[Hardware] Study Materials F5CAB2 Review - F5CAB2 Latest Demo
80
Hardware Study Materials F5CAB2 Review - F5CAB2 Latest Demo
Posted at 3/7/2026 01:45:57      View196 | Replies1        Print      Only Author   [Copy Link] 1#
The experts in our company have been focusing on the F5CAB2 examination for a long time and they never overlook any new knowledge. The content of our study materials has always been kept up to date. Don't worry if any new information comes out after your purchase of our F5CAB2 study guide. We will inform you by E-mail when we have a new version. With our great efforts, our study materials have been narrowed down and targeted to the F5CAB2 examination. So you don't need to worry about wasting your time on useless F5CAB2 exam materials information.
Perhaps now you are one of the candidates of the F5 F5CAB2 exam, perhaps now you are worried about not passing the exam smoothly. Now we have good news for you: our F5CAB2 study materials will solve all your worries and help you successfully pass it. With the high pass rate as 98% to 100%, you will find that we have the best BIG-IP Administration Data Plane Concepts (F5CAB2) F5CAB2 learning braindumps which contain the most accurate real exam questions.
Three Easy-to-Use Formats of Pass4Leader F5CAB2 ExamSharp tools make good work. Valid F5CAB2 test questions and answers will make your exam easily. If you still feel difficult in passing exam, our products are suitable for you. F5CAB2 test questions and answers are worked out by Pass4Leader professional experts who have more than 8 years in this field. With so many years' development, we can keep stable high passing rate for F5 F5CAB2 Exam. You will only spend dozens of money and 20-30 hours' preparation on our F5CAB2 test questions, passing exam is easy for you.
F5 F5CAB2 Exam Syllabus Topics:
  • Explain the relationship between interfaces, trunks, VLANs, self-IPs, routes and their status
  • statistics: This domain covers BIG-IP networking components including interfaces, trunks, VLANs, self-IPs, and routes, their dependencies and status, plus predicting traffic paths and egress IPs.
  • Identify the different virtual server types: This domain covers BIG-IP virtual server types: Standard, Forwarding, Stateless, Reject, Performance Layer 4, and Performance HTTP.
  • Define ADC application objects: This domain covers ADC basics including application objects, load balancing methods, server selection, and key ADC features and benefits.
  • Determine expected traffic behavior based on configuration: This domain focuses on predicting traffic behavior based on persistence, processing order, object status, egress IPs, and connection
  • rate limits.
Topic 5
  • Explain high availability (HA) concepts: This domain addresses HA concepts including integrity methods, implementation approaches, and advantages of high availability configurations.
F5 BIG-IP Administration Data Plane Concepts (F5CAB2) Sample Questions (Q12-Q17):NEW QUESTION # 12
A BIG-IP Administrator assigns the default HTTP health monitor to a pool that has three members listening on port 80. When the administrator connects to each pool member using the curl utility, two of the members respond with a status of 404 Not Found, while the third responds with 200 OK. What will the pool show for member availability? (Choose one answer)
  • A. Two members offline and one member online
  • B. Two members online and one member offline
  • C. All members offline
  • D. All members online
Comprehensive and Detailed Explanation From BIG-IP Administration Data Plane Concepts documents:
In BIG-IP LTM, health monitors are used to determine the availability of pool members and directly influence traffic flow decisions in the data plane.
Key characteristics of the default HTTP monitor according to BIG-IP Administration Data Plane Concepts:
Sends an HTTP request (typically GET /)
Expects an HTTP response code of 200 OK
Any response other than 200 is treated as a monitor failure
A failed monitor causes the pool member to be marked offline (down)
In this scenario:
Two pool members return 404 Not Found
A 404 response indicates that the requested object was not found
This does not meet the success criteria of the default HTTP monitor
These two members are therefore marked offline
One pool member returns 200 OK
This matches the expected response
The member is marked online
Resulting Pool Member Availability:
2 members: Offline
1 member: Online
Why the Other Options Are Incorrect:
B - 404 responses are not considered healthy by the default HTTP monitor C - At least one member responds with the expected 200 OK D - Members returning 404 responses fail the monitor and cannot be marked online Key Data Plane Concept Reinforced:
BIG-IP health monitors make binary availability decisions based strictly on configured success criteria. For HTTP monitors, response codes matter-404 is a failure, even if the service is technically reachable.
NEW QUESTION # 13
A BIG-IP Administrator has acluster of devices.
What should the administrator doafter creating a new Virtual Server on device 1? (Choose one answer)
  • A. Create a new cluster on device 1
  • B. Synchronize the settings ofdevice 1 to the group
  • C. Synchronize the settings of thegroup to device 1
  • D. Create a new virtual server on device 2
In a BIG-IPdevice service cluster, configuration objects such asvirtual servers, pools, profiles, and iRules are maintained throughconfiguration synchronization (config-sync).
Key BIG-IP concepts involved:
* Device Service Cluster (DSC)A cluster is a group of BIG-IP devices that share configuration data. One device is typically used to make changes, which are then synchronized to the rest of the group.
* Config-Sync Direction Matters
* Changes are made on alocal device
* Those changes must bepushed to the group
* The correct operation is"Sync Device to Group"
WhyCis correct:
* The virtual server was createdonly on device 1
* Other devices in the cluster do not yet have this object
* To propagate the new virtual server to all cluster members, the administrator mustsynchronize device 1 to the group Why the other options are incorrect:
* A. Synchronize the settings of the group to device 1This would overwrite device 1's configuration with the group's existing configuration and mayremove the newly created virtual server.
* B. Create a new cluster on device 1The cluster already exists. Creating a new cluster is unnecessary and disruptive.
* D. Create a new virtual server on device 2This defeats the purpose of centralized configuration management and risks configuration drift.
Conclusion:
After creating a new virtual server on a BIG-IP device that is part of a cluster, the administrator must synchronize the configuration from that device to the groupso all devices share the same ADC application objects.
NEW QUESTION # 14
* Sends an HTTP request (typically GET /)
* Expects an HTTP response code of 200 OK
* Any response other than 200 is treated as a monitor failure
* A failed monitor causes the pool member to be marked offline (down)
In this scenario:
* Two pool members return 404 Not Found
* A 404 response indicates that the requested object was not found
* This does not meet the success criteria of the default HTTP monitor
* These two members are therefore marked offline
* One pool member returns 200 OK
* This matches the expected response
* The member is marked online
* 2 members: Offline
* 1 member: Online
* B - 404 responses are not considered healthy by the default HTTP monitor
* C - At least one member responds with the expected 200 OK
* D - Members returning 404 responses fail the monitor and cannot be marked online Key Data Plane Concept Reinforced:
NEW QUESTION # 15
The diagram below shows the TCP connection setup for an application.
Which of the following virtual server types applies? (Choose one answer)
  • A. Stateless virtual server
  • B. Forwarding IP virtual server
  • C. Standard virtual server
The diagram illustrates a specific TCP handshake sequence where the BIG-IP system acts as a transparent forwarder rather than a full proxy. The key indicators that identify this as aForwarding (IP) virtual server are as follows:
* Initial Packet Processing: The diagram explicitly states that the LTM evaluates the packet lookingonly at the destination IP address. This is the fundamental characteristic of a Forwarding IP virtual server, which uses the system's routing table to make forwarding decisions instead of load balancing to a pool of members.
* Handshake Sequence: Unlike aStandardvirtual server, which completes the three-way handshake with the client (SYN, SYN-ACK, ACK)beforeinitiating a separate connection to the server, the Forwarding IP virtual server passes the client's originalSYNpacket directly to the destination node.
* Response Timing: The BIG-IP system waits for theSYN-ACKfrom the destination node before it sends a SYN-ACK back to the client. It essentially "passes through" the handshake signals while still maintaining a state entry in the connection table to track the flow.
* Packet-by-Packet Logic: While it tracks the state, it does not perform address translation (unless SNAT is specifically configured) or deep packet inspection like a full proxy would.
* Standard virtual server: A Standard virtual server is a "full proxy." It would finish the handshake with the client first and only then open a second, independent TCP connection to the backend server.
* Stateless virtual server: A stateless virtual server does not track connections in the connection table.
The diagram shows the system meticulously passing sequence numbers ($seq_num$) and acknowledgment numbers ($ack_num$) between the two sides, which requires stateful tracking of the TCP flow.
NEW QUESTION # 16
A BIG-IP is configured with a pool member located on a different subnet that is not local to the BIG-IP. To ensure that the return traffic from the pool member is sent to the client through the BIG-IP, a Source NAT (SNAT) is used and configured for SNAT Automap. The BIG-IP has a default gateway on the external VLAN, a floating and non-floating self-IP address on each VLAN, and a management address. Which IP address will the BIG-IP use as the source address for the traffic to the pool member when client traffic is sent through the virtual server?
  • A. The source address will be the management IP address.
  • B. The source address will be the floating self-IP address on the egress VLAN.
  • C. The source address will be the non-floating self-IP address on the egress VLAN.
  • D. The source address will be the first address available in the list of self-IPs.
SNAT Automapis a feature that automatically selects a self-IP address to use as the source address for translated packets. The selection logic follows a strict hierarchy to ensure that traffic is routable back to the BIG-IP:
* Egress VLAN Priority:The BIG-IP first looks at the VLAN through which the traffic is exiting toward the pool member (the egress VLAN).
* Floating Self-IP Preference:If the egress VLAN has afloating self-IP address, the BIG-IP will always prefer it for SNAT Automap. This is critical for High Availability (HA) because, during a failover, the floating IP moves to the new active device, allowing existing connections to be maintained or correctly timed out.
* Non-Floating Fallback:If no floating self-IP is available on the egress VLAN, the system will use a floating self-IP from a different VLAN. If no floating IPs exist at all, it will then fall back to the non- floating self-IP.
Key Data Plane Concept:
The management IP is never used for data plane traffic. In this scenario, since the administrator has configured a floating self-IP, that specific address becomes the source for all SNAT Automap traffic leaving that VLAN to ensure symmetric routing during HA events.
NEW QUESTION # 17
Even the fierce competition cannot stop demanding needs from exam candidates. To get more specific information about our F5CAB2 learning quiz, we are here to satisfy your wish with following details. So you can get detailed information with traits and information about our F5CAB2 Real Exam requested on the website. You can free download the demos of our F5CAB2 exam questions and click on every detail that you are interested.
F5CAB2 Latest Demo: https://www.pass4leader.com/F5/F5CAB2-exam.html
Posted at 3/10/2026 22:33:51        Only Author  2#
Thank you for sharing your article, its truly amazing! Im just about to take the New CAMS exam sims exam. Wish me success!
