Salesforce CRT-450 Reliable Dumps Files, New Study CRT-450 Questions
97
Posted at 3/7/2026 04:48:45      View:75 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest Getcertkey CRT-450 PDF Dumps and CRT-450 Exam Engine Free Share: https://drive.google.com/open?id=1ZECgLdHxnLPSOJjjfeFBBMkSfcK-TD4a
As you know that the number of the questions and answers in the real CRT-450 exam is fixed. So accordingly the information should be collected for you. Our CRT-450 study materials have done the right thing for you. However, we will never display all the information in order to make the content appear more. Our CRT-450 learning guide just want to give you the most important information. This is why CRT-450 actual exam allow you to take the exam in the shortest possible time.
Salesforce CRT-450 certification exam covers a broad range of topics, including Apex syntax and development, debugging and testing, Visualforce pages and components, security and data access, and so on. CRT-450 exam is designed to assess the developer's ability to design, build, and deploy custom applications that are scalable, maintainable, and secure. CRT-450 Exam is administered online and consists of 60 multiple-choice questions to be completed within 105 minutes. Candidates must score at least 65% to pass the exam and earn the certification.
New Study CRT-450 Questions | CRT-450 Exam Brain DumpsDon't be tied up in small things. Don't let your exam affect your regular work. Professionals do professionals. Only spend a little money on Salesforce CRT-450 exam braindumps pdf, you will pass exam easily with only 24-36 hours preparation before the real test. Work is important, relax properly is important, Let our CRT-450 Exam Braindumps pdf help you clear your exam easily so that you can achieve three things at one stroke. In fact time is money.
Salesforce CRT-450 Exam is a must-have certification for anyone who wants to become a successful Salesforce developer. Salesforce Certified Platform Developer I certification validates your skills in developing custom applications on the Salesforce platform, including designing and implementing custom objects, workflows, and validation rules.
Salesforce Certified Platform Developer I Sample Questions (Q177-Q182):NEW QUESTION # 177
Universal Containers wants a list button to display a Visualforce page that allows users to edit multiple records.
Which Visualforce feature supports this requirement?
  • A.
  • B.
  • C.
  • D.
https://developer.salesforce.com ... c_custom_button.htm
NEW QUESTION # 178
custom picklist field, Food_Preference__c, exist on a custom object. The picklist contains the following options: 'Vegan','Kosher','No Preference'. The developer must ensure a value is populated every time a record is created or updated. What is the most efficient way to ensure a value is selected every time a record is saved?
  • A. Set "Use the first value in the list as the default value" as True.
  • B. Set a validation rule to enforce a value is selected.
  • C. Mark the field as Required on the field definition.
  • D. Mark the field as Required on the object's page layout.
NEW QUESTION # 179
A visualforce interface is created for Case Management that includes both standard and custom functionality defined in an Apex class called myControllerExtension. The visualforce page should include which
<apex:page> attribute(s) to correctly implement controller functionality?
  • A. Controller=" myControllerExtension"
  • B. Controller = "case" and extensions =" myControllerExtension"
  • C. StandardController = "case" and extensions =" myControllerExtension"
  • D. Extensions=" myControllerExtension"
NEW QUESTION # 180
A developer wrote Apex code that calls out to an external system.
How should a developer write the test to provide test coverage?
  • A. Write a class that extends WebserviceMock.
  • B. Write a class that implements the HTTPCalloutMockinterface.
  • C. Write a class that extends HTTPCalloutMock.
  • D. Write a class that implements the WebserviceMockinterface.
NEW QUESTION # 181
The Sales Management team hires a new intern. The intern is not allowed to view Opportunities, but needs to see the Most Recent Closed Date of all child Opportunities when viewing an Account record. What would a developer do to meet this requirement?
  • A. Create a trigger on the Account object that queries the Close Date of the most recent Opportunities.
  • B. Create a Workflow rule on the Opportunity object that updates a field on the parent Account.
  • C. Create a formula field on the Account object that performs a MAX on the Opportunity Close Date field.
  • D. Create a roll-up summary field on the Account object that performs a MAX on the Opportunity Close Date field.
NEW QUESTION # 182
New Study CRT-450 Questions: https://www.getcertkey.com/CRT-450_braindumps.html
P.S. Free & New CRT-450 dumps are available on Google Drive shared by Getcertkey: https://drive.google.com/open?id=1ZECgLdHxnLPSOJjjfeFBBMkSfcK-TD4a
