Hardware
Free PDF 2026 Oracle 1Z1-947: Oracle GoldenGate 19c Implementation Professional
Posted at 3/6/2026 10:52:05
View183
Replies0
BTW, DOWNLOAD part of DumpStillValid 1Z1-947 dumps from Cloud Storage: https://drive.google.com/open?id=1xj1PYbSokOyX-2Hw2Zcn_lxJXp9G85Al
DumpStillValid offers affordable Oracle GoldenGate 19c Implementation Professional exam preparation material. You don't have to go beyond your budget to buy Updated 1Z1-947 Dumps. To make your 1Z1-947 exam preparation material smooth, a bundle pack is also available that includes all the 3 formats of dumps questions. DumpStillValid offers 365 days updates.
Starting from our 1Z1-947 practice materials will make a solid foundation for your exam definitively. Do not satisfied with using shortcuts during your process, regular practice with our 1Z1-947 exam prep will be easy. Tens of thousands of people has achieved success with our 1Z1-947study questions, you can absolutely do it. And you will find that passing the 1Z1-947 exam is as easy as pie.
Latest 1Z1-947 Study Plan - 1Z1-947 Reliable Braindumps PptThe DumpStillValid team is updating the Oracle 1Z1-947 study material according to the changes in the syllabus on daily basis. The users will receive 1Z1-947 updates for 365 days so they can prepare according to the updated content. The 24/7 support system has been made for customers to solve their problems and serve them in the best possible ways in order to pass the Oracle GoldenGate 19c Implementation Professional (1Z1-947) certification exam on the first try!
Oracle GoldenGate 19c Implementation Professional Sample Questions (Q34-Q39):NEW QUESTION # 34
Which database setting for the Oracle 19c database is required to enable Oracle GoldenGate?
- A. ENABLE_DATABASE_REPLICATION=true
- B. ENABLE_STREAMS_REPLICATION=true
- C. Configure the STREAMS_POOL_SIZE database parameter
- D. ENABLE_GOLDENGATE_REPLICATION=true
To enable Oracle GoldenGate in Oracle 19c, set ENABLE_GOLDENGATE_REPLICATION=TRUE, which allows the database to support GoldenGate features like Integrated Extract and Replicat.
NEW QUESTION # 35
SQLEXEC can communicate only via SQL query.
SQLEXEC can run scripts, not just SQL queries.
NEW QUESTION # 36
What Oracle GoldenGate component sends trail files over the network to the Receiver Server?
- A. The Distribution Server on the source
- B. The GoldenGate source Data Pump
- C. The Trail File Server
- D. The Extract
"A Distribution Service process will read the trail file and send it across the network to a waiting Receiver Service process..."
NEW QUESTION # 37
Table A has (ColA number Primary Key, ColB char(2), ColC varchar(10)) with one record with the following data: (1, 'AB', 'TestData') What will Extract capture by default for an update on ColC?
- A. After Image (1, 'NewValue')
- B. Before Image (1, 'AB', 'TestData') + After Image (1, 'AB', 'NewValue')
- C. After Image (1, 'AB', 'NewValue')
- D. Before Image (1, 'TestData') + After Image (1, 'NewValue')
By default, Oracle GoldenGate Extract captures both the before image and the after image of an update, including all key and updated columns, when:
* GETUPDATEBEFORES is enabled (default in many Extract configurations).
* UPDATERECORDFORMAT COMPACT (default) includes both before and after values in a single record.
NEW QUESTION # 38
In integrated mode, the Replicat process leverages the apply processing functionality that is available within the Oracle database. How does it operate?
- A. It reads the Oracle GoldenGate trail, performs data filtering, mapping and conversion. Then, it constructs logical change records from source database DML transactions. Next, it uses standard SQL to apply data directly to the target tables.
- B. It reads the Oracle GoldenGate trail, performs data filtering, mapping, and conversion. Then, it constructs logical change records (LCRs) from source database DML transactions. DDL is applied directly by Replicat. Finally, it transmits the LCRs to the inbound server, which applies the data to the target database.
- C. It reads the Oracle GoldenGate trail, performs data filtering, mapping and conversion. Then, it transmits the regular change records to the inbound server, which applies the data to the target database.
- D. It reads the Oracle GoldenGate trail, performs data filtering, mapping, and conversion. Then, it constructs logical change records (LCRs) from source database DML transactions. Then it is attached to a background process in the target database by means of lightweight streaming mechanism, which transmits the LCRs to the inbound server, which applies the data to the target database.
Integrated Replicat constructs LCRs for DML, sends them to the inbound server for apply, while DDL is applied directly by Replicat-not through the inbound server.
NEW QUESTION # 39
This will help them polish their skills and clear all their doubts. Also, you must note down your Oracle GoldenGate 19c Implementation Professional (1Z1-947) practice test score every time you try the Oracle Exam Questions. It will help you keep a record of your study and how well you are doing in them. DumpStillValid hires the top industry experts to draft the Oracle GoldenGate 19c Implementation Professional (1Z1-947) exam dumps and help the candidates to clear their Oracle GoldenGate 19c Implementation Professional (1Z1-947) exam easily. DumpStillValid plays a vital role in their journey to get the 1Z1-947 certification.
Latest 1Z1-947 Study Plan: https://www.dumpstillvalid.com/1Z1-947-prep4sure-review.html
DumpStillValid is one of the trusted and reliable platforms that is committed to offering quick Oracle GoldenGate 19c Implementation Professional (1Z1-947) exam preparation, 1Z1-947 is one of the largest international internet companies in the world and getting a certification (without 1Z1-947 best questions) is hard but useful for many ambitious IT elites, Oracle 1Z1-947 Valid Practice Questions So its status can not be ignored.
You manually establish intersite replication through the 1Z1-947 Active Directory Sites and Services tool because it is not automatically generated by the Active Directory.
Those who have unified the concept, DumpStillValid is one of the trusted and reliable platforms that is committed to offering quick Oracle GoldenGate 19c Implementation Professional (1Z1-947) exam preparation.
Starting Your Oracle 1Z1-947 Exam Preparation? Get the Right Direction Here1Z1-947 is one of the largest international internet companies in the world and getting a certification (without 1Z1-947 best questions) is hard but useful for many ambitious IT elites.
So its status can not be ignored, 1Z1-947 test training can give you three different file to prepare for test, No problem, I will take the responsibility to select the most suitable 1Z1-947 original questions for you.
- Useful 1Z1-947 Valid Practice Questions - Leader in Qualification Exams - Practical Oracle Oracle GoldenGate 19c Implementation Professional ❕ Go to website [url]www.examcollectionpass.com open and search for ▷ 1Z1-947 ◁ to download for free 🥒Interactive 1Z1-947 Questions[/url]
- Buy Actual Oracle 1Z1-947 Exam Questions Now on Discount 😀 Search for ⇛ 1Z1-947 ⇚ and download it for free on [url]www.pdfvce.com website 🏇Reliable 1Z1-947 Exam Preparation[/url]
- Examcollection 1Z1-947 Questions Answers 😺 Valid 1Z1-947 Test Duration ⌚ Valid 1Z1-947 Test Duration ➡ Open website ➥ [url]www.exam4labs.com 🡄 and search for ☀ 1Z1-947 ️☀️ for free download 🎽Reliable 1Z1-947 Dumps Pdf[/url]
- Interactive 1Z1-947 Questions ⏮ Reliable 1Z1-947 Exam Preparation ⏯ 1Z1-947 Exam Simulator Fee 🔣 Search for { 1Z1-947 } and easily obtain a free download on ▷ [url]www.pdfvce.com ◁ 📆1Z1-947 Vce Test Simulator[/url]
- Examcollection 1Z1-947 Questions Answers 😆 Valid 1Z1-947 Test Duration 🔰 Test 1Z1-947 Voucher 🚙 Search for ➽ 1Z1-947 🢪 and download it for free immediately on ▷ [url]www.vce4dumps.com ◁ 😖Interactive 1Z1-947 Questions[/url]
- 1Z1-947 Vce Test Simulator 🚀 Flexible 1Z1-947 Learning Mode ✨ 1Z1-947 Latest Exam 🍰 Enter [url]www.pdfvce.com and search for 1Z1-947 to download for free 😋1Z1-947 Exam Questions Answers[/url]
- Interactive 1Z1-947 Questions 🆎 1Z1-947 Valid Braindumps Ebook 🕒 1Z1-947 Exam Simulator Fee 🕦 Easily obtain 1Z1-947 for free download through ➡ [url]www.vceengine.com ️⬅️ 🥘1Z1-947 Exam Simulator Fee[/url]
- [url=https://blackbordergame.com/?s=Buy%20Actual%20Oracle%201Z1-947%20Exam%20Questions%20Now%20on%20Discount%20%f0%9f%a7%a5%20Search%20for%20[%201Z1-947%20]%20and%20obtain%20a%20free%20download%20on%20%ef%bc%88%20www.pdfvce.com%20%ef%bc%89%20%f0%9f%93%9a1Z1-947%20Valid%20Braindumps%20Ebook]Buy Actual Oracle 1Z1-947 Exam Questions Now on Discount 🧥 Search for [ 1Z1-947 ] and obtain a free download on www.pdfvce.com 📚1Z1-947 Valid Braindumps Ebook[/url]
- 1Z1-947 Exam Questions Answers 🍸 1Z1-947 Latest Exam 🎣 Exam 1Z1-947 Pass Guide 📄 Download ✔ 1Z1-947 ️✔️ for free by simply searching on { [url]www.troytecdumps.com } 🔢Valid 1Z1-947 Test Duration[/url]
- Buy Actual Oracle 1Z1-947 Exam Questions Now on Discount 🔎 Immediately open [url]www.pdfvce.com and search for 1Z1-947 to obtain a free download 👟Learning 1Z1-947 Mode[/url]
- Hot 1Z1-947 Valid Practice Questions | Efficient Oracle 1Z1-947: Oracle GoldenGate 19c Implementation Professional 100% Pass 📒 Copy URL ▶ [url]www.dumpsquestion.com ◀ open and search for ▶ 1Z1-947 ◀ to download for free 🎻Interactive 1Z1-947 Questions[/url]
- msadvisory.co.zw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, p.me-page.com, www.stes.tyc.edu.tw, www.dibiz.com, kayaksekolah.com, www.notebook.ai, www.stes.tyc.edu.tw, myspace.com, Disposable vapes
BONUS!!! Download part of DumpStillValid 1Z1-947 dumps for free: https://drive.google.com/open?id=1xj1PYbSokOyX-2Hw2Zcn_lxJXp9G85Al
