[General] Latest Linux Foundation CKS Exam Online, New CKS Dumps Questions
【General】 Latest Linux Foundation CKS Exam Online, New CKS Dumps Questions
Posted at 4 hour before      View:22 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that TestKingFree CKS dumps now are free: https://drive.google.com/open?id=1Rz3Pcoe764TduVN-DoFI2X9HXNTO44At
Candidates all around the globe use their full potential only to get Linux Foundation CKS certification. Once the candidate is a Linux Foundation certified, he gets multiple good career opportunities in the Linux Foundation sector. To pass the CKS Certification Exam a candidate needs to be updated and reliable Certified Kubernetes Security Specialist (CKS) (CKS) prep material.
The CKS certification exam is a performance-based exam that assesses the candidate's ability to perform tasks related to securing a Kubernetes cluster. CKS exam covers a wide range of topics, including cluster hardening, network security, identity and access management, and container security. CKS exam is conducted online and is proctored, ensuring that the candidate's skills are evaluated fairly and accurately.
Linux Foundation CKS (Certified Kubernetes Security Specialist) Exam is a certification program designed to test and validate the knowledge and skills of professionals in Kubernetes security. Kubernetes is an open-source container orchestration platform that is widely used by organizations to manage their containerized applications. As Kubernetes grows in popularity, the need for professionals with expertise in securing Kubernetes environments has also increased.
Linux Foundation CKS preparation & CKS prep4sure torrentYou can take our Linux Foundation CKS practice exams (desktop and web-based) multiple times to gauge how well you've prepared for the real Linux Foundation CKS test. These CKS practice exams are designed specifically to help you identify your mistakes and attempt the real CKS examination successfully. You can continually enhance your Certified Kubernetes Security Specialist (CKS) (CKS) test preparation by overcoming your mistakes. Customers can check their prior CKS tests and give CKS practice exams multiple times to improve themselves for the final Linux Foundation CKS test.
Linux Foundation Certified Kubernetes Security Specialist (CKS) Sample Questions (Q22-Q27):NEW QUESTION # 22
You need to implement a container image vulnerability scanning solution within your Kubernetes cluster. You want to use an external vulnerability scanner API that provides information about vulnerabilities in container images- Explain how you would design and implement this solution.
Solution (Step by Step) :
1. choose Vulnerability Scanner:
- Select a reputable vulnerability scanner API that provides a comprehensive database and accurate information about container image vulnerabilities.
- Some options include Aqua Security, Anchore Engine, Snyk, Twistlock, and more.
- Choose a scanner with a suitable API interface for integration with your Kubernetes environment.
2. Implement a Scanner Service:
- Create a Kubernetes service that will communicate with your chosen vulnerability scanner API.
- This service will act as an intermediary between Kubernetes and the external scanner
- The service should be able to:
- Accept image details (registry, image name, tag) as input.
- Send requests to the scanner API to retrieve vulnerability information.
- Process the results from the scanner and format them for Kubernetes.
- (Optional) Store the scan results for future analysis and reporting.
3. Design Scanner Workflow:
- You can trigger scans using different methods:
- Automated Scanning: Implement a mechanism (e.g., a cron job or webhook triggered by image pushes) to automatically scan new images.
- On-Demand Scanning: Allow users to manually request image scans via a command line interface (CLI) or a user interface.
4. Integration with Kubernetes:
- You can integrate your scanner service with Kubernetes using several approaches:
- Admission Webh00k1 Use a wet)h00k to intercept pod creation or updates. The webh00k can send the image details to your scanner service and block pod creation if critical vulnerabilities are detected.
- Custom Resource Definitions (CRDs): Create CRDs to manage image scanning tasks- You can define a "ImageScan" or "Vulnerabilityscan" resource that represents a scan request.
- Deployment Controller: Use a custom controller or operator to manage the scanning process. This allows you to define rules for automatic scanning
and integrate with other Kubernetes resources.
5. Scanner Service Implementation (Example):
- Here's a simplified example using Python and a hypothetical "vulnerability-scanner" APC
python
import requests
import json
6. Handle Scan Results: - After scanning, process the vulnerability information received from the API. - You can: - Store the scan results in a database or log file. - Generate alerts or reports based on the severity of vulnerabilities found. - Integrate with other security tools or dashboards for analysis and remediation.
NEW QUESTION # 23
SIMULATION
Context
A default-deny NetworkPolicy avoids to accidentally expose a Pod in a namespace that doesn't have any other NetworkPolicy defined.
Task
Create a new default-deny NetworkPolicy named defaultdeny in the namespace testing for all traffic of type Egress.
The new NetworkPolicy must deny all Egress traffic in the namespace testing.
Apply the newly created default-deny NetworkPolicy to all Pods running in namespace testing.
See the Explanation below
NEW QUESTION # 24
SIMULATION
Before Making any changes build the Dockerfile with tag base:v1
Now Analyze and edit the given Dockerfile(based on ubuntu 16:04)
Fixing two instructions present in the file, Check from Security Aspect and Reduce Size point of view.
Dockerfile:
FROM ubuntu:latest
RUN apt-get update -y
RUN apt install nginx -y
COPY entrypoint.sh /
RUN useradd ubuntu
ENTRYPOINT ["/entrypoint.sh"]
USER ubuntu
entrypoint.sh
#!/bin/bash
echo "Hello from CKS"
After fixing the Dockerfile, build the docker-image with the tag base:v2 To Verify: Check the size of the image before and after the build.
  • A. Send us the Feedback on it.
NEW QUESTION # 25
SIMULATION
Task
Analyze and edit the given Dockerfile /home/candidate/KSSC00301/Docker file (based on the ubuntu:16.04 image), fixing two instructions present in the file that are prominent security/best-practice issues.
Analyze and edit the given manifest file /home/candidate/KSSC00301/deployment.yaml, fixing two fields present in the file that are prominent security/best-practice issues.
NEW QUESTION # 26
SIMULATION
Fix all issues via configuration and restart the affected components to ensure the new setting takes effect.
Fix all of the following violations that were found against the API server:- a. Ensure the --authorization-mode argument includes RBAC b. Ensure the --authorization-mode argument includes Node c. Ensure that the --profiling argument is set to false Fix all of the following violations that were found against the Kubelet:- a. Ensure the --anonymous-auth argument is set to false.
b. Ensure that the --authorization-mode argument is set to Webhook.
Fix all of the following violations that were found against the ETCD:-
a. Ensure that the --auto-tls argument is not set to true
Hint: Take the use of Tool Kube-Bench
API server:
Turn on Role Based Access Control. Role Based Access Control (RBAC) allows fine-grained control over the operations that different entities can perform on different objects in the cluster. It is recommended to use the RBAC authorization mode.
Fix - Buildtime
Kubernetes
apiVersion: v1
kind: Pod
metadata:
creationTimestamp: null
labels:
component: kube-apiserver
tier: control-plane
namespace: kube-system
spec:
containers:
- command:
+ - kube-apiserver
+ - --authorization-mode=RBAC,Node
image: gcr.io/google_containers/kube-apiserver-amd64:v1.6.0
livenessProbe:
failureThreshold: 8
httpGet:
host: 127.0.0.1
path: /healthz
port: 6443
scheme: HTTPS
initialDelaySeconds: 15
timeoutSeconds: 15
resources:
requests:
cpu: 250m
volumeMounts:
- mountPath: /etc/kubernetes/
readOnly: true
- mountPath: /etc/ssl/certs
- mountPath: /etc/pki
hostNetwork: true
volumes:
- hostPath:
path: /etc/kubernetes
- hostPath:
path: /etc/ssl/certs
- hostPath:
path: /etc/pki
Remediation: Edit the API server pod specification file /etc/kubernetes/manifests/kube-apiserver.yaml on the master node and set the --authorization-mode parameter to a value that includes Node.
--authorization-mode=Node,RBAC
Audit:
/bin/ps -ef | grep kube-apiserver | grep -v grep
Expected result:
'Node,RBAC' has 'Node'
Remediation: Edit the API server pod specification file /etc/kubernetes/manifests/kube-apiserver.yaml on the master node and set the below parameter.
--profiling=false
Audit:
Expected result:
'false' is equal to 'false'
Fix all of the following violations that were found against the Kubelet:- Ensure the --anonymous-auth argument is set to false.
Remediation: If using a Kubelet config file, edit the file to set authentication: anonymous: enabled to false. If using executable arguments, edit the kubelet service file /etc/systemd/system/kubelet.service.d/10-kubeadm.conf on each worker node and set the below parameter in KUBELET_SYSTEM_PODS_ARGS variable.
--anonymous-auth=false
Based on your system, restart the kubelet service. For example:
systemctl daemon-reload
systemctl restart kubelet.service
Audit:
/bin/ps -fC kubelet
Audit Config:
/bin/cat /var/lib/kubelet/config.yaml
Expected result:
2) Ensure that the --authorization-mode argument is set to Webhook.
Audit
docker inspect kubelet | jq -e '.[0].Args[] | match("--authorization-mode=Webhook").string' Returned Value: --authorization-mode=Webhook Fix all of the following violations that were found against the ETCD:- a. Ensure that the --auto-tls argument is not set to true Do not use self-signed certificates for TLS. etcd is a highly-available key value store used by Kubernetes deployments for persistent storage of all of its REST API objects. These objects are sensitive in nature and should not be available to unauthenticated clients. You should enable the client authentication via valid certificates to secure the access to the etcd service.
Fix - Buildtime
Kubernetes
apiVersion: v1
kind: Pod
metadata:
annotations:
scheduler.alpha.kubernetes.io/critical-pod: ""
labels:
component: etcd
tier: control-plane
spec:
containers:
- command:
+ - etcd
+ - --auto-tls=true
image: k8s.gcr.io/etcd-amd64:3.2.18
imagePullPolicy: IfNotPresent
livenessProbe:
exec:
command:
- /bin/sh
- -ec
- ETCDCTL_API=3 etcdctl --endpoints=https://[192.168.22.9]:2379 --cacert=/etc/kubernetes/pki/etcd/ca.crt
--cert=/etc/kubernetes/pki/etcd/healthcheck-client.crt --key=/etc/kubernetes/pki/etcd/healthcheck-client.key get foo failureThreshold: 8 initialDelaySeconds: 15 timeoutSeconds: 15 name: etcd-should-fail resources: {} volumeMounts:
- mountPath: /var/lib/etcd
- mountPath: /etc/kubernetes/pki/etcd
hostNetwork: true
priorityClassName: system-cluster-critical
volumes:
- hostPath:
path: /var/lib/etcd
type: DirectoryOrCreate
- hostPath:
path: /etc/kubernetes/pki/etcd
status: {}
NEW QUESTION # 27
We are so sincere to provide a free trial version of our CKS exam questions for you, just want you to find the best product for your own. We hope that you are making a choice based on understanding our CKS study braindumps. And you will find that our CKS training materials are so popular for their special advantages. Not only the content is always the latest, but also the displays are design carefully to cater to all kinds of study conditions. We will respect your decision. And our CKS learning guide really wants to be your long-term partner.
New CKS Dumps Questions: https://www.testkingfree.com/Linux-Foundation/CKS-practice-exam-dumps.html
P.S. Free & New CKS dumps are available on Google Drive shared by TestKingFree: https://drive.google.com/open?id=1Rz3Pcoe764TduVN-DoFI2X9HXNTO44At
