[General] 1 year Of Free Salesforce Analytics-Con-301 Exam Questions Updates
104
General 1 year Of Free Salesforce Analytics-Con-301 Exam Questions Updates
Posted at 3/6/2026 18:28:08      View135 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New Analytics-Con-301 dumps are available on Google Drive shared by PassSureExam: https://drive.google.com/open?id=1U5zub3HAlEloi4_J208QKttbvrld5ixW
The curtain of life stage may be opened at any time, the key is that you are willing to show, or choose to avoid. Most of People who can seize the opportunityin front of them are successful. So you have to seize this opportunity of PassSureExam. Only with it can you show your skills. PassSureExam Salesforce Analytics-Con-301 Exam Training materials is the most effective way to pass the certification exam. With this certification, you will achieve your dreams, and become successful.
Salesforce Analytics-Con-301 Exam Syllabus Topics:
  • Business Consulting: For Tableau Consultants, this section involves designing and troubleshooting calculations and workbooks to meet advanced analytical use cases. It covers selecting appropriate chart types, applying Tableaus order of operations in calculations, building interactivity into dashboards, and optimizing workbook performance by resolving resource-intensive queries and other design-related issues.
  • IT Management: This domain measures skills related to managing Tableau environments. It includes planning server upgrades, recommending deployment solutions (on-premise or cloud), and ensuring alignment between technical and business requirements for analytics infrastructure. It also involves troubleshooting and optimizing system performance relevant to Tableau Server and Cloud deployments.
  • Data Visualization: This section evaluates the Tableau Consultants ability to design effective visual analytics solutions. It involves creating dashboards and visual reports that enhance user understanding, employing techniques like dynamic actions and advanced chart types, and ensuring performance optimization for an interactive user experience.
Salesforce Analytics-Con-301 exam study materialsWe offer you free demo for you to have a try before buying for Analytics-Con-301 learning materials, so that you can have a deeper understanding of what you are doing to buy. We recommend you to have a try before buying. Whats more, Analytics-Con-301 training materials cover most of knowledge points for the exam, and you can master major knowledge points for the exam as well as improve your professional ability in the process of learning. In order to build up your confidence for Analytics-Con-301 Exam Braindumps, we are pass guarantee and money back guarantee, and if you fail to pass the exam, we will give you refund.
Salesforce Certified Tableau Consultant Sample Questions (Q15-Q20):NEW QUESTION # 15
In what way does View Acceleration improve performance?
  • A. By optimizing the performance of views built only on extract-based data sources
  • B. By improving the performance of views that contain long-running queries with transient functions
  • C. By precompiling and fetching workbook data in a background process
  • D. By enhancing the rendering speed of visuals, such as drawing shapes and maps
View Acceleration is a Tableau Server and Tableau Cloud feature that speeds up slow-loading views by precomputing their queries in the background.
According to Tableau's server and cloud performance documentation:
* When View Acceleration is enabled for a view, Tableau runs the queries behind that view on a background process and stores the results in memory.
* When an end user later opens the view, Tableau can serve the precomputed results immediately, rather than running the potentially long-running queries at that moment.
* This improves initial load time significantly for views that are slow because of heavy queries.
It does not only work with extract-based data sources (it can also help with many live connections), so option A is too limited.
It does not change the client-side rendering engine, so option C is incorrect.
It is not specific to transient functions but to any view where the query is expensive, so option D is not accurate.
Therefore, the correct description is that View Acceleration precompiles and fetches workbook data in a background process, which matches option B.
* Tableau Server and Tableau Cloud help describing View Acceleration as precomputing and caching view results using background processes.
* Performance tuning guidance recommending View Acceleration for views with slow query execution.
NEW QUESTION # 16
A client is using the Tableau Content Migration Tool to move content from an old Tableau Server to a new Tableau Server.
Which content will need to be moved using a different tool or process?
  • A. Workbooks
  • B. Tableau Prep flows
  • C. Published data sources that use live connections
  • D. Published data sources that use extracts
When migrating content between Tableau servers, certain types of content may require special consideration or different tools for migration:
Tableau Prep Flows: These are specific to Tableau Prep and are not included in the standard content migration capabilities of the Tableau Content Migration Tool. Tableau Prep flows often require separate processes for migration due to their distinct setup and integration with data sources and workflows.
Published Data Sources and Workbooks: These can typically be migrated directly using the Tableau Content Migration Tool, which supports moving published data sources (both live connections and extracts) and workbooks without requiring additional tools.
Tableau Help and Support: Offers comprehensive tutorials and guidelines on using different tools for migrating various types of content, including the specific requirements for migrating Tableau Prep flows which are not covered by the standard content migration tool.
NEW QUESTION # 17
From the desktop, open the CC workbook. Use the US Population Estimates data source.
You need to shape the data in US Population Estimates by using Tableau Desktop. The data must be formatted as shown in the following table.
Open the Population worksheet. Enter the total number of records contained in the data set into the Total Records parameter.
From the File menu in Tableau Desktop, click Save.
See the complete Steps below in Explanation:
To shape the data in the "US Population Estimates" data source and enter the total number of records into the
"Total Records" parameter in Tableau Desktop, follow these steps:
* Open the CC Workbook and Access the Worksheet:
* From the desktop, double-click on the CC workbook to open it in Tableau Desktop.
* Navigate to the Population worksheet by selecting its tab at the bottom of the window.
* Format and Shape the Data:
* Ensure the data types match those specified in the requirements: Sex, Origin, Race as strings; Year, Age, Population as whole numbers.
* To verify or change the data type, click on the dropdown arrow next to each field name in the Data pane and select "Change Data Type" if necessary.
* Calculate Total Number of Records:
* Create a new calculated field named "Total Records". To do this, right-click in the Data pane and select "Create Calculated Field".
* Enter the formula COUNT([Record ID]) or SUM([Number of Records]) depending on how the data source identifies each row uniquely.
* Drag this new calculated field onto the worksheet to display the total number of records.
* Enter the Value into the Total Records Parameter:
* Locate the "Total Records" parameter in the Data pane. Right-click on the parameter and select
"Edit".
* Manually enter the number displayed from the calculated field into the parameter, ensuring accuracy to meet the data shaping requirement.
* Save Your Changes:
* From the File menu, click 'Save' to ensure all your changes are stored.
Tableau Desktop Guide: Provides detailed instructions on managing data types, creating calculated fields, and updating parameters.
Tableau Data Shaping Techniques: Outlines effective methods for manipulating and structuring data for analysis.
This process will ensure the data in the "US Population Estimates" is accurately shaped according to the specified format and that the total number of records is correctly calculated and entered into the designated parameter. This thorough approach ensures data integrity and accuracy in reporting.
NEW QUESTION # 18
A university has data on its undergraduate students and their majors by grade level (Freshman, Sophomore, Junior, Senior). The university is interested in visualizing the path students take as they change majors across grade levels.
Which visualization type should the consultant recommend?
  • A. Tree Chart
  • B. Chord Chart
  • C. Sankey Diagram
  • D. Radar Chart
To visualize the path students take as they change majors across different grade levels, a Sankey Diagram is highly effective. This type of visualization illustrates the flow and quantity between different stages or categories:
Sankey Diagram: It allows for a visual representation of students' movements between majors over time. Each flow's thickness is proportional to the number of students moving from one major to another, giving a clear, immediate visual cue of major popularity and student migration patterns.
To create a Sankey Diagram in Tableau, you typically need to prepare the data specifically for this type of chart. The data must include source (starting major), target (ending major), and the value (number of students). It often requires custom calculations and data reshaping to get the data in a format that a Sankey can use.
Once the data is prepared, you can use a combination of calculated fields, path binning, and line charts to simulate the flow effect in Tableau. External plugins or web-based integrations might also be employed for more direct implementations.
References
Sankey Diagrams are not natively supported in Tableau but can be implemented through creative use of data preparation and calculations, as suggested in advanced Tableau user communities and demonstrated in various Tableau public galleries.
NEW QUESTION # 19
A new Tableau user created a simple dashboard on Tableau Server using supply chain data. Now, the user wants to know if they created the dashboard in accordance with specific performance best practices.
Which approach should the consultant recommend for the client to make this determination?
  • A. Run Workbook Optimizer.
  • B. Use Performance Recording on Tableau Server.
  • C. Use Performance Recording in Tableau Desktop.
  • D. Use inbuilt dashboards in Tableau Server to troubleshoot the performance.
The Workbook Optimizer is a tool specifically designed to evaluate a workbook against performance best practices. It provides feedback on key design characteristics and offers concrete guidance on how to improve workbook performance. This tool is beneficial for both new and experienced Tableau users to ensure their dashboards are optimized for performance1.
References: The Workbook Optimizer's functionality is detailed in Tableau's official documentation, which explains how it assesses workbooks against a set of rules derived from best practices1. Additionally, the Performance Recording feature in Tableau Desktop and Server can be used to identify performance issues, but the Workbook Optimizer gives a more comprehensive analysis of the workbook's adherence to best practices23.
NEW QUESTION # 20
Over the past few years, we have gathered hundreds of industry experts, defeated countless difficulties, and finally formed a complete learning product - Analytics-Con-301 test answers, which are tailor-made for students who want to obtain Analytics-Con-301 certificates. Our customer service is available 24 hours a day. You can contact us by email or online at any time. In addition, all customer information for purchasing Analytics-Con-301 Test Torrent will be kept strictly confidential. We will not disclose your privacy to any third party, nor will it be used for profit. Then, we will introduce our products in detail.
Analytics-Con-301 Valid Cram Materials: https://www.passsureexam.com/Analytics-Con-301-pass4sure-exam-dumps.html
What's more, part of that PassSureExam Analytics-Con-301 dumps now are free: https://drive.google.com/open?id=1U5zub3HAlEloi4_J208QKttbvrld5ixW
