[General] 新版Cloud-Digital-Leader題庫上線 - Cloud-Digital-Leader資料
【General】 新版Cloud-Digital-Leader題庫上線 - Cloud-Digital-Leader資料
Posted at yesterday 22:07      View:21 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! 免費下載KaoGuTi Cloud-Digital-Leader考試題庫的完整版:https://drive.google.com/open?id=1gDS1UUFiKtnOqt7MLDyEM0qXkj49mBYZ
如果你已經決定通過Google的Cloud-Digital-Leader考試,KaoGuTi在這裏,可以幫助你實現你的目標,我們更懂得你需要通過你的Google的Cloud-Digital-Leader考試,我們承諾是為你高品質的考古題,科學的考試,過KaoGuTi的Google的Cloud-Digital-Leader考試。
考試涵蓋了廣泛的主題,包括雲計算概念、數字化轉型策略、數據分析和機器學習。考試旨在測試使用Google Cloud技術領導數字化轉型倡議所需的知識和技能。這是一個全面的考試,需要深入了解雲計算和數字化轉型。
專業的新版Cloud-Digital-Leader題庫上線,高質量的考試題庫幫助妳快速通過Cloud-Digital-Leader考試KaoGuTi的Cloud-Digital-Leader考古題和實際的認證考試一樣,不僅包含了實際考試中的所有問題,而且考古題的軟體版完全類比了真實考試的氛圍。使用了KaoGuTi的考古題,你在參加考試時完全可以應付自如,輕鬆地獲得高分。
最新的 Google Cloud Certified Cloud-Digital-Leader 免費考試真題 (Q72-Q77):問題 #72
A customer has a tens of applications that are dependent on Oracle databases in their on-premise data centers.
The customer wants to migrate to Google Cloud. Their long term goal is to move to other cloud native database technologies. What options do they have to initially move their data?
  • A. Containerize Oracle and run it using Cloud Run.
  • B. Since there is no hosted Oracle solution, leave the Oracle data on-premise while doing analytics on Google Cloud.
  • C. Migrate to Cloud SQL.
  • D. Migrate to a Bare Metal server.
答案:C
解題說明:
The Bare Metal solution is the recommended approach. You can deploy Oracle capabilities like clustered databases, replication, and all performance features at licensing costs that are similar to on-premise systems
https://cloud.google.com/archite ... are-metal-workloads
問題 #73
Which of the following NIST Cloud characteristics uses the business model of shared re-sources in a cloud environment?
  • A. Elasticity
  • B. Broad Network Access
  • C. Availability
  • D. Multi-Tenancy
答案:D
解題說明:
In cloud computing, multitenancy means that multiple customers of a cloud vendor are using the same computing resources. Even though they share resources, cloud customers aren't aware of each other, and their data is kept totally separate. Mul-titenancy is a crucial component of cloud computing; without it, cloud services would be far less practical. Multitenant architecture is a feature in many types of public cloud com-puting, including IaaS, PaaS, SaaS, containers, and serverless computing.
問題 #74
You have a well established development and operations team. Your teams were managing the en-tire software delivery/deployment cycle on-premise. When migrating to the cloud, you want to con-tinue having this approach. Which is the ideal option for you?
  • A. SaaS - Software as a Service
  • B. PaaS - Platform as a Service
  • C. IaaS - Infrastructure as a Service
  • D. IDaaS - Identity as a Service
答案:C
解題說明:
IaaS - you're given virtualized resources like VMs, Storage, Network. It is your responsibility to manage everything beyond that. This would be similar to what the organization had on-premise.
問題 #75
A prospect wants to be able to store and analyze dat
a. Their analysts already know SQL, but are not familiar with other technologies. Which of these databases can the analysts use without addi-tional training?
  • A. Cloud SQL, Bigtable, BigQuery
  • B. Cloud SQL, BigQuery, Datastore
  • C. Cloud SQL, Firestore, Datastore
  • D. Spanner, Cloud SQL, BigQuery
答案:D
解題說明:
Spanner- Cloud Spanner is a fully managed, mission-critical, relational database service that offers transactional consistency at global scale, automatic, synchronous replication for high availability, and support for two SQL Google Standard SQL and PostgreSQL.
Cloud SQL- Cloud SQL is a fully-managed database service that helps you set up, maintain, manage, and administer your relational databases on Google Cloud Platform.
BigQuery- Google BigQuery is a cloud-based Architecture and provides exceptional performance as it can auto-scale up and down based on the data load and performs data analysis efficiently. On the other hand, SQL Server is based on client-server architecture and has fixed performance throughout unless the user scales it manually.
問題 #76
A customer in the European Union region is very clear that their data should not go outside the Eu-ropean Union. Their end users are spread all over the European U. They have to choose a storage option that serves all the users within Asia via web browsers as quickly as possible. Which storage option will work for them?
  • A. Cloud Filestore is connected to virtual machines which are guaranteed to be within the European U
  • B. Cloud Storage with the dual-region option of European U
  • C. Cloud Storage with the multi-region option of European U
  • D. Cloud Storage with a single region that is known to be within the European U
答案:C
解題說明:
Multi-region option will use multiple datacenters that are within the European Union. More regions will also help with lower latency since users are spread across the European U.
https://cloud.google.com/storage/docs/locations#considerations
問題 #77
KaoGuTi為通過Cloud-Digital-Leader考試提供最完整有效的方案,幫祝廣大考生在考試中獲得更多的優勢。確保你只獲得最新的和最有效的Google Cloud-Digital-Leader考古題,我們也希望客戶能隨時隨地的訪問,于是有了多個版本的題庫資料。PDF版的題庫方便你閱讀,為你真實地再現Cloud-Digital-Leader考試題目,軟件版本的題庫作為一個測試引擎,可以幫你模擬真實的Cloud-Digital-Leader考試環境,為考生做好充足的考前準備。通過Google Cloud-Digital-Leader考試不再是夢想,我們的考古題就可以確保你成功。
Cloud-Digital-Leader資料: https://www.kaoguti.com/Cloud-Digital-Leader_exam-pdf.html
在這個什麼都不斷上漲除了工資不上漲的年代裏,難道你不想突破自己嗎,讓工資翻倍,這也不是不可能,只要通過Google的Cloud-Digital-Leader考試認證,你將會得到你想要的,而KaoGuTi將會為你提供最好的培訓資料,讓你安心的通過考試並獲得認證,它的通過率達到100%,讓你不得不驚歎,這確實是真的,不用懷疑,不用考慮,馬上就行動吧,KaoGuTi是一個能為很多參加Google Cloud-Digital-Leader認證考試的IT行業專業人士提供相關輔導資料來幫助他們拿到Google Cloud-Digital-Leader認證證書的網站,最近,參加 Google Cloud Digital Leader 考試認證的人比較多,KaoGuTi為了幫助大家通過認證,正在盡最大努力為廣大考生提供具備較高的速度和效率的服務,以節省你的寶貴時間,Cloud-Digital-Leader 考試題庫就是這樣的考試指南,它是由我們專業IT認證講師及產品專家精心打造,包括考古題及答案,比如說:選擇練習的Cloud-Digital-Leader問題集和Cloud-Digital-Leader考試關聯性不大。
切,妳特麽找死,這超脫者是好是壞,都沒太大的關系,在這個什麼都不斷上漲除了工資不上漲的年代裏,難道你不想突破自己嗎,讓工資翻倍,這也不是不可能,只要通過Google的Cloud-Digital-Leader考試認證,你將會得到你想要的,而KaoGuTi將會為你提供最Cloud-Digital-Leader好的培訓資料,讓你安心的通過考試並獲得認證,它的通過率達到100%,讓你不得不驚歎,這確實是真的,不用懷疑,不用考慮,馬上就行動吧。
免費下載新版Cloud-Digital-Leader題庫上線和資格考試與專業人士Cloud-Digital-Leader資料的領導者KaoGuTi是一個能為很多參加Google Cloud-Digital-Leader認證考試的IT行業專業人士提供相關輔導資料來幫助他們拿到Google Cloud-Digital-Leader認證證書的網站,最近,參加 Google Cloud Digital Leader 考試認證的人比較多,KaoGuTi為了幫助大家通過認證,正在盡最大努力為廣大考生提供具備較高的速度和效率的服務,以節省你的寶貴時間,Cloud-Digital-Leader 考試題庫就是這樣的考試指南,它是由我們專業IT認證講師及產品專家精心打造,包括考古題及答案。
比如說:選擇練習的Cloud-Digital-Leader問題集和Cloud-Digital-Leader考試關聯性不大,我們KaoGuTi培訓資料可以測試你在準備考試時的知識,也可以評估在約定的時間內你的表現。
2026 KaoGuTi最新的Cloud-Digital-Leader PDF版考試題庫和Cloud-Digital-Leader考試問題和答案免費分享:https://drive.google.com/open?id=1gDS1UUFiKtnOqt7MLDyEM0qXkj49mBYZ
