Posted at 3/7/2026 02:20:42
從Google Drive中免費下載最新的Fast2test CT-AI PDF版考試題庫:https://drive.google.com/open?id=172NovsL--UEMbMN8s8LgTkhRengz2lDW
我們Fast2test ISTQB的CT-AI的考試考古題是經過實踐檢驗的,我們可以提供基於廣泛的研究和現實世界的經驗,我們Fast2test擁有超過計畫0年的IT認證經驗,CT-AI考試培訓,包括問題和答案。在互聯網上,你可以找到各種培訓工具,準備自己的CT-AI考試認證,Fast2test的CT-AI考試試題及答案是最好的培訓資料,我們提供了最全面的驗證問題及答案,讓你得到一年的免費更新期。
如果你已經決定通過ISTQB的CT-AI考試,Fast2test在這裏,可以幫助你實現你的目標,我們更懂得你需要通過你的ISTQB的CT-AI考試,我們承諾是為你高品質的考古題,科學的考試,過Fast2test的ISTQB的CT-AI考試。
可靠的CT-AI更新 |高通過率的考試材料|值得信賴的CT-AI:Certified Tester AI Testing ExamFast2test提供的產品有很高的品質和可靠性。你可以先在網上免費下載部分Fast2test提供的關於ISTQB CT-AI 認證考試的練習題和答案作為嘗試。在你使用之後,相信你會很滿意我們的產品的。這麼好的一個能幫助你順利通過考試的產品,你還在猶豫什麼,快將Fast2test的產品加入您的購物車吧。
ISTQB CT-AI 考試大綱:| 主題 | 簡介 | | 主題 1 | - Testing AI-Based Systems Overview: In this section, focus is given to how system specifications for AI-based systems can create challenges in testing and explain automation bias and how this affects testing.
| | 主題 2 | - Neural Networks and Testing: This section of the exam covers defining the structure and function of a neural network including a DNN and the different coverage measures for neural networks.
| | 主題 3 | - ML: Data: This section of the exam covers explaining the activities and challenges related to data preparation. It also covers how to test datasets create an ML model and recognize how poor data quality can cause problems with the resultant ML model.
| | 主題 4 | - Introduction to AI: This exam section covers topics such as the AI effect and how it influences the definition of AI. It covers how to distinguish between narrow AI, general AI, and super AI; moreover, the topics covered include describing how standards apply to AI-based systems.
| | 主題 5 | - Test Environments for AI-Based Systems: This section is about factors that differentiate the test environments for AI-based
| | 主題 6 | - Methods and Techniques for the Testing of AI-Based Systems: In this section, the focus is on explaining how the testing of ML systems can help prevent adversarial attacks and data poisoning.
| | 主題 7 | - Testing AI-Specific Quality Characteristics: In this section, the topics covered are about the challenges in testing created by the self-learning of AI-based systems.
最新的 ISTQB AI Testing CT-AI 免費考試真題 (Q74-Q79):問題 #74
An image classification system is being trained for classifying faces of humans. The distribution of the data is
70% ethnicity A and 30% for ethnicities B, C and D. Based ONLY on the above information, which of the following options BEST describes the situation of this image classification system?
SELECT ONE OPTION
- A. This is an example of algorithmic bias.
- B. This is an example of expert system bias.
- C. This is an example of hyperparameter bias.
- D. This is an example of sample bias.
答案:D
解題說明:
* A. This is an example of expert system bias.
* Expert system bias refers to bias introduced by the rules or logic defined by experts in the system, not by the data distribution.
* B. This is an example of sample bias.
* Sample bias occurs when the training data is not representative of the overall population that the model will encounter in practice. In this case, the over-representation of ethnicity A (70%) compared to B, C, and D (30%) creates a sample bias, as the model may become biased towards better performance on ethnicity A.
* C. This is an example of hyperparameter bias.
* Hyperparameter bias relates to the settings and configurations used during the training process, not the data distribution itself.
* D. This is an example of algorithmic bias.
* Algorithmic bias refers to biases introduced by the algorithmic processes and decision-making rules, not directly by the distribution of training data.
Based on the provided information, optionB(sample bias) best describes the situation because the training data is skewed towards ethnicity A, potentially leading to biased model performance.
問題 #75
A wildlife conservation group would like to use a neural network to classify images of different animals. The algorithm is going to be used on a social media platform to automatically pick out pictures of the chosen animal of the month. This month's animal is set to be a wolf. The test teamhas already observed that the algorithm could classify a picture of a dog as being a wolf because of the similar characteristics between dogs and wolves. To handle such instances, the team is planning to train the model with additional images of wolves and dogs so that the model is able to better differentiate between the two.
What test method should you use to verify that the model has improved after the additional training?
- A. Pairwise testing using combinatorics to look at a long list of photo parameters.
- B. Metamorphic testing because the application domain is not clearly understood at this point.
- C. Adversarial testing to verify that no incorrect images have been used in the training.
- D. Back-to-back testing using the version of the model before training and the new version of the model after being trained with additional images.
答案:D
解題說明:
Back-to-back testing isused to compare two different versions of an ML model, which is precisely what is needed in this scenario.
* The model initiallymisclassified dogs as wolvesdue to feature similarities.
* Thetest team retrains the modelwith additional images of dogs and wolves.
* The best way to verify whether this additional trainingimproved classification accuracyis to compare theoriginal model's output with the newly trained model's output using the same test dataset.
* A (Metamorphic Testing):Metamorphic testing is useful forgenerating new test casesbased on existing ones but does not directly compare different model versions.
* B (Adversarial Testing):Adversarial testing is used to check how robust a model is againstmaliciously perturbed inputs, not to verify training effectiveness.
* C (Pairwise Testing) airwise testing is a combinatorial technique for reducing the number of test casesby focusing on key variable interactions, not for validating model improvements.
* ISTQB CT-AI Syllabus (Section 9.3: Back-to-Back Testing)
* "Back-to-back testing is used when an updated ML model needs to be compared against a previous version to confirm that it performs better or as expected".
* "The results of the newly trained model are compared with those of the prior version to ensure that changes did not negatively impact performance".
Why Other Options Are Incorrect:Supporting References from ISTQB Certified Tester AI Testing Study Guide:Conclusion:To verify that the model's performance improved after retraining,back-to-back testing is the most appropriate methodas it compares both model versions. Hence, thecorrect answer is D.
問題 #76
Which ONE of the following characteristics is the least likely to cause safety related issues for an Al system?
SELECT ONE OPTION
- A. Non-determinism
- B. Robustness
- C. High complexity
- D. Self-learning
答案:B
解題說明:
The question asks which characteristic is least likely to cause safety-related issues for an AI system. Let's evaluate each option:
* Non-determinism (A): Non-deterministic systems can produce different outcomes even with the same inputs, which can lead to unpredictable behavior and potential safety issues.
* Robustness (B): Robustness refers to the ability of the system to handle errors, anomalies, and unexpected inputs gracefully. A robust system is less likely to cause safety issues because it can maintain functionality under varied conditions.
* High complexity (C): High complexity in AI systems can lead to difficulties in understanding, predicting, and managing the system's behavior, which can cause safety-related issues.
* Self-learning (D): Self-learning systems adapt based on new data, which can lead to unexpected changes in behavior. If not properly monitored and controlled, this can result in safety issues.
* ISTQB CT-AI Syllabus Section 2.8 on Safety and AI discusses various factors affecting the safety of AI systems, emphasizing the importance of robustness in maintaining safe operation.
問題 #77
A motorcycle engine repair shop owner wants to detect a leaking exhaust valve and fix it before it falls and causes catastrophic damage to the engine. The shop developed and trained a predictive model with historical data files from known health engines and ones which experienced a catastrophic fails due to exhaust valve failure. The shop evaluated 200 engines using this model and then disassembled the engines to assess the true state of the valves, recording the results in the confusion matrix below.
What is the precision of this predictive model
- A. 90.0%
- B. 94.5%
- C. 94.2%
- D. 98.9%
答案:C
解題說明:
Precision is a performance metric used to evaluate the accuracy of positive predictions in a classification model. It is defined by the formula:
Precision=TPTP+FP×100% ext{Precision} = rac{TP}{TP + FP} imes 100%Precision=TP+FPTP×100% Where:
* TP (True Positives)= Number of correctly predicted positive cases
* FP (False Positives)= Number of incorrectly predicted positive cases
The confusion matrix provided in the question would typically list these values. Based on ISTQB's guidelines for calculating precision, selecting the correct number of true positives and false positives from the given data should yield94.2%as the precision.
* Section 5.1 - Confusion Matrix and ML Functional Performance Metricsexplains the calculation of precisionusing the confusion matrix.
Reference from ISTQB Certified Tester AI Testing Study Guide:
問題 #78
Which ONE of the following tests is LEAST likely to be performed during the ML model testing phase?
SELECT ONE OPTION
- A. Testing the speed of the prediction by the model.
- B. Testing the API of the service powered by the ML model.
- C. Testing the speed of the training of the model.
- D. Testing the accuracy of the classification model.
答案:C
解題說明:
The question asks which test is least likely to be performed during the ML model testing phase. Let's consider each option:
Testing the accuracy of the classification model (A): Accuracy testing is a fundamental part of the ML model testing phase. It ensures that the model correctly classifies the data as intended and meets the required performance metrics.
Testing the API of the service powered by the ML model (B): Testing the API is crucial, especially if the ML model is deployed as part of a service. This ensures that the service integrates well with other systems and that the API performs as expected.
Testing the speed of the training of the model (C): This is least likely to be part of the ML model testing phase. The speed of training is more relevant during the development phase when optimizing and tuning the model. During testing, the focus is more on the model's performance and behavior rather than how quickly it was trained.
Testing the speed of the prediction by the model (D): Testing the speed of prediction is important to ensure that the model meets performance requirements in a production environment, especially for real-time applications.
ISTQB CT-AI Syllabus Section 3.2 on ML Workflow and Section 5 on ML Functional Performance Metrics discuss the focus of testing during the model testing phase, which includes accuracy and prediction speed but not the training speed.
問題 #79
如果你想參加CT-AI認證考試,那麼是使用CT-AI考試資料是很有必要的。如果你正在漫無目的地到處尋找參考資料,那麼趕快停止吧。如果你不知道應該用什麼資料,那麼試一下Fast2test的CT-AI考古題吧。這個考古題的命中率很高,可以保證你一次就取得成功。與別的考試資料相比,這個考古題更能準確地劃出考試試題的範圍。這樣的話,可以讓你提高學習效率,更加充分地準備CT-AI考試。
CT-AI認證: https://tw.fast2test.com/CT-AI-premium-file.html
- CT-AI更新 -有效ISTQB CT-AI認證:Certified Tester AI Testing Exam 🤪 透過✔ [url]www.kaoguti.com ️✔️搜索➽ CT-AI 🢪免費下載考試資料新版CT-AI考古題[/url]
- 新版CT-AI考古題 🧁 CT-AI證照指南 🛬 CT-AI學習指南 💞 ⏩ [url]www.newdumpspdf.com ⏪最新⮆ CT-AI ⮄問題集合CT-AI考題[/url]
- 100%通過的CT-AI更新,最好的考試資料幫助妳壹次性通過CT-AI考試 🔺 到【 [url]www.kaoguti.com 】搜尋➡ CT-AI ️⬅️以獲取免費下載考試資料CT-AI考古題分享[/url]
- 值得信賴的CT-AI更新&資格考試和認證領導者-ISTQB Certified Tester AI Testing Exam 💗 免費下載➥ CT-AI 🡄只需在▛ [url]www.newdumpspdf.com ▟上搜索新版CT-AI題庫上線[/url]
- CT-AI考試指南 😀 CT-AI考試資料 🏋 CT-AI題庫資料 ⏹ ➠ [url]www.newdumpspdf.com 🠰上的免費下載[ CT-AI ]頁面立即打開最新CT-AI試題[/url]
- CT-AI考試資料 🛃 CT-AI證照指南 💄 新版CT-AI題庫上線 📴 在➡ [url]www.newdumpspdf.com ️⬅️網站上免費搜索⏩ CT-AI ⏪題庫CT-AI考題[/url]
- 最新CT-AI試題 🏰 CT-AI證照信息 🦓 新版CT-AI題庫上線 ⛰ 在➠ [url]www.testpdf.net 🠰上搜索{ CT-AI }並獲取免費下載CT-AI證照信息[/url]
- 閱讀CT-AI更新,傳遞Certified Tester AI Testing Exam有效信息 🕧 { [url]www.newdumpspdf.com }上的免費下載➠ CT-AI 🠰頁面立即打開新版CT-AI題庫上線[/url]
- CT-AI熱門認證 🍜 CT-AI考試指南 🐶 CT-AI權威考題 😮 透過➽ [url]www.pdfexamdumps.com 🢪搜索➠ CT-AI 🠰免費下載考試資料CT-AI信息資訊[/url]
- 立即下載最新的CT-AI更新 🎠 打開▛ [url]www.newdumpspdf.com ▟搜尋⇛ CT-AI ⇚以免費下載考試資料CT-AI熱門題庫[/url]
- 立即下載最新的CT-AI更新 ⛺ 在「 tw.fast2test.com 」搜索最新的▶ CT-AI ◀題庫CT-AI最新考題
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, giphy.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, ileadprofessionals.com.ng, www.stes.tyc.edu.tw, lms.abe.institute, www.stes.tyc.edu.tw, hashnode.com, Disposable vapes
P.S. Fast2test在Google Drive上分享了免費的2026 ISTQB CT-AI考試題庫:https://drive.google.com/open?id=172NovsL--UEMbMN8s8LgTkhRengz2lDW
