2026 Excellent Exam 1z0-1077-25 Fees | 100% Free Free 1z0-1077-25 Practice Exams
Posted at 3/7/2026 12:00:51
View170
Replies0
BONUS!!! Download part of DumpsTests 1z0-1077-25 dumps for free: https://drive.google.com/open?id=1b_vQ2T78ldlimkGOaimmGO1GbO95Cbhb
We guarantee that if you study our 1z0-1077-25 guide dumps with dedication and enthusiasm step by step, you will desperately pass the exam without doubt. As the authoritative provider of 1z0-1077-25 study materials, our pass rate is unmarched high as 98% to 100%. And we are always in pursuit of high pass rate of 1z0-1077-25 practice quiz compared with our counterparts to gain more attention from potential customers.
Users are buying something online (such as 1z0-1077-25 prepare questions), always want vendors to provide a fast and convenient sourcing channel to better ensure the user's use. Because without a quick purchase process, users of our 1z0-1077-25 quiz guide will not be able to quickly start their own review program. So, our company employs many experts to design a fast sourcing channel for our 1z0-1077-25 Exam Prep. All users can implement fast purchase and use our learning materials. We have specialized software to optimize the user's purchase channels, if you decide to purchase our 1z0-1077-25 prepare questions, you can achieve the product content even if the update service and efficient and convenient user experience.
Free PDF 1z0-1077-25 - Oracle Order Management Cloud Order to Cash 2025Implementation Professional Marvelous Exam FeesEverybody should recognize the valuable of our life; we can't waste our time, so you need a good way to help you get your goals straightly. Of course, our 1z0-1077-25 latest exam torrents are your best choice. I promise you that you can learn from the 1z0-1077-25 Exam Questions not only the knowledge of the certificate exam, but also the ways to answer questions quickly and accurately. Now, you can free download the demo of our 1z0-1077-25 test torrent to have a check on our wonderful quality.
Oracle Order Management Cloud Order to Cash 2025Implementation Professional Sample Questions (Q66-Q71):NEW QUESTION # 66
Your company is using Order Management Cloud to capture orders, and has integrated with a legacy inventory application for order fulfillment. A fulfillment request needs to be aggregated and sent to an external inventory application.
What step would you perform to aggregate the request?
- A. Create a new custom task by using the Supply Task Layer.
- B. Configure a fulfillment task routing rule with aggregation criteria based on time limit or total number of lines.
- C. Create a new custom task by using the Shipment Task Layer.
- D. Create a new custom task by using the Fulfillment Task Layer.
https://docs.oracle.com/cd/E5661 ... F1171442AN11B74.htm
NEW QUESTION # 67
You have set up a Processing Constraint prohibiting updates to an extensible flexfield in a fulfillment line when Ship-From Warehouse = "Operations" and the fulfillment line status = "Booked". Although the constraint has been created, it has not been enforced when a user updates a fulfillment line that meets these conditions.
Which is the most probable cause?
- A. The extensible flexfield is not enabled.
- B. The "Publish extensible flexfield" process was not run.
- C. The "generate packages"program was not submitted.
- D. A "Record Set" needs to be created for the extensible flexfieldto be visible on the "Manage Processing Constraints" page.
A processing constraint is a rule that controls the changes that can be made to an order or a fulfillment line at various stages of the order-to-cash process.A processing constraint can be based on various attributes, such as the order type, the fulfillment line status, the ship-from warehouse, and the extensible flexfield1.An extensible flexfield is a custom attribute that you can use to capture additional information that is not provided by the predefined attributes2. To set up a processing constraint based on an extensible flexfield, you need to run the
"Publish extensible flexfield" process after you create or modify the extensible flexfield.This process enables the extensible flexfield to be visible and usable in the "Manage Processing Constraints" page3. If you do not run this process, the processing constraint will not be enforced when a user updates a fulfillment line that meets the conditions.
Overview of Processing Constraints
Overview of Extensible Flexfields
Create Processing Constraints Based on Extensible Flexfields
NEW QUESTION # 68
Your company wants to revise an existing sales order in Order Management Cloud to compensate the downstream legacy fulfillment system that does not allow any update to the already interfaced fulfillment lines.
What type of compensation pattern rule would you need to de#ne for the orchestration process fulfillment step?
- A. Define one rule of type CANCEL_CREATE.
- B. Define two rules: one of type CANCEL and another of type CREATE.
- C. Define one rule of type CREATE.
- D. Define one rule of type UPDATE.
A rule that you can set on an orchestration process step that specifies the adjustments to make when an order changes.
Undo, Redo, Update, Cancel, and None are each an example of a compensation pattern. For example, assume the compensation pattern for a Create Shipment step is Redo, and that this step calls the Cancel service and the Create service.
If Order Management receives a change order that includes a new warehouse for this step, then it runs the Cancel service and the Create service again.
NEW QUESTION # 69
What will happen in the Configurator runtime UI when the LX-Luxury Package option is selected that has the following constraint rules?
. 'LX-Luxury Package' IMPLIES '8-way Power Driver Seat'
. 'LX-Luxury Package' IMPLIES '8-way Power Passenger Seat'
. 'LX-Luxury Package' IMPLIES 'Cloth'
- A. All the options after the IMPLIES keyword will be excluded.
- B. '8-way Power Driver Seat' and '8-way Power Passenger Seat' will be selected but 'Cloth' will be excluded.
- C. 8-way Power Driver Seat' will be selected but '8-way Power Passenger Seat' and 'Cloth' will be excluded.
- D. '8-way Power Driver Seat' and 'Cloth' will be selected but '8-way Power Passenger Seat' will be excluded.
- E. All the options after the IMPLIES keyword will be selected.
Answer: E
The IMPLIES keyword is used to create a configurator rule that specifies a logical implication between two expressions. The syntax of the IMPLIES keyword is:
expression1 IMPLIES expression2
This means that if expression1 is true, then expression2 must also be true.However, if expression1 is false, then expression2 can be either true or false1. In the Configurator runtime UI, the IMPLIES keyword can be used to show or hide options based on the selection of features. For example, the following rule:
means that if the LX-Luxury Package feature is selected, then the 8-way Power Driver Seat option must also be selected. However, if the LX-Luxury Package feature is not selected, then the 8-way Power Driver Seat option can be either selected or not selected.
Therefore, when the LX-Luxury Package option is selected, all the options after the IMPLIES keyword will be selected, according to the constraint rules. This means that the 8-way Power Driver Seat, the 8-way Power Passenger Seat, and the Cloth options will be selected.
How to Use the IMPLIES Keyword
NEW QUESTION # 70
You import an item-based model structure into the Configurator Modeling Environment, but realize that the minimum for one of your component attributes is incorrectly assigned.
What should you do, prior to releasing, to resolve this issue?
- A. Make the changes In the Product Hub or the Configurator Modeling Environment, All the changes are automatically reflected in the other area (that is, changes in the Configurator Modeling Environment will show in the Product Hub and vice versa).
- B. Make the changes in the Product Hub and refresh the snapshot for the item-based model structure,
- C. Make the changes in the Configurator Modeling Environment on the Item Attributes tab of the model's details.
- D. After the item-based model structure is imported, you must wait until after it is released to make the changes.
- E. You cannot change the item's user-defined attributes.
You can make the changes in the Configurator Modeling Environment on the Item Attributes tab of the model' s details, prior to releasing, to resolve the issue of incorrect minimum for one of your component attributes.
Item attributes are user-defined attributes that you can add to an item-based model or its components to capture additional information or to control the configuration process1.You can modify the item attributes in the Configurator Modeling Environment after importing the item-based modelstructure from the Product Hub2.You can change the minimum value of the component attribute on the Item Attributes tab of the model' s details3.
Item Attributes
Import Item-Based Models into Configurator
Modify Item Attributes
NEW QUESTION # 71
Our Desktop version is an application software that runs without an internet connection. It helps you to test yourself by giving the Oracle Order Management Cloud Order to Cash 2025Implementation Professional (1z0-1077-25) practice test. Our desktop version also keeps a record of your previous performance and it shows the improvement in your next 1z0-1077-25 Practice Exam. With the help of DumpsTests Oracle Order Management Cloud Order to Cash 2025Implementation Professional (1z0-1077-25) exam questions, you will be able to pass Oracle 1z0-1077-25 certification exam with ease. When you invest in our product it will surely benefit your Oracle Order Management Cloud Order to Cash 2025Implementation Professional (1z0-1077-25) exam dumps.
Free 1z0-1077-25 Practice Exams: https://www.dumpstests.com/1z0-1077-25-latest-test-dumps.html
This means with our products you can prepare for 1z0-1077-25 exam efficiently, Our 1z0-1077-25 test questions can help you have a good preparation for exam effectively, Oracle Exam 1z0-1077-25 Fees The simulated and interactive learning environment of our test engine will greatly arouse your learning interests, The past decades have witnessed that there are huge demanding of workers whose number is growing as radically as the development of the economy and technology.( 1z0-1077-25 VCE dumps) There is also widespread consensus among all IT workers that it will be a great privilege of an IT man to possess a professional Oracle Order Management Cloud certification.
You wake up one morning with a desperate need to shop the Web, Making a Basic Connection, This means with our products you can prepare for 1z0-1077-25 Exam efficiently.
Our 1z0-1077-25 test questions can help you have a good preparation for exam effectively, The simulated and interactive learning environment of our test engine will greatly arouse your learning interests.
2026 High Pass-Rate Oracle Exam 1z0-1077-25 FeesThe past decades have witnessed that there are huge demanding of workers whose number is growing as radically as the development of the economy and technology.( 1z0-1077-25 VCE dumps) There is also widespread consensus among all IT workers 1z0-1077-25 that it will be a great privilege of an IT man to possess a professional Oracle Order Management Cloud certification.
We provide free sample questions for Oracle Order Management Cloud Order to Cash 2025Implementation Professional exam.
- Valid 1z0-1077-25 Test Duration 🕒 1z0-1077-25 Latest Dumps Questions 🌱 1z0-1077-25 Reliable Real Test 🔔 Easily obtain free download of ▛ 1z0-1077-25 ▟ by searching on ➥ [url]www.examcollectionpass.com 🡄 🦝Latest 1z0-1077-25 Test Questions[/url]
- Latest 1z0-1077-25 Test Questions 📎 Certification 1z0-1077-25 Dumps 🎵 1z0-1077-25 Valid Exam Voucher 🏗 Search for ➥ 1z0-1077-25 🡄 and obtain a free download on ➡ [url]www.pdfvce.com ️⬅️ 🌵Guaranteed 1z0-1077-25 Questions Answers[/url]
- 1z0-1077-25 Valid Exam Voucher 🪂 1z0-1077-25 Online Training 🟢 1z0-1077-25 Most Reliable Questions 🔎 Download 1z0-1077-25 for free by simply searching on ➡ [url]www.prep4away.com ️⬅️ 🌭1z0-1077-25 Valid Dumps Free[/url]
- Exam 1z0-1077-25 Fees - Certification Success Guaranteed, Easy Way of Training - Free 1z0-1077-25 Practice Exams 🦗 Search for 1z0-1077-25 and obtain a free download on [url]www.pdfvce.com 🦁Guaranteed 1z0-1077-25 Questions Answers[/url]
- Dumps 1z0-1077-25 Guide ❎ 1z0-1077-25 Most Reliable Questions 〰 1z0-1077-25 Practice Exams Free 🦼 { [url]www.pdfdumps.com } is best website to obtain ⇛ 1z0-1077-25 ⇚ for free download 🎡1z0-1077-25 Valid Dumps Free[/url]
- 1z0-1077-25 Reliable Braindumps Files 🕝 1z0-1077-25 Practice Exams Free 🚤 Certification 1z0-1077-25 Dumps 🥛 Open ▷ [url]www.pdfvce.com ◁ enter ➽ 1z0-1077-25 🢪 and obtain a free download 💋Certification 1z0-1077-25 Dumps[/url]
- 1z0-1077-25 Reliable Exam Vce 🔧 1z0-1077-25 Valid Exam Voucher 🌟 1z0-1077-25 Valid Exam Voucher 🥓 Copy URL ✔ [url]www.examcollectionpass.com ️✔️ open and search for { 1z0-1077-25 } to download for free 🧩1z0-1077-25 Valid Exam Voucher[/url]
- 100% Pass Newest 1z0-1077-25 - Exam Oracle Order Management Cloud Order to Cash 2025Implementation Professional Fees 🧣 Download ➥ 1z0-1077-25 🡄 for free by simply searching on ▷ [url]www.pdfvce.com ◁ ⚓Latest 1z0-1077-25 Test Questions[/url]
- 1z0-1077-25 Real Questions Effective to Pass Oracle Exam 🛢 Easily obtain { 1z0-1077-25 } for free download through ➡ [url]www.vce4dumps.com ️⬅️ 🧽1z0-1077-25 100% Accuracy[/url]
- Exam 1z0-1077-25 Fees - Certification Success Guaranteed, Easy Way of Training - Free 1z0-1077-25 Practice Exams 😫 Search for ⮆ 1z0-1077-25 ⮄ and download it for free immediately on ⮆ [url]www.pdfvce.com ⮄ 🌗1z0-1077-25 Online Training[/url]
- 1z0-1077-25 100% Accuracy 🧵 1z0-1077-25 Valid Dumps Free 🦅 1z0-1077-25 Practice Exams Free 🧱 Enter ☀ [url]www.exam4labs.com ️☀️ and search for ➡ 1z0-1077-25 ️⬅️ to download for free 🅿1z0-1077-25 Test Fee[/url]
- www.skudci.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, edvastlearning.com, disqus.com, wibki.com, actualizados.com.ar, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free & New 1z0-1077-25 dumps are available on Google Drive shared by DumpsTests: https://drive.google.com/open?id=1b_vQ2T78ldlimkGOaimmGO1GbO95Cbhb
