[General] FCSS_SDW_AR-7.4 Frenquent Update, FCSS_SDW_AR-7.4 Test Dumps.zip
110
General FCSS_SDW_AR-7.4 Frenquent Update, FCSS_SDW_AR-7.4 Test Dumps.zip
Posted at 3/6/2026 20:09:19      View126 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New FCSS_SDW_AR-7.4 dumps are available on Google Drive shared by Test4Sure: https://drive.google.com/open?id=1QYCHRcrMET7CAavWqM1aDRrxGfUh2Suv
The language in our FCSS_SDW_AR-7.4 test guide is easy to understand that will make any learner without any learning disabilities, whether you are a student or a in-service staff, whether you are a novice or an experienced staff who has abundant experience for many years. Our FCSS - SD-WAN 7.4 Architect exam questions are applicable for everyone in all walks of life which is not depends on your educated level. Therefore, no matter what kind of life you live, no matter how much knowledge you have attained already, it should be a great wonderful idea to choose our FCSS_SDW_AR-7.4 Guide Torrent for sailing through the difficult test. On the whole, nothing is unbelievable, to do something meaningful from now, success will not wait for a hesitate person, go and purchase!
Test4Sure offers up-to-date Fortinet FCSS_SDW_AR-7.4 practice material consisting of three formats that will prove to be vital for you. You can easily ace the FCSS - SD-WAN 7.4 Architect (FCSS_SDW_AR-7.4) exam on the first attempt if you prepare with this material. The Fortinet FCSS_SDW_AR-7.4 Exam Dumps have been made under the expert advice of 90,000 highly experienced Fortinet professionals from around the globe. They assure that anyone who prepares from it will get Fortinet FCSS_SDW_AR-7.4 certified on the first attempt.
Don't Waste Time Preparing for Fortinet FCSS_SDW_AR-7.4 Exam. Crack it Instantly with This Proven MethodTest4Sure is an experienced website with great reputation which offering Fortinet dumps torrent and professional explanations. Our FCSS_SDW_AR-7.4 test questions are created by our IT elites who pay great attention to the IT exam certification so we can ensure you the authority and reliability of our FCSS_SDW_AR-7.4 Practice Test.
Fortinet FCSS_SDW_AR-7.4 Exam Syllabus Topics:
  • Configure Performances SLAs: Designed for network administrators, this part focuses on setting up performance Service Level Agreements (SLAs) within SD-WAN environments. Candidates must show proficiency in defining criteria to monitor and maintain network performance and reliability.
  • SD-WAN Configuration: This section of the exam measures the skills of network engineers and covers configuring a basic SD-WAN setup. Candidates are expected to demonstrate their ability to define SD-WAN members and zones effectively, ensuring foundational network segmentation and management.
  • Rules and Routing: Targeted at network engineers, this section assesses the ability to configure SD-WAN rules and routing policies. Candidates will be tested on managing traffic flow and prioritization across the SD-WAN infrastructure.
  • Advanced IPsec: Intended for security engineers, this section covers the deployment of advanced IPsec topologies for SD-WAN, including hub-and-spoke models, ADVPN configurations, and complex multi-hub or multi-region deployments. Candidates need to demonstrate expertise in securing wide-area networks using IPsec technologies.
Topic 5
  • Centralized Management: This domain evaluates network administrators competence in deploying and managing SD-WAN configurations centrally using FortiManager. It includes tasks such as implementing branch configurations and utilizing overlay templates to streamline network management.
Fortinet FCSS - SD-WAN 7.4 Architect Sample Questions (Q57-Q62):NEW QUESTION # 57
An administrator is configuring SD-WAN to load balance their network traffic. Which two things should they consider when setting up SD-WAN? (Choose two.)
  • A. You can select the outbandwidth hash mode with all strategies that allow load balancing.
  • B. Only the manual and best-quality strategies allow SD-WAN load balancing.
  • C. When applicable, FortiGate load balances the traffic through all members that meet the SLA target.
  • D. SD-WAN load balancing is possible only using the best quality and lowest cost (SLA) strategies.
FortiGate load balances traffic across all members that meet the SLA targets, depending on the strategy used.
The outbandwidth hash mode can be selected with load-balancing strategies to distribute traffic based on flow characteristics.
NEW QUESTION # 58
You are planning a large SD-WAN deployment with approximately 1000 spokes and want to allow ADVPN between the spokes. Some remote sites use FortiSASE to connect to the company's SD-WAN hub. Which overlay routing configuration should you use?
  • A. BGP per overlay with dynamic BGP for ADVPN shortcut routing.
  • B. BGP on loopback with dynamic BGP for ADVPN shortcut routing.
  • C. BGP on loopback with IPsec phase2 selectors for ADVPN shortcut routing.
  • D. BGP per overlay with BGP next-hop convergence for ADVPN shortcut routing.
For a large-scale SD-WAN deployment (such as 1000 spokes) where ADVPN shortcut routing is required and some remote sites connect via FortiSASE, the recommended overlay routing configuration is BGP running on loopback interfaces, combined with dynamic BGP for ADVPN shortcut routing. This design leverages the scalability and resilience of BGP, allowing dynamic discovery and route exchange necessary for shortcut tunnels between spokes in ADVPN environments. Using loopback interfaces for BGP peering is considered best practice because it decouples routing protocol stability from physical link status, ensuring that if a physical underlay interface fails, the BGP session remains up as long as there's an alternate path. With dynamic BGP, each spoke can efficiently learn the routes to other spokes and dynamically establish shortcuts, which is critical at this scale. This method also integrates smoothly with FortiSASE for remote connectivity to the SD-WAN hub, providing flexibility and centralized management.
[FCSS_SDW_AR-7.4 1-0.docx Q6]
Fortinet SD-WAN Reference Architecture Guide 7.4, "Scalable Routing with BGP on Loopback and ADVPN Shortcuts" Fortinet SD-WAN Concept Guide, "Overlay Routing Designs for Large Deployments"
NEW QUESTION # 59
Refer to the exhibit, which shows an SD-WAN zone configuration on the FortiGate GUI. What can you conclude about the zone and member configuration on this device?
  • A. The overlay-factories zone contains no member.
  • B. You can delete the virtual-wan-link zones.
  • C. The underlay zone contains three members.
  • D. You can move HUB1-VPN3 from the HUB1 zone to the overlay-shops zone.
NEW QUESTION # 60
Which statement best describe the role of the ADVPN device in handling traffic?
  • A. This is a spoke. The kernel received a shortcut request and forwards the query to another spoke.
  • B. This is a hub that has received a query from a spoke and has forwarded it to another spoke.
  • C. This is a hub in a dual-region topology. The remote hub tunnel ID is 10.0.2.101.
  • D. This is a spoke that has received a shortcut query from another spoke and has forwarded the response to its hub.
Within ADVPN topologies, shortcut requests and responses traverse spokes and hubs. Fortinet documentation states:
"When a spoke receives a shortcut query from another spoke, it may forward the response to its hub for validation or to facilitate dynamic shortcut tunnel setup. This mechanism allows direct spoke-to-spoke communication for optimized routing and performance, reducing latency and offloading the hub after initial control-plane mediation." This is a core benefit of ADVPN's dynamic shortcut feature.
NEW QUESTION # 61
Refer to the exhibits. The exhibits show two IPsec templates to define Branch IPsec 1 and Branch_IPsec_2. Each template defines a VPN tunnel. The error message that FortiManager displayed when the administrator tried to assign the second template to the FortiGate device is also shown. Which statement best describes the cause of the issue?
  • A. You should review the branch1_fgt configuration for configured tunnels in the rootVDOM.
  • B. You can assign only one template with a tunnel type of static to each FortiGate device.
  • C. You can assign only one IPsec template to each FortiGate device.
  • D. You should use the same outgoing interface of both templates.
FortiManager allows only one IPsec template to be assigned per FortiGate device. The error indicates a conflicting template assignment, meaning assigning both Branch_IPsec_1 and Branch_IPsec_2 to the same device (branch1_fgt) is not permitted.
NEW QUESTION # 62
As the tech industry continues to evolve and adapt to new technologies, professionals who hold the FCSS - SD-WAN 7.4 Architect (FCSS_SDW_AR-7.4) certification are better equipped to navigate these changes and stay ahead of the curve, increasing their value to employers and clients. In today's fast-paced and ever-changing Fortinet sector, having the Fortinet FCSS_SDW_AR-7.4 Certification has become a necessary requirement for individuals looking to advance their careers and stay competitive in the job market.
FCSS_SDW_AR-7.4 Test Dumps.zip: https://www.test4sure.com/FCSS_SDW_AR-7.4-pass4sure-vce.html
What's more, part of that Test4Sure FCSS_SDW_AR-7.4 dumps now are free: https://drive.google.com/open?id=1QYCHRcrMET7CAavWqM1aDRrxGfUh2Suv
