100% Pass 2026 Microsoft Newest DP-420 Guaranteed Success
Posted at 12 hour before
2026 Latest PassTestking DP-420 PDF Dumps and DP-420 Exam Engine Free Share: https://drive.google.com/open?id=1kv_fOqSidYy1HFgD34Sz4MOCdBE6V_1n
Under the support of our study materials, passing the exam won’t be an unreachable mission. More detailed information is under below. We are pleased that you can spare some time to have a look for your reference about our DP-420 test prep. As long as you spare one or two hours a day to study with our laTest DP-420 Quiz prep, we assure that you will have a good command of the relevant knowledge before taking the exam. What you need to do is to follow the DP-420 exam guide system at the pace you prefer as well as keep learning step by step.
Microsoft DP-420 certification exam is ideal for cloud architects, developers, and IT professionals who are looking to enhance their skills in designing and implementing cloud-native applications. Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB certification exam is designed to test the candidates' ability to design and implement scalable, fault-tolerant cloud-native applications using Cosmos DB. DP-420 Exam also covers various topics related to Cosmos DB, including partitioning, data modeling, indexing, and querying.
PassTestking DP-420 Exam Practice Test Questions Available In Three User-Friendly FormatsWith our wide range of Microsoft DP-420 exam questions types and difficulty levels, you can tailor your Microsoft DP-420 exam practice to your needs. Your performance and exam skills will be improved with our Microsoft DP-420 Practice Test software. The software provides you with a range of Microsoft DP-420 exam dumps, all of which are based on past Microsoft DP-420 certifications.
Microsoft Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Sample Questions (Q76-Q81):NEW QUESTION # 76
You have a database named db1 in an Azure Cosmos DB f You have a third-party application that is exposed thro You need to migrate data from the application to a What should you use?
- A. Database Migration Assistant
- B. Azure Data Factory
- C. Azure Migrate
you can migrate data from various data sources to Azure Cosmos DB using different tools and methods. The choice of the migration tool depends on factors such as the data source, the Azure Cosmos DB API, the size of data, and the expected migration duration . Some of the common migration tools are:
* Azure Cosmos DB Data Migration tool: This is an open source tool that can import data to Azure Cosmos DB from sources such as JSON files, MongoDB, SQL Server, CSV files, and Azure Cosmos DB collections. This tool supports the SQL API and the Table API of Azure Cosmos DB2.
* Azure Data Factory: This is a cloud-based data integration service that can copy data from various sources to Azure Cosmos DB using connectors. This tool supports the SQL API, MongoDB API, Cassandra API, Gremlin API, and Table API of Azure Cosmos DB
* Azure Cosmos DB live data migrator: This is a command-line tool that can migrate data from one Azure Cosmos DB container to another container within the same or different account. This tool supports live migration with minimal downtime and works with any Azure Cosmos DB API4.
For your scenario, if you want to migrate data from a third-party application that is exposed through an OData endpoint to a container in Azure Cosmos DB for NoSQL, you should use Azure Data Factory. Azure Data Factory has an OData connector that can read data from an OData source and write it to an Azure Cosmos DB sink using the SQL API5. You can create a copy activity in Azure Data Factory that specifies the OData source and the Azure Cosmos DB sink, and run it on demand or on a schedule.
NEW QUESTION # 77
The settings for a container in an Azure Cosmos DB Core (SQL) API account are configured as shown in the following exhibit.
Which statement describes the configuration of the container?
- A. All items will be deleted after one hour.
- B. Items stored in the collection will expire only if the item has a time to live value.
- C. Items stored in the collection will be retained always, regardless of the items time to live value.
- D. All items will be deleted after one year.
When DefaultTimeToLive is -1 then your Time to Live setting is On (No default) Time to Live on a container, if present and the value is set to "-1", it is equal to infinity, and items don't expire by default.
Time to Live on an item:
This Property is applicable only if DefaultTimeToLive is present and it is not set to null for the parent container.
If present, it overrides the DefaultTimeToLive value of the parent container.
Reference: https://docs.microsoft.com/en-us/azure/cosmos-db/sql/time-to-live
NEW QUESTION # 78
You plan to create an operational system that will store data in an Azure Cosmos OB 'or NoSQL account.
You need to configure the account to meet the following requirements:
*Support Spark queries.
*Support the analysis of data from the last six months.
*Only pay for analytical compute when running queries.
Which three actions should you perform? Each correct answer presents part of the solution. NOTE Each correct selection is worth one point.
- A. Create a container and set the analytical property to six months.
- B. Create an Azure Synapse pipeline.
- C. Create an Azure Databanks notebook.
- D. Enable Azure Synapse Link for the account
- E. Create an Azure Synapse linked service.
- F. Create a container and set the time to live to six months.
Answer: A,C,D
NEW QUESTION # 79
You need to provide a solution for the Azure Functions notifications following updates to con-product. The solution must meet the business requirements and the product catalog requirements.
Which two actions should you perform? Each correct answer presents part of the solution.
- A. Configure the trigger for each function to use a different leaseCollectionName
- B. Configure the trigger for each function to use the same leaseCollectionNair.e
- C. Configure the trigger for each function to use the same leaseCollectionPrefix
- D. Configure the trigger for each function to use a different leaseCollectionPrefix
leaseCollectionPrefix: when set, the value is added as a prefix to the leases created in the Lease collection for this Function. Using a prefix allows two separate Azure Functions to share the same Lease collection by using different prefixes.
Scenario: Use Azure Functions to send notifications about product updates to different recipients.
Trigger the execution of two Azure functions following every update to any document in the con-product container.
https://docs.microsoft.com/en-us ... cosmosdb-v2-trigger
Topic 2, Mix Questions
Mix Questions
DP-420 Mix Questions IN THIS CASE STUDY
NEW QUESTION # 80
You have an Azure Cosmos DB for NoSQL account named account1 that supports an application named App1. App1 uses the consistent prefix consistency level.
You configure account1 to use a dedicated gateway and integrated cache.
You need to ensure that App1 can use the integrated cache.
Which two actions should you perform for APP1? Each correct answer presents part of the solution.
the Azure Cosmos DB integrated cache is an in-memory cache that is built-in to the Azure Cosmos DB dedicated gateway. The dedicated gateway is a front-end compute that stores cached data and routes requests to the backend database. You can choose from a variety of dedicated gateway sizes based on the number of cores and memory needed for your workload1. The integrated cache can reduce the RU consumption and latency of read operations by serving them from the cache instead of the backend containers2.
For your scenario, to ensure that App1 can use the integrated cache, you should perform these two actions:
* Change the account endpoint to https://account1.sqlx.cosmos.azure.com. This is the dedicated gateway endpoint that you need to use to connect to your Azure Cosmos DB account and leverage the integrated cache. The standard gateway endpoint (https://account1.documents.azure.com) will not use the integrated cache2.
* Change the consistency level of requests to session. This is the highest consistency level that is supported by the integrated cache. If you use a higher consistency level (such as strong or bounded staleness), your requests will bypass the integrated cache and go directly to the backend containers
NEW QUESTION # 81
Microsoft DP-420 Exam Dumps are one of the best ways to prepare for your Microsoft DP-420 certification exams. They offer an excellent range of study materials and practice tests that can help you become certified in no time. These Microsoft DP-420 Exam Dumps are also updated regularly to ensure that you are always up to date with the latest information.
Valid DP-420 Test Pdf: https://www.passtestking.com/Microsoft/DP-420-practice-exam-dumps.html
- Valid DP-420 Study Guide 🥈 New DP-420 Exam Duration 💅 Related DP-420 Exams 🧂 Search for ▷ DP-420 ◁ and download it for free on 「 [url]www.prepawaypdf.com 」 website 😳New DP-420 Braindumps Ebook[/url]
- Pass Guaranteed 2026 DP-420: Accurate Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Guaranteed Success 😋 Search for ➥ DP-420 🡄 and download exam materials for free through ▷ [url]www.pdfvce.com ◁ 📘Test DP-420 Passing Score[/url]
- Exam DP-420 Consultant 🍌 DP-420 Valid Exam Blueprint 😈 Questions DP-420 Pdf 📳 Enter 《 [url]www.troytecdumps.com 》 and search for ▛ DP-420 ▟ to download for free 🧰Reliable DP-420 Study Materials[/url]
- Quiz DP-420 Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Realistic Guaranteed Success 📌 Download 「 DP-420 」 for free by simply searching on ▶ [url]www.pdfvce.com ◀ 📒New DP-420 Exam Test[/url]
- Valid DP-420 Guaranteed Success Offer You The Best Valid Test Pdf | Microsoft Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB 🥘 Search for ( DP-420 ) and obtain a free download on ⇛ [url]www.prepawayexam.com ⇚ 🦯Exam DP-420 Consultant[/url]
- Newest DP-420 Guaranteed Success – Pass DP-420 First Attempt 😮 Easily obtain free download of ▶ DP-420 ◀ by searching on 《 [url]www.pdfvce.com 》 🕠Latest DP-420 Exam Book[/url]
- Valid DP-420 Study Guide 🏧 Reliable DP-420 Braindumps Ppt 📆 Test DP-420 Passing Score 🏞 Easily obtain ➡ DP-420 ️⬅️ for free download through 《 [url]www.examcollectionpass.com 》 🚔DP-420 Test Result[/url]
- Valid DP-420 Guaranteed Success Offer You The Best Valid Test Pdf | Microsoft Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB 🐤 Open website ➡ [url]www.pdfvce.com ️⬅️ and search for 【 DP-420 】 for free download 💰DP-420 Valid Exam Blueprint[/url]
- Exam DP-420 Tutorial 🍴 Exam DP-420 Consultant ♥ Exam DP-420 Consultant 🍸 Search for ▛ DP-420 ▟ and download exam materials for free through ▶ [url]www.validtorrent.com ◀ 🍽Valid DP-420 Study Guide[/url]
- Quiz DP-420 Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Realistic Guaranteed Success 😭 Open ➠ [url]www.pdfvce.com 🠰 enter ➡ DP-420 ️⬅️ and obtain a free download 🆒Test DP-420 Result[/url]
- DP-420 Valid Exam Blueprint 🌌 DP-420 Interactive EBook 🥰 New DP-420 Braindumps Ebook 🍯 Simply search for ⮆ DP-420 ⮄ for free download on ▷ [url]www.troytecdumps.com ◁ 👇
ass DP-420 Guaranteed[/url] - www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, learn.csisafety.com.au, novoedglobal.com, www.intensedebate.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, shubhbundela.com, Disposable vapes
DOWNLOAD the newest PassTestking DP-420 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1kv_fOqSidYy1HFgD34Sz4MOCdBE6V_1n
