[General] SAP C-ARCIG-2508 Sample Questions & Latest C-ARCIG-2508 Exam Experience
99
【General】 SAP C-ARCIG-2508 Sample Questions & Latest C-ARCIG-2508 Exam Experience
Posted at 3/7/2026 03:05:39      View:101 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that TestPDF C-ARCIG-2508 dumps now are free: https://drive.google.com/open?id=1yHsgD1nxdqlTnZgaQJhhjodygoKgnlbA
Just like the saying goes, it is good to learn at another man’s cost. In the process of learning, it is more important for all people to have a good command of the method from other people. The SAP Certified Associate - Implementation Consultant - Managed gateway for spend management and SAP Business Network exam questions from our company will help you find the good study method from other people. Using the C-ARCIG-2508 Test Guide from our company, you can not only pass your exam, but also you will have the chance to learn about the different and suitable study skills. We believe these skills will be very useful for you near life.
SAP C-ARCIG-2508 Exam Syllabus Topics:
  • Managed Gateway Tools: This section of the exam measures skills of Solution Architects and addresses the tools provided within Managed Gateway. It covers their role in monitoring, managing, and troubleshooting integration scenarios.
  • Managed Gateway Configuration: This section of the exam measures skills of Implementation Consultants and emphasizes practical knowledge of configuring Managed Gateway. It includes mapping, routing, and handling different business process requirements.
  • SAP Ariba Procurement Integration Configuration: This section of the exam measures the skills of Implementation Consultants and focuses on procurement-related integration tasks. It highlights knowledge of system setup that enables seamless procurement processes between SAP Ariba and SAP S
  • 4HANA.
  • CI to Managed Gateway: This section of the exam measures the skills of Implementation Consultants and deals with the integration setup between SAP Ariba and Managed Gateway. It emphasizes understanding connection points and smooth data flow for business processes.
Topic 5
  • Master Data: This section of the exam measures skills of Solution Architects and ensures knowledge of handling master data within SAP Ariba integrations. It focuses on consistent and accurate synchronization across connected systems.
Latest C-ARCIG-2508 Exam Experience, Reliable C-ARCIG-2508 Cram MaterialsThe clients can try out and download our C-ARCIG-2508 study materials before their purchase. They can immediately use our C-ARCIG-2508 training guide after they pay successfully. And our expert team will update the C-ARCIG-2508 study materials periodically after their purchase and if the clients encounter the problems in the course of using our C-ARCIG-2508 Learning Engine our online customer service staff will enthusiastically solve their problems.
SAP Certified Associate - Implementation Consultant - Managed gateway for spend management and SAP Business Network Sample Questions (Q46-Q51):NEW QUESTION # 46
What action is required when you access the SAP Managed Gateway for Soend&Network for the first time?
  • A. Create an integration project in the Managed Gateway portal
  • B. Ensure that the Trading Partner System Information or Basic Data is populated
  • C. Ensure that cross-reference data is maintained
  • D. Ensure that a connection for direct connectivity deployment is created
Solution:
From learning.sap.com-specifically in the "Understanding Projects from a High Level" lesson under the Administering SAP Integration Suite, Managed Gateway for Spend & Network learning journey-the required first step when accessing the Managed Gateway for the first time is:
*A. Create an integration project in the Managed Gateway portal
This step uses a self-service wizard that guides you through the process, including specifying cross- reference data and basic system information to set up the handshake between your backend ERP and the cloud gateway.
learning.sap.com
The other options (B, C, D) are not described as required first-time actions in that context.
NEW QUESTION # 47
You are a consultant on an SAP S/4HANA Cloud greenfield project. Which of the following aspects should you focus on to achieve and maintain clean core data quality? Note: There are 2correctanswers to this question.
  • A. Accuracy
  • B. Stability
  • C. Efficiency
  • D. Timeliness
From the learning.sap.com content related to the Clean Core approach for SAP S/4HANA Cloud (particularly in greenfield projects), two key aspects of data quality emphasized for achieving and maintaining clean core data are:
*Timeliness
*Accuracy learning.sap.com
NEW QUESTION # 48
You are migrating from Ariba Cl to SAP Managed Gateway for Spend&Network solutions. If you choose to make changes to the partner profile manually, which of the following fields of outbound parameters should you focus on? Note: There are 3correctanswers to this question.
  • A. Message Type
  • B. Extension
  • C. Basic Type
  • D. Receiver Port
  • E. Partner No.
Answer: B,C,D
NEW QUESTION # 49
Which values are associated with the interface setup BAdI parameter "IP_SOLUTION" in SAP Business Network integration via Managed Gateway for Spend&Network?Note: There are 3correctanswers to this question.
  • A. P2P
  • B. scc
  • C. Buy
  • D. src
  • E. AN
Answer: C,D,E
NEW QUESTION # 50
Which values are sent from the SAP ERP or SAP S/4HANA (on-premise) system to the Managed Gateway upon executing the "Send SAP Information to Managed Gateway for Spend&Network" report? Note: There are 2 correct answers to this question.
  • A. Managed Gateway-AddOn Software Component details
  • B. SAP Logical System ID
  • C. Managed Gateway User ID
  • D. SAP Application Server Hostname
NEW QUESTION # 51
Our company has been putting emphasis on the development and improvement of C-ARCIG-2508 test prep over ten year without archaic content at all. So we are bravely breaking the stereotype of similar content materials of the exam, but add what the exam truly tests into our C-ARCIG-2508 Exam Guide. So we have adamant attitude to offer help rather than perfunctory attitude. We esteem your variant choices so all these versions of C-ARCIG-2508 study materials are made for your individual preference and inclination.
Latest C-ARCIG-2508 Exam Experience: https://www.testpdf.com/C-ARCIG-2508-exam-braindumps.html
DOWNLOAD the newest TestPDF C-ARCIG-2508 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1yHsgD1nxdqlTnZgaQJhhjodygoKgnlbA
