New N10-009 Exam Online, N10-009 Exam Question
74
Posted at 3/7/2026 04:01:07      View:131 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of ITCertMagic N10-009 dumps from Cloud Storage: https://drive.google.com/open?id=1GujuR2Ibhcmc2q_2pUvloXkKQucQ3hBg
In order to cater to meet different needs of candidates, three versions of N10-009 learning materials are available. N10-009 PDF version is printable, and if you prefer the hard one, you can choose this version for your practice. N10-009 Soft test engine can install in more than 200 personal computers, and it can also stimulate the real examenvironment, and you can know what the real exam is like. N10-009 Online Test engine is convenient and easy to learn, you can learn anytime and anyplace. This version can record your process of training, and you can have a general review before next training.
The client only needs 20-30 hours to learn our N10-009 learning questions and then they can attend the test. Most people may devote their main energy and time to their jobs, learning or other important things and can’t spare much time to prepare for the test. But if clients buy our N10-009 Training Materials they can not only do their jobs or learning well but also pass the test smoothly and easily because they only need to spare little time to learn and prepare for the N10-009 test.
Newest N10-009 Exam Questions: CompTIA Network+ Certification Exam supply you high-quality Preparation Dump - ITCertMagicITCertMagic is one of the only few platforms offering updated CompTIA exam preparatory products for the N10-009 at an affordable rate. Our CompTIA N10-009 exam questions preparation products help you know your weaknesses before the actual CompTIA Network+ Certification Exam exam. CompTIA N10-009 Exam Questions preparation materials are affordable for everyone. Moreover, we give you free updates for 365 days. ITCertMagic offers reliable, updated CompTIA Exam Questions at an affordable price and also gives a 30% discount on all CompTIA exam questions.
CompTIA N10-009 Exam Syllabus Topics:
  • Selection and configuration of wireless devices.
  • Networking Concepts: For network administrators and IT support professionals, this domain covers
  • Cloud concepts and connectivity options, and Common networking ports.
CompTIA Network+ Certification Exam Sample Questions (Q18-Q23):NEW QUESTION # 18
Which of the following can be implemented to add an additional layer of security between a corporate network and network management interfaces?
  • A. Console server
  • B. API interface
  • C. Jump box
  • D. In-band management
A jump box is a hardened, isolated system that provides secure access to critical infrastructure devices like routers and firewalls.
CompTIA Network+ (N10-009) Official Study Guide - Domain 4.3: Explain network security techniques.
NEW QUESTION # 19
Which of the following is the best VPN to use for reducing data bandwidth requirements of the corporate network?
  • A. Split-tunnel
  • B. Full-tunnel client
  • C. Site-to-site
  • D. GRE tunnel
Asplit-tunnel VPNallows a device to route some traffic through the VPN (typically corporate traffic) while sending other traffic (like general internet browsing) directly over the local internet connection. Thisreduces the load on the corporate networkbecause not all traffic is routed through the VPN tunnel.
* Site-to-site VPNsare for permanent links between locations.
* Full-tunnel VPNsroute all traffic through the VPN, increasing the bandwidth usage on the corporate network.
* GRE (Generic Routing Encapsulation)is a tunneling protocol that doesn't encrypt and doesn't reduce bandwidth usage by itself.
#Reference:
CompTIA Network+ N10-009 Official Objectives: 3.3 - Given a scenario, configure and deploy common VPN technologies.
NEW QUESTION # 20
Users are unable to access files on their department share located on flle_server 2. The network administrator has been tasked with validating routing between networks hosting workstation A and file server 2.
INSTRUCTIONS
Click on each router to review output, identity any Issues, and configure the appropriate solution If at any time you would like to bring back the initial state of trie simulation, please click the reset All button;
See the solution configuration below in Explanation.
NEW QUESTION # 21
A network administrator wants to configure a backup route in case the primary route fails. A dynamic routing protocol is not installed on the router. Which of the following routing features should the administrator choose to accomplish this task?
  • A. Neighbor adjacency
  • B. Hop count
  • C. Administrative distance
  • D. Link state flooding
Introduction to Administrative Distance
Administrative distance (AD) is a value used by routers to rank routes from different routing protocols. AD represents the trustworthiness of the source of the route. Lower AD values are more preferred. If a router has multiple routes to a destination from different sources, it will choose the route with the lowest AD.
Static Routes and Backup Routes
When a dynamic routing protocol is not used, static routes can be employed. Static routes are manually configured routes. To ensure a backup route, multiple static routes to the same destination can be configured with different AD values.
Configuring Static Routes with Administrative Distance
The primary route is configured with a lower AD value, making it the preferred route. The backup route is configured with a higher AD value. In the event of the primary route failure, the router will then use the backup route.
Example Configuration:
plaintext
Copy code
ip route 192.168.1.0 255.255.255.0 10.0.0.1 1
ip route 192.168.1.0 255.255.255.0 10.0.0.2 10
In the above example, 192.168.1.0/24 is the destination network.
10.0.0.1 is the next-hop IP address for the primary route with an AD of 1.
10.0.0.2 is the next-hop IP address for the backup route with an AD of 10.
Verification:
After configuration, use the show ip route command to verify that the primary route is in use and the backup route is listed as a candidate for use if the primary route fails.
CompTIA Network+ guide explains the concept of administrative distance and its use in static routing configuration (see page Ref 9fasic Configuration Commands).
NEW QUESTION # 22
Which of the followingservicesruns onport 636?
  • A. TFTP
  • B. LDAPS
  • C. Syslog
  • D. SMTP
LDAP over SSL (LDAPS)usesport 636to providesecure, encrypted authenticationfor directory services.
Breakdown of Options:
* A. SMTP (Simple Mail Transfer Protocol)- Usesport 25, not 636.
* B. Syslog- Usesport 514 (UDP),not 636.
* C. TFTP (Trivial File Transfer Protocol)- Usesport 69 (UDP),not 636.
* D. LDAPS (Lightweight Directory Access Protocol Secure)-#Correct answer.Usesport 636for secure directory authentication.
NEW QUESTION # 23
Our N10-009 exam simulation is accumulation of knowledge about the exam strictly based on the syllabus of the exam. They give users access to information and exam, offering simulative testing environment when you participate it like in the classroom. Besides, contents of N10-009 study guide are selected by experts which are appropriate for your practice in day-to-day life. It is especially advantageous for busy workers who lack of sufficient time to use for passing the N10-009 Preparation materials. And as the high pass rate of more than 98%, you will pass for sure with it.
N10-009 Exam Question: https://www.itcertmagic.com/CompTIA/real-N10-009-exam-prep-dumps.html
P.S. Free & New N10-009 dumps are available on Google Drive shared by ITCertMagic: https://drive.google.com/open?id=1GujuR2Ibhcmc2q_2pUvloXkKQucQ3hBg
