Test JS-Dev-101 Tutorials - New JS-Dev-101 Braindumps Free
Posted at 3/7/2026 07:10:25
Prep4sureExam JS-Dev-101 exam dumps in three different formats has JS-Dev-101 questions PDF and the facility of Salesforce JS-Dev-101 dumps. We have made these Salesforce JS-Dev-101 questions after counseling a lot of experts and getting their feedback. The 24/7 customer support team is available at Prep4sureExam for Salesforce JS-Dev-101 Dumps users so that they don't get stuck in any hitch.
All contents are being explicit to make you have explicit understanding of this exam. Some people slide over ticklish question habitually, but the experts help you get clear about them and no more hiding anymore. Their contribution is praised for their purview is unlimited. None cryptic contents in JS-Dev-101 practice materials you may encounter.
New JS-Dev-101 Braindumps Free, Valid JS-Dev-101 Cram MaterialsWith the development of technology, our JS-Dev-101 training engine will be updated regularly. Actually, we never stop researching the new functions of the study materials. Normally, we will release our new version of the JS-Dev-101 exam simulation on our website once it passed the tests. Many details will be perfected in the new version of our JS-Dev-101 Study Materials not not on the content, but also on the displays. And we have been in this career for over ten years, our JS-Dev-101 learning guide is perfect.
Salesforce Certified JavaScript Developer - Multiple Choice Sample Questions (Q94-Q99):NEW QUESTION # 94
Refer to thefollowing code that imports a module named utils:
import (foo, bar) from '/path/Utils.js';
foo() ;
bar() ;
Which two implementations of Utils.js export foo and bar such that the code above runs without error?
Choose 2 answers
- A. const foo = () => { return 'foo' ; }const bar = () => { return 'bar' ; }export { bar, foo }
- B. // FooUtils.js and BarUtils.js existImport (foo) from '/path/FooUtils.js';Import (boo) from ' /path/NarUtils.js';
- C. const foo = () => { return 'foo';}const bar = () => {return 'bar'; }Export default foo, bar;
- D. Export default class {foo() { return 'foo' ; }bar() { return 'bar' ; }}
NEW QUESTION # 95
Refer to the code below:
Function changeValue(obj) {
Obj.value = obj.value/2;
Const objA = (value: 10);
Const objB = objA;
changeValue(objB);
Const result = objA.value;
What is the value of result after the code executes?
- A. Undefined
- B. Nan
- C. 0
- D. 1
NEW QUESTION # 96
A developer creates a genericfunction to log custom messages in the console. To do this, the function below is implemented.
01 function logStatus(status){
02 console./*Answer goes here*/{'Item status is: %s', status};
03 }
Which three console logging methods allow the use of string substitution in line 02?
- A. Error
- B. Log
- C. Message
- D. Assert
- E. Info
Answer: A,B,E
NEW QUESTION # 97
Given the code below:
01 setTimeout(() => {
02 console.log(1);
03 }, 1100);
04 console.log(2);
05 new Promise((resolve, reject) => {
06 setTimeout(() => {
07 reject(console.log(3));
08 }, 1000);
09 }).catch(() => {
10 console.log(4);
11 });
12 console.log(5);
What is logged to the console?
Comprehensive and Detailed Explanation From JavaScript Knowledge:
We must track synchronous code, setTimeout callbacks (macrotasks), and Promise rejection handling (microtasks).
Step-by-step:
Synchronous code first:
Line 01-03: Schedules a timeout at 1100 ms: logs 1 (later).
Line 04: console.log(2); → logs 2.
Lines 05-09: Construct a new Promise.
The executor runs immediately.
Inside it, another setTimeout is set for 1000 ms:
setTimeout(() => {
}, 1000);
Line 09-11: .catch(() => { console.log(4); }) attached to the promise.
Line 12: console.log(5); → logs 5.
So after all synchronous code, the console has:
2
5
At 1000 ms: inner setTimeout fires
The callback:
Inside:
console.log(3) runs first, logging 3.
console.log(3) returns undefined.
Then reject(undefined) is called.
So at about 1000 ms, we log:
3
When the promise is rejected:
The .catch handler is scheduled as a microtask.
After the current macrotask (the timeout callback) completes, the microtask queue runs.
Thus .catch(() => { console.log(4); }) runs shortly after, in the same 1000 ms tick.
So immediately after 3, the catch handler logs:
4
Now the logs in order are:
2
5
3
4
At 1100 ms: outer setTimeout fires
The callback from line 01 runs:
console.log(1);
Logs: 1.
Final log order:
2 (line 4, sync)
5 (line 12, sync)
3 (1000 ms timeout, then inside logs before reject)
4 (promise catch microtask after rejection)
1 (1100 ms timeout)
Concatenated: 25341.
Therefore, the correct option is:
Study Guide / Concept Reference (no links):
Event loop: call stack, macrotask queue (timers), microtask queue (promises) setTimeout scheduling and ordering Promise rejection, .catch, and microtasks Evaluation order of function arguments (reject(console.log(3)))
________________________________________
NEW QUESTION # 98
Refer to the HTML below:
<div id="main">
<ul>
<li>Leo</li>
<li>Tony</li>
<li>Tiger</li>
</ul>
</div>
Which JavaScript statement results in changing " Tony" to "Mr. T."?
- A. document.querySelector('$main li:second-child').innerHTML = ' Mr. T. ';
- B. document.querySelector('$main li:nth-child(2)'),innerHTML =' Mr. T. ';
- C. document.querySelectorAll('$main $TONY').innerHTML = ' Mr. T. ';
- D. document.querySelector('$main li.Tony').innerHTML = ' Mr. T. ';
NEW QUESTION # 99
Life is full of ups and downs. We cannot predicate what will happen in the future. To avoid being washed out by the artificial intelligence, we must keep absorbing various new knowledge. Our JS-Dev-101 learning questions will inspire your motivation to improve yourself. Tens of thousands of our loyal customers are benefited from our JS-Dev-101 Study Materials and lead a better life now after they achieve their JS-Dev-101 certification.
New JS-Dev-101 Braindumps Free: https://www.prep4sureexam.com/JS-Dev-101-dumps-torrent.html
Prep4sureExam New JS-Dev-101 Braindumps Free is providing you best 100% valid up to date actual New JS-Dev-101 Braindumps Free - Salesforce Certified JavaScript Developer - Multiple Choice Updated helping question series that brings you the best results, Salesforce Test JS-Dev-101 Tutorials We always be here for you with 24/7 service, Planning for Salesforce JS-Dev-101 exam with Prep4sureExam is a perfect and right way to success, You will never fell disappointed with our JS-Dev-101 exam quiz.
You can then join the Group from that page, Conclusion and Future Work, JS-Dev-101 Prep4sureExam is providing you best 100% valid up to date actual Salesforce Certified JavaScript Developer - Multiple Choice Updated helping question series that brings you the best results.
Practical Salesforce Test JS-Dev-101 Tutorials With Interarctive Test Engine & Pass-Sure New JS-Dev-101 Braindumps FreeWe always be here for you with 24/7 service, Planning for Salesforce JS-Dev-101 Exam with Prep4sureExam is a perfect and right way to success, You will never fell disappointed with our JS-Dev-101 exam quiz.
Secondly, you can get our JS-Dev-101 practice test only in 5 to 10 minutes after payment, which enables you to devote yourself to study as soon as possible.
- First-hand Salesforce Test JS-Dev-101 Tutorials: Salesforce Certified JavaScript Developer - Multiple Choice 📪 Search for ⇛ JS-Dev-101 ⇚ and download it for free on ▷ [url]www.pdfdumps.com ◁ website 🏁JS-Dev-101 PDF[/url]
- JS-Dev-101 dumps - Pdfvce - 100% Passing Guarantee 🪐 Search for ➤ JS-Dev-101 ⮘ on ⇛ [url]www.pdfvce.com ⇚ immediately to obtain a free download 🏄Latest JS-Dev-101 Study Plan[/url]
- JS-Dev-101 PDF 🦑 Reliable JS-Dev-101 Test Practice 🌺 JS-Dev-101 Test Vce Free 🏆 Search for ✔ JS-Dev-101 ️✔️ and download it for free immediately on [ [url]www.practicevce.com ] 🍺Reliable JS-Dev-101 Exam Registration[/url]
- Free PDF Salesforce - Reliable JS-Dev-101 - Test Salesforce Certified JavaScript Developer - Multiple Choice Tutorials 🚈 Enter ✔ [url]www.pdfvce.com ️✔️ and search for 【 JS-Dev-101 】 to download for free 🌌Reliable JS-Dev-101 Braindumps[/url]
- Prepares you for the format of your JS-Dev-101 exam dumps 🧨 Search for ▛ JS-Dev-101 ▟ and obtain a free download on ➽ [url]www.exam4labs.com 🢪 🍣Valid JS-Dev-101 Exam Labs[/url]
- Test JS-Dev-101 Tutorials Free PDF | Efficient New JS-Dev-101 Braindumps Free: Salesforce Certified JavaScript Developer - Multiple Choice 🆓 Easily obtain ( JS-Dev-101 ) for free download through ⮆ [url]www.pdfvce.com ⮄ ⏪JS-Dev-101 Latest Exam Book[/url]
- 100% Pass Quiz 2026 Updated JS-Dev-101: Test Salesforce Certified JavaScript Developer - Multiple Choice Tutorials 🥌 Search for [ JS-Dev-101 ] and download it for free on ➥ [url]www.troytecdumps.com 🡄 website 🐺JS-Dev-101 New Study Plan[/url]
- Reliable JS-Dev-101 Braindumps 📥 JS-Dev-101 Latest Test Answers 💹 Reliable JS-Dev-101 Braindumps 🕒 Search for ➥ JS-Dev-101 🡄 and obtain a free download on ➽ [url]www.pdfvce.com 🢪 🌈Relevant JS-Dev-101 Questions[/url]
- Reliable JS-Dev-101 Exam Registration 🚁 JS-Dev-101 PDF 🚁 Latest JS-Dev-101 Study Plan 🤦 Search for ⮆ JS-Dev-101 ⮄ and download it for free immediately on ➽ [url]www.pass4test.com 🢪 🏋Reliable JS-Dev-101 Braindumps[/url]
- Prepares you for the format of your JS-Dev-101 exam dumps 🕞 Search for ➠ JS-Dev-101 🠰 on ➠ [url]www.pdfvce.com 🠰 immediately to obtain a free download 🤭Study Guide JS-Dev-101 Pdf[/url]
- Salesforce Test JS-Dev-101 Tutorials - 100% Pass 2026 Realistic New JS-Dev-101 Braindumps Free 🍧 ➤ [url]www.easy4engine.com ⮘ is best website to obtain ▶ JS-Dev-101 ◀ for free download 🛐Valid JS-Dev-101 Exam Tips[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, youpainter.com, www.stes.tyc.edu.tw, wedacareer.com, Disposable vapes
