[General] Valid SPLK-3002 Exam Vce | SPLK-3002 Dumps Torrent
【General】 Valid SPLK-3002 Exam Vce | SPLK-3002 Dumps Torrent
Posted at 4 hour before      View:18 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that TroytecDumps SPLK-3002 dumps now are free: https://drive.google.com/open?id=1MhCGxFX2KkRwebu1oQWuveVOS14bT9jo
These Splunk SPLK-3002 updated dumps are launched in the market after suggestions from experienced professionals. Therefore, this Splunk SPLK-3002 exam study material is kept to the point and concise. The Splunk SPLK-3002 practice material for Exams. Choice are essential for your successful learning. Often applicants for the exam run on a tight daily schedule before the final Splunk SPLK-3002 Exam, so actual Splunk IT Service Intelligence Certified Admin exam questions are fruitful to prepare successfully on the first try.
The Splunk SPLK-3002 Exam focuses on evaluating the candidates' knowledge and skills in configuring and managing ITSI core components, including Service Analyzers, Glass Tables, Notable Events, and KPI-based alerts. Candidates will also be required to demonstrate their capacity to customize ITSI with advanced configurations, such as machine learning techniques, anomaly detection, and correlating events. By earning the Splunk IT Service Intelligence Certified Admin certification, IT professionals can establish themselves as experts in Splunk ITSI administration and contribute to their organizations' IT service management success.
Valid SPLK-3002 Exam Vce | Reliable SPLK-3002 Dumps Torrent: Splunk IT Service Intelligence Certified AdminWith so many methods can boost individual competitiveness, people may be confused, which can really bring them a glamorous work or brighter future? We are here to tell you that a SPLK-3002 certification definitively has everything to gain and nothing to lose for everyone. You might have seen lots of advertisements about SPLK-3002 learning question, there are so many types of SPLK-3002 exam material in the market, why you should choose us? Our reasons are as follow. Our SPLK-3002 test guide is test-oriented, which makes the preparation become highly efficient.
Splunk IT Service Intelligence Certified Admin Sample Questions (Q69-Q74):NEW QUESTION # 69
In distributed search, which components need to be installed on instances other than the search head?
  • A. SA-IndexCreation and SA-ITSI-Licensechecker on indexers.
  • B. SA-IndexCreation on idexers; SA-ITSI-Licensechecker and SA-UserAccess on the license master.
  • C. SA-ITSI-Licensechecker on indexers.
  • D. SA-IndexCreation and SA-ITOA on indexers; SA-ITSI-Licensechecker and SA-UserAccess on the license master.
SA-IndexCreation is required on all indexers. For non-clustered, distributed environments, copy SA- IndexCreation to $SPLUNK_HOME/etc/apps/ on individual indexers.
Reference: https://docs.splunk.com/Document ... 2/Install/InstallDD In distributed search, the components that need to be installed on instances other than the search head are SA- IndexCreation and SA-ITSI-Licensechecker on indexers. SA-IndexCreation is an add-on that creates the indexes required by ITSI, such as itsi_summary and itsi_tracked_alerts. SA-ITSI-Licensechecker is an add-on that monitors the license usage of ITSI and generates alerts when the license limit is exceeded or about to expire. These components need to be installed on indexers because they handle the data ingestion and storage functions for ITSI. The other components, such as ITSI app and SA-ITOA, need to be installed on the search head(s) because they handle the search management and presentation functions for ITSI. References: Install IT Service Intelligence in a distributed environment
NEW QUESTION # 70
What are valid ITSI Glass Table editor capabilities? (Choose all that apply.)
  • A. Correlation search creation.
  • B. Creating glass tables.
  • C. Service swapping configuration.
  • D. Adding KPI metric lanes to glass tables.
Answer: B,C,D
Create a glass table to visualize and monitor the interrelationships and dependencies across your IT and business services.
The service swapping settings are saved and apply the next time you open the glass table.
You can add metrics like KPIs, ad hoc searches, and service health scores that update in real time against a background that you design. Glass tables show real-time data generated by KPIs and services.
NEW QUESTION # 71
Which of the following is a good use case for a Multi-KPI alert?
  • A. Alerting when comparing the values of two or more KPIs indicates an unusual condition is occurring.
  • B. Alerting when the trend of two or more KPIs indicates service failure is imminent.
  • C. Alerting when the values of two or more KPIs go into maintenance mode.
  • D. Alerting when two or more KPIs are deviating from their typical pattern.
A Multi-KPI alert in Splunk IT Service Intelligence (ITSI) is designed to trigger based on the conditions of multiple Key Performance Indicators (KPIs). This type of alert is particularly useful when a single KPI's state is not sufficient to indicate an issue, but the correlation between multiple KPIs can provide a clearer picture of an emerging problem. The best use case for a Multi-KPI alert is therefore when comparing the values of two or more KPIs indicates an unusual condition is occurring. This allows for more nuanced and context-rich alerting mechanisms that can identify complex issues not detectable by monitoring individual KPIs. This approach is beneficial in complex environments where the interplay between different performance metrics needs to be considered to accurately detect and diagnose issues.
NEW QUESTION # 72
Besides creating notable events, what are the default alert actions a correlation search can execute? (Choose all that apply.)
  • A. Include in RSS feed.
  • B. Run a script.
  • C. Ping a host.
  • D. Send email.
Answer: A,B,D
Throttling applies to any correlation search alert type, including notable events and actions (RSS feed, email, run script, and ticketing).
Reference: https://docs.splunk.com/Documentation/ITSI/4.10.2/EA/ConfigCS B, C, and D are correct answers because they are the default alert actions that a correlation search can execute besides creating notable events. You can configure a correlation search to send an email, include the results in an RSS feed, or run a custom script when the search matches a defined pattern. Ping a host is not a default alert action for correlation searches. References: Configure correlation search settings in ITSI
NEW QUESTION # 73
When creating a custom deep dive, what color are services/KPIs in maintenance mode within the topology view?
  • A. Gray
  • B. Purple
  • C. Gear Icon
  • D. Blue
When creating a custom deep dive, services or KPIs that are in maintenance mode are shown in gray color in the topology view. This indicates that they are not actively monitored and do not generate alerts or notable events. Reference: Deep Dives
NEW QUESTION # 74
Latest Splunk SPLK-3002 Dumps are here to help you to pass your Splunk Certification exam with TroytecDumps' valid, real, and updated SPLK-3002 Exam Questions with passing guarantee. The Splunk SPLK-3002 certification is a valuable certificate that is designed to advance the professional career. With the Splunk IT Service Intelligence Certified Admin (SPLK-3002) certification exam seasonal professionals and beginners get an opportunity to demonstrate their expertise. The Splunk IT Service Intelligence Certified Admin exam recognizes successful candidates in the market and provides solid proof of their expertise.
SPLK-3002 Dumps Torrent: https://www.troytecdumps.com/SPLK-3002-troytec-exam-dumps.html
DOWNLOAD the newest TroytecDumps SPLK-3002 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1MhCGxFX2KkRwebu1oQWuveVOS14bT9jo
