Hardware
SOA-C02yԇ & SOA-C02yԇ}
Posted at 3/7/2026 12:08:05
View294
Replies1
혱һ£ԏ녴惦dVCESoft SOA-C02ԇ}棺https://drive.google.com/open?id=1a7E9rBCr3b9XyVgFLZK3Np9vNARi0WxH
AmazonSOA-C02ԇJCVCESoftǮǰAmazonSOA-C02ԇJCͿ}ʂ䆖}ṩJCĺxеٮٮߣ҂YԴ౻ӆ£оoܵPԺ;oԣʂAmazonSOA-C02JC㌢ҪxҪ_ʼӖҪͨ^һεĿ}҂ֿ}ÿ¸һΣ㌢õõYԴcЈrƷ|ͿɿԵıC
Mxxһo㎧^Ҹxo^ęCһe^xֻ VCESoft AmazonSOA-C02ԇӖYÿITʿͨ^ITJC횵ӖYϣ@ݿԇYϾ͵УеĿԇy}ӭж⡣ VCESoft AmazonSOA-C02ԇӖYᘌԏwV¿죬ӖYϣеITJCҪ£㶼ͨ^ġ
SOA-C02yԇJCԇؓ؟˲ϺͿŵSOA-C02yԇ}ڞʂSOA-C02ԇŬWKҸе۵ĕr֪e˶ڎʲNһ܇һҪITJCԇˡʲN鿼ԇ㷲ĕrsһŝMMȻԵõĘأ߆ȻǡN֪ʲNe˺pͿͨ^SOA-C02ԇǾʹVCESoftSOA-C02}ֻÌW@}Ϳpͨ^ԇņXò˼hǾͿcԇһ°ɡwһ¿}demo,@ͿԴ_J@YϵƷ|ˡVCESoftվɡ
RdSOA-C02ԇһJCmϾһAWSղČIˆTӡдJCĺxC˸NAWSյļܣEC2RDSS3AWSݺLIAM߀˽ʹAWSߣCloudFormationBeanstalkAWS LambdaԄӻͺAWSյIJ
Amazon SOA-C02 JCȫȱJɣܹ߶ҕ IT IʿfһͶY@ôJCԎIʿͬÓfٍXK_IC⣬ԓJCЧڞ֮꣬ጣIʿͨ^ͨ^JCԇɺϸijmӋ¡
µ AWS Certified Associate SOA-C02 Mԇ} (Q244-Q249):} #244
A SysOps administrator must configure a resilient tier of Amazon EC2 instances for a high performance computing (HPC) application. The HPC application requires minimum latency between nodes Which actions should the SysOps administrator take to meet these requirements? (Select TWO.)
- A. Place the EC2 instances in an Auto Scaling group within a single subnet
- B. Launch the EC2 instances into a cluster placement group
- C. Create a Multi-AZ Network Load Balancer in front of the EC2 instances
- D. Create an Amazon Elastic File System (Amazon EPS) file system Mount the file system to the EC2 instances by using user data
- E. Launch the EC2 instances into a partition placement group
𰸣B,E
}f
For high-performance computing (HPC) applications requiring minimal latency between nodes, using a placement group strategy is crucial.
* Cluster Placement Group:
* Provides low-latency network performance within a single Availability Zone by placing instances close together on the network.
* Suitable for applications that require high throughput or low latency.
* Partition Placement Group:
* Helps reduce the impact of hardware failures by dividing instances into partitions, where each partition can be placed on distinct racks in the data center.
* Suitable for applications that need high availability and fault tolerance.
Setting Up Placement Groups:
* Create a Placement Group:
* Open the Amazon EC2 console at Amazon EC2 Console.
* In the navigation pane, choose Placement Groups.
* Choose Create placement group, specify the name, and choose either Cluster or Partition as the strategy.
* Launch Instances:
* When launching new instances, specify the placement group name to ensure they are placed accordingly.
Placement Groups
Creating and Managing Placement Groups
} #245
A SysOps administrator must create an IAM policy for a developer who needs access to specific AWS services. Based on the requirements, the SysOps administrator creates the following policy:
Which actions does this policy allow? (Select TWO.)
- A. Describe AWS load balancers.
- B. Create an AWS Storage Gateway.
- C. Delete an Amazon Simple Queue Service (Amazon SQS) queue.
- D. Create an IAM role for an AWS Lambda function.
- E. Invoke an AWS Lambda function.
𰸣A,E
}f
The provided IAM policy grants the following permissions:
* Describe AWS Load Balancers:
* The policy allows actions with the prefix elasticloadbalancing:. This includes actions like DescribeLoadBalancers and other Describe* actions related to Elastic Load Balancing.
Reference: Elastic Load Balancing API Actions
Invoke AWS Lambda Function:
The policy allows actions with the prefix lambda:, which includes InvokeFunction and other actions that allow listing and describing Lambda functions.
Reference: AWS Lambda API Actions
The actions related to AWS Storage Gateway (create), IAM role (create), and Amazon SQS (delete) are not allowed by this policy. The policy only grants describe/list permissions for storagegateway, elasticloadbalancing, lambda, and list permissions for SQS.
} #246
A company has an initiative to reduce costs associated with Amazon EC2 and AWS Lambda. Which action should a SysOps administrator take to meet these requirements?
- A. Create an AWS Budgets alert to alarm when account spend reaches 80% of the budget.
- B. Use AWS Compute Optimizer and take action on the provided recommendations.
- C. Purchase Reserved Instances through the Amazon EC2 console.
- D. Analyze the AWS Cost and Usage Report by using Amazon Athena to identity cost savings.
𰸣B
}f
AWS Compute Optimizer recommends optimal AWS resources for your workloads to reduce costs and improve performance. It provides actionable recommendations to help you choose the right EC2 instances and AWS Lambda configurations.
* Access AWS Compute Optimizer:
* Open the AWS Compute Optimizer console at AWS Compute Optimizer Console.
* Review the recommendations for your EC2 instances and AWS Lambda functions.
* Implement Recommendations:
* Analyze the recommendations, which might include resizing instances, changing instance types, or modifying Lambda memory settings.
* Apply the recommendations to optimize your resources and reduce costs.
* AWS Compute Optimizer
* Getting Started with AWS Compute Optimizer
} #247
A company wants to enhance its security by applying IAM permissions boundaries. The company tries to use IAM policy conditions and receives the following error:
"Error: error updating IAM Role (role-name) assume role policy:
AccessDenied: User: id-arn is not authorized to perform:
iam:UpdateAssumeRolePolicy on resource: role role-namestatus code:
403, request id: request-id"
The policy that contains the condition includes the following snippet:
What is the reason for the error?
- A. Condition keys are not allowed in conjunction with permissions boundaries.
- B. Permissions boundaries are not allowed with IAM policies.
- C. The UpdateAssumeRolePolicy action is not compatible with the iam
ermissionsBoundary condition key. - D. IAM user id-arn is not allowed to assume role-name.
𰸣C
} #248
A company plans to launch a static website on its domain example com and subdomain www example.com using Amazon S3.
How should the SysOps administrator meet this requirement?
- A. Create two S3 buckets named example.com and www.example.com.
Configure the subdomain bucket to redirect requests to the domain bucket. - B. Create one S3 bucket with a wildcard named '.example.com tor both the domain and subdomain.
- C. Create two S3 buckets named http://www.example.com and http://example.com. Configure the wildcard (') bucket to redirect requests to the domain bucket.
- D. Create one S3 bucket named example.com for both the domain and subdomain.
𰸣A
}f
https://docs.aws.amazon.com/Amaz ... ting-custom-domain- walkthrough.html
} #249
҂Amazon SOA-C02}ɌIITFõļgˮõČWYϣµSOA-C02ԇ}õԴ_ُI҂}Y挍ЧģʹҲԿpɫ@Amazon SOA-C02JCЧĿ}sُ܇ɣ֮ͿdُISOA-C02}죬@ĿԇЫ@ø߷֣ͨ^SOA-C02ԇ
SOA-C02yԇ}: https://www.vcesoft.com/SOA-C02-pdf.html
- ڙSOA-C02yԇ}YԇIṩ̺|SOA-C02yԇ 🛰 _Wվ➠ [url]www.newdumpspdf.com 🠰▶ SOA-C02 ◀MdSOA-C02}[/url]
- µSOA-C02JCԇYώ ♥ ➽ [url]www.newdumpspdf.com 🢪Wվ➡ SOA-C02 ️⬅️KMdSOA-C02}[/url]
- SOA-C02} 🚜 SOA-C02} 🏛 SOA-C02¿} 🍡 ➽ [url]www.pdfexamdumps.com 🢪➽ SOA-C02 🢪ԫ@ȡMdSOA-C02JC[/url]
- SOA-C02WPӛ 🧪 SOA-C02ԇ} 🥫 SOA-C02ָ 🍵 M☀ [url]www.newdumpspdf.com ️☀️ь✔ SOA-C02 ️✔️MdSOA-C02JC[/url]
- SOA-C02ԇ 🕗 SOA-C02JC 🚾 SOA-C02} 🙍 ڡ [url]www.newdumpspdf.com ✔ SOA-C02 ️✔️K@ȡMdSOA-C02}[/url]
- SOA-C02C 🆓 SOA-C02} 🤔 SOA-C02ԇ} 🍿 _⏩ [url]www.newdumpspdf.com ⏪K⇛ SOA-C02 ⇚ԫ@ȡMdSOA-C02}[/url]
- ЧSOA-C02yԇAmazon AWS Certified AssociateJCSOA-C02ԇ}ṩMd 👋 [ [url]www.newdumpspdf.com ]ϵ[ SOA-C02 ]MdֻьSOA-C02C[/url]
- ЧSOA-C02yԇAmazon AWS Certified AssociateJCSOA-C02ԇ}ṩMd 🏀 _➡ [url]www.newdumpspdf.com ️⬅️K✔ SOA-C02 ️✔️ԫ@ȡMdSOA-C02WPӛ[/url]
- SOA-C02C ☣ SOA-C02ԇc 🧁 SOA-C02JC 🍬 _➤ [url]www.pdfexamdumps.com ⮘ݔ➤ SOA-C02 ⮘K@ȡMdSOA-C02ԇ}[/url]
- SOA-C02ԇ 🙎 SOA-C02ԇ 😊 SOA-C02ԇ} 🚏 _➡ [url]www.newdumpspdf.com ️⬅️ݔ✔ SOA-C02 ️✔️K@ȡMdSOA-C02ԇ[/url]
- SOA-C02ԇc 🥠 SOA-C02} 🐗 SOA-C02} ⏲ ⮆ [url]www.vcesoft.com ⮄ SOA-C02 ԫ@ȡMdSOA-C02ԇ俼[/url]
- kelas.mahveenclinic.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
