Salesforce AP-209 Actual Test - Reliable AP-209 Test Question
104
Posted at 3/6/2026 18:38:25      View:111 | Replies:0        Print      Only Author   [Copy Link] 1#
Our accurate, reliable, and top-ranked Advanced Field Service Accredited Professional (AP-209) exam questions will help you qualify for your Salesforce AP-209 certification on the first try. Do not hesitate and check out ExamTorrent excellent Advanced Field Service Accredited Professional (AP-209) practice exam to stand out from the rest of the others.
Salesforce AP-209 Exam Syllabus Topics:
  • Mobile: This domain covers offline functionality in the Field Service Mobile app, mobile customization and extension options, technician management capabilities, and communication features between dispatchers, technicians, and customers.
  • Resource Management: This domain focuses on managing resource availability, Service Territory Management capabilities, handling different resource types, and implementing optimal scheduling strategies for field service personnel.
  • Optimization: This domain covers using service objectives for automated scheduling, global optimization engine capabilities, troubleshooting optimization issues, and strategies to improve scheduling quality and efficiency.
  • Implementation Strategies and Design: This domain covers the full consulting project lifecycle from planning and requirements gathering through deployment, and determining appropriate deployment strategies and licensing needs for Field Service implementations.
Quiz 2026 Professional AP-209: Advanced Field Service Accredited Professional Actual TestIf you use our AP-209 practice test software, you can prepare for the exam in an atmosphere that is quite similar to the AP-209 real test, which will greatly aid in your preparation. The Salesforce AP-209 desktop practice exam software keeps track of your previous tries. This feature will help you identify where you need the most improvement so you can focus your efforts and boost your score the next time you take the Advanced Field Service Accredited Professional (AP-209) practice test.
Salesforce Advanced Field Service Accredited Professional Sample Questions (Q33-Q38):NEW QUESTION # 33
Out of the below options, which three questions should a consultant typically ask during the first day of an initial implementation?
  • A. What needs to be synced with Salesforce? What integration is needed with external apps?
  • B. What Service Objectives and what should their corresponding weights be within the different Scheduling Policies?
  • C. Which Dynamic Gantt features should be incorporated into the use cases?
  • D. What are the different types of services provided to customers? What are the skills required and the estimated duration?
  • E. How are the different business units set up? Geographical/ functional/ both?
Answer: A,D,E
During the "Day 1" or Scoping phase of an implementation, the goal is to define the high-level architecture and business model.
* A is correctefiningIntegrationpoints (ERP, HR, Inventory) is a foundational requirement that dictates the project scope and data strategy.
* D is correctefining theWork(Work Types, Skills, Durations) is the core of the Field Service data model. You cannot configure the system without knowing what services are being performed.
* E is correctefining theTerritory Structure(Business Units) sets up the security model, sharing settings, and resource organization.
* Options B and Care incorrect for thefirst daybecause they are detailed configuration specifics (Refinement). You cannot define "Service Objective Weights" or "Gantt Features" until you understand the basic business goals, services, and territories.
NEW QUESTION # 34
Green Energy Solutions would like to track their vehicles' availability, so that once a Work Order is created, both a Service Resource and a vehicle need to be assigned to the work, to ensure that the resource will use an available vehicle for the job.
How would a consultant recommend implementing this requirement?
  • A. Set the vehicle as a Service Resource, create a Work Order and two Service Appointments, one for the mobile worker and one for the vehicle, use 'Complex Work' with a dependency of type 'Immediately Follow'
  • B. Set the vehicle as a 'Required Product'. Once a resource is assigned to the work a 'vehicle' product will be consumed via the Field Service mobile App to indicate that this vehicle is being used
  • C. Set the vehicle as a Service Resource, create a Work Order and two Service Appointments, one for the mobile worker and one for the vehicle, use 'Complex Work' with a dependency of type 'Same Start'
  • D. Set the vehicle as a 'Required Product'. Once the Work Order is created it will inherit the 'Required Product' and notify the resource that this vehicle needs to be used for the job
The requirement is to schedule two distinct resources (a Human and a Vehicle) for the same job at the same time.
* Option C is correct.
* Vehicle as Service Resource:You must model the vehicle as a Service Resource (Type: Asset) to track its availability on the Gantt and prevent double-booking.
* Complex Work (Same Start):To ensure the vehicle and the technician are booked together, you use Complex Work dependencies. "Same Start" ensures that the vehicle appointment and the technician appointment are scheduled to begin simultaneously.
* Options A and Dare incorrect becauseProductsare not scheduled. Consuming a product does not check if the vehicle is available at that specific time, potentially leading to double-booking the van.
* Option Bis incorrect because "Immediately Follow" implies a sequence (Technician finishes -> Vehicle starts), which is not how a shared ride/equipment scenario works.
NEW QUESTION # 35
Which three topics should a consultant raise during the project scoping discussion of a field service implementation?
  • A. Work Parameters: how work is being defined
  • B. Sprint Review: to review what will be done during the sprint cycle
  • C. Project Objectives: what is essential
  • D. Terminology: translate objectives and priorities into Field Service
  • E. Solution Design: request for acceptance
Answer: A,C,D
During Scoping (the initial phase), the goal is to align on the "What" and "Why" before moving to the "How."
* Option A is correct (Work Parameters):You must define what constitutes a "Job" (Work Order), how long it takes, and what skills are needed. This is the foundation of the data model.
* Option C is correct (Terminology):Mapping the customer's language to Salesforce terms (e.g., "We have 'Truck Rolls' -> In Salesforce, that is a 'Service Appointment'") is crucial to avoid confusion throughout the project.
* Option D is correct (Project Objectives)efining what is "Essential" (MVP) vs. "Nice to Have" sets the project boundaries and success metrics.
* Option B (Sprint Review) happensduringthe build phase (Agile methodology), not during initial scoping.
* Option E (Solution Design) is theoutputof the scoping/analysis phase, not a topic you ask about during the initial discovery.
NEW QUESTION # 36
Universal Containers stores critical job information in the description field on the Service Appointment.
Dispatchers need to have a view into this data from the Gantt with minimal clicks, job information is often many characters.
What should a consultant recommend to meet their requirements?
  • A. Add the description field to the 'Service Tooltip Gantt' field set on Service Appointment, this field set controls the tooltip layout shown when hovering over an appointment on the Gantt
  • B. Add the description field to the 'Service Appointment List Columns' field set on Service Appointment.
    Adjust column widths to expose the entire description field, this field set controls the fields that appear in the appointment list as columns
  • C. Add the description field to the 'Service Appointment List Preview' field set on Service Appointment, this field set controls the fields that appear when a user hovers on the appointment information icon
  • D. Create a list view and add the description field as a column to appear in the Service Appointment list view within the Gantt
The requirement is to see data "from the Gantt" (the visual chart) with "minimal clicks."
* Option D is correct.TheService Tooltip Ganttfield set on the Service Appointment object controls the pop-up text box that appears when a dispatcherhoverstheir mouse over a Service Appointment bar on the Gantt chart. This requireszero clicksand is the fastest way to inspect details like "Description" without opening the full record.
* Options A, B, and C refer to the "Appointment List" (the textual list on the left side of the console).
While useful, scrolling through long descriptions in a list column is difficult (Option A) and requires looking away from the Gantt chart itself.
NEW QUESTION # 37
Which two statements are true regarding offline available inventory?
  • A. For multi-location inventory, the app primes multiple locations and related items, but there are limits to be aware of
  • B. The user's inventory is primed
  • C. Inventory items can be viewed offline but cannot be consumed offline
  • D. Multi-location inventory is not supported in the mobile app
  • E. Only the most recently created Inventory items created are primed
Offline capabilities are a critical feature of the Field Service mobile app.
* Option E is correct:The fundamental behavior of the app is to "rime" (download for offline use) the inventory associated with the Service Resource. This ensures that when a technician is in a basement with no signal, they can still view their van stock and consume parts (create Product Consumed records).
* Option B is correct:Salesforce Field Service supportsMulti-Location Inventory(e.g., a technician has a Van location and a Garage location). The app is capable of priming these additional locations so the tech can transfer stock between them. However, consultants must be aware of data volume limits (priming thousands of parts can slow down sync times), so configuration settings restrict how far back or how many items are synced.
* Option Dis incorrect because the app specifically allows for theconsumptionof parts while offline; the transactions sync back to the server once connectivity is restored.
NEW QUESTION # 38
We know that every user has their favorite. Therefore, we have provided three versions of AP-209 practice guide: the PDF, the Software and the APP online. You can choose according to your actual situation. If you like to use computer to learn, you can use the Software and the APP online versions of the AP-209 Exam Questions. If you like to write your own experience while studying, you can choose the PDF version of the AP-209 study materials. Our PDF version can be printed and you can take notes as you like.
Reliable AP-209 Test Question: https://www.examtorrent.com/AP-209-valid-vce-dumps.html
