[General] Fortinet FCSS_NST_SE-7.6 Download Fee, Exam FCSS_NST_SE-7.6 Study Solutions
100
【General】 Fortinet FCSS_NST_SE-7.6 Download Fee, Exam FCSS_NST_SE-7.6 Study Solutions
Posted at 3/6/2026 00:19:13      View:123 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Fortinet FCSS_NST_SE-7.6 dumps are available on Google Drive shared by RealVCE: https://drive.google.com/open?id=1Z-CpqTiN7N5mMSFteuOqqtzlf9g2dw_U
Our FCSS_NST_SE-7.6 training materials have won great success in the market. Tens of thousands of the candidates are learning on our FCSS_NST_SE-7.6 practice engine. First of all, our FCSS_NST_SE-7.6 study dumps cover all related tests about computers. It will be easy for you to find your prepared learning material. If you are suspicious of our FCSS_NST_SE-7.6 Exam Questions, you can download the free demo from our official websites.
Fortinet FCSS_NST_SE-7.6 Exam Syllabus Topics:
  • Security profiles: This part measures skills of Security Operations Specialists and covers identifying and resolving problems linked to FortiGuard services, web filtering configurations, and intrusion prevention systems to maintain protection across network environments.
  • Routing: This section focuses on Network Engineers and involves tackling issues related to packet routing using static routes, as well as OSPF and BGP protocols to support enterprise network traffic flow.
  • VPN: This section is aimed at IT Professionals and includes diagnosing and addressing issues with IPsec VPNs, specifically IKE version 1 and 2, to secure remote and site-to-site connections within the network infrastructure.
  • Authentication: This section evaluates the abilities of System Administrators and requires troubleshooting both local and remote authentication methods, including resolving Fortinet Single Sign-On (FSSO) problems for secure network access.
Topic 5
  • System troubleshooting: This section of the exam measures the skills of Network Security Support Engineers and addresses diagnosing and correcting issues within Security Fabric setups, automation stitches, resource utilization, general connectivity, and different operation modes in FortiGate HA clusters. Candidates work with built-in tools to effectively find and resolve faults.
Exam Fortinet FCSS_NST_SE-7.6 Study Solutions | FCSS_NST_SE-7.6 Reliable Exam TipsWe have created a number of reports and learning functions for evaluating your proficiency for the FCSS - Network Security 7.6 Support Engineer (FCSS_NST_SE-7.6) exam dumps. In preparation, you can optimize FCSS - Network Security 7.6 Support Engineer (FCSS_NST_SE-7.6) practice exam time and question type by utilizing our Fortinet FCSS_NST_SE-7.6 Practice Test software. RealVCE makes it easy to download Fortinet FCSS_NST_SE-7.6 exam questions immediately after purchase. You will receive a registration code and download instructions via email.
Fortinet FCSS - Network Security 7.6 Support Engineer Sample Questions (Q45-Q50):NEW QUESTION # 45
An administrator wants to capture encrypted phase 2 traffic between two FotiGate devices using the built-in sniffer.
If the administrator knows that there Is no NAT device located between both FortiGate devices, which command should the administrator run?
  • A. diagnose sniffer packet any 'udp port 4500'
  • B. diagnose sniffer packet any 'udp port 500'
  • C. diagnose sniffer packet any 'lp proto 50'
  • D. diagnose sniffer packet any 'ah'
To capture encrypted IPsec phase 2 (ESP) traffic between two FortiGate devices, the correct protocol filter to use is ip proto 50. According to the Fortinet official sniffing and debugging documentation, ESP (Encapsulating Security Payload) is used for encrypted phase 2 payload transfer and always uses IP protocol number 50. Running the command diagnose sniffer packet any 'ip proto 50' captures only ESP packets, which represent the encrypted traffic-whether originating or transiting the device.
If there is no NAT device between FortiGates, ESP is not encapsulated in UDP (thus not on UDP port 4500; if NAT-T were required, packets would be UDP-encapsulated, but the scenario explicitly says NAT is not in use). UDP port 500 is for IKE control (negotiation) traffic, and AH (Authentication Header, ip proto 51) is not used for encryption in standard IPsec phase 2 with ESP.
This matches the official CLI reference from Fortinet for VPN and traffic analysis.
FortiOS CLI Reference: diagnose sniffer packet, ESP, IP Protocol Numbers FortiGate VPN Administration Guide: Traffic Capture and Analysis of IPsec Traffic
NEW QUESTION # 46
Refer to the exhibit, which shows the output of a debug command.
Which two statements about the output are true? (Choose two.)
  • A. In the network connected to port4, two OSPF routers are down.
  • B. One of the neighbors has a router ID of 0.0.0.4.
  • C. There are a total of five OSPF routers attached to the vorz4 network segment
  • D. The interlace is part of the OSPF backbone area.
FortiOS Admin Guide: OSPF, Debug Outputs
NEW QUESTION # 47
Refer to the exhibit, which shows a partial output from the get router info routing-table database command.
The administrator wants to configure a default static route for port3 and assign a distance of 50 and a priority of 0.
What will happen to the port1 and port2 default static routes after the port3 default static route is created?
  • A. Both default static routes shown in the output will be injected into the FIB.
  • B. The port2 default static route will be injected into the forwarding information base (FIB).
  • C. Neither of the routes shown in the output will be injected into the FIB.
  • D. The port1 default static route will be injected into the FIB.
NEW QUESTION # 48
The output of a BGO debug command is shown.
What is the most likely reason that the local FortiGate is not receiving any prefixes from its neighbors?
  • A. The RIB-OUT configuration for router 10.127.0.75 prevents any route advertisement to the local router.
  • B. None of the three neighbors has successfully established the TCP three-way handshake with the local router.
  • C. The router 100.64.3.1 is waiting for the OPEN message from the local router.
  • D. The local router is waiting for the keepalive message from the router 10.125.0.60.
To identify the reason for the lack of prefixes, we must interpret the State/PfxRcd and Up/Down columns in the get router info bgp summary exhibit.
Analyze Neighbor Status:
Neighbor 10.125.0.60: State is OpenSent. This session is not established. It is stuck in the negotiation phase.
Neighbor 100.64.3.1: State is Active. This session is not established. The router is actively trying to initiate a TCP connection.
Neighbor 10.127.0.75:
Up/Down: 02:45:55. This indicates the BGP session has been Up (Established) for almost 3 hours.
State/PfxRcd: 0. This number represents the count of prefixes received. The session is fully established, but the neighbor has sent zero routes.
Determine the Cause:
Since the session with 10.127.0.75 is established, connectivity and handshakes (Options A, B, C) are not the issue for this neighbor.
The fact that it is Up but sending 0 prefixes strongly implies that the neighbor is configured to filter out its routes before sending them to the local FortiGate.
Option D correctly identifies this as a RIB-OUT (Routing Information Base - Outbound) configuration issue on the neighbor (Router 10.127.0.75), which prevents it from advertising its routes.
FortiGate Security 7.6 Study Guide (BGP): "In the BGP summary, if the State/PfxRcd shows a number (e.g.,
0), the session is Established. A value of 0 means the peering is up, but no routes have been received, often due to route-map or prefix-list filtering on the remote peer."
NEW QUESTION # 49
Exhibit.
Refer to the exhibit, which shows the output of a diagnose command.
What can you conclude about the debug output in this scenario?
  • A. FortiGate used 64.26.151.37 as the initial server to validate its contract.
  • B. The first server provided to FortiGate when it performed a DNS query looking for a list of rating servers, was 121.111.236.179.
  • C. There is a natural correlation between the value in the FortiGuard-requests field and the value in the Weight field.
  • D. Servers with a negative TZ value are less preferred for rating requests.
The exhibit displays the output from the diagnose debug rating command on a FortiGate device. This command is used to display information about FortiGuard Web Filtering or other security-related queries performed by FortiGate to FortiGuard servers. Official Fortinet documentation outlines the meaning of each field in the server list. The FortiGate maintains a list of available FortiGuard servers, selecting the optimal server based on factors such as weight, round-trip time (RTT), and regional settings.
The very first entry in the server list after "Server List" is the server FortiGate initially uses, prioritized by factors such as proximity and RTT. Here, 64.26.151.37 is listed first, and the FortiGuard-requests value confirms that this server handled the highest number of requests.
The IPs, weights, and lost/failed counters are monitored for server performance and selection over time.
FortiGate's default operational logic is to try the first entry for contract validation and use the next in the list if the first is unavailable or has high latency or packet loss.
There is no direct correlation between the Weight and the number of FortiGuard-requests. The servers with higher or lower weights may still handle different request volumes based on availability and performance.
The TZ (time zone) value's sign (positive or negative) does not affect server preference; it is informational, showing the server's location relative to UTC, not a rating metric.
DNS query results for FortiGuard servers are not shown here, and the provided servers are not returned in DNS query order.
This command and interpretation are detailed in the FortiOS Administration Guide's section describing FortiGuard server selection and contract validation processes.
FortiOS Administration Guide: FortiGuard Service Connectivity and Debugging Official Technical Notes on diagnose debug rating output structure
NEW QUESTION # 50
At the RealVCE offer students Fortinet FCSS_NST_SE-7.6 practice test questions, and 24/7 support to ensure they do comprehensive preparation for the FCSS - Network Security 7.6 Support Engineer (FCSS_NST_SE-7.6) exam. RealVCE FCSS - Network Security 7.6 Support Engineer (FCSS_NST_SE-7.6) practice test material covers all the key topics and areas of knowledge necessary to master the Fortinet Certification Exam.
Exam FCSS_NST_SE-7.6 Study Solutions: https://www.realvce.com/FCSS_NST_SE-7.6_free-dumps.html
P.S. Free & New FCSS_NST_SE-7.6 dumps are available on Google Drive shared by RealVCE: https://drive.google.com/open?id=1Z-CpqTiN7N5mMSFteuOqqtzlf9g2dw_U
