Valid 1Z0-947 Exam Objectives & 1Z0-947 Practice Tests
78
Posted at 3/6/2026 21:26:17      View83 | Replies0        Print      Only Author   [Copy Link] 1#
2026 Latest Itexamguide 1Z0-947 PDF Dumps and 1Z0-947 Exam Engine Free Share: https://drive.google.com/open?id=1vLCgIEB1o-aRlLw5qtEF07rrwNTeUciL
There are a lot of users of 1Z0-947 learning prep, and our staff has come in contact with various kinds of help. Therefore, you can rest assured that we can solve any problem you have with our 1Z0-947 exam questions. If you are concerned that online services are relatively indifferent, the staff at 1Z0-947 practice quiz will definitely change your mind. Our staff really regards every user as a family member and sincerely provides you with excellent service.
No study materials can boost so high efficiency and passing rate like our 1Z0-947 exam reference when preparing the test 1Z0-947 certification. Our 1Z0-947 exam practice questions provide the most reliable exam information resources and the most authorized expert verification. Our test bank includes all the possible questions and answers which may appear in the real exam and the quintessence and summary of the exam papers in the past. We strive to use the simplest language to make the learners understand our 1Z0-947 Exam Reference and passed the 1Z0-947 exam.
1Z0-947 Practice Tests | 1Z0-947 Exam DetailsThe Oracle 1Z0-947 certification exam is one of the best credentials in the modern Oracle world. The Oracle GoldenGate 19c Implementation Professional (1Z0-947) certification offers a unique opportunity for beginners or experienced professionals to demonstrate their expertise and knowledge with an industry-recognized certificate. With the Oracle GoldenGate 19c Implementation Professional (1Z0-947) exam dumps, you can not only validate your skill set but also get solid proof of your proven expertise and knowledge.
Oracle GoldenGate 19c Implementation Professional Sample Questions (Q108-Q113):NEW QUESTION # 108
How should you specify the data source for a secondary Extract functioning as a Data Pump?
  • A. SOURCEISTRAIL
  • B. LOCTRAILSOURCE
  • C. SOURCEISSTABLE
  • D. EXTTRAILSOURCE
For a secondary Extract functioning as a Data Pump, you should specify the data source using EXTTRAILSOURCE. This parameter tells GoldenGate to use the local trail file (created by the primary Extract) as the source for the data pump.
NEW QUESTION # 109
What Oracle GoldenGate microservices component is used to handle all incoming trail files?
  • A. Trail File server
  • B. Administration server
  • C. Service Manager
  • D. Receiver server
The Receiver Server is the GoldenGate Microservices component that handles all incoming trail files, replacing the need for multiple Collectors on the target side. It supports WebSockets and other protocols to securely receive data from the Distribution Server
NEW QUESTION # 110
What is the purpose of a data pump Extract in Oracle GoldenGate?
  • A. Directly applies changes to target
  • B. Encrypts trail files
  • C. Reads from local trail and forwards to remote system
  • D. Monitors performance metrics
It allows recovery if the network or target system fails by maintaining a local trail.
NEW QUESTION # 111
Initial Load is a process of extracting data records from the source database and loading those records onto the target database. There are many advantages in using GoldenGate to obtain the data from the source and load the records onto the target. What describes the advantage of continuing to make data changes on the source database while loading data onto the target database?
  • A. Enable data changes on source tables without locking tables.
  • B. Enable Extract to indicate in the trail file when initial load commenced.
  • C. Enable the LGWR to indicate in the transaction log when initial load commenced.
  • D. Enable change delivery to handle collisions with initial load.
"Oracle GoldenGate can perform a one-time initial load while the source tables remain online and active. You do not need to lock the source tables during the load. Oracle GoldenGate tracks ongoing changes with Change Data Capture (CDC) and applies them after the load completes."
NEW QUESTION # 112
What is the adminclient in GoldenGate MA?
  • A. A browser-based management tool
  • B. A CLI tool that uses REST APIs to manage deployments
  • C. A background replication daemon
  • D. A GUI for performance metrics visualization
Command-line utility (like GGSCI) using REST API for Microservices Architecture control/config.
NEW QUESTION # 113
You only need 20-30 hours to practice our software and then you can attend the exam. You neednt spend too much time to learn our 1Z0-947 study questions and you only need spare several hours to learn our Oracle GoldenGate 19c Implementation Professional guide torrent each day. Our 1Z0-947 study questions are efficient and can guarantee that you can pass the exam easily. For many people, they dont have enough time to learn the 1Z0-947 Exam Torrent. The in-service staff is both busy in their jobs and their family lives and for the students they may have to learn or do other things. But if you buy our 1Z0-947 exam torrent you can save your time and energy and spare time to do other things. Please trust us.
1Z0-947 Practice Tests: https://www.itexamguide.com/1Z0-947_braindumps.html
Here, 1Z0-947 pdf test dumps can solve your worries and problem, There are 1Z0-947 free demo in our exam page for your reference and one-year free update are waiting for you, Oracle Valid 1Z0-947 Exam Objectives You can test your true level through simulated exams, Whenever you have questions about our 1Z0-947 training braindumps, you are welcome to contact us via E-mail, We offer Oracle 1Z0-947 desktop practice test software which works on Windows computers after installation.
Upload photos and create and manage albums, In other words, the chapter isn't so much about how to write scripts as about how to make them run faster, Here, 1Z0-947 PDF test dumps can solve your worries and problem.
The Best Valid 1Z0-947 Exam Objectives & Leader in Qualification Exams & Authorized Oracle Oracle GoldenGate 19c Implementation ProfessionalThere are 1Z0-947 free demo in our exam page for your reference and one-year free update are waiting for you, You can test your true level through simulated exams.
P.S. Free 2026 Oracle 1Z0-947 dumps are available on Google Drive shared by Itexamguide: https://drive.google.com/open?id=1vLCgIEB1o-aRlLw5qtEF07rrwNTeUciL
