[General] MB-335 Sample Questions Pdf & MB-335 Reliable Exam Prep
111
【General】 MB-335 Sample Questions Pdf & MB-335 Reliable Exam Prep
Posted at 3/6/2026 02:14:37      View:114 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of ExamTorrent MB-335 dumps from Cloud Storage: https://drive.google.com/open?id=1lOtRuKsJZEepgASnocdL6BltV05HkwAZ
The Microsoft Dynamics 365 Supply Chain Management Functional Consultant Expert (MB-335) Exam Questions offered by ExamTorrent provide you with a good idea of what you can expect in the MB-335 exam from Microsoft. All the MB-335 exam topics and objectives are well covered by our product. Thus, ExamTorrent Microsoft MB-335 Practice Questions are considered a very good resource that will help you in your practicing by focusing on your weak points and strengthening them to easily pass the MB-335 exam.
Our MB-335 quiz torrent can provide you with a free trial version, thus helping you have a deeper understanding about our MB-335 test prep and estimating whether this kind of study material is suitable to you or not before purchasing. With the help of our trial version, you will have a closer understanding about our MB-335 Exam Torrent from different aspects, ranging from choice of three different versions available on our test platform to our after-sales service. In a word, you can communicate with us about MB-335 test prep without doubt, and we will always be there to help you with enthusiasm.
Pass Guaranteed 2026 Microsoft MB-335: Microsoft Dynamics 365 Supply Chain Management Functional Consultant Expert –Valid Sample Questions PdfExamTorrent online digital Microsoft MB-335 exam questions are the best way to prepare. Using our Microsoft MB-335 exam dumps, you will not have to worry about whatever topics you need to master. To practice for a Microsoft MB-335 Certification Exam in the ExamTorrent (free test), you should perform a self-assessment. The MB-335 practice test ExamTorrent keeps track of each previous attempt and highlights the improvements with each attempt.
Microsoft Dynamics 365 Supply Chain Management Functional Consultant Expert Sample Questions (Q25-Q30):NEW QUESTION # 25
A company uses Asset management in Dynamics 365 Supply Cham Management. The company also uses Dynamics 365 Guides independently of the Dynamics 365 Supply Chain Management implementation.
Maintenance workers requite a checklist template to complete work orders. A solution must help the workers through work order steps. The solution must use Dynamics 365 Guides with Dynamics 365 Supply Chain Management.
You need to integrate the solution.
NEW QUESTION # 26
You are a production manager at a company which produces large batches of coffee and creamers.
After a quality inspection, batch 120008 of your cold brew coffee (item number CB-0001) was found to be too acidic and must be reworked.
You need to add 20 grams of sugar and stir the product for an additional 0.S hours.
What three actions are required on the rework order? Each correct answer presents pan of the solution.
  • A. Delete all route operations except for a half an hour stirring operation.
  • B. Add 20 grams of sugar to the production formula.
  • C. Delete all items from the production formula except for 20 grams of sugar.
  • D. Add a route operation for 0.5 run time hours of stirring.
  • E. Manually reserve batch 120008 after estimating the batch order.
Answer: A,B,D
The correct answer is B, C, and E. Here is the explanation:
To rework a batch order in Dynamics 365 Supply Chain Management, you need to create a new batch order and set the Rework batch toggle to Yes1. You also need to select the Batch number of the original batch that needs to be reworked1. The new batch order will have only one formula line that represents the original batch, and no route operations1.
To add 20 grams of sugar and stir the product for an additional 0.5 hours, you need to do the following actions on the rework order:
Add 20 grams of sugar to the production formula. You can do this by clicking on the Formula option on the All production orders form and adding a new formula line for sugar with a quantity of 20 grams1. You can also specify the ingredient type for sugar, such as Compensating or Filler2.
Add a route operation for 0.5 run time hours of stirring. You can do this by clicking on the Route option on the All production orders form and adding a new route operation for stirring with a run time of 0.5 hours1. You can also specify the resource or resource group that will perform the stirring operation3.
Delete all route operations except for a half an hour stirring operation. You can do this by clicking on the Route option on the All production orders form and deleting any existing route operations that are not related to stirring1. This way, you can avoid unnecessary steps and costs for the rework order.
NEW QUESTION # 27
A company uses Dynamics 365 Supply Chain Management. Equipment installations in multiple regional locations require monthly maintenance.
Two maintenance technicians have holiday time off scheduled this month.
You need to ensure that all scheduled work orders are completed within the month around the holiday schedules.
Which feature should you use?
  • A. Job scheduling
  • B. Capacity toad calculation
  • C. Activity-based subcontracting
  • D. Planning optimization
  • E. Operations scheduling
NEW QUESTION # 28
You need to set up the state control for sales of motorcycles.
Which two actions should you perform? Each correct answer presents part of the solution.
  • A. Create an exclusive restricted product list for Missouri and add the motorcycle part to the list.
  • B. Create an exclusive restricted product list for California and add the motorcycle part to the list.
  • C. Create an inclusive restricted product list for United States and add the motorcycle part to the list.
  • D. Create an inclusive restricted product list for United States. Do not add the motorcycle part to the list.
https://stoneridgesoftware.com/w ... ics-365-operations/
Topic 2, Fabrikam inc sanitation cleaning solutions
Background
Fabrikam Inc. is a manufacturer of sanitation cleaning solutions and equipment including carpet/floor cleaners, pressure washers, scrubbers and vacuums.
Fabrikam Inc. is a single legal entity based in New York city.
_ Current environment
Products manufactured
* Cleaning equipment
o floor cleaner
o pressure washers
o scrubbers
o vacuums
* Liquid cleaning solutions
o No scent
o Orange scent (subcontracted to a vendor named VendorA)
o Pine scent (subcontracted to a vendor named VendorA)
The production quantity for the finished unscented liquid cleaning solution is 40-liters. IngredientC 'or unscented liquid cleaning solution Is stored in inventory in 50-liter barrels and allocated in 50-liter increments. Two barrels of IngredientC are uses to produce a barrel of unscented liquid cleaning solution.
Production sites
* The Eastern United States facility manufactures equipment.
* The Western United States facility manufactures liquid cleaning solutions.
* Raw materials and finished products are stocked at the warehouse and distributed from the warehouse.
Warehouse facilities
The warehouse consists of the following zones:
_ Requirements
Cleaning equipment manufacturing
You identify the following require merits for manufacturing cleaning equipment:
* Production is Make to Stock and must be scheduled at an operational level.
* Machine equipment is produced on an assembly line. Scheduling must be based on production orders.
* Finished products must be packaged and shipped directly from the warehouse.
* To reduce delivery times and excess inventory, equipment must be produced as needed.
* The ability to schedule production must be based on resource capacity and the availability of required materials.
* Production order operations must be scheduled to start only when capacity and materials are available at the same time and in the required quantities.
Liquid cleaning solution manufacturing
* Production is Make lo Order and is scheduled at the job level. Products must be manufactured in batches.
* You must be able to calculate the estimated consumption of ingredients and ensure that the amount is divisible by the number of units the raw material is available.
* Formula changes must be reviewed and approved. You must ensure that approved formulas cannot be deleted or edited. Approved formulas may be deactivated.
* An ingredient used to manufacture unscented cleaning solution is defined as a restricted product. You must be able to automatically print a product safety data sheet (PSDS) with the packing slip for any order that includes unscented cleaning solution.
* Production must be scheduled to start by date and time according to the order that is specified by the production route.
* You must implement a scheduled Kanban rule that meets the following requirements:
o Prevent overloading a work cell for scheduled Kanbans.
o Visualize excess inventory in a supermarket.
o Store products in supermarkets before they are consumed or shipped.
* You must link relevant financial dimension data to the inventory transactions at each site to ensure that you can trace profit and loss figures directly to East site and West site respectively.
* You must set up production operations for sub-contracting of Pine scent and Orange scent solution to VendorA to ensure that a purchase order is automatically created based on estimation of a production order.
Costing
* The price of raw materials used for manufacturing unscented cleaning solution must be tracked based upon commodity exchange pricing. The margin and cost multiplier must be set up for commodity traded raw material.
* You must set up cost calculation groups to ensure that indirect costs that originate in the manufacturing of finished goods are recognized and absorbed into the product cost.
* The production manager needs to set up picking list journals and BOM item consumption.
Reporting
* Production control parameters must be setup for reporting of automatic BOM and Route consumption.
* You must create reports that include information about cost records and categories for items, and calculation formulas for indirect costs.
* You must treat manufactured items as purchased items for cost roll-up purposes during BOM calculations and reporting.
* You must configure automatic route consumption in connection with the automatic running of Report as finished.
Inventory control
You must not be required to track the tot number for items when you enter inventory information into the system. Lot numbers for items must be entered when items are picked from inventory.
Issues
Users report the following issues:
* The production manager observes that items are being deducted from inventory two times on production jobs. A shop supervisor mistakenly registers the process for assembling batteries for the pressure washers to Registered as prepared. You must reschedule the process for a future date.
* Customer1 orders 20 barrels of unscented solution. The order is confirmed. Production must be scheduled to start on December 21 to meet the customer's delivery deadline.
* User2 reports that costs for manufactured items are twice as high as expected.
* UserD reports that the formula for the liquid cleaning solution sometimes changes during production. You must enforce the policies regarding formula editing for current and future use.
NEW QUESTION # 29
You need to determine the sales price for a new limited-edition bicycle for the summer season.
What should you do?
  • A. Run inventory close for the BOM items for the limited-edition bicycle.
  • B. Create the production order for the limited-edition bicycle and click estimate.
  • C. Run the pricing simulator for the limited-edition bicycle for a quantity of one.
  • D. Run the category price rules for the limited-edition bicycle using a cost-plus calculation.
Topic 4, Case Study 4, Fabrikam inc.
Fabrikam, Inc. Is a discrete manufacturer of outdoor patio furniture. The company originated as a sole owner working from a home garage, then moved into a commercial storage space, and later into a full manufacturing facility. The company operates as two operating legal entities, one in the United States and the other in Mexico.
As the company grew, the existing software systems failed to grow with it. This meant that financial reporting was managed in an outdated accounting system; raw materials planning, production, and inventory control were managed in another system; and cost calculations were tracked in multiple spreadsheets managed by analysts.
Current environment
The Fabrikam. inc. engineering team uses a third-party computer-aided design (CAD) system for drawings.
These drawings are later introduced into one or more companies for sale. A customer service center handles complaint calls and places orders for distributors.
The current system landscape creates a lack of controls and visibility across the systems, leading to overages of some raw materials, shortages on others, and large quantities of scrap. Heavy production volume provides little to no room for system downtime. The staff manually creates production orders, which leads to double work for system entry later. This delay has a ripple effect into the materials planning.
The company currently sources teakwood from India, making it a more expensive and high-end material.
Cedar and redwood are both sourced from the Western US. Truck driver shortages across the nation have caused shipping costs to rise sharply.
Fabrikam, Inc. recently decided to expand into the gas firepit market. All products are currently being prototyped. The company decides that the firepit prototype should be initially available only in the United States. The firepits will be manufactured only in Nevada and Arizona. The firepits are produced as prototyping: this production line operates only on Mondays.
Fabrikam, Inc. has purchased new manufacturing equipment for the firepit metal fabrication. This purchase includes a warranty, which requires that the company perform routine maintenance. Fabrikam, inc. elects to complete the maintenance in house on a quarterly schedule and maintain appropriate records for warranty purposes. The metal fabrication equipment consists of three separate machines used in a single production process.
Fabrikam. Inc. made the decision to move to Dynamics 365 Supply Chain Management.
Application and environment
* Fabrikam, inc. must move systems and processing to software as a service (SaaS) whenever possible because the company does not have enough IT staff to support hardware.
Inventory and costing
* Finished goods fall into three categories:
* Wood furniture (teak, cedar, redwood) o Outdoor heating (firepits. gas heaters)
* Each outdoor heating item with slight variations, such as a chrome or steel finish, must have a unique item number, o Repair parts (nuts and bolts, ignitors. and other parts)
* The system must account for the fact that Fabrikam. inc. must take legal ownership of teakwood at the time of shipment, not at the time of receipt into the warehouse.
* The company must accrue for the costs of the teakwood materials as soon as the company takes ownership.
The company takes ownership at the time of shipment, which is posted prior to physical receipt at the warehouse.
Engineering
* Engineers who specialize in gas consumer goods will design the firepits and ate the only users with authority to release the products for sale.
* Engineering must notify customer service of any open orders that may contain a released product version that may be discontinued or delayed.
* The change request workflow must route to the engineer.
Production
* The raw material and subcomponent goods for the firepit must be managed by the engineer. This means the engineer must oversee any new items, material changes, address problems, and so on.
* The metal fabrication equipment must be tracked at the locations where the firepits are produced.
* The production team must operate on an all-day/everyday model, with each team operating in a 12-hour shift. This is a recent change to keep up with high demand for products, as well as for planning a new product line.
* Raw material and subcomponent items for the firepit prototype must not be available for use until engineering is ready for the prototype product release.
* Due to the production staff schedule, all equipment must be planned according to the staffing.
* Maintenance for each of the three pieces of machinery must be scheduled at the same time so that only the local maintenance technician works on the equipment.
* When the firepits are ready for the test market they must made be available for sale.
* The United States operating company must review any engineering products before they are available for sales or production orders,
* The engineering team must release the engineering product into the United States operating company,
* The engineering BOM lines must not be removed by the United States operating company.
* The operations manager is concerned that system downtime is so frequent that It is impacting efficiency due to the all-day/everyday production operation model.
* Fabrikam, inc. marketing campaigns in the desert states of Arizona- Nevada, and New Mexico have led to an increased demand for teakwood furniture to endure weather elements. Supply and demand for this wood lowered expected margins with increased shipping costs and price increases from the vendors.
* User1 reports that the inventory value of the teakwood is not on the financial reports, even though ownership of the product begins at the port of shipment,
* Upon receipt into the physical warehouse, User2 reports that the warehouse workers received less teakwood than the ordered amount on the purchase order.
Engineering and production
* As the firepits are produced and feedback received from the test market, records must be maintained of each revision to the firepit design.
* Firepits must have attributes associated with them to specify the type of gas line that is available for the firepit such as natural gas or propane.
* Customer service is receiving calls that the firepit ignition switch does not always work as expected. This issue was reported through an engineering change request.
* User3 reports resource issues on the production shop floor due to system maintenance issues and other delays. The company does not want User3 or the other workers to stop production.
* User4 reports that a bolt needed for cedar wood furniture is out of stock. A temporary substitution bolt was identified prior to starting the production order.
* User5 reports that a hinge for redwood furniture will be discontinued at the end of the year. Production must reflect an updated part.
* A large order was placed for 1,500 pieces of teakwood furniture and production orders must start as soon as possible.
* Users reports the following:
* Only 100 pieces of furniture can be produced on the night shift due to resourcing. Enough raw materials are on hand to complete 100 pieces, but not enough to produce all 1.500 pieces.
* The production floor is organized into dedicated production lines, each with their own warehouse. The warehouse workers must pick the raw materials to the correct warehouse location.
NEW QUESTION # 30
As long as you free download the demos of our MB-335 exam braindumps, you will be surprised by the high quality. It is all about the superior concrete and precision of our MB-335 learning quiz that help. Every page and every points of knowledge have been written from professional experts who are proficient in this line who are being accounting for this line over ten years. Come and buy our MB-335 Study Guide, you will be benefited from it.
MB-335 Reliable Exam Prep: https://www.examtorrent.com/MB-335-valid-vce-dumps.html
We will keep you updated with the Microsoft Certified: Dynamics 365 MB-335 exam content and for three months within your purchase you will get the MB-335 dumps pdf updates free of cost, It is highly recommended for you to use MB-335 braindumps that will allow you to clear Microsoft Microsoft Certified: Dynamics 365 MB-335 exam on the first attempt, Under coordinated synergy of all staff, our MB-335 practice braindumps achieved a higher level of perfection by keeping close attention with the trend of dynamic market.
Configure Mac OS X Server to control access to files and provide MB-335 services based on user and group accounts, Well first of all I know that there are a lot of resources out therefrom a small business perspective that really focus people MB-335 Reliable Exam Prep on stories and situations and examples of other businesses that don't actually correlate very well to creative work.
Latest updated MB-335 Sample Questions Pdf & Leader in Qualification Exams & Professional MB-335: Microsoft Dynamics 365 Supply Chain Management Functional Consultant ExpertWe will keep you updated with the Microsoft Certified: Dynamics 365 MB-335 Exam content and for three months within your purchase you will get the MB-335 dumps pdf updates free of cost.
Our Microsoft Dynamics 365 Supply Chain Management Functional Consultant Expert (MB-335) questions PDF version is great for busy candidates who like to learn on the go with their smartphones or tablets, I will show you the advantages of our Microsoft Dynamics 365 Supply Chain Management Functional Consultant Expert pdf torrent.
P.S. Free 2026 Microsoft MB-335 dumps are available on Google Drive shared by ExamTorrent: https://drive.google.com/open?id=1lOtRuKsJZEepgASnocdL6BltV05HkwAZ
