Plat-Admn-202 Latest Dumps Files | Hot Plat-Admn-202 Questions
Posted at 3/7/2026 08:28:28
View157
Replies1
With the help of Plat-Admn-202 study materials, you can conduct targeted review on the topics which to be tested before the exam, and then you no longer have to worry about the problems that you may encounter a question that you are not familiar with during the exam. With Plat-Admn-202 study materials, you will not need to purchase any other review materials. We have hired professional IT staff to maintain Plat-Admn-202 Study Materials and our team of experts also constantly updates and renew the question bank according to changes in the syllabus.
It is acknowledged that high-quality service after sales plays a vital role in enhancing the quality of our Plat-Admn-202 learning engine. Therefore, we, as a leader in the field specializing in the Plat-Admn-202 exam material especially focus on the service after sales. In order to provide the top service on our Plat-Admn-202 training prep, our customer agents will work 24/7. So if you have any doubts about the Plat-Admn-202study guide, you can contact us by email or the Internet at any time you like.
Hot Plat-Admn-202 Questions, Plat-Admn-202 Latest VersionHaving a good command of professional knowledge for customers related to this Plat-Admn-202 exam is of superior condition. However, that is not certain and sure enough to successfully pass this exam. You need efficiency and exam skills as well. Actually, a great majority of exam candidates feel abstracted at this point, wondering which one is the perfect practice material they are looking for. We have gained high appraisal for the high quality Plat-Admn-202 Guide question and considerate serves. All content is well approved by experts who are arduous and hardworking to offer help. They eliminate banal knowledge and exam questions out of our Plat-Admn-202 real materials and add new and essential parts into them. And they also fully analyzed your needs of Plat-Admn-202 exam dumps all the time.
Salesforce Certified Platform App Builder Sample Questions (Q292-Q297):NEW QUESTION # 292
The finance manager at Universal Containers wants to receive a new business notification email each time a new client is won. The sales manager wants to receive a task letting them know to onboard the new client unless it is a top-tier client.
Which automation tool should an app builder use to best address all these requests?
- A. Screen flow
- B. Record-triggered flow
- C. Approval process
- D. Apex
Record-triggered flow is the automation tool that the app builder should use to best address all these requests of sending an email to the finance manager and creating a task for the sales manager when a new client is won. According to the Salesforce documentation, "Record-triggered flows automate processes for you. They start when a record is created or updated, or when a platform event occurs." A record-triggered flow can perform actions such as sending an email alert or creating a record based on criteria or conditions. Screen flow, Apex, and Approval process are not automation tools that can handle all these requests.
NEW QUESTION # 293
Universal Containers uses a custom object called Projects. When managers assign projects they set a custom field on the project called Estimated Hours. Once set, users should be able to decrease but not increase the value How can an app builder meet this requirement?
- A. Create a formula default value for the custom field.
- B. Create a formula held that uses the PREVGROUPVAL function
- C. Create a validation rule that uses the ISCHANGED function
- D. Create a validation rule that uses the PRIOR VALUE function.
Create a validation rule that uses the PRIORVALUE function is how an app builder can meet the requirement of preventing users from increasing the value of Estimated Hours after it is set. According to the Salesforce documentation, " RIORVALUE returns the previous value of a field." The validation rule can compare the current value and the prior value of Estimated Hours and display an error message if the current value is greater than the prior value. Creating a formula default value for the custom field, creating a formula field that uses the PREVGROUPVAL function, and creating a validation rule that uses the ISCHANGED function are not valid or correct solutions for this requirement.
NEW QUESTION # 294
Universal Containers wants to streamline its data capture process by linking fields together. They wish to do this so that the available value on dependents fields are driven by value selected on controlling fields. Which consideration supports the stated requirements? Choose 3 answers
- A. Custom picklist field can be either controlling or dependent field
- B. Checkbox fields can be controlling fields but not dependent fields
- C. Multi select picklist can be dependent picklist but not controlling fields
- D. The import wizard only allows value to be imported into a dependent picklist if they match the appropriate controlling field
- E. Standard and custom picklist fields can be dependent fields.
Answer: A,B,D
The import wizard only allows values to be imported into a dependent picklist if they match the appropriate controlling field. This ensures data integrity and prevents invalid values from being imported. Custom picklist fields can be either controlling or dependent fields. This allows the app builder to create custom dependencies between custom picklists. Checkbox fields can be controlling fields but not dependent fields. This allows the app builder to create dependencies based on checkbox values, such as true or false. Multi-select picklist fields can be dependent picklist fields but not controlling fields. This allows the app builder to create dependencies based on multiple values selected in a multi-select picklist field. Standard and custom picklist fields can be dependent fields, but not all standard picklist fields can be controlling fields. Some standard picklist fields, such as Lead Status or Opportunity Stage, cannot be controlling fields because they are used in other processes, such as lead conversion or sales path
NEW QUESTION # 295
Service Agents are required to confirm a user's identity before providing support information over the phone.
Which feature can an app builder use to help agents meet this requirement?
- A. Include Surveys as a Case related list
- B. Case Validation Rules
- C. Guided Action Flows on the record page
- D. Add Path to the top of the Case layout
Guided Action Flows (Screen Flows embedded in Lightning record pages) can walk agents through required steps - such as verifying identity - before proceeding.
Why A (Guided Action Flows) is correct:Exact Extract:"Use Guided Action Flows in Lightning App Builder to help agents complete processes in a step-by-step format directly on a record page." - Salesforce Help | Guided Action FlowsThe app builder can embed a Screen Flow that prompts the agent to verify identity (e.g., asking security questions), then allows access or marks verification complete.
Why not B ath helps users track record stages, not enforce procedural steps.
Why not C:Surveys are used for feedback collection after cases, not real-time identity verification.
Why not D:Validation Rules enforce data quality on record save, not process guidance.
Salesforce Platform App Builder Exam Guide | Business Logic and Process Automation
NEW QUESTION # 296
Sales reps at Cloud Kicks (CK) forget to submit for approval when CK needs orders reviewed before close won. CK wants to automatically submit opportunities into the Secure Commitment Stage to eliminate manual submission.
Which three features would meet the business requirements?
Choose 3 answers
- A. Workflow
- B. Chatter action
- C. Process Builder
- D. Flow
- E. Apex
Answer: C,D,E
The app builder should use three features to meet the business requirements:
Process Builder: This is a type of automation tool that can execute actions based on certain criteria. In this case, the process builder can have a criteria that evaluates if an opportunity is in the Secure Commitment Stage, and then execute an action that submits it for approval.
Apex: This is a programming language that allows developers to execute complex logic on the Salesforce platform. Apex can be used to create triggers that run before or after certain events, such as insert, update, delete, or undelete of records. In this case, Apex can be used to create a trigger that runs before an opportunity is updated and submits it for approval if it is in the Secure Commitment Stage.
Flow: This is another type of automation tool that can guide users through a series of screens and perform actions based on user input. Flow can also be triggered by certain events, such as when a record is created or updated. In this case, Flow can be used to create a record-triggered flow that runs after an opportunity is updated and submits it for approval if it is in the Secure Commitment Stage. Option A and D are not features that can meet the business requirements.
NEW QUESTION # 297
You can enter the company you want and improve your salary if you have the certification for this field. Plat-Admn-202 test materials of us can help you pass the exam and obtain the certification successfully. Plat-Admn-202 exam dumps offer you free demo for you to have a try, so that you can know what the complete version is like. In addition, we provide you with free update for 365 days after purchasing Plat-Admn-202 Training Materials, and our system will send you the latest version for Plat-Admn-202 exam dumps automatically. We have online and offline chat service, and if you have any questions for Plat-Admn-202 exam materials, you can contact us.
Hot Plat-Admn-202 Questions: https://www.realvce.com/Plat-Admn-202_free-dumps.html
If there are any updates, we will send you the new version of Plat-Admn-202 training materials: Salesforce Certified Platform App Builder quickly, RealVCE provides updated and valid Salesforce Plat-Admn-202 Exam Questions because we are aware of the absolute importance of updates, keeping in mind the dynamic Salesforce Plat-Admn-202 exam syllabus, Salesforce Plat-Admn-202 Latest Dumps Files We will give you 100% passing guarantee on your purchased exam dumps and also money back assurance if you will not clear your exam.
Processing and Memory, Visual and written learners, If there are any updates, we will send you the new version of Plat-Admn-202 training materials: Salesforce Certified Platform App Builder quickly.
RealVCE provides updated and valid Salesforce Plat-Admn-202 Exam Questions because we are aware of the absolute importance of updates, keeping in mind the dynamic Salesforce Plat-Admn-202 Exam Syllabus.
2026 Valid Plat-Admn-202 C 100% Free Latest Dumps Files | Hot Plat-Admn-202 QuestionsWe will give you 100% passing guarantee on your Plat-Admn-202 purchased exam dumps and also money back assurance if you will not clear your exam, We are an experienced and professional exam preparation provider with high passing rate especially for Plat-Admn-202 certification examinations.
We provide discounts at intervals for clients as feedbacks for your support during Hot Plat-Admn-202 Questions these years and send new updates to your mailbox once you place your order for one year wholly to relieve you of any kinds of questions and worries.
- 2026 High-quality Plat-Admn-202 Latest Dumps Files | 100% Free Hot Plat-Admn-202 Questions 🤟 Search for ➡ Plat-Admn-202 ️⬅️ and download exam materials for free through [url]www.vceengine.com 🍜
lat-Admn-202 Latest Test Simulations[/url] - Latest Plat-Admn-202 Test Preparation 🪂 Plat-Admn-202 Latest Test Simulations 🐻 Valid Plat-Admn-202 Exam Prep 🏳 Search for ⮆ Plat-Admn-202 ⮄ and download exam materials for free through ☀ [url]www.pdfvce.com ️☀️ 🟦Certification Plat-Admn-202 Exam[/url]
- Latest Plat-Admn-202 Test Training Materials Will Update Constantly - [url]www.prepawaypdf.com 🦎 Open ⏩ www.prepawaypdf.com ⏪ enter ➠ Plat-Admn-202 🠰 and obtain a free download 🎲New Plat-Admn-202 Exam Sample[/url]
- Buy Pdfvce Salesforce Plat-Admn-202 Exam Dumps With Free Updates ⏯ Easily obtain free download of ⮆ Plat-Admn-202 ⮄ by searching on ➤ [url]www.pdfvce.com ⮘ 🥂
lat-Admn-202 Exams Torrent[/url] - All Three [url]www.troytecdumps.com Salesforce Plat-Admn-202 Exam Dumps Format is Ready for Download 🌵 Search for ➤ Plat-Admn-202 ⮘ and download it for free immediately on ➥ www.troytecdumps.com 🡄 🎣Latest Plat-Admn-202 Exam Topics[/url]
- Latest Plat-Admn-202 Exam Topics 🚜 Plat-Admn-202 Latest Test Simulations 🥊 Plat-Admn-202 Latest Test Simulations 🆓 Open [url]www.pdfvce.com enter { Plat-Admn-202 } and obtain a free download 🛢
lat-Admn-202 Practical Information[/url] - Latest Plat-Admn-202 Exam Topics 🚲 Certification Plat-Admn-202 Exam 💐 Plat-Admn-202 Exams Torrent 🔏 Search for ✔ Plat-Admn-202 ️✔️ on ⮆ [url]www.pdfdumps.com ⮄ immediately to obtain a free download 🍯Exam Sample Plat-Admn-202 Questions[/url]
- [url=https://ilhankyuchyuk.eu/?s=Ensure%20Your%20Success%20With%20Valid%20-%20Updated%20Salesforce%20Plat-Admn-202%20Exam%20Questions%20[2026]%20%f0%9f%90%9d%20Open%20%e2%8f%a9%20www.pdfvce.com%20%e2%8f%aa%20and%20search%20for%20%e2%96%b7%20Plat-Admn-202%20%e2%97%81%20to%20download%20exam%20materials%20for%20free%20%e2%98%80Plat-Admn-202%20Latest%20Test%20Simulations]Ensure Your Success With Valid - Updated Salesforce Plat-Admn-202 Exam Questions [2026] 🐝 Open ⏩ www.pdfvce.com ⏪ and search for ▷ Plat-Admn-202 ◁ to download exam materials for free ☀
lat-Admn-202 Latest Test Simulations[/url] - Plat-Admn-202 Latest Test Simulations 🚮 Plat-Admn-202 Examcollection Questions Answers ➰ Plat-Admn-202 Valid Real Exam 🎠 Download ▷ Plat-Admn-202 ◁ for free by simply entering ☀ [url]www.pass4test.com ️☀️ website 🤗
lat-Admn-202 Certified[/url] - Try a Free Demo and Then Buy Salesforce Plat-Admn-202 Exam Dumps 🎏 Open ☀ [url]www.pdfvce.com ️☀️ enter ▛ Plat-Admn-202 ▟ and obtain a free download 👝New Plat-Admn-202 Exam Sample[/url]
- Free PDF Quiz Salesforce - Plat-Admn-202 - Salesforce Certified Platform App Builder CValid Latest Dumps Files 🕌 Search for ✔ Plat-Admn-202 ️✔️ and easily obtain a free download on ➤ [url]www.prep4sures.top ⮘ 😇
lat-Admn-202 Latest Test Simulations[/url] - www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, buildnation.com.bd, learning.d6driveresponsibly.it, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
