[General] Nutanix - NCP-EUC - Nutanix Certified Professional - End User Computing (NCP-EUC
138
【General】 Nutanix - NCP-EUC - Nutanix Certified Professional - End User Computing (NCP-EUC
Posted at 10 hour before      View:21 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Nutanix NCP-EUC dumps are available on Google Drive shared by DumpExam: https://drive.google.com/open?id=1D-PJE3MjUS835S1BPd-TNwUkpQZNUVGh
NCP-EUC Exam is a Nutanix certification exam and IT professionals who have passed some Nutanix certification exams are popular in IT industry. So more and more people participate in NCP-EUC certification exam, but NCP-EUC certification exam is not very simple. If you do not have participated in a professional specialized training course, you need to spend a lot of time and effort to prepare for the exam. But now DumpExam can help you save a lot of your precious time and energy.
Nutanix NCP-EUC, or Nutanix Certified Professional - End-User Computing, is an industry-recognized certification program designed to validate the skills and knowledge of professionals working in the end-user computing field. Nutanix Certified Professional - End User Computing (NCP-EUC) 6.10 Exam certification is offered by Nutanix, a leading provider of cloud computing and hyper-converged infrastructure solutions.
NCP-EUC Exam PDF - NCP-EUC Valid Exam CostWith so many online resources, knowing where to start when preparing for an Nutanix NCP-EUC exam can be tough. But with Nutanix NCP-EUC practice test, you can be confident you're getting the best possible Nutanix NCP-EUC Exam Dumps. Nutanix exam mirrors the Nutanix NCP-EUC exam-taking experience, so you know what to expect on Nutanix NCP-EUC exam day.
Nutanix Certified Professional - End User Computing (NCP-EUC) 6.10 Exam Sample Questions (Q80-Q85):NEW QUESTION # 80
A company wants to test the impact of a security policy before enforcing it and potentially blocking traffic.
Which Flow Network Security feature is best for this?
  • A. Isolation Policy
  • B. Quarantine Policy
  • C. Monitor Mode
  • D. Enforce Mode
Comprehensive and Detailed Explanation From Exact Extract of Nutanix End User Computing documents:
According to Nutanix Flow Network Security Guide:
* Policy States: Security policies in Nutanix Flow have two primary operating modes: Monitor and Enforce.
* Monitor Mode: In Monitor Mode (Option A), the policy rules are evaluated, and traffic that would have been blocked is logged, but the traffic is allowed to pass.
* Use Case: This is explicitly designed for the scenario described: "testing the impact... before enforcing." It allows the administrator to visualize the flow logs (via the Visualizer) to ensure no legitimate traffic would be dropped, before switching the toggle to Enforce Mode (Option B) which actually blocks the traffic.
NEW QUESTION # 81
An administrator received a report that users are being disconnected from their sessions consistently after IO minutes. The administrator suspects the gold image is incorrectly configured, Which action should the administrator take to resolve this issue?
  • A. Disable the monitor power saving settings.
  • B. Disable hard drive power saving settings.
  • C. Sysprep the gold image with the CopyProfile set to True.
  • D. Uninstall and remove the Windows Store applications.
gold image is a term used to describe a template for a virtual machine (VM) that contains a preconfigured operating system and applications1. A gold image can be used to create multiple session hosts that share the same configuration1. However, a gold image needs to be properly prepared before being used as a template123.
One of the steps involved in preparing a gold image is to run sysprep on the VM. Sysprep is a tool that removes system-specific data such as computer name, security identifier (SID), and driver cache from Windows23. This allows the VM to be generalized and duplicated without causing conflicts or errors23.
One of the options that can be set when running sysprep is CopyProfile. CopyProfile is a setting that determines whether the user profile settings of the built-in administrator account are copied to the default user profile2. The default user profile is used as a template for creating new user profiles on Windows2. If CopyProfile is set to True, then any changes made by the administrator account (such as desktop wallpaper, screen saver, Start menu items, etc.) will be applied to all new user profiles2.
Therefore, if users are being disconnected from their sessions consistently after 10 minutes, it could be because the gold image has some incorrect settings in the default user profile that cause session timeout or termination. To resolve this issue, one possible solution is to sysprep the gold image with CopyProfile set to True, and make sure that there are no settings in the administrator account that could affect session stability (such as power saving options or Windows Store applications)2.
NEW QUESTION # 82
What are two types Of Frame environment delivery models? (Choose two.)
  • A. Frame on Cisco LICS running VMware ESXi
  • B. BYO public cloud
  • C. Nutanix private cloud model running AHV
  • D. Frame on HP running Hyper-V.
Frame is a cloud-native desktop-as-a-service platform that allows you to deliver virtual desktops and applications from any cloud. Frame supports multiple public clouds, such as AWS, Azure, GCP, and Alibaba Cloud2. You can bring your own public cloud account and use Frame to provision and manage your virtual desktops on demand.
Frame also supports Nutanix private cloud model running AHV, which is a native hypervisor for Nutanix Enterprise Cloud Platform. You can use Frame to deliver virtual desktops and applications from your own data center using Nutanix AHV clusters3. You can benefit from the simplicity, scalability, and performance of Nutanix hyperconverged infrastructure.
NEW QUESTION # 83
An administrator has been evaluating a performance issue with the current Citrix VD' solution on Nutanix.
During the evaluation, the administrator finds out there is a feature that is enabled called Shadow Clones.
What would happen if an administrator disabled Shadow Clones within a company's VDI environment?
  • A. Boot storms would be eliminated because the number of desktops would be throttled.
  • B. Deployment times would increase as the number deployed desktops increase,
  • C. Boot storms would be eliminated due to desktop resource contention.
  • D. Deployment times would decrease when deploying additional desktops.
Nutanix's Shadow Clones feature is used to create linked clones or snapshots of base VMs, which can improve VM provisioning time and storage efficiency by reducing the amount of duplicated data.
If an administrator disables Shadow Clones within a company's VDI environment, it is likely that deployment times would increase as the number of deployed desktops increases. This is because linked clones or snapshots would no longer be used, so each new desktop deployment would require creating a full copy of the base VM.
Nutanix Shadow Clones allow for distributed caching of a particular disk or VM data, which are in a
'multi-reader' scenario. This can help in scenarios such as VDI or private clone boot storms, where VMs on multiple nodes read from the same set of base disks12
NEW QUESTION # 84
Due to a recent unprivileged access incident, an administrator needs to better protect critical applications by preventing lateral movement within the EUC environment.
Which Flow Network Security feature will accomplish this task?
  • A. Inbound policies
  • B. VM quarantine
  • C. Microsegmentation
  • D. Outbound policies
Microsegmentation is the specific functional capability within Nutanix Flow Network Security designed to control and restrict east-west traffic between virtual machines.
While traditional firewalls protect the perimeter (North-South), Microsegmentation applies stateful firewall policies directly to the vNIC of each VM. This allows an administrator to define granular rules that explicitly allow or deny traffic between individual VMs or groups of VMs (e.g., preventing a compromised VDI desktop from accessing a database server on the same subnet). This feature is the primary mechanism used to prevent lateral movement within the environment.
NEW QUESTION # 85
If you are craving for getting promotion in your company, you must master some special skills which no one can surpass you. To suit your demands, our company has launched the Nutanix Certified Professional - End User Computing (NCP-EUC) 6.10 Exam NCP-EUC exam materials especially for office workers. For on one hand, they are busy with their work, they have to get the Nutanix NCP-EUC Certification by the little spread time.
NCP-EUC Exam PDF: https://www.dumpexam.com/NCP-EUC-valid-torrent.html
DOWNLOAD the newest DumpExam NCP-EUC PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1D-PJE3MjUS835S1BPd-TNwUkpQZNUVGh
