[General] 2026 Palo Alto Networks CloudSec-Pro: Palo Alto Networks Cloud Security Professi
42
General 2026 Palo Alto Networks CloudSec-Pro: Palo Alto Networks Cloud Security Professi
Posted at 3/6/2026 15:44:09      View229 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Palo Alto Networks CloudSec-Pro dumps are available on Google Drive shared by PDF4Test: https://drive.google.com/open?id=13QD5krmsUlmBfrllFHf0vBzLi-chnIVc
The second format is a web-based format that can be accessed from browsers like Firefox, Microsoft Edge, Chrome, and Safari. It means you don't need to download or install any software or plugins to take the Palo Alto Networks Cloud Security Professional practice test. The web-based format of the Palo Alto Networks CloudSec-Pro Certification Exams practice test supports all operating systems. The third and last format is desktop software format which can be accessed after installing the software on your Palo Alto Networks Cloud Security Professional (CloudSec-Pro) Windows Pc or Laptop. These formats are built especially for the students so they don't stop preparing for the Palo Alto Networks Cloud Security Professional (CloudSec-Pro) certification.
To effectively getting ready for Palo Alto Networks CloudSec-Pro test, do you know what tools are worth using? Let me tell you. PDF4Test Palo Alto Networks CloudSec-Pro pdf dumps are the most credible. The exam dumps is rare certification training materials which are researched by IT elite. PDF4Test CloudSec-Pro braindump has a high hit rate. 100% sail through your exam. This is because IT experts can master the question point well, so that all questions the candidates may come across in the actual test are included in PDF4Test exam dumps. Is it amazing? But it is true. After you use our dumps, you will believe what I am saying.
Quiz Free CloudSec-Pro Download Pdf - Unparalleled Palo Alto Networks Cloud Security Professional Reliable Test DurationTo ensure that the CloudSec-Pro dumps PDF format remains up to date, the Palo Alto Networks CloudSec-Pro questions in it are regularly revised to reflect any modifications to the CloudSec-Pro exam content. This commitment to staying current and aligned with the CloudSec-Pro Exam Topics ensures that candidates receive the Palo Alto Networks Cloud Security Professional (CloudSec-Pro) updated questions.
Palo Alto Networks Cloud Security Professional Sample Questions (Q238-Q243):NEW QUESTION # 238
An administrator needs to write a script that automatically deactivates access keys that have not been used for
30 days.
In which order should the API calls be used to accomplish this task? (Drag the steps into the correct order from the first step to the last.) Select and Place:
* POST https://api.prismacloud.io/login
* GET https://api.prismacloud.io/access_keys
* PATCH https://api.prismacloud.io/acces ... atus/<status>
To write a script that automatically deactivates access keys that have not been used for 30 days, an administrator would need to follow an ordered sequence of API calls to the Prisma Cloud platform.
The first API call must authenticate the script with the Prisma Cloud API, which is typically done using a POST request to the login endpoint. This step is necessary to establish a session and retrieve an authentication token required for subsequent API calls.
Once the script is authenticated, the next call is a GET request to the access_keys endpoint. This retrieves a list of all access keys within the environment. The script can then parse through these keys to determine which ones have not been used within the specified timeframe of 30 days.
For each access key that meets the criteria (unused for 30 days), the script must send a PATCH request to the specific access key's endpoint, which includes the access key ID and the desired status. This request will change the status of the access key to 'inactive' or a similar status that denotes deactivation.
Following this ordered sequence ensures that the script systematically authenticates, evaluates, and updates the status of access keys based on their usage, thereby maintaining security and compliance within the Prisma Cloud environment.
NEW QUESTION # 239
Where can Defender debug logs be viewed? (Choose two.)
  • A. From the Console, Manage > Defenders > Manage > Defenders. Select the Defender from the deployed Defenders list, then click Actions > Logs
  • B. From the Console, Manage > Defenders > Deploy > Defenders. Select the Defender from the deployed Defenders list, then click Actions > Logs
  • C. /var/lib/twistlock/log/defender.log
  • D. /var/lib/twistlock/defender.log
In Prisma Cloud, Defender debug logs are essential for troubleshooting and understanding the Defender's operational behavior. The logs can be accessed through two primary methods:
A). The first method (B) involves using the Prisma Cloud Console's user interface. By navigating to Manage > Defenders > Manage > Defenders, administrators can select a deployed Defender from the list and access its logs by clicking Actions > Logs. This method provides a convenient way to view logs directly from the Console without the need to access the Defender host directly.
D). The second method (D) involves accessing the logs directly from the file system of the host where the Defender is deployed. The correct path for the Defender logs is /var/lib/twistlock/log/defender.log. This method is useful for situations where direct access to the host is available, and it allows for more in-depth troubleshooting by examining the raw log files.
Options A and C are incorrect because the paths and navigation steps provided do not accurately reflect the structure and functionality of Prisma Cloud's logging system.
NEW QUESTION # 240
Prisma Cloud Compute has been installed on Onebox. After Prisma Cloud Console has been accessed.
Defender is disconnected and keeps returning the error "No console connectivity" in the logs.
What could be causing the disconnection between Console and Defender in this scenario?
  • A. Port 8083 is not open for Console and Defender communication.
  • B. Onebox script installed an older version of the Defender.
  • C. The license key provided to the Console is invalid.
  • D. Port 8084 is not open for Console and Defender communication.
By default, Defender is configured to communicate with Console on port 8084. If port 8084 is closed, then Defender cannot communicate with Console. https://knowledgebase.paloaltonetworks.com/KCSArticleDetail?
id=kA10g000000PNWXCA4#:~:text=If%20port%208084%20is%20closed%2C%20then%20Defender%
20cannot%20communicate%20with%20Console.&text=Resolve%20the%20issue%20by%20setting,%3E%
20Load%20Balancer%20%3E%20Defender).
NEW QUESTION # 241
Which command correctly outputs scan results to stdout in tabular format and writes scan results to a JSON file while still sending the results to Console?
  • A. $ twistcli images scan--address--username--password--details--json-output scan-results.jsonnginx:latest
  • B. $ twistcli images scan--address--u--p--details--output-file scan-results.jsonnginx:latest
  • C. $ twistcli images scan--address--user--password--details--file-output scan-results.jsonnginx:latest
  • D. $ twistcli images scan--address--user--password--stdout-tabular--output-file scan-results.jsonnginx:latest
The correct command to output scan results to stdout in tabular format and write scan results to a JSON file while still sending the results to Console is:
--address <console_address>
--user <username>
--password <password>
--publish
nginx:latest
This command uses the --output-file option to write the scan results to a file and the --publish option to send the results to the Console. The --stdout-tabular option is not necessary as by default, twistcli writes scan results to stdout in a human-readable format. The placeholders <console_address>, <username>, and
<password> should be replaced with the actual address of the Console, and the user's credentials12.
Please replace the placeholders with your actual Prisma Cloud Console address and credentials to execute the command successfully. If you have any more questions or need further assistance, feel free to ask.
NEW QUESTION # 242
Which action must be taken to enable a user to interact programmatically with the Prisma Cloud APIs and for a nonhuman entity to be enabled for the access keys?
  • A. Create a role with Account Group Read Only and assign it to the user.
  • B. Create a role with System Admin and generate access keys.
  • C. Create a user with a role that has minimal access.
  • D. Create a role and assign it to the Service Account.
To enable a user to interact programmatically with Prisma Cloud APIs and for a nonhuman entity to access keys, the correct action is to create a role and assign it to the Service Account (D). Service accounts in Prisma Cloud are designed for programmatic access by applications or automated tools, allowing these entities to interact with Prisma Cloud APIs securely. By creating a specific role with the necessary permissions and assigning it to a service account, administrators can ensure that the entity has the appropriate level of access required for its operations, aligning with the principle of least privilege and enhancing the security posture of API interactions.
NEW QUESTION # 243
The web-based Palo Alto Networks CloudSec-Pro practice test software is designed explicitly for the Palo Alto Networks Cloud Security Professional exam. It is a well-known self-preparation tool that contains CloudSec-Pro Exam Questions approved by Palo Alto Networks Certified Professionals. Our Palo Alto Networks CloudSec-Pro exam questions are periodically updated and are similar to the real Palo Alto Networks Cloud Security Professional exam questions. The Palo Alto Networks CloudSec-Pro Practice Test has a close resemblance with the actual Palo Alto Networks CloudSec-Pro exam. Multiple This Palo Alto Networks certification exam needs to be finished in a certain time duration, therefore Palo Alto Networks CloudSec-Pro practice test allows candidates to practice in the allocated time set according to their own needs.
CloudSec-Pro Reliable Test Duration: https://www.pdf4test.com/CloudSec-Pro-dump-torrent.html
We believe you will get wonderful results with the help of our CloudSec-Pro exam questions as we have been professional in this field, Palo Alto Networks Free CloudSec-Pro Download Pdf If you have any other questions just contact with us through online service or by email, and we will give a reply to you as quickly as possible, You really can't find a more cost-effective product than CloudSec-Pro Dumps learning quiz!
You can't step through code running on a database CloudSec-Pro Reliable Test Duration server, and any output generally winds up in an inaccessible log on the server somewhere, if anywhere at all, This is our target that helps you to make it easier to get CloudSec-Pro certification and you can find job more easily.
High-quality Palo Alto Networks Free CloudSec-Pro Download Pdf & Authorized PDF4Test - Leader in Certification Exam MaterialsWe believe you will get wonderful results with the help of our CloudSec-Pro Exam Questions as we have been professional in this field, If you have any other questions just contact with us CloudSec-Pro through online service or by email, and we will give a reply to you as quickly as possible.
You really can't find a more cost-effective product than CloudSec-Pro Dumps learning quiz, So stop hesitating, our CloudSec-Pro guide torrent are your right choice, At the same time, our CloudSec-Pro exam cram review will give you a vivid description to the intricate terminology, which makes you learn deeply and quickly.
DOWNLOAD the newest PDF4Test CloudSec-Pro PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=13QD5krmsUlmBfrllFHf0vBzLi-chnIVc
