800-150 Valid Test Test - 800-150 Valid Dumps Pdf
111
Posted at 3/6/2026 11:09:28      View:155 | Replies:1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of PassExamDumps 800-150 dumps for free: https://drive.google.com/open?id=1aUesriwUwVxmK7RmiJAuN-nXVdryaPtC
The pass rate is 98.75%, and we can ensure you pass the exam successfully if you buying 800-150 exam braindumps from us. Most candidates can pass the exam just one time. And we ensure you that if you can’t pass the exam, you just need to send us the failure scanned, we will refund your money. We can ensure you that your money can receive rewards. In addition, we have three versions for 800-150 Training Materials, and you can buy the most suitable in accordance with your own needs.
Cisco 800-150 Exam Syllabus Topics:
  • Cisco Software: This section of the exam measures the skills of a Network Engineer and discusses Cisco’s software systems and licensing. It explains the difference between IOS install and bundle modes and gives an overview of different licensing models. Students learn how to manage Cisco software images, including backing up, transferring, and installing images via FTP, TFTP, or USB. It also covers how to handle configuration files to keep devices running properly and ensure smooth upgrades or replacements.
  • Cisco Infrastructure and Collaboration Infrastructure: This section of the exam measures the skills of a Collaboration Engineer and focuses on Cisco infrastructure devices, endpoints, and collaboration technologies. It introduces network devices, collaboration endpoints like IP phones and video systems, and explains on-premises collaboration deployments using tools like Cisco Unified Communications Manager. It also covers how video systems integrate into collaboration environments and highlights Cisco’s cloud services for enterprise communication, including Webex Meetings, Webex Teams, and hosted collaboration solutions.
  • Cisco Hardware Replacement: This section of the exam measures the skills of a Technical Support Engineer and teaches how to safely and correctly replace Cisco hardware. It explains safety procedures such as creating safe work zones and handling electrostatic discharge. Students learn the step-by-step processes to replace a wide range of Cisco devices, from switches and routers to firewalls, UCS servers, and collaboration endpoints. It also covers configuring Cisco NX-OS software, including understanding operating modes, boot procedures, and password recovery, and introduces Cisco collaboration endpoint solutions like IP phones and video systems.
Cisco Realistic 800-150 Valid Test Test 100% Pass QuizOur company always put the quality of the 800-150 practice materials on top priority. In the past ten years, we have made many efforts to perfect our 800-150 study materials. Our 800-150 study questions cannot tolerate any small mistake. All staff has made great dedication to developing the 800-150 Exam simulation. Our professional experts are devoting themselves on the compiling and updating the exam materials and our services are ready to guide you 24/7 when you have any question.
Cisco Supporting Cisco Devices for Field Technicians Sample Questions (Q76-Q81):NEW QUESTION # 76
What is the primary purpose of backing up the endpoint configuration prior to replacing the device?
  • A. To update the firmware of the device
  • B. To generate a performance report for the old device
  • C. To troubleshoot network connectivity issues
  • D. To restore settings on the new device after replacement
Backing up the configuration of a network device before replacement is a critical step to ensure business continuity and minimize downtime. The primary purpose of this backup is to restore the existing settings onto the new device, ensuring that it operates identically to the one being replaced.
This process includes preserving interface configurations, routing protocols, access control lists, and other essential parameters. By restoring the backed-up configuration to the new device, network administrators can quickly reintegrate it into the network infrastructure without the need for manual reconfiguration, thereby reducing the risk of errors and service disruptions.
Options A, B, and C do not align with the primary objective of configuration backups in the context of device replacement.
NEW QUESTION # 77
Which action must be taken when editing a captured configuration of an old device for reuse in a replacement device?
  • A. Remove all configurations under line vty 0 4.
  • B. Add the enable password cisco command.
  • C. Keep all access-listcommands intact.
  • D. Retain all username entries.
Within theFLDTECtraining, especially underMaintenance and RMA Procedures, there is a strong emphasis on safely transferring and adapting configurations from failed or decommissioned devices to replacement units.
The official guidance includes the following:
"When reusing a configuration from an old device, make sure to retain the necessary security elements such as username entries. This ensures the replacement device is still accessible under the correct user credentials." Here's a breakdown of why the correct answer isB:
* A. Remove all configurations under line vty 0 4:This would eliminate remote access settings, making it harder to manage the device.
* B. Retain all username entries:Correct. Keeping the username entries ensures continued secure access and avoids loss of administrative control.
* C. Keep all access-list commands intact:Not always required - ACLs are often tailored to interface- specific settings or environments which may differ between devices.
* D. Add the enable password cisco command:Not a best practice. Default passwords (like cisco) should be avoided for security reasons, and it's not required if enable secret is already in use.
NEW QUESTION # 78
Which operating system powers the Cisco Nexus series of switches and is optimized formodern data center deployments?
  • A. IOS
  • B. IOS XR
  • C. IOS XE
  • D. NX-OS
Cisco NX-OSis the operating system specifically developed forCisco Nexus series switches, which are widely used in modern data centers. NX-OS is optimized forscalability, high availability, and virtualization features.
It differs from IOS and IOS XE (used in traditional routers and switches) and IOS XR (used in carrier-grade platforms). NX-OS includes advanced features such as Virtual Port Channels (vPC), FabricPath, and integrated Layer 2/3 capabilities tailored for data center networks.
Reference:Supporting Cisco Devices for Field Technicians (FLDTEC) - Cisco IOS Software Basics
NEW QUESTION # 79
Refer to the exhibit. Which component is highlighted on the Cisco I/O module image?
  • A. fan module LED
  • B. captive screw
  • C. fixed port
  • D. chassis connections LED
The highlighted component on the Cisco I/O module is the chassisconnections LED, which indicates the status of connectivity between the I/O module and the chassis.
In the exhibit, the orange arrow points to asmall rectangular LED indicatorlocated to the left side of the I/O module (Cisco UCS-IOM-2304). This specific LED isnot aligned with the ports, fans, or screws, which helps identify it correctly.
Chassis connections LED (B)is responsible for indicating thestatus of uplink/downlink communication between the I/O module and the chassis.
* Greenusually indicates a healthy link.
* Amberoroffmay indicate a problem or no connection.
Why the other answers are incorrect:
* A. Captive screw# These are at the far corners, not where the arrow points.
* C. Fan module LED# This IOM doesn't have user-visible fan LEDs atthe front face.
* D. Fixed port# These are the large rectangular SFP ports clearly visible in the middle, not near the arrow.
This identification is important whentroubleshooting chassis-to-IOM connectivityor verifyingmodule status LEDsduring field maintenance.
NEW QUESTION # 80
How must the power to a system with dual power supplies on a Cisco Nexus switch be connected?
  • A. Connect both power supplies to a power distribution unit with built-in redundancy.
  • B. Connect both power supplies to a single power source.
  • C. Connect each power supply to a separate power source.
  • D. Connect the primary power supply to the main source and the secondary to a backup generator.
In a Cisco Nexus switch with dual power supplies, the recommended method is to connect each power supply to a separate power source (Option C). This ensures power redundancy and fault tolerance.
If one power source fails (e.g., due to a power outage or circuit failure), the switch can continue operating uninterrupted using the second power source. Connecting both to a single source (Option D) defeats the purpose of redundancy.
NEW QUESTION # 81
Once the user has used our 800-150 learning material for a mock exercise, the product's system automatically remembers and analyzes all the user's actual operations. The user must complete the test within the time specified by the simulation system, and there is a timer on the right side of the screen, as long as the user begins the practice of 800-150 Learning Materials, the timer will run automatic and start counting.
800-150 Valid Dumps Pdf: https://www.passexamdumps.com/800-150-valid-exam-dumps.html
What's more, part of that PassExamDumps 800-150 dumps now are free: https://drive.google.com/open?id=1aUesriwUwVxmK7RmiJAuN-nXVdryaPtC
Posted at 3/9/2026 08:52:51        Only Author  2#
I’m so thankful for this article, it’s very inspiring! We’ve made Latest Cybersecurity-Practitioner practice questions download available, free of charge, to provide you with helpful content.
