[Hardware] VMware 3V0-24.25 Preparation Materials Available In Different Formats
81
【Hardware】 VMware 3V0-24.25 Preparation Materials Available In Different Formats
Posted at 3/7/2026 08:01:17      View:141 | Replies:2        Print      Only Author   [Copy Link] 1#
In today's world, the Advanced VMware Cloud Foundation 9.0 vSphere Kubernetes Service (3V0-24.25) certification exam has become increasingly popular, providing professionals with the opportunity to upskill and stay competitive in the tech industry. At ExamDumpsVCE, we understand the importance of obtaining the VMware 3V0-24.25 Certification in the VMware sector, where technological advancements constantly evolving.
Along with Advanced VMware Cloud Foundation 9.0 vSphere Kubernetes Service (3V0-24.25) self-evaluation exams, 3V0-24.25 dumps PDF is also available at ExamDumpsVCE. These 3V0-24.25 questions can be used for quick Advanced VMware Cloud Foundation 9.0 vSphere Kubernetes Service (3V0-24.25) preparation. Our 3V0-24.25 dumps PDF format works on a range of Smart devices, such as laptops, tablets, and smartphones. Since 3V0-24.25 Questions Pdf are easily accessible, you can easily prepare for the test without time and place constraints. You can also print this format of ExamDumpsVCE's Advanced VMware Cloud Foundation 9.0 vSphere Kubernetes Service (3V0-24.25) exam dumps to prepare off-screen and on the go.
In-Depth of Questions 3V0-24.25 valuable resourceTheExamDumpsVCE is one of the leading and reliable platforms that has been helping Advanced VMware Cloud Foundation 9.0 vSphere Kubernetes Service 3V0-24.25 exam candidates in their preparation. With high pass rate and Advanced VMware Cloud Foundation 9.0 vSphere Kubernetes Service 3V0-24.25 at a preferential price.To enhance your competitiveness in your field.
VMware Advanced VMware Cloud Foundation 9.0 vSphere Kubernetes Service Sample Questions (Q15-Q20):NEW QUESTION # 15
A DevOps Engineer attempts to deploy a database VM using the following YAML manifest, but the kubectl apply command results in the object staying in a pending state, and kubectl get virtualmachine shows a failure condition.
# postgres-vm.yaml
apiVersion: vmoperator.vmware.com/v1alpha1
kind: VirtualMachine
metadata:
namespace: dev-playground
spec:
className: guaranteed-xlarge
imageName: centos-8-stream-v10.ova
powerState: poweredOn
The VI Administrator checks the dev-playground namespace status:
nsx-cli> get namespace dev-playground
VM Service: Enabled
Assigned VM Classes:
- best-effort-small
- guaranteed-medium
Assigned Content Libraries:
- K8s-Images (Contains: centos-8-stream-v10.ova)
What is the root cause of the provisioning failure?
  • A. The VM Class guaranteed-xlarge requested in the YAML is not assigned to the dev-playground namespace.
  • B. The powerState field is invalid; VMs are powered on by default.
  • C. The imageName must include the full Content Library path (e.g., lib/K8s-Images/centos-8-stream- v10.ova).
  • D. The VM Service is not compatible with CentOS 8 Stream images.
NEW QUESTION # 16
A Cloud Administrator needs to resolve a "Condition: False" error on a Supervisor Cluster related to network connectivity. The Supervisor cannot reach the external image registry to pull system images.
Review the following log snippet from the Supervisor's WCP service:
E1121 10:05:01.442 controller.go:120] Failed to pull image 'projects.registry.vmware.com/tkg/tanzu- kubernetes-grid-service-v2.0.0':
rpc error: code = Unknown desc = Error response from daemon: Get
https://projects.registry.vmware.com/v2/: dial tcp 10.128.0.45:443: i/o timeout The administrator verifies that the firewall rules allow traffic from the Supervisor Management Network IP range to the internet.
What configuration on the Supervisor is most likely missing or incorrect, preventing this connection?
(Select all that apply.)
  • A. The Egress CIDR for the Namespaces is exhausted.
  • B. The Supervisor's Management Network Gateway is configured incorrectly.
  • C. The DNS Server settings on the Supervisor are incorrect, causing name resolution to fail.
  • D. The Proxy Settings (HTTP/HTTPS Proxy) have not been configured or are incorrect on the Supervisor, preventing it from routing internet-bound traffic through the corporate gateway.
  • E. The Image Registry Service has not been enabled on the Supervisor.
NEW QUESTION # 17
A Platform Engineer is optimizing the IP address consumption of the NSX Advanced Load Balancer (Avi) used by a Supervisor Cluster. The current "Essentials" edition deployment consumes a new Service Engine (SE) IP and a VIP for every LoadBalancer service, leading to IP exhaustion.
The engineer wants to switch to a design where multiple Kubernetes Services share the same Service Engine group and potentially consolidate VIPs where possible (using L7 Ingress), but the immediate concern is the backend SE scaling.
Review the current setting: Service Engine Group: Default-Group Max VS per SE: 10 What configuration change on the Avi Controller would optimize resource usage for this VKS deployment? (Select all that apply.)
  • A. Use AKO (Avi Kubernetes Operator) features to implement L7 Ingress (sharing a single VIP/VS for multiple apps) instead of creating a type: LoadBalancer (L4) for every app.
  • B. Enable NSX-T Cloud mode in Avi instead of vCenter Cloud mode.
  • C. Configure the IPAM Profile to use a larger subnet.
  • D. Switch the Supervisor configuration to use HAProxy, which is more efficient.
  • E. Increase the Max Virtual Services per Service Engine limit in the Service Engine Group settings (e.g., to 50 or 100), allowing more services to be packed onto existing SEs before spawning new ones.
Answer: A,E
NEW QUESTION # 18
A Cloud Administrator is tasked with resolving a complex "Split-Brain" scenario in a Zonal Supervisor deployment following a storage outage in Zone-B.
Context:
The Supervisor spans Zone-A, Zone-B, and Zone-C. A storage array failure in Zone-B caused the Supervisor Control Plane VM in that zone to become isolated and read-only. The outage is now resolved, but the Supervisor status remains Warning. TKG clusters in Zone-B are unreachable.
Review the following diagnostic data from the Supervisor:
# kubectl get nodes -L topology.kubernetes.io/zone
NAME   STATUS   ROLES ZONE
42018c-supervisor-control-plane-0 Ready   master Zone-A
42018c-supervisor-control-plane-1 NotReady master Zone-B
42018c-supervisor-control-plane-2 Ready   master Zone-C
# kubectl get etcd -n kube-system
NAME STATUS HEALTH
etcd-0 Healthy true
etcd-1 Unhealthy false <-- Corresponds to Zone-B node
etcd-2 Healthy true
The administrator determines that the etcd member in Zone-B has diverged and cannot automatically rejoin the quorum.
What is the correct recovery procedure to restore full health to the Supervisor? (Choose 2.)
  • A. Redeploy the Supervisor Control Plane VM using the kubectl delete node 42018c-supervisor-control- plane-1 command.
  • B. Delete the NotReady Control Plane VM (42018c-supervisor-control-plane-1) from the vSphere Client inventory. The vSphere Cluster Service (vCLS) / EAM will detect the missing agent and automatically redeploy a fresh Control Plane VM, forcing etcd to resync from the healthy members.
  • C. SSH into the healthy etcd-0 node and run etcdctl member remove to manually evict the failed member, then allow the Supervisor to self-heal.
  • D. Use the vSphere Client to put the Supervisor into "Maintenance Mode" and then "Exit Maintenance Mode" to trigger a full cluster reconciliation.
  • E. Restore the entire Supervisor Cluster from a Velero backup taken prior to the outage.
NEW QUESTION # 19
A developer is unable to log in to a specific TKG cluster using the command kubectl vsphere login.
They receive an "Unauthorized" error.
The Security Analyst reviews the role bindings in the target namespace dev-team-1:
apiVersion: rbac.authorization.k8s.io/v1
kind: RoleBinding
metadata:
namespace: dev-team-1
subjects:
- kind: User
apiGroup: rbac.authorization.k8s.io
roleRef:
kind: ClusterRole
The analyst confirms the user is valid in Active Directory.
What is the misconfiguration in the RoleBinding preventing successful interaction/authorization?
  • A. The kind must be Group, not User.
  • B. The name field in subjects is using the prefix sso:, but for vCenter SSO backed users, the Supervisor typically expects the format devuser1@corp.local (UPN) without a manual prefix, or the prefix depends on the specific claim mapping, but sso: is generally incorrect for standard AD integration.
  • C. The roleRef is pointing to a Pod Security Policy (PSP) role, which grants pod execution permissions but does not grant the basic get, list, or watch permissions required to view resources or authenticate successfully to the API context.
  • D. kubectl vsphere login does not support Active Directory users.
  • E. The binding is in the wrong namespace.
NEW QUESTION # 20
In a rapidly growing world, it is immensely necessary to tag your potential with the best certifications, such as the 3V0-24.25 certification. But as you may be busy with your work or other matters, it is not easy for you to collect all the exam information and pick up the points for the 3V0-24.25 Exam. Our professional experts have done all the work for you with our 3V0-24.25 learning guide. You will pass the exam in the least time and with the least efforts.
3V0-24.25 Cheap Dumps: https://www.examdumpsvce.com/3V0-24.25-valid-exam-dumps.html
The 3V0-24.25 exam torrent is compiled by the experienced professionals and of great value, Just browser our websites and choose our 3V0-24.25 study materials for you, 99% pass rate, So, to help you prepare well for the Professional Level Exams 3V0-24.25 exam, we cover this preparation guide, If we have any updated version of 3V0-24.25 latest vce pdf, it will be immediately pushed to customers, Our 3V0-24.25 training materials are professional practice material under warranty.
Read this article by Louis Columbus to learn about Microsoft's 3V0-24.25 initial efforts at streamlining this task, Streamline your workflow with Mission Control and Spaces.
The 3V0-24.25 exam torrent is compiled by the experienced professionals and of great value, Just browser our websites and choose our 3V0-24.25 study materials for you.
Real VMware 3V0-24.25 Exam Questions in PDF Format99% pass rate, So, to help you prepare well for the Professional Level Exams 3V0-24.25 exam, we cover this preparation guide, If we have any updated version of 3V0-24.25 latest vce pdf, it will be immediately pushed to customers.
Posted at 3/8/2026 00:15:15        Only Author  2#
This article is incredibly inspiring, thank you for sharing! Thanks to the JN0-481 new study guide pdf, I received a promotion and a pay raise. Now it’s open to everyone for free. Wishing you all the best in your career!
Posted at 3/9/2026 08:55:39        Only Author  3#
Thank you for sharing this thought-provoking article! Best of luck! Here are the free New study questions 300-215 sheet study resources for you.
