[General] IIBA-CCA Practice Test Online - New IIBA-CCA Exam Vce
105
General IIBA-CCA Practice Test Online - New IIBA-CCA Exam Vce
Posted at 3/6/2026 21:07:22      View140 | Replies0        Print      Only Author   [Copy Link] 1#
This certification gives us more opportunities. Compared with your colleagues around you, with the help of our IIBA-CCA preparation questions, you will also be able to have more efficient work performance. Our IIBA-CCA study materials can bring you so many benefits because they have the following features. I hope you can use a cup of coffee to learn about our IIBA-CCA training engine. Perhaps this is the beginning of your change.
Therefore, you have the option to use IIBA IIBA-CCA PDF questions anywhere and anytime. IIBA-CCA dumps are designed according to the Certificate in Cybersecurity Analysis (IIBA-CCA) certification exam standard and have hundreds of questions similar to the actual IIBA-CCA Exam. Prep4cram Certificate in Cybersecurity Analysis (IIBA-CCA) web-based practice exam software also works without installation.
TOP IIBA-CCA Practice Test Online - High-quality IIBA Certificate in Cybersecurity Analysis - New IIBA-CCA Exam VceThe IIBA-CCA practice materials are a great beginning to prepare your exam. Actually, just think of our IIBA-CCA practice materials as the best way to pass the exam is myopic. They can not only achieve this, but ingeniously help you remember more content at the same time. It is estimated conservatively that the passing rate of the exam is over 98 percent with our IIBA-CCA Study Materials as well as considerate services. We not only provide all candidates with high pass rate study materials, but also provide them with good service.
IIBA Certificate in Cybersecurity Analysis Sample Questions (Q24-Q29):NEW QUESTION # 24
What is a Recovery Point Objective RPO?
  • A. The point in time prior to the outage to which business and process data must be recovered
  • B. The target time to restore systems to operational status following an outage
  • C. The maximum time a system may be out of service before a significant business impact occurs
  • D. The target time to restore a system without experiencing any significant business impact
A Recovery Point Objective defines the acceptable amount of data loss measured in time. It answers the question: "After an outage or disruptive event, how far back in time can we restore data and still meet business needs?" If the RPO is 4 hours, the organization is stating it can tolerate losing up to 4 hours of data changes, meaning backups, replication, journaling, or snapshots must be frequent enough to restore to a point no older than 4 hours before the incident. That is exactly what option A describes: the specific point in time prior to the outage to which data must be recovered.
RPO is often paired with Recovery Time Objective but they are not the same. RTO focuses on how quickly service must be restored, while RPO focuses on how much data the organization can afford to lose. Options B, C, and D all describe time-to-restore concepts, which align with RTO or related recovery targets rather than RPO.
In operational resilience and disaster recovery planning, RPO drives technical design choices: backup frequency, replication methods, storage and retention strategies, and validation testing. Lower RPO values generally require more robust and often more expensive solutions, such as near-real-time replication and strong change capture controls. RPO also influences incident response and recovery procedures to ensure restoration steps reliably meet the agreed data-loss tolerance.
Top of Form
NEW QUESTION # 25
What is risk mitigation?
  • A. Documenting the risk in full and preparing a recovery plan
  • B. Reducing the risk by implementing one or more countermeasures
  • C. Eliminating the risk by stopping the activity which causes risk
  • D. Purchasing insurance against a cybersecurity breach
Risk mitigation is the risk treatment approach focused on reducing risk to an acceptable level by lowering either the likelihood of a risk event, the impact of that event, or both. In cybersecurity risk management, mitigation is accomplished by implementing controls and countermeasures such as technical safeguards, process changes, and administrative measures. Examples include patching vulnerable systems, hardening configurations, enabling multi-factor authentication, applying least privilege, network segmentation, encryption, improved logging and monitoring, secure development practices, and user awareness training. Each of these actions reduces exposure or limits damage if an incident occurs.
The other options describe different risk treatment strategies, not mitigation. Purchasing insurance is generally considered risk transfer, where financial impact is shifted to a third party, but the underlying threat and vulnerability may still exist. Eliminating risk by stopping the risky activity is risk avoidance; it removes the exposure by discontinuing the process, system, or behavior causing the risk. Documenting the risk and preparing a recovery plan aligns more closely with risk acceptance combined with contingency planning or resilience planning; it acknowledges the risk and focuses on recovery rather than reducing the probability of occurrence.
Therefore, the correct definition of risk mitigation is reducing the risk through implementing one or more countermeasures.
NEW QUESTION # 26
A significant benefit of role-based access is that it:
  • A. simplifies the assignment of correct access levels to a user based on the work they will perform.
  • B. ensures that employee accounts will be shut down on departure or role change.
  • C. ensures that tasks and associated privileges for a specific business process are disseminated among multiple users.
  • D. makes it easier to audit and verify data access.
Role-based access control assigns permissions to defined roles that reflect job functions, and users receive access by being placed into the appropriate role. The major operational and security benefit is that it simplifies and standardizes access provisioning. Instead of granting permissions individually to each user, administrators manage a smaller, controlled set of roles such as Accounts Payable Clerk, HR Specialist, or Application Administrator. When a new employee joins or changes responsibilities, access can be adjusted quickly and consistently by changing role membership. This reduces manual errors, limits over-provisioning, and helps enforce least privilege because each role is designed to include only the permissions required for that function.
RBAC also improves governance by making access decisions more repeatable and policy-driven. Security and compliance teams can review roles, validate that each role's permissions match business needs, and require approvals for changes to role definitions. This approach supports segregation of duties by separating conflicting capabilities into different roles, which lowers fraud and misuse risk.
Option B is a real advantage of RBAC, but it is typically a secondary outcome of having structured roles rather than the primary "significant benefit" emphasized in access-control design. Option C relates to identity lifecycle processes such as deprovisioning, which can be integrated with RBAC but is not guaranteed by RBAC alone. Option D describes distributing tasks among multiple users, which is more aligned with segregation of duties design, not the core benefit of RBAC.
NEW QUESTION # 27
How should categorization information be used in business impact analysis?
  • A. To identify discrepancies between the security categorization and the expected business impact
  • B. To determine the time and effort required for business impact assessment
  • C. To ensure that systems are designed to support the appropriate security categorization
  • D. To assess whether information should be shared with other systems
Security categorization (commonly based on confidentiality, integrity, and availability impact levels) is meant to reflect the level of harm that would occur if an information type or system is compromised. A business impact analysis, on the other hand, examines the operational and organizational consequences of disruptions or failures-such as loss of revenue, inability to deliver critical services, legal or regulatory exposure, reputational harm, and impacts to customers or individuals. Because these two activities look at impact from different but related perspectives, categorization information should be used during the BIA to confirm that the stated security categorization truly matches real business consequences.
Using categorization as an input helps analysts validate assumptions about criticality, sensitivity, and tolerance for downtime. If the BIA shows that outages or data compromise would produce greater harm than the existing categorization implies, that discrepancy signals under-classification and insufficient controls. Conversely, if the BIA demonstrates limited impact, it may indicate over-classification, potentially driving unnecessary cost and operational burden. Identifying these mismatches early supports better risk decisions, prioritization of recovery objectives, and selection of controls proportionate to actual impact.
The other options describe activities that may occur in architecture, governance, or project planning, but they are not the primary purpose of using categorization information in a BIA. The key value is reconciliation: aligning security impact levels with verified business impact.
NEW QUESTION # 28
What is whitelisting in the context of network security?
  • A. Denying access to applications that have been determined to be malicious
  • B. Running software to identify any malware present on a computer system
  • C. Explicitly allowing identified people, groups, or services access to a particular privilege, service, or recognition
  • D. Grouping assets together based on common security requirements, and placing each group into an isolated network zone
Whitelisting, often called an "allow list," is a security approach where access is granted only to explicitly approved identities, services, applications, IP addresses, domains, or network flows. In network security, this means the default stance is "deny by default," and only pre-authorized entities are allowed to communicate or use specific resources. Option C matches this definition because it describes the core idea: explicitly permitting known, approved subjects (people, groups, service accounts, systems) to access a defined privilege or service.
Cybersecurity documents emphasize whitelisting as a strong risk-reduction technique because it constrains the attack surface. Instead of trying to block every bad thing (which is difficult due to evolving threats), whitelisting focuses on allowing only what is required for business operations. Examples include firewall rules that only permit specific source IPs to reach an admin interface, network segmentation policies that allow only required ports between zones, and application whitelisting that permits only approved executables to run. When implemented correctly, it reduces lateral movement opportunities, limits command-and-control traffic, and prevents unauthorized tools from executing.
Whitelisting is different from segmentation (option A), which is about isolating zones based on security needs, and different from blacklisting (option B), which blocks known-bad items. It is also not malware scanning (option D), which detects malicious code after it appears. Whitelisting aligns with least privilege and zero trust principles by tightly controlling what is allowed.
NEW QUESTION # 29
If you want to buy IIBA IIBA-CCA Exam Study Guide online services, then we Prep4cram is one of the leading service provider's site. These training products to help you pass the exam, we guarantee to refund the full purchase cost. Our website provide all the study materials and other training materials on the site and each one enjoy one year free update facilities. If these training products do not help you pass the exam, we guarantee to refund the full purchase cost.
New IIBA-CCA Exam Vce: https://www.prep4cram.com/IIBA-CCA_exam-questions.html
If you want to learn IIBA-CCA practice guide anytime, anywhere, then we can tell you that you can use our products on a variety of devices, After your successful payment of our IIBA-CCA study material, you will get another convenience which is the most convenient and unique feature of our IIBA-CCA training vce, Our IIBA-CCA free download pdf can meet your requirement and help you pass with ease.
Broadcast: Multicast is used to dynamically discover neighbors, IIBA-CCA Moreover, in the absence of a test suite, the makers of standards found themselves in an odd position.
If you want to learn IIBA-CCA Practice Guide anytime, anywhere, then we can tell you that you can use our products on a variety of devices, After your successful payment of our IIBA-CCA study material, you will get another convenience which is the most convenient and unique feature of our IIBA-CCA training vce.
IIBA-CCA - Certificate in Cybersecurity Analysis Pass-Sure Practice Test OnlineOur IIBA-CCA free download pdf can meet your requirement and help you pass with ease, Of course, we do not take this for granted, IIBA-CCA test dumps are edited by Prep4cram professional experts, and the IIBA-CCA test training is customized according to the customer's feedback.
