[General] 2026 Updated SD-WAN-Engineer Test Cram - Palo Alto Networks SD-WAN Engineer Real
111
【General】 2026 Updated SD-WAN-Engineer Test Cram - Palo Alto Networks SD-WAN Engineer Real
Posted at 3/6/2026 11:34:35      View:119 | Replies:0        Print      Only Author   [Copy Link] 1#
Authentic Solutions Of The Palo Alto Networks SD-WAN-Engineer Exam Questions. Consider sitting for an Palo Alto Networks SD-WAN Engineer and discovering that the practice materials you've been using are incorrect and useless. The technical staff at It-Tests has gone through the Palo Alto Networks certification process and knows the need to be realistic and exact. Hundreds of professionals worldwide examine and test every Palo Alto Networks SD-WAN-Engineer Practice Exam regularly.
Palo Alto Networks SD-WAN-Engineer Exam Syllabus Topics:
  • Deployment and Configuration: This domain focuses on Prisma SD-WAN deployment procedures, site-specific settings, configuration templates for different locations, routing protocol tuning, and VRF implementation for network segmentation.
  • Planning and Design: This domain covers SD-WAN planning fundamentals including device selection, bandwidth and licensing planning, network assessment, data center and branch configurations, security requirements, high availability, and policy design for path, security, QoS, performance, and NAT.
  • Unified SASE: This domain covers Prisma SD-WAN integration with Prisma Access, ADEM configuration, IoT connectivity via Device-ID, Cloud Identity Engine integration, and User
  • Group-based policy implementation.
  • Troubleshooting: This domain focuses on resolving connectivity, routing, forwarding, application performance, and policy issues using co-pilot data analysis and analytics for network optimization and reporting.
Topic 5
  • Operations and Monitoring: This domain addresses monitoring device statistics, controller events, alerts, WAN Clarity reports, real-time network visibility tools, and SASE-related event management.
SD-WAN-Engineer latest exam question & SD-WAN-Engineer training guide dumps & SD-WAN-Engineer valid study torrentWe attach importance to candidates' needs and develop the SD-WAN-Engineer practice materials from the perspective of candidates, and we sincerely hope that you can succeed with the help of our practice materials. Our aim is to let customers spend less time to get the maximum return. By choosing our SD-WAN-Engineer practice materials, you only need to spend a total of 20-30 hours to deal with exams, because our SD-WAN-Engineer practice materials are highly targeted and compiled according to the syllabus to meet the requirements of the exam. As long as you follow the pace of our SD-WAN-Engineer practice materials, you will certainly have unexpected results.
Palo Alto Networks SD-WAN Engineer Sample Questions (Q16-Q21):NEW QUESTION # 16
An administrator is configuring a BGP peer on a Data Center ION to learn routes from the core switch. The goal is to have the ION learn these prefixes and then advertise them to all remote branch sites across the SD-WAN overlay.
Which setting must be configured on the BGP Peer to ensure these learned routes are redistributed into the SD-WAN fabric?
  • A. Enable "Graceful Restart".
  • B. Configure a "Prefix List" to deny all.
  • C. Set the "Scope" to "Global".
  • D. Set the "Admin Distance" to 20.
Comprehensive and Detailed Explanation
In Prisma SD-WAN routing configuration, the Scope setting on a BGP Peer (or a Static Route) controls the redistribution logic for the prefixes learned from that source.
Local Scope: If a BGP peer is configured with "Local" scope, the ION device will install the learned routes into its local routing table for its own reachability, but it will not advertise (redistribute) these routes to other ION devices via the Secure Fabric. They remain local to the site.
Global Scope: To advertise reachability to the rest of the network, the BGP peer must be configured with "Global" scope. This tells the ION that any prefixes learned from this specific neighbor (e.g., the DC Core Switch) should be propagated across the SD-WAN overlay to remote branches. This is the critical setting for enabling branch-to-DC communication for applications hosted behind that BGP peer. Without "Global" scope, the branches would never learn the routes to the data center subnets.
NEW QUESTION # 17
What is the default action for real-time media applications if link performance is poor?
  • A. Raise an alarm.
  • B. Move flows.
  • C. Apply Forward Error Correction (FEC).1
  • D. Drop the flow.
According to the Prisma SD-WAN Performance Policy Default Behavior documentation, the default action configured for applications (including real-time media) when a path experiences poor performance (violates the SLA thresholds for latency, jitter, or packet loss) is to Move Flows.
The Prisma SD-WAN ION device continuously monitors the health of all available paths. If the active path for a media application degrades and fails to meet the specified SLA, the default policy dictates that the traffic should be steered (moved) to an alternate, compliant path that meets the performance criteria.
While Forward Error Correction (FEC) is a powerful feature available in Prisma SD-WAN to mitigate packet loss for real-time applications, it is an optional action that must be explicitly enabled or configured within the performance policy rules. It is not the default action in the base system configuration; the primary default mechanism for handling performance issues is to leverage the multi-path fabric to switch to a better link.
NEW QUESTION # 18
For how many hours are Prisma SD-WAN VPN shared secrets valid?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
In the Prisma SD-WAN architecture, security is built directly into the AppFabric using a centralized, controller-led approach to key management. Unlike traditional VPNs that rely on manual Internet Key Exchange (IKE) or static Pre-Shared Keys (PSKs) which can be administratively burdensome and security- vulnerable, Prisma SD-WAN automates the entire lifecycle of encrypted tunnels. The Prisma SD-WAN Controller acts as the central authority for identity and key distribution for all ION (Instant-On Network) devices within the tenant's fabric.
Specifically, the VPN shared secrets used to secure these tunnels are ephemeral and are valid for exactly 24 hours. This 24-hour validity period is a security best practice implemented by Palo Alto Networks to limit the
"blast radius" or window of exposure in the unlikely event that a key is compromised. The controller automatically handles the generation, distribution, and rotation of these secrets. Before the 24-hour timer expires, the controller pushes new keys to the ION devices, which then perform a hitless rollover. This ensures that the data plane remains active and encrypted without requiring manual intervention from a network administrator. If an ION device loses its control plane connection to the controller, it will maintain its existing tunnels using the current keys until they expire, at which point it must re-authenticate with the controller to receive a new set of valid secrets. This automated rotation is a core component of the Prisma SD- WAN Zero-Trust security model.
NEW QUESTION # 19
When defining a Path Quality Profile (SLA) for a "Transactional" application group (e.g., Citrix, Oracle), the administrator sets the "Packet Loss" threshold to 1%.
What happens to the traffic for this application if all active paths currently exceed this 1% loss threshold?
  • A. The system automatically enables a Backup path, even if the Active paths are technically "Up" but degraded.
  • B. The traffic is dropped to prevent data corruption.
  • C. The system selects the best available path (lowest loss) among the active paths, even if it violates the profile.
  • D. The traffic is queued indefinitely until a path recovers.
This behavior describes the "Best Available Path" logic inherent in Prisma SD-WAN's availability design.
* SLA Thresholds: Path Quality Profiles act as filters to identify compliant paths.
* Total Violation: If all configured "Active" paths violate the SLA (e.g., Path A has 2% loss, Path B has
5% loss, and the threshold is 1%), the system does not drop the traffic (Option A) because maintaining connectivity is prioritized over perfect quality.
* Selection Logic: The system enters a fallback state where it compares the available active paths and selects the "Least Bad" one-the path that is closest to meeting the SLA (in this case, Path A with 2% loss).
* Backup Paths: Traffic would only move to a Backup path (Option D) if the policy explicitly configures the backup path to engage upon SLA violation of the active set. However, strictly speaking, if only active paths are considered and all fail, it picks the best of the active group rather than blackholing the traffic.
NEW QUESTION # 20
When identifying devices for IoT classification purposes, which two methods does Prisma SD-WAN use to discover devices that are not directly connected to the branch ION? (Choose two.)
  • A. CDP
  • B. SNMP
  • C. Syslog
  • D. LLDP
Prisma SD-WAN (formerly CloudGenix) integrates with Palo Alto Networks IoT Security to provide comprehensive visibility into all devices at a branch, including those that are not directly connected to the ION device. While the ION automatically detects and classifies devices connected directly to its interfaces via traffic inspection (DPI), DHCP, and ARP analysis, gaining visibility into off-branch devices (devices connected to downstream switches or access points) requires additional discovery mechanisms that can query the network infrastructure or ingest its logs.
1. SNMP (Simple Network Management Protocol): This is the primary active discovery method for off-branch devices. The Prisma SD-WAN ION device acts as a sensor that actively polls local network switches and wireless controllers using SNMP. By querying the ARP tables and MAC address tables (Bridge MIBs) of these intermediate network devices, the ION can identify endpoints that are connected to the switch ports, even if those endpoints are not currently sending traffic through the ION. This allows the system to map the topology and discover silent or lateral-traffic-only devices.
2. Syslog: In conjunction with SNMP, the IoT Security solution can utilize Syslog messages to discover and profile devices. Network infrastructure devices (like switches and WLAN controllers) can be configured to send Syslog messages to the collection point (which enables the IoT Security service) whenever a device connects or disconnects (e.g., port up/down events, DHCP snooping logs, or 802.1x authentication logs). These logs provide real-time data about device presence and identity (MAC/IP mappings) for devices that are not directly adjacent to the ION, ensuring 100% visibility across the branch network segments. LLDP (A) and CDP (B) are typically Link Layer discovery protocols used for discovering directly connected neighbors and do not propagate beyond the immediate link, making them unsuitable for discovering devices multiple hops away or behind a switch.
NEW QUESTION # 21
The Palo Alto Networks SD-WAN-Engineer certification exam is one of the hottest certifications in the market. This Palo Alto Networks SD-WAN-Engineer exam offers a great opportunity to learn new in-demand skills and upgrade your knowledge level. By doing this successful SD-WAN-Engineer Palo Alto Networks SD-WAN Engineer exam candidates can gain several personal and professional benefits.
New SD-WAN-Engineer Test Pattern: https://www.it-tests.com/SD-WAN-Engineer.html
