[General] Oracle 1z0-809 Questions: Tips to Get Results Effortlessly [2026]
【General】 Oracle 1z0-809 Questions: Tips to Get Results Effortlessly [2026]
Posted at yesterday 20:03      View:17 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of ActualCollection 1z0-809 dumps from Cloud Storage: https://drive.google.com/open?id=1AHKyf4oq-hn5UHivjio3iJ3ENMlUbk_P
Good product can was welcomed by many users, because they are the most effective learning tool, to help users in the shortest possible time to master enough knowledge points, so as to pass the qualification test, and our 1z0-809 study materials have always been synonymous with excellence. Our 1z0-809 Study Materials can help users achieve their goals easily, regardless of whether you want to pass various qualifying examinations, our products can provide you with the learning materials you want.
Oracle 1z0-809 exam, also known as the Java SE 8 Programmer II exam, is designed to test the knowledge and skills of Java programmers who have experience with the Java programming language and the Java SE 8 platform. 1z0-809 exam is the second of two exams required to become an Oracle Certified Professional, Java SE 8 Programmer. It is intended for developers who have a strong foundation in Java and want to demonstrate their proficiency in advanced Java programming concepts and techniques.
The Oracle 1z0-809 Exam is intended for professionals who have already obtained the Oracle Certified Associate (OCA) certification and are interested in advancing their career in the field of Java development. It is also suitable for those with basic knowledge and experience in Java programming who want to improve their skills and knowledge of the language.
New 1z0-809 Exam Sample & VCE 1z0-809 DumpsIf you can own the 1z0-809 certification means that you can do the job well in the area so you can get easy and quick promotion. The latest 1z0-809 quiz torrent can directly lead you to the success of your career. Our materials can simulate real operation exam atmosphere and simulate exams. The download and install set no limits for the amount of the computers and the persons who use 1z0-809 Test Prep. So we provide the best service for you as you can choose the most suitable learning methods to master the 1z0-809 exam torrent. Believe us and buy our 1z0-809 exam questions.
Oracle Java SE 8 Programmer II Sample Questions (Q73-Q78):NEW QUESTION # 73
Given:
and the command:
java Product 0
What is the result?
  • A. A NumberFormatException is thrown at run time.
  • B. New Price: 0.0
  • C. A compilation error occurs at line n1.
  • D. An AssertionError is thrown.
NEW QUESTION # 74
Given the code fragments:
interface CourseFilter extends Predicate<String> {
public default boolean test (String str) {
return str.equals ("Java");
and
List<String> strs = Arrays.asList("Java", "Java EE", "Java ME");
Predicate<String> cf1 = s - > s.length() > 3;
Predicate cf2 = new CourseFilter() { //line n1
public boolean test (String s) {
return s.contains ("Java");
long c = strs.stream()
.filter(cf1)
.filter(cf2//line n2
.count();
System.out.println(c);
What is the result?
  • A. 0
  • B. A compilation error occurs at line n1.
  • C. 1
  • D. A compilation error occurs at line n2.
NEW QUESTION # 75
Given:
public class Test<T> {
private T t;
public T get () {
return t;
public void set (T t) {
this.t = t;
public static void main (String args [ ] ) {
Test<String> type = new Test<>();
Test type 1 = new Test ();//line n1
type.set("Java");
type1.set(100);//line n2
System.out.print(type.get() + " " + type1.get());
What is the result?
  • A. A compilation error occurs. To rectify it, replace line n2 with:
    type1.set (Integer(100));
  • B. Java 100
  • C. java.lang.string@<hashcode>java.lang.Integer@<hashcode>
  • D. A compilation error occurs. To rectify it, replace line n1 with:
    Test<Integer> type1 = new Test<>();
NEW QUESTION # 76
Assume customers.txt is accessible and contains multiple lines.
Which code fragment prints the contents of the customers.txt file?
  • A. Stream<ath> stream = Files.list (Paths.get ("customers.txt")); stream.forEach( c) -> System.out.println(c));
  • B. Stream<String> stream = Files.find (Paths.get ("customers.txt")); stream.forEach((String c) -> System.out.println(c));
  • C. Stream<String> lines = Files.lines (Paths.get ("customers.txt")); lines.forEach( c) -> System.out.println(c));
  • D. Stream<ath> stream = Files.find (Paths.get ("customers.txt")); stream.forEach( c) -> System.out.println(c));
NEW QUESTION # 77
Given the content of the employee.txtfile:
Every worker is a master.
Given that the employee.txtfile is accessible and the file allemp.txtdoes NOT exist, and the code fragment:
What is the result?
  • A. allemp.txt is created and the content of employee.txt is copied to it.
  • B. Exception 2
  • C. The program executes, does NOT affect the system, and produces NO output.
  • D. Exception 1
NEW QUESTION # 78
With our customer-oriented 1z0-809 actual question, you can be one of the former exam candidates with passing rate up to 98 to 100 percent. You will pay just a small amount of money on our 1z0-809 exam guide but harvest colossal success with potential bright future. And we have confidence that your future aims will come along with this successful exam as the beginning. So choosing 1z0-809 actual question is choosing success.
New 1z0-809 Exam Sample: https://www.actualcollection.com/1z0-809-exam-questions.html
BONUS!!! Download part of ActualCollection 1z0-809 dumps for free: https://drive.google.com/open?id=1AHKyf4oq-hn5UHivjio3iJ3ENMlUbk_P
