[General] DEA-C02 Guide Torrent, DEA-C02 Exam Questions Fee
99
【General】 DEA-C02 Guide Torrent, DEA-C02 Exam Questions Fee
Posted at 3/7/2026 09:31:31      View:93 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of 2Pass4sure DEA-C02 dumps for free: https://drive.google.com/open?id=1gFT1Gaj8pO7yKX9VbV-bYO8quSq-Pp_2
There are a lot of leading experts and professors in different field in our company. The first duty of these leading experts and professors is to compile the DEA-C02 exam questions. In order to meet the needs of all customers, the team of the experts in our company has done the research of the DEA-C02 Study Materials in the past years. And they have considered every detail of the DEA-C02 practice braindumps to be perfect. That is why our DEA-C02 learning guide enjoys the best quality in the market!
Our DEA-C02 Study Materials are written by experienced experts in the industry, so we can guarantee its quality and efficiency. The content of our DEA-C02 study materials is consistent with the proposition law all the time. We can't say it’s the best reference, but we're sure it won't disappoint you. This can be borne out by the large number of buyers on our website every day. A wise man can often make the most favorable choice, I believe you are one of them.
DEA-C02 Exam Questions Fee & Latest DEA-C02 Exam TestIt is time for you to plan your life carefully. After all, you have to make money by yourself. If you want to find a desirable job, you must rely on your ability to get the job. Now, our DEA-C02 study materials will help you master the popular skills in the office. Believe it or not, our DEA-C02 Study Materials will relieve you from poverty. It is important to make large amounts of money in modern society.
Snowflake SnowPro Advanced: Data Engineer (DEA-C02) Sample Questions (Q315-Q320):NEW QUESTION # 315
You are working on a Snowpark Python application that needs to process a stream of data from Kafka, perform real-time aggregations, and store the results in a Snowflake table. The data stream is highly variable, with occasional spikes in traffic that overwhelm your current Snowpark setup, leading to significant latency in processing. Which of the following strategies, either individually or in combination, would be MOST effective to handle these traffic spikes and ensure near real-time processing?
  • A. Use Snowpark's async actions (e.g., to offload data processing to separate threads or processes, allowing your main Snowpark application to continue receiving data.
  • B. Configure the Snowflake warehouse used by your Snowpark application to use auto-suspend and auto-resume with a short auto-suspend time to minimize costs during periods of low traffic.
  • C. Implement dynamic warehouse scaling. Utilize Snowflake's Resource Monitors and the ability to programmatically resize warehouses through Snowpark. Monitor the queue depth or latency of your Snowpark application, and dynamically scale up the warehouse size when thresholds are exceeded. Then, scale it back down when traffic subsides.
  • D. Implement a message queuing system (e.g., RabbitMQ, Kafka) between Kafka and your Snowpark application to buffer incoming data during traffic spikes.
  • E. Use 'CACHE RESULT for all queries in snowpark that use Kafka
Options A and D offer the best approach. Implementing a message queue (A) provides a buffer for incoming data during spikes, preventing your Snowpark application from being overwhelmed. Dynamic warehouse scaling (D) allows you to automatically increase the compute resources available to your Snowpark application when needed, ensuring it can handle the increased workload. Auto suspend/resume (B) is good for cost optimization but doesn't address the processing capacity during spikes. Async actions (C) can help, but are not as scalable or resilient as a proper message queue combined with dynamic warehouse scaling. Caching results (E) is irrelevant since the data from Kafka is always changing.
NEW QUESTION # 316
You have a requirement to create a UDF in Snowflake that transforms data based on a complex set of rules defined in an external Python library. The library requires specific dependencies. You also need to ensure the UDF is secure and that the code is not visible to unauthorized users. Which of the following steps MUST be taken to achieve this?
  • A. Create a Python UDF and directly upload the Python library code into the UDF's body. Snowflake automatically manages dependencies for UDFs.
  • B. Create a Snowflake Anaconda environment specifying the required Python library dependencies. Then, create a Python UDF, reference the Anaconda environment, and use the 'SECURE' keyword.
  • C. Create an external function pointing to an AWS Lambda function or Azure Function that hosts the Python code and its dependencies. Secure the external function using API integration and role-based access control.
  • D. Package all the Python libaries code into one file, then create an Javascript UDF and load/execute the python code inside the Javascript UDF.
  • E. Upload the Python library and its dependencies as internal stages. Create a Java UDF that executes the Python code using the 'ProcessBuilder' class. Mark the Java UDF as 'SECURE'
Using Snowflake Anaconda environments allows you to manage Python dependencies for UDFs. Creating a Python UDF referencing the environment and using the 'SECURE keyword ensures both dependency management and code protection. Uploading libraries as internal stages and using Java UDFs is an unnecessarily complex approach. Snowflake does not automatically manage dependencies; they must be explicitly specified through Anaconda. Creating a Python inside a Javascript UDF is not a supported pattern
NEW QUESTION # 317
A data engineering team is implementing a data governance strategy in Snowflake. They need to track the lineage of a critical table 'SALES DATA' from source system ingestion to its final consumption in a dashboard. They have implemented masking policies on sensitive columns in 'SALES DATA. Which combination of Snowflake features and actions will MOST effectively allow them to monitor data lineage and object dependencies, including visibility into masking policies?
  • A. Rely solely on a third-party data catalog tool that integrates with Snowflake's metadata API. These tools automatically track lineage and policy information and provide the best and most effective results.
  • B. Utilize Snowflake's Data Governance features, specifically enabling Data Lineage using Snowflake Horizon and utilize the view along with query the 'QUERY HISTORY view. These features natively track data flow and policy application.
  • C. Use the INFORMATION_SCHEMA views like 'TABLES', 'COLUMNS', and 'POLICY_REFERENCES'. These views, combined with custom queries to analyze query history logs, will provide a complete lineage and masking policy overview.
  • D. Create a custom metadata repository and use Snowflake Scripting to parse query history and object metadata periodically. Manually track dependencies and policy changes by analyzing the output.
  • E. Enable Account Usage views like 'QUERY_HISTORY, and 'ACCESS_HISTORY. These views directly show table dependencies and policy applications.
Snowflake Horizon's Data Lineage feature is designed to track the flow of data through your Snowflake environment. Combining this with 'POLICY_REFERENCES (which shows which policies are applied to which objects) and (to see how data is transformed) provides the most complete and native solution. Account Usage views and INFORMATION_SCHEMA views provide valuable metadata, but don't offer lineage tracking out-of-the-box like Snowflake Horizon. While third-party tools and custom solutions are options, leveraging Snowflake's native capabilities is generally more efficient and cost-effective for basic lineage tracking.
NEW QUESTION # 318
You are building a data pipeline to ingest clickstream data into Snowflake. The raw data is landed in a stage and you are using a Stream on this stage to track new files. The data is then transformed and loaded into a target table 'CLICKSTREAM DATA. However, you notice that sometimes the same files are being processed multiple times, leading to duplicate records in 'CLICKSTREAM DATA. You are using the 'SYSTEM$STREAM HAS DATA' function to check if the stream has data before processing. What are the possible reasons this might be happening, and how can you prevent it? (Select all that apply)
  • A. The COPY INTO command used to load the files into Snowflake has the 'ON ERROR = CONTINUE option set, allowing it to skip corrupted files, causing subsequent processing to pick them up again.
  • B. The auto-ingest notification integration is configured incorrectly, causing duplicate notifications to be sent for the same files. This is particularly applicable when using cloud storage event triggers.
  • C. The 'SYSTEM$STREAM HAS DATA' function is unreliable and should not be used for production data pipelines. Use 'COUNT( on the stream instead.
  • D. The transformation process is not idempotent. Even with the same input files, it produces different outputs each time it runs.
  • E. The stream offset is not being advanced correctly after processing the files. Ensure that the files are consumed completely and a DML operation is performed to acknowledge consumption.
Answer: B,D,E
Several factors could lead to duplicate processing: B (Stream offset not advancing): Streams track changes based on an offset. If the offset is not advanced after processing, the same changes will be re-processed. C (Non-idempotent transformation): If the transformation logic isn't idempotent, re-processing the same data will lead to different results, effectively creating duplicates. E (Duplicate Auto-ingest Notifications): If the auto-ingest process is configured to send duplicate notifications for the same files (due to misconfiguration of cloud storage event triggers, for example), the COPY INTO command will run multiple times for the same file. 'SYSTEM$STREAM HAS DATA is a valid function (A is incorrect). 'ON _ ERROR = CONTINUE (D) would prevent files from being skipped but would not itself cause duplicate processing. The skipping might surface other issues, but isn't the direct cause.
NEW QUESTION # 319
You've created a JavaScript UDF in Snowflake to perform complex string manipulation. You need to ensure this UDF can handle a large volume of data efficiently. The UDF is defined as follows:
When testing with a large dataset, you observe poor performance. Which of the following strategies, when applied independently or in combination, would MOST likely improve the performance of this UDF?
  • A. Convert the JavaScript UDF to a Java UDF, utilizing Java's more efficient string manipulation libraries and leveraging Snowflake's Java UDF execution environment.
  • B. Increase the warehouse size to the largest available size (e.g., X-Large) to provide more resources for the UDF execution.
  • C. Replace the JavaScript UDF with a SQL UDF that uses built-in Snowflake string functions like 'REGEXP REPLACE and 'REPLACE. SQL UDFs are generally more optimized within Snowflake's execution engine.
  • D. Pre-compile the regular expressions used within the JavaScript UDF outside of the function and pass them as constants into the function. JavaScript regex compilation is expensive, and pre-compilation can reduce overhead.
  • E. Ensure the input 'STRING' is defined with the maximum possible length to provide sufficient memory allocation for the JavaScript engine to manipulate the string.
Answer: A,C,D
Options A, C and E can all contribute to better performance. SQL UDFs benefit from Snowflake's optimized execution engine for standard operations, making them often faster than JavaScript UDFs for string manipulation when possible. Pre-compiling regular expressions (Option C) avoids redundant compilation steps during each UDF invocation. Converting to a Java UDF (Option E) gives more control over efficiency compared to JS. The option D may help, but the performance gain is not guaranteed and is more related to resource availability than the UDF's efficiency. The option B is not valid since the size of input STRING won't matter the javascript engine.
NEW QUESTION # 320
You can get 365 days of free DEA-C02 real dumps updates and free demos. Save your time and money. Start Snowflake DEA-C02 exam preparation with DEA-C02 actual dumps. Our firm provides real, up-to-date, and expert-verified SnowPro Advanced: Data Engineer (DEA-C02) DEA-C02 Exam Questions. We make certain that consumers pass the SnowPro Advanced: Data Engineer (DEA-C02) DEA-C02 certification exam on their first attempt. Furthermore, we want you to trust the SnowPro Advanced: Data Engineer (DEA-C02) DEA-C02 practice questions that we created.
DEA-C02 Exam Questions Fee: https://www.2pass4sure.com/SnowPro-Advanced/DEA-C02-actual-exam-braindumps.html
We will provide the DEA-C02 exam cram review practice for the staff to participate in DEA-C02 actual test, Without complex collection work and without no such long wait, you can get the latest and the most trusted DEA-C02 exam materials on our website, Snowflake DEA-C02 Guide Torrent The study material is available in three different formats, Snowflake DEA-C02 Guide Torrent What can people do to increase their professional skills and won approvals from their boss and colleagues?
That's the notion behind the title of this book, Mona Sinha is Assistant Professor of Marketing at the Michael J, We will provide the DEA-C02 Exam Cram Review practice for the staff to participate in DEA-C02 actual test.
Trustable Snowflake Guide Torrent – Useful DEA-C02 Exam Questions FeeWithout complex collection work and without no such long wait, you can get the latest and the most trusted DEA-C02 exam materials on our website, The study material is available in three different formats.
What can people do to increase their professional skills and won approvals from their boss and colleagues, With helpful learning way and study materials, DEA-C02 exam questions seem easier.
P.S. Free 2026 Snowflake DEA-C02 dumps are available on Google Drive shared by 2Pass4sure: https://drive.google.com/open?id=1gFT1Gaj8pO7yKX9VbV-bYO8quSq-Pp_2
