validity of our PCNSE practice engine. Just have a try, then you will fall in love with our PCNSE learning quiz!
There are three different kinds of our PCNSE exam questions: the PDF, Software and APP online. And i love the Software for the best for no matter how many software you have installed on your computers, our PCNSE learning materials will never be influenced. Also, our PCNSE Study Guide just need to be opened with internet service for the first time. Later, you can freely take it everywhere as long as you use it in the Windows system.
PCNSE Sample Test Online 100% Pass | High-quality PCNSE Test Questions: Palo Alto Networks Certified Network Security Engineer ExamDifferent from the common question bank on the market, PCNSE exam guide is a scientific and efficient learning system that is recognized by many industry experts. In normal times, you may take months or even a year to review a professional exam, but with PCNSE exam guide you only need to spend 20-30 hours to review before the exam. And with PCNSE learning question, you will no longer need any other review materials, because our study materials already contain all the important test sites. At the same time, PCNSE Test Prep helps you to master the knowledge in the course of the practice. And at the same time, there are many incomprehensible knowledge points and boring descriptions in the book, so that many people feel a headache and sleepy when reading books. But with PCNSE learning question, you will no longer have these troubles.
Palo Alto Networks Certified Network Security Engineer Exam Sample Questions (Q66-Q71):NEW QUESTION # 66
Which method will dynamically register tags on the Palo Alto Networks NGFW?
  • A. XML API or the VM Monitoring agent on the NGFW or on the User-ID agent
  • B. XML-API or the VMware API on the firewall or on the User-ID agent or the CLI
  • C. Restful API or the VMWare API on the firewall or on the User-ID agent or the read-only domain controller (RODC)
  • D. Restful API or the VMware API on the firewall or on the User-ID agent
https://www.paloaltonetworks.com ... sses-and-tags-dynam
https://docs.paloaltonetworks.co ... irtual-environment/
NEW QUESTION # 67
An administrator receives the following error message:
"IKE phase-2 negotiation failed when processing Proxy ID. Received local id 192.168 33 33/24 type IPv4 address protocol 0 port 0, received remote id 172.16 33.33/24 type IPv4 address protocol 0 port 0." How should the administrator identify the root cause of this error message?
  • A. Verify that the IP addresses can be pinged and that routing issues are not causing the connection failure
  • B. Check whether the VPN peer on one end is set up correctly using policy-based VPN
  • C. In the IPSec Crypto profile configuration, verify that PFS is either enabled on both VPN peers or disabled on both VPN peers.
  • D. In the IKE Gateway configuration, verify that the IP address for each VPN peer is accurate
https://docs.paloaltonetworks.co ... erpret-vpn-error-me The VPN peer on one end is using policy-based VPN. You must configure a Proxy ID on the Palo Alto Networks firewall.
NEW QUESTION # 68
Which two statements correctly describe Session 380280? (Choose two.)
  • A. The session has ended with the end-reason unknown.
  • B. The session did not go through SSL decryption processing.
  • C. The application has been identified as web-browsing.
  • D. The session went through SSL decryption processing.
NEW QUESTION # 69
Which feature checks Panorama connectivity status after a commit?
  • A. HTTP Server profiles
  • B. Scheduled config export
  • C. Device monitoring data under Panorama settings
  • D. Automated commit recovery
https://docs.paloaltonetworks.co ... matic-panorama-conn
NEW QUESTION # 70
A customer would like to support Apple Bonjour in their environment for ease of configuration.
Which type of interface in needed on their PA-3200 Series firewall to enable Bonjour Reflector in a segmented network?
  • A. Layer 2 interface
  • B. Layer 3 interface
  • C. Virtual Wire interface
  • D. Loopback interface
https://docs.paloaltonetworks.co ... ng-admin/configure- interfaces/configure-bonjour-reflector-for-network-segmentation
NEW QUESTION # 71
Our accurate, reliable, and top-ranked Palo Alto Networks Certified Network Security Engineer Exam (PCNSE) exam questions will help you qualify for your Palo Alto Networks PCNSE certification on the first try. Do not hesitate and check out It-Tests excellent Palo Alto Networks Certified Network Security Engineer Exam (PCNSE) practice exam to stand out from the rest of the others.
PCNSE Test Questions: https://www.it-tests.com/PCNSE.html
Palo Alto Networks PCNSE study material contains very relevant and precise knowledge about the course outline and delivers it in a professional style, Master all the PCNSE dumps' exam questions and answers, The sooner you use PCNSE training materials, the more chance you will pass the PCNSE exam, and the earlier you get your certificate, Palo Alto Networks PCNSE Sample Test Online You can practice anytime, anywhere.
Introduction to Virtual Routers, Not that they PCNSE all agreed with one another—those attitudes are very individual, Palo Alto Networks PCNSE Study Material contains very relevant and PCNSE Test Questions precise knowledge about the course outline and delivers it in a professional style.
High-quality Palo Alto Networks Certified Network Security Engineer Exam valid exam cram & Palo Alto Networks PCNSE dumps torrentMaster all the PCNSE dumps' exam questions and answers, The sooner you use PCNSE training materials, the more chance you will pass the PCNSE exam, and the earlier you get your certificate.
You can practice anytime, anywhere, Chrome, Internet Explorer, Firefox, Safari, Opera, and all the major browsers support the web-based Palo Alto Networks Certified Network Security Engineer Exam (PCNSE) practice exam.
What's more, part of that It-Tests PCNSE dumps now are free: https://drive.google.com/open?id=1sEEhriR0f9PzPUIj_GJhevXAfpq-XbdT
