[General] Top FCP_FMG_AD-7.6 Certification Practice - How to Prepare for Fortinet FCP_FMG_
63
General Top FCP_FMG_AD-7.6 Certification Practice - How to Prepare for Fortinet FCP_FMG_
Posted at 3/6/2026 02:18:58      View155 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Fortinet FCP_FMG_AD-7.6 dumps are available on Google Drive shared by Itbraindumps: https://drive.google.com/open?id=1k6AfMTq82sj1KxyTtSLwxOnVQSlltFiB
Our FCP_FMG_AD-7.6 study materials have included all significant knowledge about the exam. So you do not need to pick out the important points by yourself. Also, our FCP_FMG_AD-7.6 practice engine can greatly shorten your preparation time of the exam. So you just need our FCP_FMG_AD-7.6 learning questions to help you get the certificate. You will find that the coming exam is just a piece of cake in front of you and you will pass it with ease.
Itbraindumps's FCP_FMG_AD-7.6 exam training materials is more accurate and easier to understand, more authoritative than other FCP_FMG_AD-7.6 exam dumps provided by any other website. After choose Itbraindumps, you won't regret. If you are still worried, you can first try FCP_FMG_AD-7.6 Dumps Free demo and answers on probation. After you buy Itbraindumps's FCP_FMG_AD-7.6 exam training materials, we guarantee you will pass FCP_FMG_AD-7.6 test with 100%.
Fortinet - High Pass-Rate FCP_FMG_AD-7.6 - FCP - FortiManager 7.6 Administrator Certification PracticeBecause industry of information technology is fast-moving. To excel in this advanced industry, pass the FCP_FMG_AD-7.6 exam of the Fortinet FCP_FMG_AD-7.6 certification. Hundreds of applicants have faced issues in updated dumps material to crack the Fortinet FCP_FMG_AD-7.6 examination in one go.
Fortinet FCP_FMG_AD-7.6 Exam Syllabus Topics:
  • Device Manager: This section of the exam measures the skills of Network Security Engineers and focuses on registering devices within ADOMs and handling device configurations. Candidates also learn how to install changes through scripts and diagnose issues using the revision history.
  • Advanced Configuration: This section of the exam measures the skills of Network Security Engineers and includes knowledge of high availability (HA), FortiGuard service configuration, and global database ADOM settings. These advanced functions help strengthen system reliability and streamline management at a larger scale.
  • Policy and Objects: This section of the exam measures the skills of System Administrators and evaluates their ability to manage policies and objects within FortiManager. It involves ADOM revisions, workspace mode, and policy imports and installations, emphasizing consistent policy control across networks.
Fortinet FCP - FortiManager 7.6 Administrator Sample Questions (Q47-Q52):NEW QUESTION # 47
Refer to the exhibits.
An administrator needs to push a FortiToken Mobile to assign it to HR_user in the HQ-NGFW-1.
However, when installing the policy package, they receive the following error message:
Why is the administratornotable to install the FortiToken on the HQ-NGFW-1 firewall?
  • A. The administrator must use per-device mapping to assign the FortiToken to HQ-NGFW-1.
  • B. The administrator must use a user local meta field to assign FortiToken.
  • C. The administrator must use a valid FortiToken that exists on HQ-NGFW-1.
  • D. The administrator must use a metadata variable to assign the same FortiToken to multiple users in FortiManager.
The error occurs because the FortiToken used (FTKM0B4A9AC5C56D) must already exist and be registered on the FortiGate device HQ-NGFW-1. FortiManager cannot push or create new FortiTokens on the device; the token must be valid and present on the FortiGate before it can be assigned to a user.
NEW QUESTION # 48
The administrator uses FortiManager to push a CLI script using the Remote FortiGate Directly (via CLI) option to configure an IPsec VPN. However, when running the script, the administrator receives the following error:
config vpn ipsec phase2-interface [parameter(s) invalid. detail: object mismatch] What must the administrator do to resolve the script error and successfully apply the IPsec configuration?
  • A. Run the script using the policy package or ADOM database method.
  • B. Use IPsec templates to deploy provisioning templates.
  • C. Add a second config vpn ipsec phase2-interface block without linking it to phase1.
  • D. Add the end command after finishing the IPsec phase 1-interface configuration block.
Running the script through the policy package or ADOM database method allows FortiManager to properly interpret object relationships and dependencies in the IPsec configuration, preventing object mismatch errors when pushing complex VPN settings directly via CLI.
NEW QUESTION # 49
If one of the secondary FortiManager devices fails, which action must be performed to return the FortiManager HA manual mode to a working state?
  • A. Run a sanity check on the failed device to make sure HA heartbeat packets are using TCP port
    5199.
  • B. The FortiManager high availability (HA) state transition is transparent to administrators and does not require any reconfiguration.
  • C. Manually promote one of the working secondary devices to the primary role.
  • D. Remove the peer IP of the failed device on the primary device.
If a secondary fails, there is no change. Primary remains the same. Admin must remove the IP of the secondary. if you remove a secondary member from the HA configuration, the primary FortiManager removes the secondary serial number from the central management configuration of FortiGate, and updates the managed FortiGate devices immediately.
NEW QUESTION # 50
What is the purpose of ADOM revisions?
  • A. ADOM revisions find unused, duplicate, and unnecessary firewall policies and objects.
  • B. ADOM revisions compare previous snapshots of the Policy Package and ADOM-level objects with the device-level database.
  • C. ADOM revisions show specific changes in a policy package when it is installed.
  • D. ADOM revisions save the current state of all policy packages and objects for an ADOM.
ADOM revisions save the current state of all policy packages and objects within an ADOM, allowing administrators to track changes over time and revert to previous configurations if needed.
NEW QUESTION # 51
Company policy dictates that any time a change is made to a policy package on FortiManager an ADOM revision is created before the change installed, and that revision is held for a minimum of
90 days.
Over the past three months, each installed change has resulted in several unused policies and duplicate objects.
The FortiManager administrator plans to upgrade the FortiGate devices and then upgrade the FortiManager ADOM from version 7.4 to 7.6.
Which action can the administrator take to avoid slow ADOM upgrades?
  • A. Find unused firmware templates, then delete them before upgrading.
  • B. Limit ADOM revisions before upgrading.
  • C. Export firewall policies to Excel, delete them on the ADOM. then reimport them after upgrading the ADOM.
  • D. Check and repair the global configuration database before upgrading.
Limiting ADOM revisions reduces the number of stored historical configurations, which helps avoid performance degradation and slow ADOM upgrades caused by a large volume of revisions.
NEW QUESTION # 52
Every working person knows that FCP_FMG_AD-7.6 is a dominant figure in the field and also helpful for their career. If FCP_FMG_AD-7.6 reliable exam bootcamp helps you pass the exams and get a qualification certificate you will obtain a better career even a better life. Our study FCP_FMG_AD-7.6 Guide materials cover most of latest real FCP_FMG_AD-7.6 test questions and answers. If you are certainly determined to make something different in the field, a useful certification will be a stepping-stone for your career.
New FCP_FMG_AD-7.6 Exam Labs: https://www.itbraindumps.com/FCP_FMG_AD-7.6_exam.html
