[General] Pass Your Salesforce AP-202 Exam with Perfect Salesforce Exam Discount AP-202 Vo
66
General Pass Your Salesforce AP-202 Exam with Perfect Salesforce Exam Discount AP-202 Vo
Posted at 3/7/2026 02:35:01      View174 | Replies0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Actual4dump AP-202 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1Fbn_ErSG8-PslwejLZ3N9DYiW-UzdGh_
Success does not come only from the future, but it continues to accumulate from the moment you decide to do it. At the moment you choose AP-202 practice quiz, you have already taken the first step to success. The next thing you have to do is stick with it. AP-202 Training Materials will definitely live up to your expectations. Not only our AP-202 study materials contain the latest exam questions and answers, but also the pass rate is high as 98% to 100%.
You know, the AP-202 certification is tough and difficult IT certification. In order to get a better life, many people as you still want to chase after it. There is a useful and reliable study material of Salesforce AP-202 actual test for you. The AP-202 Pdf Dumps will teach you the basic technology and tell you how to affectively prepare for the AP-202 real test. In a word, AP-202 updated dumps is the best reference for you preparation.
AP-202 Valid Exam Test, Reliable AP-202 Test SimsFacts proved that if you do not have the certification, you will be washed out by the society. So it is very necessary for you to try your best to get the AP-202 certification in a short time. If you are determined to get the certification, our AP-202 question torrent is willing to give you a hand; because the study materials from our company will be the best study tool for you to get the certification. Now I am going to introduce our AP-202 Exam Question to you in detail, please read our introduction carefully, we can make sure that you will benefit a lot from it. If you are interest in it, you can buy it right now.
Salesforce B2B Commerce for Developers Accredited Professional Sample Questions (Q182-Q187):NEW QUESTION # 182
What should a developer's implementation code return if the External Prices are the same as Sales Prices for  Products in the Cart?
  • A. sfdc_checkout.IntegrationStatus. FAILED. Status
  • B. sfde_checkout.IntegrationStatus. Status. SUCCESS
  • C. sfdc_checkout.IntegrationStatus.Success. STATUS
  • D. sfdc_checkout.IntegrationStatus.Status.FAILED
When implementing code for external pricing comparisons, if the external prices are the same as the sales prices for products in the cart, the implementation should ideally return a status indicating success (such as sfdc_checkout.IntegrationStatus.Status.SUCCESS). This indicates that the external pricing verification has passed and there are no discrepancies between the external and sales prices.
NEW QUESTION # 183
A developer is building a custom component in Lightning web components (LWC) that has a grandchild component that needs to pass information to the grandparent component. What is the correct way to demonstrate the passing of a message from the grandchild component to the grandparent component?
  • A.
  • B.
  • C.
  • D.
The correct way to demonstrate the passing of a message from the grandchild component to the grandparent component in LWC is to use the PubSub library. The PubSub library is a utility that enables Lightning web components to communicate across the DOM tree without using intermediaries. The grandchild component can publish a message to a channel, and the grandparent component can subscribe to that channel and receive the message. This way, the communication is decoupled and does not depend on the component hierarchy. Option B shows the correct syntax for using the PubSub library to pass a message from the grandchild component to the grandparent component. Option A is incorrect because it uses th@apidecorator to expose a property on the grandchild component, which is not a valid way to communicate with the grandparent component. Option C is incorrect because it uses the@wiredecorator to wire a property on the grandchild component to a function on the grandparent component, which is also not a valid way to communicate with the grandparent component. Option D is incorrect because it uses the@trackdecorator to track a property on the grandchild component, which is not a valid way to communicate with the grandparent component.Communicate Across the DOM | Lightning Web Components Developer Guide,Child to grandparent communication in LWC,PubSub Library for Lightning Web Components
NEW QUESTION # 184
Universal Containers (UC) needs to display data from standard objects (entities) in a different format than what comes with B2B Commerce out of the box. In doing this, what is one advantage of using the Lightning Data Service vs using a custom Controller class?
  • A. JavaScript proxies for transport objects are created in the developer's IDE automatically.
  • B. Lightning Data Service translates the developer's component implementation to a VisualForce page for backward compatibility.
  • C. There is a Visual Studio add-in that accelerates the layout process
  • D. The developer can read, create, or modify single records or metadata without writing Apex code.
Lightning Data Service (LDS) is a Salesforce UI API layer that empowers developers to perform CRUD operations and manage Salesforce data without the need for custom Apex controllers. LDS is designed to improve performance, user interface consistency, and developer productivity by handling data operations and sharing rules, thus reducing the need for server-side code. For more details, refer to the Salesforce documentation on Lightning Data Service: Salesforce Lightning Data Service Documentation.
NEW QUESTION # 185
A developer is trying to integrate a new shipping provider to use during checkout in a storefront Which two steps must the developer take to make an integration available for selection?
  • A. Enter the integration class name and version in the store administration.
  • B. Modify the StorelntegratedService to map to an Apex class ID using Workbench.
  • C. Create a RegisteredExternalService record using Workbench.
  • D. Create an Apex class that uses the integration framework.
To make an integration available for selection, a developer must create a RegisteredExternalService record using Workbench and create an Apex class that uses the integration framework. Creating a RegisteredExternalService record using Workbench allows the developer to register their custom integration class as an external service in Salesforce B2B Commerce. The RegisteredExternalService record contains information such as the class name, version, display name, description, and category of the integration class. The category determines where and how the integration class can be used in B2B Commerce, such as ShippingService or TaxService. Creating an Apex class that uses the integration framework allows the developer to define custom logic for integrating with an external service provider's API or service. The integration framework provides interfaces and classes for various types of integrations, such as shipping, tax, payment, inventory, and freight. The developer can implement these interfaces and classes in their custom Apex class and override their methods with their own logic. Modifying the StoreIntegratedService to map to an Apex class ID using Workbench is not a required step for making an integration available for selection, as it is only used for registering internal services that are provided by Salesforce B2B Commerce out-of-the-box. Entering the integration class name and version in store administration is not a required step either, as it is only used for selecting an existing integration class that has already been registered as an external service. Salesforce [B2B Commerce Developer Guide: Integration Framework], [B2B Commerce Developer Guide: RegisteredExternalService Object]
NEW QUESTION # 186
What is default behavior for how theSalesforce B2B Commerce Global APIs transform Salesforce data?
  • A. Fields names are returned with c." prepended in their name.
  • B. Fields names can be mapped to any naming convention desired
  • C. Fields names are returned with a lowercase first letter,camelcase convention
  • D. Fields names are returned using the Salesforce naming convention.
The default behavior for how the Salesforce B2B Commerce Global APIs transform Salesforce data is to return field names with a lowercase first letter, camelcase convention. For example, the field name ccrz__E_Product__c in Salesforce will be transformed to eProduct in the API. This is done to follow the JavaScript naming convention and to avoid conflicts with the standard Salesforce fields and relationships. Salesforce B2B Commerce and D2C Commerce Developer Guide,Query Transformation
NEW QUESTION # 187
We offer three different formats for preparing for the B2B Commerce for Developers Accredited Professional (AP-202) exam questions, all of which will ensure your definite success on your B2B Commerce for Developers Accredited Professional (AP-202) exam dumps. Actual4dump is there with updated AP-202 Questions so you can pass the B2B Commerce for Developers Accredited Professional (AP-202) exam and move toward the new era of technology with full ease and confidence.
AP-202 Valid Exam Test: https://www.actual4dump.com/Salesforce/AP-202-actualtests-dumps.html
Besides, we have the promise of No help, full refund which can full refund your loss of the AP-202 premium files if you fail the exam with our dumps, Not only because the outstanding content of B2B Commerce for Developers Accredited Professional AP-202 real dumps that produced by our professional expert but also for the reason that we have excellent vocational moral to improve our B2B Commerce for Developers Accredited Professional AP-202 learning materials quality, The information in the AP-202 braindumps has been made simple up to the level of even an average exam candidate.
Now, people tell us were way too low, Most of the managers AP-202 in the room were not aware of lean and appeared to be confused about the goals that were being presented.
Besides, we have the promise of No help, full refund which can full refund your loss of the AP-202 Premium Files if you fail the exam with our dumps, Not only because the outstanding content of B2B Commerce for Developers Accredited Professional AP-202 real dumps that produced by our professional expert but also for the reason that we have excellent vocational moral to improve our B2B Commerce for Developers Accredited Professional AP-202 learning materials quality.
100% Pass 2026 AP-202: B2B Commerce for Developers Accredited Professional CHigh Hit-Rate Exam Discount VoucherThe information in the AP-202 braindumps has been made simple up to the level of even an average exam candidate, Our company is trying to satisfy every customers demand.
Finally, the AP-202 dumps pdf is easily portable and can be used on smart devices or printed out.
P.S. Free 2026 Salesforce AP-202 dumps are available on Google Drive shared by Actual4dump: https://drive.google.com/open?id=1Fbn_ErSG8-PslwejLZ3N9DYiW-UzdGh_
